今天是:2024年10月16日(星期三)
2019年10月16日 | PIC16c54的I2C读写程序
2019-10-16 来源:eefocus
TITLE " TWO WIRE/I2C BUS INTERFACE WITH PIC16C5x "
LIST P=16C54
;** Two wire/I2C Bus READ/WRITE Sample Routines of Microchip's
;** 24Cxx / 85Cxx serial CMOS EEPROM interfacing to a
;** PIC16C54 8-bit CMOS single chip microcomputer
;** Revsied Version 2.0 (4/2/92).
;** Part use = PIC16C54-XT/JW
;** Note: 1) All timings are based on a reference crystal frequency of 2MHz
;** which is equivalent to an instruction cycle time of 2 usec.
;** 2) Address and literal values are read in octal unless otherwise
;** specified.
; Program: I2CBUS.ASM
; Revision Date:
; 12-12-95 Compatibility with MPASMWIN 1.30
; Files Assignment
PC EQU 2 ; Program counter
STAT EQU 3 ; PIC status byte
FSR EQU 4 ; File Select Register
RA EQU 5 ; Port A use to select device address
RB EQU 6 ; RB7 = SDA, RB6 = SCL
STATUS EQU 08 ; Status register
FLAG EQU 09 ; Common flag bits register
EEPROM EQU 0A ; Bit buffer
ERCODE EQU 0B ; Error code (to indicate bus status)
ADDR EQU 10 ; Address register
DATAI EQU 11 ; Stored data input register
DATAO EQU 12 ; Stored data output register
SLAVE EQU 13 ; Device address (1010xxx0)
TXBUF EQU 14 ; TX buffer
RXBUF EQU 15 ; RX buffer
COUNT EQU 16 ; Bit counter
TIMER0 EQU 18 ; Delay timer0
TIMER1 EQU 19 ; Delay timer1
; Bit Assignments
; Status bits
Z EQU 2
C EQU 0
; FLAG Bits
ERR1 EQU 0 ; Error flag
; Instruction Destination Bits
F EQU 1
W EQU 0
; EEPROM Bits
DI EQU 7 ; EEPROM input
DO EQU 6 ; EEPROM output
; I2C Device Bits
SDA EQU 7 ; RB7, data in/out
SCL EQU 6 ; RB6, serial clock
;END FILES/BITS EQUATE
PAGE
; Two wire/I2C - CPU communication error status table and subroutine
; input : W-reg = error code
; output : ERCODE = error code
; FLAG(ERR1) = 1
; code error status mode
; 1 : SCL locked low by device (bus is still busy)
; 2 : SDA locked low by device (bus is still busy)
; 3 : No acknowledge from device (no handshake)
; 4 : SDA bus not released for master to generate STOP bit
;Subroutine to identify the status of the serial clock (SCL) and serial data
;(SDA) condition according to the error status table. Codes generated are
;useful for bus/device diagnosis.
ERR
BTFSS FLAG,ERR1 ; Remain as first error encountered
MOVWF ERCODE ; Save error code
BSF FLAG,ERR1 ; Set error flag
RETLW 0
; START bus communication routine
; input : none
; output : initialize bus communication
;Generate START bit (SCL is high while SDA goes from high to low transition)
;and check status of the serial clock.
BSTART
MOVLW B'00111111' ; Put SCL, SDA line in output state
TRIS RB
bsf RB,SDA ;make sure sda is high
BSF RB,SCL ; Set clock high
MOVLW 1 ; Ready error status code 1
BTFSS RB,SCL ; Locked?
CALL ERR ; SCL locked low by device
BCF RB,SDA ; SDA goes low during SCL high
NOP ; Timing adjustment
NOP
NOP
BCF RB,SCL ; Start clock train
RETLW 0
;END SUB
PAGE
; STOP bus communication routine
; Input : None
; Output : Bus communication, STOP condition
;Generate STOP bit (SDA goes from low to high during SCL high state)
;and check bus conditions.
BSTOP
TRIS RB
BCF RB,SDA ; Return SDA to low
BSF RB,SCL ; Set SCL high
nop
nop
nop
MOVLW 1 ; Ready error code 1
BTFSS RB,SCL ; High?
CALL ERR ; No, SCL locked low by device
BSF RB,SDA ; SDA goes from low to high during SCL high
MOVLW 4 ; Ready error code 4
BTFSS RB,SDA ; High?
CALL ERR ; No, SDA bus not release for STOP
RETLW 0
;END SUB
; Serial data send from PIC to serial EEPROM, bit-by-bit subroutine
; Input : None
; Output : To (DI) of serial EEPROM device
BITIN
MOVLW B'10111111' ; Force SDA line as input
TRIS RB
BSF RB,SDA ; Set SDA for input
BCF EEPROM,DI
BSF RB,SCL ; Clock high
MOVLW 1
BTFSC RB,SCL ; Skip if SCL is high
GOTO BIT1
BIT1
BTFSC RB,SDA ; Read SDA pin
BSF EEPROM,DI ; DI = 1
NOP ; Delay
BCF RB,SCL ; Return SCL to low
RETLW 0
;END SUB
PAGE
; Serial data receive from serial EEPROM to PIC, bit-by-bit subroutine
; Input : EEPROM file
; Output : From (DO) of serial EEPROM device to PIC
BITOUT
MOVLW B'00111111' ; Set SDA, SCL as outputs
TRIS RB
BTFSS EEPROM,DO
GOTO BIT0
BSF RB,SDA ; Output bit 0
MOVLW 2
BTFSC RB,SDA ; Check for error code 2
GOTO CLK1
GOTO CLK1 ; SDA locked low by device
BIT0
BCF RB,SDA ; Output bit 0
NOP ; Delay
NOP
NOP
CLK1
BSF RB,SCL
MOVLW 1 ; Error code 1
BTFSC RB,SCL ; SCL locked low?
GOTO BIT2 ; No.
BTFSS FLAG,ERR1 ; Yes.
BIT2
NOP
NOP
RETLW 0
;END SUB
PAGE
; RECEIVE DATA subroutine
; Input : None
; Output : RXBUF = Receive 8-bit data
RX
MOVLW .8 ; 8 bits of data
MOVWF COUNT
CLRF RXBUF
RXLP
RLF RXBUF, F ; Shift data to buffer
SKPC
BCF RXBUF,0 ; carry ---> f(0)
SKPNC
BSF RXBUF,0
CALL BITIN
BTFSC EEPROM,DI
BSF RXBUF,0 ; Input bit =1
DECFSZ COUNT, F ; 8 bits?
GOTO RXLP
BSF EEPROM,DO ; Set acknowledge bit = 1
CALL BITOUT ; to STOP further input
RETLW 0
;END SUB
; TRANSMIT DATA subroutine
; Input : TXBUF
; Output : Data X'mitted to EEPROM device
TX
MOVLW .8
MOVWF COUNT
TXLP
BCF EEPROM,DO ; Shift data bit out.
BTFSC TXBUF,7 ; If shifted bit = 0, data bit = 0
BSF EEPROM,DO ; Otherwise data bit = 1
CALL BITOUT ; Serial data out
RLF TXBUF, F ; Rotate TXBUF left
SKPC ; f(6) ---> f(7)
BCF TXBUF,0 ; f(7) ---> carry
SKPNC ; carry ---> f(0)
BSF TXBUF,0
DECFSZ COUNT, F ; 8 bits done?
GOTO TXLP ; No.
CALL BITIN ; Read acknowledge bit
MOVLW 3
BTFSC EEPROM,DI ; Check for acknowledgement
CALL ERR ; No acknowledge from device
RETLW 0
;END SUB
PAGE
; BYTE-WRITE, write one byte to EEPROM device
; Input : DATAO= data to be written
; ADDR = destination address
; SLAVE = device address (1010xxx0)
; Output : Data written to EEPROM device
ORG 080 ; The location for BYTE-WRITE routine can be
; ; assigned anywhere between (377-777) octal.
WRBYTE
MOVF SLAVE,W ; Get SLAVE address
MOVWF TXBUF ; to TX buffer
CALL BSTART ; Generate START bit
CALL TX ; Output SLAVE address
MOVF ADDR,W ; Get WORD address
MOVWF TXBUF ; into buffer
CALL TX ; Output WORD address
MOVF DATAO,W ; Move DATA
CALL TX ; Output DATA and detect acknowledgement
CALL BSTOP ; Generate STOP bit
goto wrt_end
; BYTE-READ, read one byte from serial EEPROM device
; Input : ADDR = source address
; Output : DATAI = data read from serial EEPROM
ORG 0C0 ; The location for BYTE-READ routine can be
RDBYTE
MOVF SLAVE,W ; Move SLAVE address
MOVWF TXBUF ; into buffer (R/W = 0)
CALL TX ; Output SLAVE address. Check ACK.
MOVWF TXBUF
CALL TX ; Output WORD address. Check ACK.
CALL BSTART ; START READ (if only one device is
MOVF SLAVE,W ; connected to the I2C bus)
MOVWF TXBUF
BSF TXBUF,0 ; Specify READ mode (R/W = 1)
CALL RX ; READ in data and acknowledge
MOVF RXBUF,W ; Save data from buffer
MOVWF DATAI ; to DATAI file.
goto rd_end
;Test program to read and write ramdom
start
movlw 0AE ;set A2=A1=A0=1
movwf SLAVE ; /
movlw 2 ;set r/w loc. = 2
movwf ADDR ; /
movlw 55 ;write 55 to SEEPROM
movwf DATAO ; /
goto WRBYTE ;write a byte
wrt_end
call delay ;wait for write
;operation (internal)
goto RDBYTE ;read back data
rd_end
movlw 55 ;test if read
xorwf DATAI,W ;correct?
btfss STAT,Z ;yes then skip
wrong
goto wrong
correct
goto correct
;At 2.0Mhz, delay = approx. 3mS.
delay
clrf 1F ;clear last location
dly1
nop
nop
nop
decfsz 1F, F ;reduce count
goto dly1 ;loop
retlw 0
org 0x1FF
goto start
ENDTITLE " TWO WIRE/I2C BUS INTERFACE WITH PIC16C5x "
根据Altium(Protel) 公司在2010年7月12日向悉尼证交所提交的2010年年报预告信息,该公司2009年7月1日至2010年6月30日止,预计共完成销售额是4650万美元,同比下降9% 。 在大中国地区(包括台湾和香港),预计共完成销售额是440万美元,同比下降43% ...… 查看全部问答> |
大家好,小弟现在正在学习嵌入式这一块,最近看到U-Boot,现在希望能在其中添加一条自己的命令,可是却遇到了这样的问题。 小弟所用的版本是1.3.3,算是比较新的版本。基本上是依照网上介绍的做法来添加的。可是把u-boot ...… 查看全部问答> |
请问各位,网卡的全双工/半双工是对MAC而言还是对PHY说的啊,我现在的项目是MAC+PHY结构,自己看资料,发现设置全双工半双工是在PHY芯片上,但是看MAC的工作原理是,全双工半双工控制着MAC的发送流程,看资料上说的是半双工的时候,MAC发送数据要检 ...… 查看全部问答> |
我的系统是2410+vxworks,最近有个应用问题想使用位域来解决,我定义了如下结构体: typedef union { struct { unsigned char Type : 3; &nbs ...… 查看全部问答> |
一个开关电源电路图的分析,+310V电压经过1R1,1R2,稳压二极管1D1(防止栅极因电压过高击穿)给开关管G12栅极提供电压,使其导通,G12导通后,变压器初级56对地导通,+310V给变压器充电,由于电感对初级电流的阻碍作用,变压器上的电流从小到大,当 ...… 查看全部问答> |
