今天是:2024年10月17日(星期四)
正在发生
2019年10月17日 | STM32 3个硬件SPI的使用
2019-10-17 来源:eefocus
硬件平台:STM32F103
SPI1初始化过程
static OS_EVENT *spi1_sem_event;
static void SPI1SemInit(void)
    spi1_sem_event = OSSemCreate(1);
extern void SPI1SemGet(void)
    uint8_t err;
    OSSemPend(spi1_sem_event, 0, &err);
extern void SPI1SemPut(void)
    OSSemPost(spi1_sem_event);
static void Spi1_Init(void)
    SPI_InitTypeDef  SPI_InitStructure;
    GPIO_InitTypeDef GPIO_InitStructure;
    /* Enable SPI1 and GPIO clocks */
    /*!< SPI_FLASH_SPI_CS_GPIO, SPI_FLASH_SPI_MOSI_GPIO,
       SPI_FLASH_SPI_MISO_GPIO, SPI_FLASH_SPI_DETECT_GPIO
       and SPI_FLASH_SPI_SCK_GPIO Periph clock enable */
    /*!< SPI_FLASH_SPI Periph clock enable */
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_SPI1, ENABLE);
    /*!< AFIO Periph clock enable */
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE);
    /*!< Configure SPI_FLASH_SPI pins: SCK */
    GPIO_InitStructure.GPIO_Pin = PIN_SPI1_SCLK;
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
    GPIO_Init(PORT_SPI1_SCLK, &GPIO_InitStructure);
    /*!< Configure SPI_FLASH_SPI pins: MISO */
    GPIO_InitStructure.GPIO_Pin = PIN_SPI1_MISO;
    GPIO_Init(PORT_SPI1_MISO, &GPIO_InitStructure);
    /*!< Configure SPI_FLASH_SPI pins: MOSI */
    GPIO_InitStructure.GPIO_Pin = PIN_SPI1_MOSI;
    GPIO_Init(PORT_SPI1_MOSI, &GPIO_InitStructure);
    /* SPI1 configuration */
    // W25X16: data input on the DIO pin is sampled on the rising edge of the CLK.
    // Data on the DO and DIO pins are clocked out on the falling edge of CLK.
    SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex; //设置SPI单向或者双向的数据模式:SPI设置为双线双向全双工
    SPI_InitStructure.SPI_Mode = SPI_Mode_Master;//设置SPI工作模式:设置为主SPI
    SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;//设置SPI的数据大小:SPI发送接收8位帧结构
#if 0
    SPI_InitStructure.SPI_CPOL = SPI_CPOL_High; //串行同步时钟的空闲状态为高电平
    SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge; //串行同步时钟的第二个跳变沿(上升或下降)数据被采样
#else
    SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low;      //时钟悬空低
    SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge;    //数据捕获于第1个时钟沿
#endif
    SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;   //NSS信号由硬件(NSS管脚)还是软件(使用SSI位)管理:内部NSS信号有SSI位控制
    SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_2;//定义波特率预分频的值:波特率预分频值为2
    SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB; //指定数据传输从MSB位还是LSB位开始:数据传输从MSB位开始
    SPI_InitStructure.SPI_CRCPolynomial = 7;//CRC值计算的多项式
    SPI_Init(SPI1, &SPI_InitStructure);
    /* Enable SPI1  */
    SPI_Cmd(SPI1, ENABLE);
    SPI1SemInit();
extern void SPI1_SetSpeed(u8 SpeedSet)
    //如果速度设置输入0,则低速模式,非0则高速模式
    if(SpeedSet == 1)
        SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_32;
    else
        SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_4;
extern void spi1WriteData(Uchar *buf,Uint len)
    for (; len ; len--,buf++)
        while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_TXE) == RESET);
        SPI_I2S_SendData(SPI1, *buf);
        while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_RXNE) == RESET);
        SPI_I2S_ReceiveData(SPI1);
extern u8 SPI1_Swap_DataMSB(u8 byte)
    u8 retry=0;
    while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_TXE) == RESET) //检查指定的SPI标志位设置与否:发送缓存空标志位
        retry++;
        if(retry>200)return 0;
    SPI_I2S_SendData(SPI1, byte); //通过外设SPIx发送一个数据
    retry=0;
    while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_RXNE) == RESET) //检查指定的SPI标志位设置与否:接受缓存非空标志位
        retry++;
    return SPI_I2S_ReceiveData(SPI1); //返回通过SPIx最近接收的数据
SPI2初始化过程
static OS_EVENT *spi2_sem_event;
static void SPI2SemInit(void)
    spi2_sem_event = OSSemCreate(1);
extern void SPI2SemGet(void)
    uint8_t err;
    OSSemPend(spi2_sem_event, 0, &err);
extern void SPI2SemPut(void)
    OSSemPost(spi2_sem_event);
extern void Spi2_Init(void)
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI2, ENABLE);
    //RCC_APB2PeriphClockCmd(RCC_APB1Periph_AFIO, ENABLE);
    GPIO_InitStructure.GPIO_Pin = PIN_SPI2_SCLK;
    GPIO_Init(PORT_SPI2_SCLK, &GPIO_InitStructure);
    GPIO_InitStructure.GPIO_Pin = PIN_SPI2_MISO;
    GPIO_Init(PORT_SPI2_MISO, &GPIO_InitStructure);
    GPIO_InitStructure.GPIO_Pin = PIN_SPI2_MOSI;
    GPIO_Init(PORT_SPI2_MOSI, &GPIO_InitStructure);
    /* SPI2 configuration */
#if 1
#else
#endif
    SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_16;
    SPI_Init(SPI2, &SPI_InitStructure);
    /* Enable SPI2  */
    SPI_Cmd(SPI2, ENABLE);
    SPI2SemInit();
* Function Name  : SPI_SetSpeed
* Description    : SPI设置速度为高速
* Input          : u8 SpeedSet
*                  如果速度设置输入0,则低速模式,非0则高速模式
*                  SPI_SPEED_HIGH   1
*                  SPI_SPEED_LOW    0
* Output         : None
* Return         : None
void SPI2_SetSpeed(u8 SpeedSet)
    if(SpeedSet == 1)
    else
extern void spi2WriteData(Uchar *buf,Uint len)
        while (SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_TXE) == RESET);
        SPI_I2S_SendData(SPI2, *buf);
        while (SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_RXNE) == RESET);
        SPI_I2S_ReceiveData(SPI2);
extern u8 SPI2_Swap_DataMSB(u8 byte)
  /* Loop while DR register in not emplty */
  /* Send byte through the SPI1 peripheral */
  SPI_I2S_SendData(SPI2, byte);
  /* Wait to receive a byte */
  /* Return the byte read from the SPI bus */
  return SPI_I2S_ReceiveData(SPI2);
SPI3初始化过程
static OS_EVENT *spi3_sem_event;
static void SPI3SemInit(void)
    spi3_sem_event = OSSemCreate(1);
extern void SPI3SemGet(void)
    uint8_t err;
    OSSemPend(spi3_sem_event, 0, &err);
extern void SPI3SemPut(void)
    OSSemPost(spi3_sem_event);
static void Spi3_Init(void)
AVAGO公司的发展小趣事
随着公司规模的扩大和技术的不断积累,AVAGO公司开始寻求多元化的发展道路。除了继续深耕半导体领域外,公司还积极拓展其他相关领域,如传感器、无线通信等。同时,公司还与其他行业的领军企业建立了紧密的战略合作关系,共同推动技术创新和市场拓展。
AZ Displays公司的发展小趣事
随着技术的不断进步和市场需求的不断变化,AZ Displays的产品应用领域也在不断拓展。除了传统的消费电子领域外,公司的产品还广泛应用于航空电子、医疗、导航系统、工业控制等多个领域。通过与各行业合作伙伴的紧密合作,AZ Displays成功打开了新的市场大门,实现了业务的快速增长。
Crane Connectors公司的发展小趣事
Crane Connectors公司自创立之初,便致力于电子连接器技术的研发与创新。面对激烈的市场竞争,公司不断投入研发资源,推出了一系列具有自主知识产权的新型连接器产品。这些产品凭借出色的性能、稳定性和可靠性,迅速获得了市场的认可,为公司赢得了大量订单。随着技术的不断升级和产品的持续优化,Crane Connectors逐渐在电子连接器领域树立了良好的品牌形象,实现了市场的快速扩张。
Auris公司的发展小趣事
Auris公司在技术研发方面取得了显著成果。其中,一款名为Auris Robotic Endoscopy System(ARES)的医疗机器人尤为引人注目。这款机器人能够通过精准的操控,帮助医生在不切口的情况下发现早期肺癌,提高了诊断的精确性。20XX年,食品与药品监督管理局(FDA)正式批准了ARES机器人的使用,这是对Auris公司技术实力和产品质量的高度认可。
南京绿芯(Grenergy)公司的发展小趣事
AB Connectors Ltd公司的发展小趣事
在快速发展的过程中,AB Connectors Ltd始终将品质管理放在首位。公司建立了完善的质量管理体系,从原材料采购、生产加工到产品出厂检验等各个环节都实行严格的质量控制。此外,公司还引进了先进的生产设备和检测技术,不断提高产品的精度和稳定性。这些措施有效提升了产品的品质水平,赢得了客户的信任和好评。
基于S52的超声波测距仪
基于S52的超声波测距仪…
浅谈电视监控系统智能化和集约化方案
视频监控一直是安防技术应用的热点之一,以其直观、方便、信息内容丰富而被广泛应用于军队、银行、海关、机场、高速公路、商场、医院、学校、机关、社会小区、家庭等各种场合。视频监控系统的智能化水平和集成化发展速度,也直接反映了不同阶段电子 ...…
vs2008下安装sqlce
1.安装哪个版本的sqlce? 2.如何配置 3.基本增删查改和SQL Server是否一致?…
买个无线网卡,却无法上网!
每次拨号连接网络都提示“设置系统参数失败”!! 前几天还好好的,刚出现的这个毛病。…
电脑蓝屏
宏基笔记本,刚给电脑除尘,给电脑装了一个2G的内存条,重装了好几次系统,玩一会就出现蓝屏STOP 0x000000c2 (0x00000007, 0x00000CD4, 0x00000000, 0xE2195AF8),各位大侠,快点告诉我这到底是什么问题?…
有人知道ADV7170/7171可以用VGA连接到电脑显示器上显示吗
我现在在做一个板子,输出的DA用的ADV7170,准备输出RGB信号通过VGA连接到电脑显示器上显示,同步信号通过FPGA产生 但是我了解到这个芯片输出的RGB好像是欧洲SCART的标准,就是隔行的,但是我知道电脑上的VGA都是逐行的信号吧,那这么做兼容吗? ...…
PCB加工快速焊接
北京力合安达电路科技有限公司 徐晓红:13671271976…
nbcool 帮帮我吧
我真的不知道哪里出错了 就是改不出来 你看看我的帖子 你给我回后 我又回复了 谢谢阿   …
大家有没有人了解武汉爱维特公司的?
我在网上投递了他们公司的嵌入式开发工程师,今天他们打电话给我说要先培训四个月,然后才能上班,并且让我交5000元的培训费,这个公司我咋感觉是骗子公司呢!~…
DK-LM3S9B96下载程序问题请教
     初学LM3S9B96,现遇到问题:      1.用DK-LM3S9B96开发板自带的IDCI下载程序,报错不能下载成功,错误为“Could not find an Cortex-M device”,见贴图;      2.用JLINK下载 ...…
