今天是:2024年11月08日(星期五)
正在发生
2019年11月08日 | atmega16与24l01按键主程序
2019-11-08 来源:51hei
#include
#include
#include"NRF24L01.h"
//#define Open_TX
#define Open_RX
typedef unsigned char  uint8;                   /* defined for unsigned 8-bits integer variable     无符号8位整型变量  */
typedef signed   char  int8;                    /* defined for signed 8-bits integer variable       有符号8位整型变量  */
typedef unsigned short uint16;                  /* defined for unsigned 16-bits integer variable    无符号16位整型变量 */
typedef signed   short int16;                   /* defined for signed 16-bits integer variable      有符号16位整型变量 */
typedef unsigned int   uint32;                  /* defined for unsigned 32-bits integer variable    无符号32位整型变量 */
typedef signed   int   int32;                   /* defined for signed 32-bits integer variable      有符号32位整型变量 */
typedef float          fp32;                    /* single precision floating point variable (32bits) 单精度浮点数(32位长度) */
typedef double         fp64;                    /* double precision floating point variable (64bits) 双精度浮点数(64位长度) */
extern uint8_t RX_BUF[];
extern uint8_t TX_BUF[];
void motorrun();
uint8 HandleKey();
uint8 KEY_Release;
uint32 i,MS1;
#define  KEY1_Press  ((keys & 0x03) == 3)
#define  KEY1_Pressed ((keys & 0x03) == 2)
#define  KEY1_Release ((keys & 0x03) == 1)
#define  KEY1_Released ((keys & 0x03) == 0)
int main(void)
//nRF24L01_Config();
//usartInit();
uint8 keys = 0;
nRF24L01_Initial();
while(1)
      #ifdef Open_TX
   keys=HandleKey();
   if(KEY1_Release)
   TX_BUF[0]=0x55;
   NRF24L01_Send();
   if(TX_BUF[0]==0x55)
   for(i=1;i<100;i++)
    PORTB &=~ (1<    _delay_ms(1000);
    PORTB |= (1<    _delay_ms(1000);
   //printf("rnSend data:0x%xrn",TX_BUF[0]);
   _delay_ms(5000);
      #else
   PORTD &=~(1<   NRF24L01_Receive();
   _delay_ms(2000);
   if(RX_BUF[0]==0X55)
   motorrun();
   while(1);
   #endif
uint8 HandleKey(void)
static uint8 key1laststa = 1,pressure = 0;
uint8 ret = 0;
DDRB &= ~(1 << PB1);
if(PINB & (1 << PB1))  //KEY1
  ret = (ret & ~(0x03 << 0)) | (0x00 << 0);
  if(key1laststa == 0) //release
   ret = (ret & ~(0x03 << 0)) | (0x01 << 0);
  key1laststa = 1;
else
  ret = (ret & ~(0x03 << 0)) | (0x02 << 0);
  if(key1laststa == 1) //press
   ret = (ret & ~(0x03 << 0)) | (0x03 << 0);
  key1laststa = 0;
return ret;
void motorrun()
PORTD |=(1<PORTD &=~  (1<PORTD &=~  (1<PORTD &=~  (1<PORTC &=~(1<for(i=0;i<4000;i++)
  PORTC |= (1 << PC0);
  _delay_ms(20);
  PORTC &=~ (1 << PC0);
  _delay_ms(20);
柯爱亚(ceaiya)公司的发展小趣事
在稳固国内市场的同时,柯爱亚积极寻求海外市场的发展机会。公司不仅参加了多个国际电子展览会,还与国际知名企业建立了合作关系。此外,柯爱亚还通过投资、并购等方式,不断拓展业务范围,实现了多元化发展。这些举措使柯爱亚在国际市场上的影响力逐渐增强。
得力(deli)公司的发展小趣事
得力公司在文具和打印机领域取得成功后,并未满足于此,而是继续寻求新的增长点。2016年,得力集团与余姚得力工具有限公司合资成立宁波得力工具有限公司,正式进入电动工具领域。得力凭借其在技术研发和品质控制方面的优势,迅速在电动工具市场占据一席之地。特别是其自主研发的“红芯”系列电动工具,凭借其高品质、高性价比的特点,赢得了用户的广泛好评。
CEVA, Inc公司的发展小趣事
CEVA公司在超低功耗技术方面取得了显著突破。公司开发的超低功耗IP包括由专用DSP与AI和其他类型的加速器组成的综合平台。这些加速器针对低功耗工作负载进行了优化,包括5G基带处理、智能视觉、语音识别、物理层处理和传感器融合等。这些技术的突破使得CEVA的产品在保持高性能的同时,能够大幅度降低功耗,满足了市场对节能设备的需求。
力芯微(ETEK)公司的发展小趣事
在2009至2012年的培育期,力芯微公司准确把握下游市场更迭,快速推出的双SIM卡电源控制芯片得到了三星电子的认可。此后,公司陆续开发了负载开关、电池开关和LDO等产品,并在三星电子的手机上得到广泛应用。这一合作不仅提升了力芯微在业界的知名度,也为公司带来了可观的订单和利润。
Helium公司的发展小趣事
2017年,随着区块链技术的兴起,Helium团队看到了新的机遇。他们意识到区块链的透明性和自确认性可以为物联网网络的建设带来革命性变化。于是,Helium决定将网络建设“去中心化”,并借助区块链技术重新定义激励机制。这一决策标志着Helium从单纯的物联网项目转变为融合区块链技术的创新企业。通过去中心化的方式,Helium降低了网络建设和维护的成本,加速了网络覆盖的速度,为物联网设备提供了更加便捷和经济的连接方案。
Digital Core Design公司的发展小趣事
1988年,Core Design由Jeremy Heath-Smith创立,起初仅有8名员工和1万6千英镑的注册资金。这家新兴的游戏开发公司很快凭借其首款游戏《Rick Dangerous》在英国游戏市场崭露头角。这款游戏凭借其独特的游戏机制和引人入胜的故事情节,迅速登上英国游戏销量榜的榜首,并赢得了欧洲年度游戏奖,为Core Design的未来发展奠定了坚实的基础。
编码器介绍及应用
SCHA系列光电编码器 S38S系列增量型光电编码器 S40S系列编码器 LBJ系列旋转编码器 SF50C系列旋转编码器 SF50J系列旋转编码器 SF50P系列旋转编码器 S50S8系列编码器 S50S10系列编码器 SF38K系列编码器 SZLF系列编码器 SF38K系列半中空轴 ...…
上传点资料
本帖最后由 paulhyde 于 2014-9-15 09:26 编辑 [ 本帖最后由 HiVi1120 于 2009-8-22 17:29 编辑 ]  …
TD数字无绳电话年内上市:欲成杀手级产品
  家庭信息机之后,TD-SCDMA又推出固网产品。全球首款基于TD-SCDMA的数字无绳电话解决方案的推出,标志着中国移动针对家庭用户的TD-SCDMA产品系列中将再度丰富。   数字无绳电话是现代家庭电话的升级换代产品,将满足家庭电话更新需求。中国 ...…
便携式心电监护系统的设计
  心电图(ECG)是心脏疾病诊断的重要手段。常规心电图是病人在静卧情况下由医院的心电图仪记录的短时间心电活动,由于心脏病发作带有很大的偶然性和突发性,所以在非发作期做常规心电图检查获取疾病信息的几率很低。   因此,将心电监护从病床 ...…
有个问题困惑我好几天了,望大侠们指点一下
我写了一个小驱动叫keyboard.sys,然后我用SRVINSTW.EXE把这个驱动注册了服务叫mykeyboard,为什么我在命令行里用net start mykeyboard命令时总是提示“发生系统所误161  指定的路径无效”,我真晕了,不知道错在什么地方…
求助:ARM标号问题
$IF (EXTERNAL_MODE)         CODE_BASE      EQU    0x80000000 $ELSE         CODE_BASE      EQU    0x00000000 ...…
关于68013A自动指针的问题
我使用的是68013A芯片,使用GPIF接口来控制MAX115进行数据的读写,在GPIF初始化的代码中(由GPIF Designer生成),有一部分是将波形描述符转移到0xE400,这里使用了自动指针来自动转移。我的问题是,正常下载运行之后,得不到pipe信息,描述符等信 ...…
BIOS程序碰到的一个问题,大家进来支个招啊
本帖最后由 dontium 于 2015-1-23 13:31 编辑 2812用BIOS写的程序,先跑两个任务,然后任务挂起,之后按理应该跑我定义的一个PRD函数,可是却停在一个FXN_F_selfLoop的语句里出不来,哪位大虾告诉小弟这是什么原因啊?应该怎么解决呢?谢谢! ...…
三级管的特性问题
在书上看到这么一句话:三极管作为开关用的时候,c和e之间的电压VCE非常小,此时的直流增益一般只有原来的1/5左右,怎么理解呀?…
