今天是:2024年10月30日(星期三)
2019年10月30日 | MSP430杂谈--AD7745硬件IIC驱动与模拟IIC驱动
2019-10-30 来源:eefocus
和上一篇AD7793类似,项目中也涉及到利用AD7745读取电容值,来测环境湿度。编写了基于MSP430的AD7745的硬件IIC驱动和模拟IIC驱动,分享给大家。
AD7745硬件IIC驱动完整版下载链接:https://download.csdn.net/download/qq_42580947/11041942
AD7745模拟IIC驱动完整版下载链接:https://download.csdn.net/download/qq_42580947/11041947
PS:目前资源积分无法自行调整,有谁知道可以修改积分的方法请告知,我想免费分享给大家。
1. AD7745的硬件IIC驱动
MCU:MSP430F57XX
AD7745的硬件IIC驱动失败的几个原因有:单片机配置IIC资源错误(包括IIC的时钟,IIC的运行模型等配置错误),单片机的系统时钟配置错误(注意MCLK, SMCLK, ACLK的分配)
1.1 AD7745的写函数
void AD7745_W(unsigned char addr, unsigned char data)
while(UCB0STAT& UCBBUSY)
InitUCB0();
UCB0CTL1 |= UCTR;
UCB0CTL1 |= UCTXSTT;
UCB0TXBUF = addr;
delayus(200);
while(!(UCB0IFG & UCTXIFG0));
UCB0TXBUF = data;
delayus(200);
UCB0CTL1 |= UCTXSTP;
while (UCB0CTL1 & UCTXSTP);
1.2 AD7745的读函数
void AD7745_R(unsigned char addr, unsigned char *buffer, char n)
unsigned char index;
UCB0CTL1 |= UCTR;
delayus(200);
UCB0TXBUF = addr;
delayus(200);
UCB0CTL1 &=~ UCTR;
RXByteCtr = n;
delayus(200);
for(index=0; index < n-1; index++)
while(!(UCB0IFG & UCRXIFG0));
*buffer++ = UCB0RXBUF;
delayus(200);
UCB0CTL1 |= UCTXSTP+UCTXNACK;
delayus(200);
while((UCB0IFG&UCRXIFG)==0);
*buffer = UCB0RXBUF;
delayus(200);
1.3 AD7745的复位
void Reset_AD7745()
InitUCB0();
UCB0CTL1 |= UCTR;
delayus(200);
UCB0TXBUF = 0xBF;
1.4 AD7745的初始化
void Init_AD7745(void)
AD7745_W(0x0D, offset_buf[0]);
AD7745_W(0x0E, offset_buf[1]);
capdac_offset = Capdac_Parameter;
out_buff[4] = 0x80+capdac_offset; //CAPDACA is set to capdac_offset
out_buff[5] = 0x80; //CAPDACB is set to 0
CAPDAC = (float)(capdac_offset*CAPDAC_UNIT); //CAPDAC只会取4值,即4.25,8.5,12.75,17
AD7745_W(0x07, out_buff[0]); // data collect
AD7745_W(0x08, out_buff[1]);
AD7745_W(0x09, out_buff[2]);
AD7745_W(0x0A, out_buff[3]);
AD7745_W(0x0B, out_buff[4]);
AD7745_W(0x0C, out_buff[5]);
memset(DataArr,0,sizeof(float)*DataNumber);
1.5 读取测量数据
void ReadData(void)
AD7745_R(0x01, in_buff, sizeof(in_buff)); // read the data register
CDC_Register_data = in_buff[1];
CDC_Register_data = 0;
CDC_Register_data <<= 8;
CDC_Register_data += in_buff[2];
CDC_Register_data += in_buff[0];
CDC_Register_data &= 0x00ffffff;
CDC_Capacitance2 = (float)(FULL_SCALE-SEMI_SCALE);
if(CDC_Register_data>= SEMI_SCALE)
CDC_Capacitance1 = (float)(CDC_Register_data-SEMI_SCALE);
CDC_Capacitance = 4.096 * (CDC_Capacitance1/CDC_Capacitance2);
else
CDC_Capacitance1 = (float)(SEMI_SCALE-CDC_Register_data);
CDC_Capacitance = -4.096 * (CDC_Capacitance1/CDC_Capacitance2);
CDC_Capacitance = CAPDAC+CDC_Capacitance;
Capacitance = CDC_Capacitance;
2. AD7745模拟IIC驱动
模拟IIC驱动失败的最主要原因是:时钟!时钟!时钟!注意时钟的配置和延时的处理
2.1 AD7745基础子函数的处理
void start()
SCL_OUT;
SDA_OUT;
SDA_H;
delayms(1);
SCL_H;
delayms(1);
SDA_L;
delayms(1);
SCL_L;
delayms(1);
void stop()
SDA_OUT;
SCL_OUT;
SDA_L;
delayms(1);
SCL_H;
delayms(1);
SDA_H;
delayms(1);
void Ack()
SDA_OUT;
SCL_OUT;
SCL_L;
SDA_L;
delayms(1);
SCL_H;
delayms(1);
SCL_L;
void NAck()
SDA_OUT;
SCL_OUT;
SCL_L;
SDA_H;
delayus(2);
SCL_H;
delayus(2);
SCL_L;
unsigned int WAck()
SDA_H;
SDA_IN;
SCL_H;
while(P1IN & BIT6)
SCL_L;
delayms(1);
return 0;
1.2 读取字节数据
uchar read_byte()
uchar i,read_data;
SDA_OUT;
SCL_L;
SDA_H;
for(i = 0;i<8;i++)
SDA_H;
delayus(2);
SCL_H;
SDA_IN;
delayus(2);
read_data <<= 1;
if(P1IN & BIT6)
read_data |= 0x01;
SDA_OUT;
SCL_L;
delayms(5);
return(read_data);
1.3 写字节数据
void write_byte(uint data)
uchar i;
SCL_OUT;
SDA_OUT;
for(i = 0;i<8;i++)
if(data & 0x80)
SDA_H;
else
SDA_L;
delayms(1);
SCL_H;
delayms(1);
SCL_L;
delayms(1);
data = data << 1;
delayms(5);
1.4 向指定地址写数据
void write_dat(uchar addr,uchar write_data)
start();
write_byte(OP_WRITE);
WAck();
write_byte(addr);
WAck();
write_byte(write_data);
WAck();
stop();
delayus(1000);
1.5 从指定地址读数据
uchar read_random(uint random_addr)
uchar i;
start();
WAck();
write_byte(random_addr);
WAck();
start();
write_byte(OP_READ);
WAck();
i = read_byte();
stop();
return i;
1.6 AD7745的初始化
void Init_AD7745()
start();
write_byte(0X09);
WAck();
write_byte(0xBF);
delayus(500);
WAck();
stop();
1.7 写数组与读数组
void EEPROM_WriteArray (unsigned char dest_addr, unsigned char* src_addr,
unsigned char len)
unsigned char i;
start();
WAck();
write_byte(dest_addr);
WAck();
for( i = 0; i < len; i++ )
write_byte(src_addr[i]);
WAck();
stop();
delayus(1000);
void EEPROM_ReadArray (unsigned char* dest_addr, unsigned char src_addr,
unsigned char len)
uchar i;
start();
WAck();
write_byte(src_addr);
WAck();
start();
WAck();
dest_addr[i] = read_byte();
if(i!=len-1)
Ack();
else
NAck();
stop();
1.8 AD7745的配置
void Capdacsetup(void)
EEPROM_WriteArray(0x0D, offset_buf, sizeof(offset_buf)); // OFFSET寄存器初始化
Capdac_Parameter = 127;
EEPROM_WriteArray(0x07, out_buff, sizeof(out_buff)); // data collect
1.9 读取测量数据
void ReadData(void)
EEPROM_ReadArray(in_buff, 0x01, sizeof(in_buff)); // read the data register
CDC_Register_data = in_buff[0];
CDC_Register_data += in_buff[1];
else
DataArr[Int_dec++]=CDC_Capacitance;
if(Int_dec==DataNumber)
Int_dec=0;
上一篇:MSP430勘误表使用
下一篇:msp430学习笔记之uart
你开发的项目文档化了吗?看看老外是怎么做的。希望参与项目管理的朋友都进来看看 出差报告 引言 我于8月24日~10月22日在瑞典研究所出差,为期2个月,这里把工作情况做一下回顾和总结,以期对今后自己以及产品今后的工作和发展有一点作用。 任务完成情况 此次到瑞典研究所主要是 ...… 查看全部问答> |
请问大家,在BSP内核中加载I2C内核,在evc调用出现超时错误,这是怎么回事啊? I2C_Open ---- >I2C_IOControl(0x40004, 0x1a02f244, 16, 0x0) I2C IOCTL_I2C_WRITE 090704 I2C IOCTL_I2C_WRITE 090704 MapPtrToProcess +I2C_Write[1]: 0x9E, 0x1, 0x20, 1 EnterCriticalSection ResetEvent Be ResetEvent Af SyncIst ...… 查看全部问答> |
采用Marvell公司最新的基于第三代 Intel XScale 技术CPU PXA 310开发平台 CES-310开发平台简介 深圳市海天雄电子有限公司 CES-310 开发平台(实用型)简介 ■ 功能与特色 CES-310 开发平台采用Marvell公司最新的基于第三代 Intel XScale 技术CPU PXA 310 设计而成,本平台在多媒体处理,速度等方面较之前推出的CPU 平台 ...… 查看全部问答> |
把STM32按照正确的时序进入待机模式之后, 一开始都还正常..外部中断是不能唤醒的, 除非在PA0(WAKE UP PIN)上加一个上升沿. 但是很奇怪的是, 我发现我开一下台灯, 系统居然自己复位了, 就好像我按了复位键或者按了PA0一样....随后发现,貌似外 ...… 查看全部问答> |
我在程序中写了这样一段代码。 clock_t start,stop,overhead; start=clock(); stop=clock(); overhead=stop-start; start=clock(); doSth(); stop=clock(); printf(\\"%d\\\\n\\",stop-start-overhead); 我发现输出的结果总是0,调 ...… 查看全部问答> |
我的项目是手持产品,目前已经进入尾声,但是在关机之后还会有约5个毫安的电流。请问如何解决?一般情况下,关机之后都进行那些处理才能达到TI宣称的功耗值。???????!!!!!!… 查看全部问答> |
