今天是:2024年10月09日(星期三)
2019年10月09日 | STM32F030 使用内部时钟和外部时钟
2019-10-09 来源:eefocus
static void SetSysClock(void)
__IO uint32_t StartUpCounter = 0, HSEStatus = 0;
/* SYSCLK, HCLK, PCLK configuration ----------------------------------------*/
#if defined (PLL_SOURCE_HSI)
/* At this stage the HSI is already enabled */
/* Enable Prefetch Buffer and set Flash Latency */
FLASH->ACR = FLASH_ACR_PRFTBE | FLASH_ACR_LATENCY;
/* HCLK = SYSCLK */
RCC->CFGR |= (uint32_t)RCC_CFGR_HPRE_DIV1;
/* PCLK = HCLK */
RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE_DIV1;
/* PLL configuration = (HSI/2) * 12 = ~48 MHz */
RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_PLLSRC | RCC_CFGR_PLLXTPRE | RCC_CFGR_PLLMULL));
RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_HSI_Div2 | RCC_CFGR_PLLXTPRE_PREDIV1 | RCC_CFGR_PLLMULL12);
/* Enable PLL */
RCC->CR |= RCC_CR_PLLON;
/* Wait till PLL is ready */
while((RCC->CR & RCC_CR_PLLRDY) == 0)
/* Select PLL as system clock source */
RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_SW));
RCC->CFGR |= (uint32_t)RCC_CFGR_SW_PLL;
/* Wait till PLL is used as system clock source */
while ((RCC->CFGR & (uint32_t)RCC_CFGR_SWS) != (uint32_t)RCC_CFGR_SWS_PLL)
#else
#if defined (PLL_SOURCE_HSE)
/* Enable HSE */
RCC->CR |= ((uint32_t)RCC_CR_HSEON);
#elif defined (PLL_SOURCE_HSE_BYPASS)
/* HSE oscillator bypassed with external clock */
RCC->CR |= (uint32_t)(RCC_CR_HSEON | RCC_CR_HSEBYP);
#endif /* PLL_SOURCE_HSE */
/* Wait till HSE is ready and if Time out is reached exit */
do
HSEStatus = RCC->CR & RCC_CR_HSERDY;
StartUpCounter++;
} while((HSEStatus == 0) && (StartUpCounter != HSE_STARTUP_TIMEOUT));
if ((RCC->CR & RCC_CR_HSERDY) != RESET)
HSEStatus = (uint32_t)0x01;
else
HSEStatus = (uint32_t)0x00;
if (HSEStatus == (uint32_t)0x01)
/* HCLK = SYSCLK */
/* PCLK = HCLK */
/* PLL configuration = HSE * 6 = 48 MHz */
RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_PREDIV1 | RCC_CFGR_PLLXTPRE_PREDIV1 | RCC_CFGR_PLLMULL6);
/* Enable PLL */
else
{ /* If HSE fails to start-up, the application will have wrong clock
configuration. User can add here some code to deal with this error */
#endif /* PLL_SOURCE_HSI */
秀偶的STM32-3.2寸TFT-ADS830-IDT7205示波器完工!完全开源!60M采样速率!! 最近一直在玩STM32和LCD屏,从字符到TFT,从1.8到3.5寸,挨个都摸了个摸,公司产品出来了,可一直想用这些东东来作点什么. 示波器上班用公司的,虽说也是便携的,但也不好带回家去用呵,看看市场上动辙千元以上,唉,还是自己动手来DIY方便自己,也造福网友 ...… 查看全部问答> |
需要选择一款数字I/O卡,主要是用来进行信号的延时,输入的是光电开关转换的数字量,经过I/O卡的延时处理,输出触发信号去驱动摄像机进行数据采集,延迟大约0.5秒,速度不需要很快,希望用过类似性价比比较高的高手推荐一款,价格在1000元以内。… 查看全部问答> |
vxworks目标机运行一段时间后就失去一切网络连接了,有可能是什么原因造成的呢? 我的基于vxworks5.5(tornado2.2)的嵌入式系统负责计费,并及时将信息通过网络(ftp功能)传到服务器上。 可是经常在运行一段时间后(例如几个小时,或者一天以后)发现失去了网络连接。 ftp, telnet都无法连到目标机上,但是系统其他功能还正常, ...… 查看全部问答> |
近期准备学习DSP,现在手头有一块2812芯片,想买块板子自己焊接(最小系统),于是上淘宝转了转,发现淘宝卖2812最小系统板的商家特别少。 目前在淘宝上看中了两块板子,可是同样是最小系统这两块板子差价惊人:一块20元、另一块130多(板子整体质 ...… 查看全部问答> |
在工程simpleapp工程文件中有个sapi.c文件中有个API专门指定某个设备是否可以入网/****************************************************************************** * @fn zb_PermitJoiningRequest ...… 查看全部问答> |
这是我测温度的程序,可是测出来的温度是yy.0,请大家帮我看一下 void ADC12(void) { ADC12CTL0 &= ~ENC; ...… 查看全部问答> |
【Altera SoC体验之旅】对ADC采样数据进行FFT处理 本帖最后由 coyoo 于 2015-4-17 11:06 编辑 前面看了柱斑的3篇有关ADC采样的帖子,我的板子没有ADC,所以我也只能从同事的DAQ采集得到的数据进行FFT处理,当然只是进行仿真。学校学习的FFT的原理老早就丢给了老师,最近一段时间花了点时间复习了F ...… 查看全部问答> |
