今天是:2024年09月30日(星期一)
2019年09月30日 | STM32F4 CAN2配置
2019-09-30 来源:eefocus
通信协议
基本知识
特别注意 CAN2配置时,滤波器要从[14]开始配置。
代码块
#define CAN2_PORT CAN2
#define CAN2_GPIO_PORT GPIOB
#define CAN2_RX_PIN GPIO_Pin_12
#define CAN2_TX_PIN GPIO_Pin_13
#define CAN_ID_Chassis 130
struct CAN_Socket
unsigned int u32_StdId;
unsigned int u32_ExtId;
unsigned char u8_IDE;
unsigned char u8_RTR;
unsigned char u8_DLC;
unsigned char u8_FMI;
unsigned char u8_data[8];
typedef struct CAN_Socket CAN;
CAN Send_Socket;
CanRxMsg RxMessage2;
CanTxMsg TxMessage2;
void CAN_Data_Init(void)
int i;
Send_Socket.u32_StdId = CAN_ID_Chassis;
Send_Socket.u8_IDE = CAN_ID_STD;
Send_Socket.u8_RTR = CAN_RTR_DATA;
Send_Socket.u8_DLC = DLC_MAX;
for(i = 0; i<8; i++)
Send_Socket.u8_data[i] = 0;
void CAN2_Setup()
GPIO_InitTypeDef GPIO_InitStructure;
CAN_InitTypeDef CAN_InitStructure;
CAN_FilterInitTypeDef CAN_FilterInitStructure;
NVIC_InitTypeDef NVIC_InitStructure;
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB,ENABLE);
RCC_APB1PeriphClockCmd(RCC_APB1Periph_CAN2, ENABLE);
GPIO_InitStructure.GPIO_Pin = CAN2_RX_PIN|CAN2_TX_PIN;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
//GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
//GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
GPIO_Init(CAN2_GPIO_PORT, &GPIO_InitStructure);
GPIO_PinAFConfig(GPIOB, GPIO_PinSource12, GPIO_AF_CAN2); //CAN_RX = PB12
GPIO_PinAFConfig(GPIOB, GPIO_PinSource13, GPIO_AF_CAN2); //CAN_TX = PB13
CAN_DeInit(CAN2);
CAN_StructInit(&CAN_InitStructure);
/* CAN cell init */
CAN_InitStructure.CAN_TTCM = DISABLE;
CAN_InitStructure.CAN_ABOM = DISABLE;
CAN_InitStructure.CAN_AWUM = DISABLE;
CAN_InitStructure.CAN_NART = ENABLE;
CAN_InitStructure.CAN_RFLM = DISABLE;
CAN_InitStructure.CAN_TXFP = DISABLE;
CAN_InitStructure.CAN_Mode = CAN_Mode_Normal;
CAN_InitStructure.CAN_SJW = CAN_SJW_1tq;//同步跳转时间段
CAN_InitStructure.CAN_BS1 = CAN_BS1_3tq;//时间段1
CAN_InitStructure.CAN_BS2 = CAN_BS2_3tq;//时间段2
CAN_InitStructure.CAN_Prescaler = 6;//波特率分频器
/* CAN 波特率配置 = 42MHz/[(1+3+3)*6] = 1MHz (APB1的时钟频率一般为42MHz)*/
if(CAN_Init(CAN2, &CAN_InitStructure) == CANINITFAILED)
do {}
while(1);
/* CAN filter init */
CAN_FilterInitStructure.CAN_FilterNumber = 14;//CAN2的滤波器从14开始
CAN_FilterInitStructure.CAN_FilterMode = CAN_FilterMode_IdMask;
CAN_FilterInitStructure.CAN_FilterScale = CAN_FilterScale_32bit;
CAN_FilterInitStructure.CAN_FilterIdHigh = 0x0000;
CAN_FilterInitStructure.CAN_FilterIdLow = 0x0000;
CAN_FilterInitStructure.CAN_FilterMaskIdHigh = 0x0000;
CAN_FilterInitStructure.CAN_FilterMaskIdLow = 0x0000;
// CAN_FilterInitStructure.CAN_FilterFIFOAssignment=0;
CAN_FilterInitStructure.CAN_FilterFIFOAssignment = CAN_FIFO0;
CAN_FilterInitStructure.CAN_FilterActivation = ENABLE;
CAN_FilterInit(&CAN_FilterInitStructure);
CAN_ITConfig(CAN2, CAN_IT_FMP0, ENABLE);
NVIC_InitStructure.NVIC_IRQChannel = CAN2_RX0_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
void CAN2_RX0_IRQHandler(void)
int i;
RxMessage2.StdId = 0x00;
RxMessage2.ExtId = 0x00;
for(i =0; i<8; i++)
RxMessage2.Data[i] = 0;
CAN_Receive(CAN2, CAN_FIFO0, &RxMessage2);
switch(RxMessage2.StdId)
case 1:
break;
case 2:
break;
default:
break;
void CAN_TxSocket_CAN2(CAN *can_Socket)
char i = 0;
TxMessage2.StdId=can_Socket->u32_StdId;
TxMessage2.ExtId=can_Socket->u32_ExtId;
TxMessage2.IDE=can_Socket->u8_IDE;
TxMessage2.RTR= can_Socket->u8_RTR;
TxMessage2.DLC=can_Socket->u8_DLC;
for(i =0; i TxMessage2.Data[i] = can_Socket->u8_data[i]; } i = CAN_Transmit(CAN2, &TxMessage2); } int main(void) { CAN2_Setup(); CAN_Data_Init(); while(1) { if(Send_Flag == 1)//这个flag可用一个定时器来计时,这里不做特别说明 { Send_Flag = 0; CAN_TxSocket_CAN2(&Send_Socket);//Send_Socket中可以存入要发送的数据 } } }
产品名称:ATMEL9260ARM + JN5139Zigbee 售价:1188元 产品规格:14*9.2cm 10*6cm 产品型号:CA-9260-ZB-EK &nb ...… 查看全部问答> |
我手里的CY1C12开发板上的芯片是FPGA的EP1C12Q240C8,今天我用一个小程序,试图点亮那四个七段数码管。用的动态显示。然而,当我配置管脚,下载到板上后,数码管能够顺序点亮,但是不是之前程序里面设计的数字,有些乱码的感觉。 我怀疑是管脚配置 ...… 查看全部问答> |
XILINX FPGA 设计的点滴 1、为时钟信号选用全局时钟缓冲器BUFG 2、尽量只用一个时钟沿来寄存数据 3、除了用CLKDLL或DCM产生的时钟外不要在内部产生时钟 4、注意状态机编码的可靠性:状态机转移状态改变的位数越少,则功能越可靠。 5、逻辑 ...… 查看全部问答> |
刚刚接触Wince 6.0 现在要实现一个使用url链接下载的功能 ,参考了网上一些程序编写如下代码 void CHttpGet::Download(CString url) { try { CStdioFile* pSFile=NULL; CInternetSession ...… 查看全部问答> |
我将ADS1.2下一个工程移植到Keil3 IDE下时,在解决了一些编译错误问题后,也参考了一些说明,编译完成后没有错误,当然有一堆的警告,什么字符串无效,最后一行没空等,但是连接没有生成默认该生成的.axf文件,导致调试也找不到.axf文件,当然也生 ...… 查看全部问答> |
evc中怎样编辑多国语言 比如说我要SetWindowText(_T(\"? ?? ??\")); 但在Evc中成了SetWindowText(_T(\"? ?? ??\")); … 查看全部问答> |
EE_FPGA V1.0 调试进展(2010.10.17更新) 正面: 反面: 目前进展: 1. 最小系统工作 2. LED工作 3. key工作 4. usb转串口驱动正常,串口工作正常 稍后上图,敬请关注 10.17更新 [ 本帖最后由 chenzhufly 于 2010-10-17 14:20 编辑 ]… 查看全部问答> |
