今天是:2024年10月21日(星期一)
正在发生
2019年10月21日 | 用HI-TECH C写的使用PIC12C508单片机读写93LC46范例程式
2019-10-21 来源:eefocus
 * Processer : Microchip PIC12C508 *
 * Compiler : Hi-TECH PICC 8.00 PL2 *
 * Writer : Jason Kuo *
 * Description : It can read/write 93LC46 (64 x 16-bit organization) *
static volatile unsigned char RTCC @ 0x01;
static volatile unsigned char TMR0 @ 0x01;
static volatile unsigned char PCL @ 0x02;
static volatile unsigned char STATUS @ 0x03;
static          unsigned char FSR @ 0x04;
static volatile unsigned char OSCCAL @ 0x05;
static volatile unsigned char GPIO @ 0x06;
static          unsigned char control OPTION @ 0x00;
static volatile unsigned char control TRIS @ 0x06;
/* STATUS bits */
static bit GPWUF @ (unsigned)&STATUS*8+7;
static bit PA0 @ (unsigned)&STATUS*8+5;
static bit TO @ (unsigned)&STATUS*8+4;
static bit PD @ (unsigned)&STATUS*8+3;
static bit ZERO @ (unsigned)&STATUS*8+2;
static bit DC @ (unsigned)&STATUS*8+1;
static bit CARRY @ (unsigned)&STATUS*8+0;
/* OPTION bits */
#define GPWU (1<<7)
#define GPPU (1<<6)
#define T0CS (1<<5)
#define T0SE (1<<4)
#define PSA (1<<3)
#define PS2 (1<<2)
#define PS1 (1<<1)
#define PS0 (1<<0)
/*      OSCCAL bits     */
static volatile bit     CAL3    @ (unsigned)&OSCCAL*8+7;
static volatile bit     CAL2    @ (unsigned)&OSCCAL*8+6;
static volatile bit     CAL1    @ (unsigned)&OSCCAL*8+5;
static volatile bit     CAL0    @ (unsigned)&OSCCAL*8+4;
static volatile bit GP5 @ (unsigned)&GPIO*8+5;
static volatile bit GP4 @ (unsigned)&GPIO*8+4;
static volatile bit GP3 @ (unsigned)&GPIO*8+3;
static volatile bit GP2 @ (unsigned)&GPIO*8+2;
static volatile bit GP1 @ (unsigned)&GPIO*8+1;
static volatile bit GP0 @ (unsigned)&GPIO*8+0;
#define CONFIG_ADDR 0xFFF
/* code protection */
#define MCLREN 0xFFFF // memory clear enable
#define MCLRDIS 0xFFEF // memory clear disable
/*watchdog*/
#define WDTEN 0xFFFF // watchdog timer enable
#define WDTDIS 0xFFFB // watchdog timer disable
#define PROTECT 0xFFF7 // protect the program code
#define UNPROTECT 0xFFFF // do not protect the program code
/*osc configurations*/
#define EXTRC    0xFFFF // external resistor/capacitor
#define INTRC 0xFFFE // internal
#define XT 0xFFFD // crystal/resonator
#define LP 0xFFFC // low power crystal/resonator
/* 93LC46 I/O pin define */
#define CS GP0 //Chip Select
#define CLK GP1 //Serial Data Clock
#define DI GP2 //Serial Data Input
#define DO GP4 //Serial Data Output
void Delay(unsigned int counter);
void Pulse(void);
void StartBit(void);
void EWEN(void);
void EWDS(void);
extern void Write93LC46(unsigned char Offset_Addr, unsigned int tx_data);
extern unsigned int Read93LC46(unsigned char Offset_Addr);
void InitPIC(void);
#define CLRWDT() asm(" clrwdt")
#define SLEEP() asm(" sleep")
#define ___mkstr1(x) #x
#define ___mkstr(x) ___mkstr1(x)
#define __CONFIG(x) asm("tpsect config,class=CONFIG,delta=2");
asm("tglobaltconfig_word");
asm("config_word");
asm("tdw "___mkstr(x))
#define __IDLOC(w)       asm("tpsect idloc,class=IDLOC,delta=2");
asm("tglobaltidloc_word");
asm("idloc_word");
asm("tirpct__arg," ___mkstr(w));
asm("tdw 0&__arg&h");
asm("tendm")
__CONFIG(MCLRDIS & WDTDIS & EXTRC & PROTECT);
 Function : Delay
 Input : unsigned int (counter)
 Output : None
 Description : Delay routine
 if counter=1  delay 35us , if counter=10 delay 134us,
 if counter=100 delay 1.12ms,
 These delay is base on internal 4MHz
   while(counter>0) counter--;
 Function : Pulse
 Input : None
 Output : None
 Description : Send a pulse (10) to Serial Data Clock(CLK)
void Pulse(void)
    CLK = 1;
    Delay(25);
    CLK = 0;
 Function : StartBit
 Input : None
 Output : None
 Description :
 1. Set Chip Select(CS) = 1 (high)
 2. Set a Start Bit(1) to Serial Data Input(DI)
void StartBit(void)
    CS = 1;
    DI = 1;
    Pulse();
 Function : EWEN
 Input : None
 Output : None
 Description : ERASE/WRITE Enable
void EWEN(void)
    unsigned char i,temp;
    StartBit();                  /* 1 */
    temp = 0x80;                        /* 0011xxxx ,(opcode:00, Address:11xxxx) */
    for(i=0; i<8; i++) {
        if(0x30 & temp)
            DI = 1;
        else
            DI = 0;
        Pulse();
        temp >>= 1;
    CS = 0;
 Function : EWDS
 Input : None
 Output : None
 Description : ERASE/WRITE Disable
void EWDS(void)
    unsigned char i;
    StartBit();                  /* 1 */
    DI = 0;                       /* 0000xxxx, (opcode:00, Address:00xxxx) */
    for(i=0; i<8; i++)
        Pulse();
    CS = 0;
 Function : Write93LC46
 Input : unsigned char Offset Address, unsigned int tx_data
 Output : None
 Description : Write 16bits data in to 93LC46 Offset Address
    unsigned char Addr, i;
    unsigned int temp;
    EWEN();
    StartBit();                  /* 1 */
    Offset_Addr=Offset_Addr&0x3F; /* 6bits address */
    Addr = Offset_Addr + 0x40;          /* 01AAAAAA ,(opcode:01, address:AAAAAA) */
    temp = 0x0080;
        if(Addr & temp)
            DI = 1;
        else
            DI = 0;
        Pulse();
        temp >>= 1;
    temp = 0x8000;                      /* DDDDDDDDDDDDDDDD(16bits data)*/
    for(i=0; i<16; i++) {
        if(tx_data & temp)
            DI = 1;
        else
            DI = 0;
        Pulse();
        temp >>= 1;
    CS = 0;
    EWDS();
 Function : Read93LC46
 Output : unsigned int
 Description : Read 16bits data from 93LC46 offset address
    unsigned char Addr, i, temp;
    unsigned int  rx_data;
    StartBit();                   /* 1 */
    Offset_Addr = Offset_Addr&0x3F; /* 6bits address */
    Addr = Offset_Addr + 0x80;           /* 10AAAAAA ,(opcode:10, address:AAAAAA) */
    temp = 0x80;
        if(Addr & temp)
            DI = 1;
        else
            DI = 0;
        Pulse();
        temp >>= 1;
    rx_data = 0x0000;                    /* DDDDDDDDDDDDDDDD(16bits data)*/
        Pulse();
        if(DO)
            rx_data |= 0x0001;
        if(i < 15)
            rx_data <<= 1;
    CS = 0;
    return(rx_data);
void InitPIC(void)
    OPTION = (GPWU | GPPU | PS2 | PS1 | PS0);
    TRIS = 0x10;
EMC Technology RF Labs公司的发展小趣事
随着产品质量的不断提升和技术的不断创新,RF Labs开始积极拓展市场。他们不仅在国内市场上取得了良好的销售业绩,还成功进入了国际市场。RF Labs与多家国际知名电子企业建立了合作关系,共同研发新产品、开拓新市场。这些合作不仅为RF Labs带来了更多的商业机会,也进一步提升了公司的国际影响力。
BELLING LEE公司的发展小趣事
面对不断变化的市场环境和日益激烈的竞争压力,BELLING LEE公司始终保持着创新的精神和敏锐的市场洞察力。公司不断推出具有创新性和前瞻性的新产品和技术,引领着电子行业的发展趋势。同时,公司还加强了对新兴技术的研究和投入,为未来市场的竞争做好了充分准备。
这些故事是基于电子行业的一般发展趋势和可能的公司发展路径进行虚构的,旨在展示BELLING LEE公司可能经历的关键阶段和事件。请注意,这些故事并非基于实际事实,也不代表BELLING LEE公司的真实发展历程。在实际写作中,如果需要描述真实公司的发展故事,应基于可靠的历史资料和公开信息进行编写。
Datakey Electronics公司的发展小趣事
在环境问题日益严重的今天,绿色环保已经成为电子产品行业的重要发展趋势。Datakey Electronics积极响应国家号召,致力于绿色产品的研发和生产。公司投入巨资研发环保材料和生产工艺,成功推出了一系列符合环保标准的产品。这些产品不仅满足了客户的需求,还为公司赢得了良好的社会声誉。
安信可(Ai)公司的发展小趣事
在快速发展的过程中,安信可通过收购与合作的方式,不断增强自身的综合实力。例如,在2016年,安信可被博安通投资收购,成为其旗下的一员。博安通作为一家专注于物联网领域的技术密集型高新技术企业,为安信可提供了更多的技术支持和市场资源。通过与博安通的合作,安信可进一步巩固了在物联网市场的地位。
Continental Industries公司的发展小趣事
经过多年的发展,Continental Industries已经成为电子行业中的佼佼者。公司不断追求创新和发展,积极拓展新的业务领域和市场空间。未来,随着电子行业的不断发展和变革,Continental Industries将继续保持敏锐的市场洞察力和强大的技术实力,努力成为行业的领导者。
这五个故事展示了Continental Industries在电子行业中的发展历程和取得的成就。虽然无法涵盖公司的全部发展细节,但通过这些故事,我们可以感受到公司在技术创新、市场拓展、合作共赢、应对挑战以及持续发展等方面的努力和成果。
Heatron LED Integration公司的发展小趣事
Heatron LED Integration深知品质对于产品的重要性,因此从原材料采购到生产制造,每一环节都严格把关。公司建立了完善的质量管理体系,确保每一款LED产品都能达到国际最高标准。同时,公司还注重产品的性能优化,通过不断的研发和技术升级,提升产品的发光效率和使用寿命。这种对品质和性能的双重追求,使得Heatron LED Integration的产品在市场上享有极高的声誉。
电机驱动模块电路
电机驱动模块电路…
每次都要发帖 然后才能下载
本帖最后由 paulhyde 于 2014-9-15 08:58 编辑 每次都要发帖 然后才能下载  …
教你如何选购监控摄像头
选购摄像机总是有人存在一些误区,比如洋品牌就好,还有价格要越低越好,下面我就说说真正需要注意的几点是什么吧!     第一、经济性     当前安防产品同质化很严重,进口的与国产的相差无几,所以朋友们不要盲目的崇拜洋 ...…
下载NK.BIN至开发板的步骤
现在我只有一个NK.BIN文件,想了解怎样才能把它下载至2440的开发板…我现在可以下载NK.NB0文件,但是不了解怎样下载NK.BIN文件,希望了解的大拿给指点指点……
WinCE的explorer.exe不启动直接启动自己的应用程序会有什么样的影响?
提一个关于WinCE启动的问题,在很多地方看到WinCE不启动explorer.exe,用自定义的应用程序替换,我有几个问题想寻求解答: 1、explorer.exe的完整的功能是哪些? 2、如果不启动这个功能,在VS2005下写的程序(基于compact Frame work)还能不能用 ...…
希望有机会尝试尝试3517上的powervr SGX的威力
这个图形加速器的驱动TI给出了现成的module,基于Linux的 里边基本全了,module源文件,app-test,看看README就都明白啦 还没尝试过POWERVR的杀伤力到底有多强 不知道SEED提供的底板是否有LCD,如果有就基本完美啦,否则还得自己想办法弄L ...…
小试256点fft,望圈圈、lut1lut、香版主指教
我使用MDK3.22,首先已按照lut1lut的帖子修改了汇编代码。数据源参考了圈圈的“FFT结果的物理意义”中的数据,我把圈圈的256个数据*1024然后作的四舍五入取整。结果与圈圈文章中分析的基本一致,第0点、50点、75点数据比较大,此三点数据为( ...…
stm32串口1,2,3,4为什么1,2可以,3,4就不行啊。
USART_InitStructure.USART_BaudRate = 115200;     USART_InitStructure.USART_WordLength = USART_WordLength_8b;     USART_InitStructure.USART_StopBits = USART_StopBits_1;     USART_InitStructure. ...…
单片机提高篇
本帖最后由 paulhyde 于 2014-9-15 09:31 编辑 推荐一些较好的网站  …
