今天是:2024年08月29日(星期四)
2019年08月29日 | STM32 >> 矩阵键盘(代码风格优美,简明易懂)
2019-08-29 来源:eefocus
本文有关矩阵键盘的使用原理适用于所有微机控制器,同时也适用于所有规格的矩阵键盘。
key.h
* @file bsp_key.h
* @author Waao
* @version V1.0.0
* @date 23-Jan-2019
* @brief This file contains some board support package's definition for the KEY.
* @attention
* None
#ifndef __BSP_KEY_H_
#define __BSP_KEY_H_
#include #include #include // Column1, Column2, Column3, Column4 #define C1_PIN GPIO_Pin_2 #define C1_GPIO_PORT GPIOE #define C1_GPIO_CLK RCC_AHB1Periph_GPIOE #define C2_PIN GPIO_Pin_3 #define C2_GPIO_PORT GPIOE #define C2_GPIO_CLK RCC_AHB1Periph_GPIOE #define C3_PIN GPIO_Pin_4 #define C3_GPIO_PORT GPIOE #define C3_GPIO_CLK RCC_AHB1Periph_GPIOE #define C4_PIN GPIO_Pin_5 #define C4_GPIO_PORT GPIOE #define C4_GPIO_CLK RCC_AHB1Periph_GPIOE // Row1, Row2, Row3, Row4 #define R1_PIN GPIO_Pin_12 #define R1_GPIO_PORT GPIOB #define R1_GPIO_CLK RCC_AHB1Periph_GPIOB #define R2_PIN GPIO_Pin_13 #define R2_GPIO_PORT GPIOB #define R2_GPIO_CLK RCC_AHB1Periph_GPIOB #define R3_PIN GPIO_Pin_14 #define R3_GPIO_PORT GPIOB #define R3_GPIO_CLK RCC_AHB1Periph_GPIOB #define R4_PIN GPIO_Pin_15 #define R4_GPIO_PORT GPIOB #define R4_GPIO_CLK RCC_AHB1Periph_GPIOB // detect and output #define DETECT_C1 GPIO_ReadInputDataBit(C1_GPIO_PORT, C1_PIN) #define DETECT_C2 GPIO_ReadInputDataBit(C2_GPIO_PORT, C2_PIN) #define DETECT_C3 GPIO_ReadInputDataBit(C3_GPIO_PORT, C3_PIN) #define DETECT_C4 GPIO_ReadInputDataBit(C4_GPIO_PORT, C4_PIN) #define DETECT_R1 GPIO_ReadInputDataBit(R1_GPIO_PORT, R1_PIN) #define DETECT_R2 GPIO_ReadInputDataBit(R2_GPIO_PORT, R2_PIN) #define DETECT_R3 GPIO_ReadInputDataBit(R3_GPIO_PORT, R3_PIN) #define DETECT_R4 GPIO_ReadInputDataBit(R4_GPIO_PORT, R4_PIN) // Keys #define S1 0x77 #define S2 0xB7 #define S3 0xD7 #define S4 0xE7 #define S5 0x7B #define S6 0xBB #define S7 0xDB #define S8 0xEB #define S9 0x7D #define S10 0xBD #define S11 0xDD #define S12 0xED #define S13 0x7E #define S14 0xBE #define S15 0xDE #define S16 0xEE void GPIO_RCC_Config(void); void ROCI_GPIO_Config(void); void RICO_GPIO_Config(void); void KEY_GPIO_ConfigAndDetect(void); #endif 有关输入输出管脚的选择可以多试验几组,有的管脚即使你配置成上拉输入,当你松开按键之后依然不会返回高电平,我在此就因为这个问题被卡了一阵子 关于我的矩阵键盘检测的原理简明阐述如下: 首先设置为行输出低电平,列上拉输入(即无外部干扰时保持高电平); 检测到按键按下,此时通过检测列的电平情况从而得知哪一列有按键被按下; 然后确定有按键被按下后,设置为列输出低电平,行上拉输入; 通过检测行的电平情况从而得知哪一行有按键被按下; 最后通过“不平行的两条直线相交于一点”原理,推知具体被按下的按键。 key.c /** ****************************************************************************** * @file bsp_key.c * @author Waao * @version V1.0.0 * @date 23-Jan-2019 * @brief This file contains some board support package's functions for the KEY. * ****************************************************************************** * @attention * * None * ****************************************************************************** */ #include /** * @brief Initialize the RCC of the 8 GPIO line. * @param None * @retval None */ void GPIO_RCC_Config(void) { RCC_AHB1PeriphClockCmd(C1_GPIO_CLK, ENABLE); RCC_AHB1PeriphClockCmd(C2_GPIO_CLK, ENABLE); RCC_AHB1PeriphClockCmd(C3_GPIO_CLK, ENABLE); RCC_AHB1PeriphClockCmd(C4_GPIO_CLK, ENABLE); RCC_AHB1PeriphClockCmd(R1_GPIO_CLK, ENABLE); RCC_AHB1PeriphClockCmd(R2_GPIO_CLK, ENABLE); RCC_AHB1PeriphClockCmd(R3_GPIO_CLK, ENABLE); RCC_AHB1PeriphClockCmd(R4_GPIO_CLK, ENABLE); } /** * @brief Initialize the Row out Column in. * @param None * @retval None */ void ROCI_GPIO_Config(void) { GPIO_InitTypeDef GPIO_Structure; //============ Column ============= GPIO_Structure.GPIO_Mode = GPIO_Mode_IN; GPIO_Structure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Structure.GPIO_OType = GPIO_OType_PP; GPIO_Structure.GPIO_PuPd = GPIO_PuPd_UP; GPIO_Structure.GPIO_Pin = C1_PIN; GPIO_Init(C1_GPIO_PORT, &GPIO_Structure); GPIO_Structure.GPIO_Pin = C2_PIN; GPIO_Init(C2_GPIO_PORT, &GPIO_Structure); GPIO_Structure.GPIO_Pin = C3_PIN; GPIO_Init(C3_GPIO_PORT, &GPIO_Structure); GPIO_Structure.GPIO_Pin = C4_PIN; GPIO_Init(C4_GPIO_PORT, &GPIO_Structure); //============== Row =============== GPIO_Structure.GPIO_Mode = GPIO_Mode_OUT; GPIO_Structure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Structure.GPIO_OType = GPIO_OType_PP; GPIO_Structure.GPIO_PuPd = GPIO_PuPd_DOWN; GPIO_Structure.GPIO_Pin = R1_PIN; GPIO_Init(R1_GPIO_PORT, &GPIO_Structure); GPIO_Structure.GPIO_Pin = R2_PIN; GPIO_Init(R2_GPIO_PORT, &GPIO_Structure); GPIO_Structure.GPIO_Pin = R3_PIN; GPIO_Init(R3_GPIO_PORT, &GPIO_Structure); GPIO_Structure.GPIO_Pin = R4_PIN; GPIO_Init(R4_GPIO_PORT, &GPIO_Structure); GPIO_ResetBits(R1_GPIO_PORT, R1_PIN); GPIO_ResetBits(R2_GPIO_PORT, R2_PIN); GPIO_ResetBits(R3_GPIO_PORT, R3_PIN); GPIO_ResetBits(R4_GPIO_PORT, R4_PIN); } /** * @brief Initialize the Row in Column out. * @param None * @retval None */ void RICO_GPIO_Config(void) { GPIO_InitTypeDef GPIO_Structure; //============== Row ================== GPIO_Structure.GPIO_Mode = GPIO_Mode_IN; GPIO_Structure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Structure.GPIO_OType = GPIO_OType_PP; GPIO_Structure.GPIO_PuPd = GPIO_PuPd_UP; GPIO_Structure.GPIO_Pin = R1_PIN; GPIO_Init(R1_GPIO_PORT, &GPIO_Structure); GPIO_Structure.GPIO_Pin = R2_PIN; GPIO_Init(R2_GPIO_PORT, &GPIO_Structure); GPIO_Structure.GPIO_Pin = R3_PIN; GPIO_Init(R3_GPIO_PORT, &GPIO_Structure); GPIO_Structure.GPIO_Pin = R4_PIN; GPIO_Init(R4_GPIO_PORT, &GPIO_Structure); //============ Column ================ GPIO_Structure.GPIO_Mode = GPIO_Mode_OUT; GPIO_Structure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Structure.GPIO_OType = GPIO_OType_PP; GPIO_Structure.GPIO_PuPd = GPIO_PuPd_DOWN; GPIO_Structure.GPIO_Pin = C1_PIN; GPIO_Init(C1_GPIO_PORT, &GPIO_Structure); GPIO_Structure.GPIO_Pin = C2_PIN; GPIO_Init(C2_GPIO_PORT, &GPIO_Structure); GPIO_Structure.GPIO_Pin = C3_PIN; GPIO_Init(C3_GPIO_PORT, &GPIO_Structure); GPIO_Structure.GPIO_Pin = C4_PIN; GPIO_Init(C4_GPIO_PORT, &GPIO_Structure); GPIO_ResetBits(C1_GPIO_PORT, C1_PIN); GPIO_ResetBits(C2_GPIO_PORT, C2_PIN); GPIO_ResetBits(C3_GPIO_PORT, C3_PIN); GPIO_ResetBits(C4_GPIO_PORT, C4_PIN); } /** * @brief Configure the GPIO, and detect whether the key was pressed down * @param None * @retval None */ void KEY_GPIO_ConfigAndDetect(void) { u8 TEMP_COMBINE = 0, TEMP_ROCI = 0, TEMP_RICO = 0; GPIO_RCC_Config(); printf("nWhy so serious ?tThe game just begin!"); while(1) { ROCI_GPIO_Config(); TEMP_ROCI = (u8)(((u8)DETECT_C1) << 3) | (((u8)DETECT_C2) << 2) | (((u8)DETECT_C3) << 1) | (((u8)DETECT_C4) << 0); if(TEMP_ROCI != 0x0f) { Delay(1000); // Eliminate the shaking. The parameter's unit is 10us if(TEMP_ROCI != 0x0f) // Ensure one of the keys was pressed down indeed. { RICO_GPIO_Config(); TEMP_RICO = (u8)(((u8)DETECT_R1) << 3) | (((u8)DETECT_R2) << 2) | (((u8)DETECT_R3) << 1) | (((u8)DETECT_R4) << 0); TEMP_COMBINE = (u8)((TEMP_ROCI << 4) | TEMP_RICO); // Combine the two situation and we can know which key was pressed down. switch(TEMP_COMBINE) { case S1: printf("nS1 was pressed down!"); break; case S2: printf("nS2 was pressed down!"); break; case S3: printf("nS3 was pressed down!"); break; case S4: printf("nS4 was pressed down!"); break;
请教关于DXP2004中原理图的“Title Block”的修改 请教大家一个问题: 在 Protel DXP2004 sp2 的原理图编辑中,它右下角的那个“Title Block”的区域中的信息,有没有非常方便的方法修改呢? 恳请大家告诉我正确的方法,谢谢!… 查看全部问答> |
新买回来的摄像头,驱动安装正常,用amcap预览正常,默认打开的视频窗口大小是800*600,可是在qq视频设置里面,图像的帧率却很低,显示很慢,在msn的视频设置中是正常的,请问各位高手故障现象的原因在什么地方呢?是驱动的问题还是qq软件的不兼容?… 查看全部问答> |
一下还不习惯用ST的库函数(懒记),所以自己对GPIO口进行 另外,对ST的一些寄存器定义也不大习惯,所以也重新做了定义,例如GPIOx_BSRR我另外定义了一个GPIOx_SET,GPIOx_BRR我另外定义了一个GPIOx_CLR,这样自己记起来轻松多了——男人何必为难自己呢...看看这个流水灯的程序,看上去是不是容易些了 ...… 查看全部问答> |
哪位朋友可以谈谈轿车着火或者溺水之后车门安全系统如何预警和自救? 看到新闻上不断有报道轿车着火之后乘客不能及时逃生,721北京暴雨也导致有驾驶员不幸在轿车中溺水身亡! 哪位朋友可以谈谈轿车着火或者溺水之后车门安全系统如何预警和自救? http://weibo.com/vishaychina… 查看全部问答> |
几款板卡,其电源部分都是用的TPS5450,外围只有7颗元件,就可以实现DC/DC转换,最大5A的输出能力。当输出电压是5V时,输入电压范围可以达到7~33V,足以满足一般场合的应用。所以给板子配适配器可以放的很宽,可以使用各类适配器,9V的,12V的,19V ...… 查看全部问答> |
