今天是:2024年10月21日(星期一)
2019年10月21日 | 使用PIC单片机读写1-wire EEPROM DS2430的范例程序
2019-10-21 来源:eefocus
; 1-wire device access
;DS2430
;memory function
;write scratchpad
;read scratchpad
;read memory :
; resource occupy by ICD2
; PROM 0x1f00 - 0x1fff
; RAM 0x70,0xf0,0x170,0x1e5~0x1f0
; master action
; 0xf0 + start addr(8) => scratchpad(8) --> master
; none => scratchpad(9) --> master
; none => scartchpad(a) --> master
; none => scratchpad(0x1f)--> master[wrap around]
; reset pulse => stop sending data
; 0xf0+reset pulse => EEPROM(0x00-0x1F) --> scratchpad(0x00-0x1F)
; copy scratchpad
; master
; 0x55 + 0xa5 => scratchpad(000-0x1f) --> EEPROM(0x00-0x1F)
; held hi for 10ms
; 0xf0 + reset pulse => copy whole from EEPROM to SCRATCHPAD
; use timer as a delay timer
; author : Rex Chen
; date : May,8th
; ver : 1.81
list p=16F877A
#include p16f877a.inc
__CONFIG _CPD_OFF & _CP_ALL & _DEBUG_ON & _BODEN_OFF & _LVP_OFF & _PWRTE_OFF & _WDT_OFF & _XT_OSC
#define OneWireDHi bsf PORTC,Bit2
#define OneWireDLo bcf PORTC,Bit2
#define CARRY STATUS,C
#define ZERO STATUS,Z
Bit0 equ H'0000'
Bit1 equ H'0001'
Bit2 equ H'0002'
Bit3 equ H'0003'
Bit4 equ H'0004'
Bit5 equ H'0005'
Bit6 equ H'0006'
Bit7 equ H'0007'
;variable defination
cblock 0x20 ; RAM area 0x20- 0x7f
SYSFLAG
TxB ; Command buffer been send
TxBuffer ; data buffer been send
RxB ; Command buffer been received
TempB ; Temp Byte to roll the data
LoopCounter
Addr ; address to access BQ2430A
PBDir ; port C direction log file
PADir ; port A direction log file
Temp
ErrCode ;
W_SAVE
STATUS_SAVE
TxBuf:8 ; Tx Temp buffer
Offset
endc
cblock 0xa0
SARS1
SARS2
SARS3
endc
cblock 0x100
HateSARS1
HateSARS2
HateSARS3
HateSARS4
endc
cblock 0x190
SARSIsAPig0
SARSIsAPig1
SARSIsAPig2
SARSIsAPig3
SARSIsAPig4
SARSIsAPig5
endc
;---------------- SYSFLAG ----------------------------------
fTxHi equ H'0000'
fTxLo equ H'0001'
fRxMode equ H'0002'
;; there are 4 memory block
;; 1. EEPROM & 2. memory scratchpad
;; 3. application register
;; 4.register scratchpad
;; aliase
;; memory function
;; write memory scratch
;; read memory scratch
;; copy memory scratch to EEPROM
;; read EEPROM to memory scratch
WScratch equ H'0F' ; 0x0f + Addr + data + data + .+ reset pulse
; // [Master --> ScratchPad ]
RScratch equ H'AA' ; 0xaa + Addr + R + R +.. + reset pulse
; // [ScratchPad --> Master ]
CPScratch equ H'55' ; 0x55 + 0xa5 + hi 10ms // [ScratchPad --> EEPROM ]
REEROM equ H'F0' ; 0xf0 + Addr +R +R + reset pulse
; // [EEPROM(addr) --> ScratchPad]
; 0xf0 + reset pulse // [EEPROM --> ScratchPad]
;; application register , application register is OTP, there are 7 bytes
;; pay attention when you use application register , it's a 64 bit OTP
WApR equ H'99' ; 0x99 + Addr + data + data .. + reset pulse
; [Master --> Application Reg]
RStatus equ H'66' ; 0x66 + 0x00 + status + reset pulse
RApR equ H'C3' ; 0xc3 + addr + data + .. + reset pulse
; application register --> master ( locked)
; register scratchpad --> master ( not lock)
LockAp equ H'5A' ; 0x5A + 0xa5
; [ register scratchpad --> application register]
; 0x5A + reset pulse cancel copy command
; a OTP type do once only
AppLocked equ B'11111100' ; application locked, the value is data in the status
;; ROM function command// implement skip rom only
SkipROM equ H'CC' ;access memory directly
SerachROM equ H'f0' ;read a bit , read the complement of the bit,write bit
MatchROM equ H'55' ;0x55 + 64 bit rom bit
ReadROM equ H'33' ;[family code & serial number & CRC ==> master ]
org H'00'
nop
goto main
;;ISR **
org H'04'
goto isr
isr
movwf W_SAVE ;; W_SAVE=W
swapf STATUS,W ;;
movwf STATUS_SAVE ;; STATUS_SAVE=STATUS[3:0]& STATUS[7:4]
btfss PIR1,TMR1IF ;; TMR1IF
goto exit_int_source_check
;; timer 1 service
nop
nop
nop
nop
exit_int_source_check ;; restore STATUS & W before exit from
swapf STATUS_SAVE,W ;; W=STATUS_SAVE=STATUS[3:0]& STATUS[7:4]
movwf STATUS
swapf W_SAVE,F ;; restore W
swapf W_SAVE,W
retfie
;; ISR &&&
main
call init
call init_int_en
movlw H'21'
movwf FSR
movlw H'3c'
movwf INDF ;
;--------- read test --------------------------
; movlw H'00'
; banksel Addr
; movwf Addr
; call RdDS2430
; movlw H'01'
; banksel Addr
; movwf Addr
; call RdDS2430
; movlw H'02'
; banksel Addr
; movwf Addr
; call RdDS2430
; banksel Offset
; clrf Offset
; pagesel VendorTable
; call VendorTable
; movwf Temp
movlw H'00'
banksel Addr
movwf Addr
movlw H'34'
banksel TxBuffer
movwf TxBuffer
call WrDS2430
movlw H'01'
banksel Addr
movwf Addr
movlw H'35'
banksel TxBuffer
movwf TxBuffer
call WrDS2430
movlw H'02'
banksel Addr
movwf Addr
movlw H'36'
banksel TxBuffer
movwf TxBuffer
call WrDS2430
;-------- read address 0 --------------------------
movlw H'00'
movwf Addr
call RdDS2430
goto $
; template to init before write
; to DS2430
; movlw H'00'
; movwf Addr
; movlw H'3C'
; movwf TxBuffer
; write DS2430 one byte
; input
; Addr = starting address to write
; TxB = data to save
; output =
; ErrCode = 0 -> write ok
; = 1 -> write fail
WrDS2430
call WrScratchPAD
call CP2EE
return
; template to init before read
; to DS2430
; movlw H'00'
; movwf Addr
; read DS2430 one byte
; input
; Addr = starting address to read
; output
; RxB = data to read
RdDS2430
call REE2ScratchPAD
call HostRdScratchPAD
return
;;--------- host read scratch pad ----------------------------
;; save desired data into RxB
HostRdScratchPAD
call DS2430AInitState
banksel TxB
movlw SkipROM
movwf TxB
call TxBYTE ; SkipROM
movlw RScratch ; read scratch PAD Command
movwf TxB
call TxBYTE
movf Addr,W ; starting address to read
movwf TxB
call TxBYTE
call R2430A ; read desired scratch pad into RxB
call RstPulse
return
;-------------- write memory scratch scratch pad ------------------------
; write one byte into scratch PAD
; input
; TxBuffer = data to save
; output
; = 1 -> write fail
WrScratchPAD
movlw SkipROM ; 0xCC
movwf TxB
movlw WScratch ; write memory scratch pad, 0x0f
movwf TxB
call TxBYTE
movf Addr,W ; starting address of memory scratch pad
movwf TxB ; TxBYTE use TxB
call TxBYTE
movf TxBuffer,W ;
movwf TxB
call TxBYTE
call RstPulse ; reset pulse
call delay500us ; wait presence pulse
return
;---------- CP2EE ---copy whole scratch pad to EE ----------------------
; verify memory scratch
CP2EE
call DS2430AInitState ; 0x55 + 0xa5 + hi 10ms // [ScratchPad -> EEPROM ]
banksel TxB
movlw SkipROM
movwf TxB
movlw CPScratch ; 0x55
movwf TxB
call TxBYTE
movlw H'a5'
movwf TxB
call TxBYTE
call ForceHi ; min 10ms refter to datasheet
return
;--------- REE2ScratchPAD --- copy whole EE to ScrathPAD ----------------
; copy EE to whole memory scatch
;format I: 0xf0 + Addr +R +R + reset pulse, copy byte by byte
;format II: 0xf0 + Addr + reset pulse, copy whole
REE2ScratchPAD
banksel TxB
movlw SkipROM
movwf TxB
movlw REEROM ;; Read from EE into ScratchPAD
movwf TxB
call TxBYTE ;;
call RstPulse ;; copy all
return
;----------R2430A ---- Host read the scratch PAD ------------------------
; Read 2430A Scratch PAD
; LSB first
; save the result in RxB
R2430A ; returns byte in RxB
movlw .8
movwf LoopCounter
clrf RxB
RLoop
call SetLo ;
nop
call SetHi ; it will pull up by resistor
nop ; delay to sample reliable bit
nop
nop
nop
nop
nop
nop
nop
nop
nop
nop
nop
nop
nop
nop
banksel PORTB
LLC谐 振 变 换 器 与不 对 称 半 桥 变 换 器 的 对 比 摘 要 : 介 绍 了LLC谐 振 变 换 器 和 不 对 称 半 桥 变 换 器 两 种 不 同 类 型 的 软 开 关 拓 扑 。 分 析 了 它 们 的 工 作 原 理 , 分 别 对 它 们 的 控 制 方 法 , 副 边 整 流 管 的 电 压 应 力 和 副 边 的 开 通 等 进 行 了 比 ...… 查看全部问答> |
由于降阻剂对接地体的腐蚀太严重,给国家造成了重大损失,在很多地方已经被禁止使用,而且已有很多专家呼吁禁用降阻剂。 因此,一些黑心厂家开始开发接地模块来取代降阻剂,以牟取更大的暴利。接地模块也是这个国家在这种浮躁的时期所独有的,相信 ...… 查看全部问答> |
请问: 单片机在使用中什么情况下某一个I/O口突然不起作用,而其它I/O口都正常?我遇到好多单片机坏的都是这个问题, 不是固定的某个I/O口,是随机的,我做了好多试验就是找不到问题,因为我是搞硬件的对软件不是太了 ...… 查看全部问答> |
我今年刚毕业,学的是嵌入式,一直在学ARM,DSP到大四自学的,不怎么懂! 现在我在一家消费类电子公司工作,主要是视频音频及图片处理的,但我的工作只是负责上层的 UI的设计,接触不到底层的知识。 所以我现在很迷茫,不知道该怎么 ...… 查看全部问答> |
大家好,我是一名刚刚毕业的大学生,学了C/C++,现在一软件公司就业,我们公司是做 \"手机嵌入式软件程序开发\" 方面的,主要项目如:手机中的电话簿,手机中的手法彩信软件,还有手机中的浏览器等等~~~我也想向“手机嵌入式软件程序开发”方向发展~~可 ...… 查看全部问答> |
