今天是:2025年04月16日(星期三)
2019年04月16日 | STM32 Keil MDK数据类型定义
2019-04-16 来源:eefocus
/* Copyright (C) ARM Ltd., 1999 */
/* All rights reserved */
* RCS $Revision: 138251 $
* Checkin $Date: 2008-10-07 12:02:11 +0100 (Tue, 07 Oct 2008) $
* Revising $Author: agrant $
#ifndef __stdint_h
#define __stdint_h
#ifndef __STDINT_DECLS
#define __STDINT_DECLS
#undef __CLIBNS
#ifdef __cplusplus
namespace std {
#define __CLIBNS std::
extern "C" {
#else
#define __CLIBNS
#endif /* __cplusplus */
* 'signed' is redundant below, except for 'signed char' and if
* the typedef is used to declare a bitfield.
* '__int64' is used instead of 'long long' so that this header
* can be used in --strict mode.
/* 7.18.1.1 */
/* exact-width signed integer types */
typedef signed char int8_t;
typedef signed short int int16_t;
typedef signed int int32_t;
typedef signed __int64 int64_t;
/* exact-width unsigned integer types */
typedef unsigned char uint8_t;
typedef unsigned short int uint16_t;
typedef unsigned int uint32_t;
typedef unsigned __int64 uint64_t;
/* 7.18.1.2 */
/* smallest type of at least n bits */
/* minimum-width signed integer types */
typedef signed char int_least8_t;
typedef signed short int int_least16_t;
typedef signed int int_least32_t;
typedef signed __int64 int_least64_t;
/* minimum-width unsigned integer types */
typedef unsigned char uint_least8_t;
typedef unsigned short int uint_least16_t;
typedef unsigned int uint_least32_t;
typedef unsigned __int64 uint_least64_t;
/* 7.18.1.3 */
/* fastest minimum-width signed integer types */
typedef signed int int_fast8_t;
typedef signed int int_fast16_t;
typedef signed int int_fast32_t;
typedef signed __int64 int_fast64_t;
/* fastest minimum-width unsigned integer types */
typedef unsigned int uint_fast8_t;
typedef unsigned int uint_fast16_t;
typedef unsigned int uint_fast32_t;
typedef unsigned __int64 uint_fast64_t;
/* 7.18.1.4 integer types capable of holding object pointers */
typedef signed int intptr_t;
typedef unsigned int uintptr_t;
/* 7.18.1.5 greatest-width integer types */
typedef signed __int64 intmax_t;
typedef unsigned __int64 uintmax_t;
#if !defined(__cplusplus) || defined(__STDC_LIMIT_MACROS)
/* 7.18.2.1 */
/* minimum values of exact-width signed integer types */
#define INT8_MIN -128
#define INT16_MIN -32768
#define INT32_MIN (~0x7fffffff) /* -2147483648 is unsigned */
#define INT64_MIN __ESCAPE__(~0x7fffffffffffffffll) /* -9223372036854775808 is unsigned */
/* maximum values of exact-width signed integer types */
#define INT8_MAX 127
#define INT16_MAX 32767
#define INT32_MAX 2147483647
#define INT64_MAX __ESCAPE__(9223372036854775807ll)
/* maximum values of exact-width unsigned integer types */
#define UINT8_MAX 255
#define UINT16_MAX 65535
#define UINT32_MAX 4294967295u
#define UINT64_MAX __ESCAPE__(18446744073709551615ull)
/* 7.18.2.2 */
/* minimum values of minimum-width signed integer types */
#define INT_LEAST8_MIN -128
#define INT_LEAST16_MIN -32768
#define INT_LEAST32_MIN (~0x7fffffff)
#define INT_LEAST64_MIN __ESCAPE__(~0x7fffffffffffffffll)
/* maximum values of minimum-width signed integer types */
#define INT_LEAST8_MAX 127
#define INT_LEAST16_MAX 32767
#define INT_LEAST32_MAX 2147483647
#define INT_LEAST64_MAX __ESCAPE__(9223372036854775807ll)
/* maximum values of minimum-width unsigned integer types */
#define UINT_LEAST8_MAX 255
#define UINT_LEAST16_MAX 65535
#define UINT_LEAST32_MAX 4294967295u
#define UINT_LEAST64_MAX __ESCAPE__(18446744073709551615ull)
/* 7.18.2.3 */
/* minimum values of fastest minimum-width signed integer types */
#define INT_FAST8_MIN (~0x7fffffff)
#define INT_FAST16_MIN (~0x7fffffff)
#define INT_FAST32_MIN (~0x7fffffff)
#define INT_FAST64_MIN __ESCAPE__(~0x7fffffffffffffffll)
/* maximum values of fastest minimum-width signed integer types */
#define INT_FAST8_MAX 2147483647
#define INT_FAST16_MAX 2147483647
#define INT_FAST32_MAX 2147483647
#define INT_FAST64_MAX __ESCAPE__(9223372036854775807ll)
/* maximum values of fastest minimum-width unsigned integer types */
#define UINT_FAST8_MAX 4294967295u
#define UINT_FAST16_MAX 4294967295u
#define UINT_FAST32_MAX 4294967295u
#define UINT_FAST64_MAX __ESCAPE__(18446744073709551615ull)
/* 7.18.2.4 */
/* minimum value of pointer-holding signed integer type */
#define INTPTR_MIN (~0x7fffffff)
/* maximum value of pointer-holding signed integer type */
#define INTPTR_MAX 2147483647
/* maximum value of pointer-holding unsigned integer type */
#define UINTPTR_MAX 4294967295u
/* 7.18.2.5 */
/* minimum value of greatest-width signed integer type */
#define INTMAX_MIN __ESCAPE__(~0x7fffffffffffffffll)
/* maximum value of greatest-width signed integer type */
#define INTMAX_MAX __ESCAPE__(9223372036854775807ll)
/* maximum value of greatest-width unsigned integer type */
#define UINTMAX_MAX __ESCAPE__(18446744073709551615ull)
/* 7.18.3 */
/* limits of ptrdiff_t */
#define PTRDIFF_MIN (~0x7fffffff)
#define PTRDIFF_MAX 2147483647
/* limits of sig_atomic_t */
#define SIG_ATOMIC_MIN (~0x7fffffff)
#define SIG_ATOMIC_MAX 2147483647
/* limit of size_t */
#define SIZE_MAX 4294967295u
/* limits of wchar_t */
/* NB we have to undef and redef because they're defined in both
* stdint.h and wchar.h */
#undef WCHAR_MIN
#undef WCHAR_MAX
#if defined(__WCHAR32)
#define WCHAR_MIN 0
#define WCHAR_MAX 0xffffffffU
#else
#define WCHAR_MIN 0
#define WCHAR_MAX 65535
#endif
/* limits of wint_t */
#define WINT_MIN (~0x7fffffff)
#define WINT_MAX 2147483647
#endif /* __STDC_LIMIT_MACROS */
#if !defined(__cplusplus) || defined(__STDC_CONSTANT_MACROS)
/* 7.18.4.1 macros for minimum-width integer constants */
#define INT8_C(x) (x)
#define INT16_C(x) (x)
#define INT32_C(x) (x)
#define INT64_C(x) __ESCAPE__(x ## ll)
#define UINT8_C(x) (x ## u)
#define UINT16_C(x) (x ## u)
#define UINT32_C(x) (x ## u)
#define UINT64_C(x) __ESCAPE__(x ## ull)
/* 7.18.4.2 macros for greatest-width integer constants */
#define INTMAX_C(x) __ESCAPE__(x ## ll)
#define UINTMAX_C(x) __ESCAPE__(x ## ull)
#endif /* __STDC_CONSTANT_MACROS */
#ifdef __cplusplus
} /* extern "C" */
} /* namespace std */
#endif /* __STDINT_DECLS */
#ifdef __cplusplus
#ifndef __STDINT_NO_EXPORTS
using ::std::int8_t;
using ::std::int16_t;
using ::std::int32_t;
上一篇:STM32常用数据类型分析
下一篇:STM32类型定义
在现实生活中我们会遇到很多气体放电的现象,有的时候我们会觉得不可思议,其实这些现象都是能用科学来解释的。科学家们通过对他们的研究,把这些现象的原理应用在我们的生活中,给我们带来了很多益处,在经过科学家的进一步研究后将会给我们带来更 ...… 查看全部问答> |
大家好,我是一个新手,我现在在用一个mini2440的学习板在学习,我的电脑是笔记本,没有那种窜口,所以买了一个usb转窜口的线接上了,在ads调试程序 以后准备考进学习板中进行,但是uartselect不知道该用哪个好?学校的学习板用的是台式机,所以选u ...… 查看全部问答> |
实验室的一个嵌入式课题,需要不断的对70*70的矩阵做运算处理,并且要有一定的GUI能力。光用2410来跑,可能是一个很吃力的事情,所以想选择arm+dsp的平台,想请教一下大家,有没有比较好的arm+dsp6的开发板,因为硕士时间比较短,所以想直接用开发 ...… 查看全部问答> |
控创的单扳机,扩展为双网卡(fei0,eeE0) eeE0:192.168.1.100:0xffffff00 udp协议组网 网上其他设备向某一端口 广播数据 广播地址:192.168.1.255 正确创建socket 后,接收不到广播数据包. 如果同一端口不广播,而是点对点则能正确收 ...… 查看全部问答> |
cpu: s3c2510 flash: AM29lv320db jtag:20-pin boot: armboot for samsung v3.1t --------------------------------------- 我把板子上的boot损坏了,板子上提供了jtag-20pin,但没有提供jtag连线,和烧写软件及驱动。 烧写软件 是不是 还和jt ...… 查看全部问答> |
按下X1 ,Y1输出。5秒后Y1关断, Y2输出。X2按下后无输出。 程序1能运行,程序2不能。请大家说初具体时序或每步执行后输入映像和输出映像寄存器的值。步甚感激! … 查看全部问答> |
