今天是:2025年01月08日(星期三)
正在发生
2020年01月08日 | PIC单片机的AT24C64通讯设计
2020-01-08 来源:eefocus
该程序实现的功能是:
将I2C_A,I2C_B.。...I2C_K内容写入EEPROM中
同时在EEPROM中读出数据从新写入各个寄存器
PIC单片机的AT24C64通讯设计
LISTP=16C74B
#include
ERRORLEVEL-302
I2C_AEQU0X20
I2C_BEQU0X21
I2C_CEQU0X22
I2C_DEQU0X23
I2C_EEQU0X24
I2C_FEQU0X25
I2C_GEQU0X26
REG1EQU0X2B
REG2EQU0X2C
COUNTEQU0X71;I2C
BCOUNTEQU0X72;I2C
TXBUFEQU0X73;I2C
RXBUFEQU0X74;I2C
BUSCONEQU0X75;I2C
BUSSTAEQU0X76;I2C
I2CBUFEQU0X77;I2C
SLAVEADDREQU0XA0;I2C
DATAADDRHEQU0X01;I2C
DATAADDRLEQU0X00;I2C
;BUSCON
SLAVE_RWEQU7
LAST_BYTE_RXEQU6
SLAVE_ACTIVEEQU5
TIME_OUTEQU4
;BUSSTA
BUS_BUSYEQU7
TX_PROGRESSEQU6
RX_PROGRESSEQU5
TX_SUCCESSEQU4
RX_SUCCESSEQU3
FATAL_ERROREQU2;SLAVEEEPROM
ABORTEQU1
ACK_ERROREQU0
R_NOT_WEQU0
TRUEEQU1
FALSEEQU0
SDAEQU0X04;I2C
SCLEQU0X03;I2C
ORG0X00
GOTOSTART
ORG0X20
STARTBCFSTATUS,RP1
BCFSTATUS,RP0
CLRFRA
CLRFRB
CLRFRC
CLRFRD
CLRFRE
BSFSTATUS,RP0
CLRFTRISA
CLRFTRISB
CLRFTRISC
CLRFTRISD
CLRFTRISE
MOVLW0X02
MOVWFI2C_A
MOVLW0X04
MOVWFI2C_B
MOVLW0X03
MOVWFI2C_C
MOVLW0X03
MOVWFI2C_D
MOVLW0X05
MOVWFI2C_E
MOVLW0X06
MOVWFI2C_F
MOVLW0X04
MOVWFI2C_G
START1
CALLI2CBUS_INIT
CALLREGTOI2CBUF
CALLI2CWRITE
CALLCLRI2CBUF
CALLD10
CALLI2CREAD
CALLI2CBUFTOREG
GOTOSTART1
;CLRI2CBUF
CLRI2CBUF
BCFSTATUS,RP0
MOVLWI2CBUF
MOVWFFSR
MOVLW0X08
MOVWFCOUNT
CLRLOOPCLRFINDF
INCFFSR,F
DECFSZCOUNT,F
GOTOCLRLOOP
RETURN
;将各个REGSTER数据写入I2CBUF缓冲区
REGTOI2CBUF
BCFSTATUS,RP0
MOVLWI2CBUF
MOVWFFSR
MOVFI2C_A,W
MOVWFINDF
INCFFSR,F
MOVFI2C_B,W
MOVWFINDF
INCFFSR,F
MOVFI2C_C,W
MOVWFINDF
INCFFSR,F
MOVFI2C_D,W
MOVWFINDF
INCFFSR,F
MOVFI2C_E,W
MOVWFINDF
INCFFSR,F
MOVFI2C_F,W
MOVWFINDF
INCFFSR,F
MOVFI2C_G,W
MOVWFINDF
RETURN
;将I2CBUF缓冲区数据写入各个REGSTER
I2CBUFTOREG
BCFSTATUS,RP0
MOVLWI2CBUF
MOVWFFSR
MOVFINDF,W
MOVWFI2C_A
INCFFSR,F
MOVFINDF,W
MOVWFI2C_B
INCFFSR,F
MOVFINDF,W
MOVWFI2C_C
INCFFSR,F
MOVFINDF,W
MOVWFI2C_D
INCFFSR,F
MOVFINDF,W
MOVWFI2C_E
INCFFSR,F
MOVFINDF,W
MOVWFI2C_F
INCFFSR,F
MOVFINDF,W
MOVWFI2C_G
RETURN
;将I2CBUF缓冲区内的数据写入EEPROM
I2CWRITE
CALLI2CSTART
BTFSSBUSSTA,BUS_BUSY
GOTOTX_FAIL
BCFBUSCON,SLAVE_RW
CALLTX_SLAVE_ADDR
BTFSSBUSSTA,TX_SUCCESS;SUCESSFULL?
GOTOTX_FAIL
CALLTX_DATA_ADDR
GOTOTX_FAIL
MOVLWI2CBUF
MOVWFFSR
MOVLW07
MOVWFCOUNT
T_BYTE_LOOP
MOVFINDF,W
MOVWFTXBUF
CALLI2CTXB
GOTOTX_FAIL
INCFFSR,F
DECFSZCOUNT,F
GOTOT_BYTE_LOOP
GOTOTX_PASS
TX_FAILCALLI2CSTOP
BCFBUSSTA,TX_PROGRESS
BCFBUSSTA,TX_SUCCESS
RETLWFALSE
TX_PASS
CALLI2CSTOP
RETLWTRUE
;从EEPROM中读出数据到I2CBUF寄存器
I2CREADBCFSTATUS,RP0
BCFBUSSTA,RX_SUCCESS
CALLI2CSTART
GOTORX_FAIL
BCFBUSCON,SLAVE_RW
CALLTX_SLAVE_ADDR
GOTORX_FAIL
CALLTX_DATA_ADDR
GOTORX_FAIL
CALLI2CSTART
BSFBUSCON,SLAVE_RW
CALLTX_SLAVE_ADDR
GOTORX_FAIL
BCFBUSSTA,LAST_BYTE_RX
MOVLWI2CBUF
MOVWFFSR
MOVLW07
MOVWFCOUNT
R_BYTE_LOOP
MOVLW0X01
XORWFCOUNT,W
BTFSCSTATUS,Z
BSFBUSSTA,LAST_BYTE_RX
CALLI2CRXB
BTFSSBUSSTA,RX_SUCCESS
GOTORX_FAIL
MOVFRXBUF,W
MOVWFINDF
INCFFSR,F
DECFSZCOUNT,F
GOTOR_BYTE_LOOP
GOTORX_PASS
RX_FAILCALLI2CSTOP
BCFBUSSTA,RX_PROGRESS
RETLWFALSE
RX_PASSCALLI2CSTOP
BCFSTATUS,RP0
BSFBUSSTA,RX_SUCCESS
RETLWTRUE
;I2C初始化
I2CBUS_INIT
BCFSTATUS,RP0
MOVFRC,W
ANDLW0X18
MOVWFRC
CLRFBUSSTA
CLRFBUSCON
RETURN
;传送设备地址
;入口:BUSCON
;出口:BUSSTA
TX_SLAVE_ADDR
BCFSTATUS,RP0
BCFBUSSTA,ACK_ERROR
MOVLWSLAVEADDR
MOVWFTXBUF
BTFSCBUSCON,SLAVE_RW
BSFTXBUF,R_NOT_W
CALLI2CTXB
BTFSCBUSSTA,TX_SUCCESS
GOTOTXADDR_SUCCESS
CLRWDT
BTFSSBUSSTA,ACK_ERROR
CALLI2CSTOP
GOTOTXADDR_END
TXADDR_SUCCESS
CLRWDT
TXADDR_END
RETURN
;TX_DATA_ADDR发送写/读的地址
TX_DATA_ADDR
BCFSTATUS,RP0
MOVLWDATAADDRH
MOVWFTXBUF
CALLI2CTXB
BCFSTATUS,RP0
GOTOTX_DATA_ADDR_ERROR
MOVLWDATAADDRL
MOVWFTXBUF
CALLI2CTXB
BCFSTATUS,RP0
GOTOTX_DATA_END
TX_DATA_ADDR_ERROR
BSFBUSSTA,ACK_ERROR
TX_DATA_END
RETURN
;向EEPROM输出一个8位数据,并检测EEPROM的ACK信号
;入口:TXBUF寄存器
;BUSSTA寄存器
;出口:EEPROM存储器
;BUSSTA寄存器
I2CTXBBCFSTATUS,RP0
BSFBUSSTA,TX_PROGRESS
MOVLW0X08
MOVWFBCOUNT
TXLOOPCLRWDT
BSFSTATUS,RP0
BCFTRISC,SCL
NOP
BCFTRISC,SDA
BCFSTATUS,RP0
RLFTXBUF,F
BSFSTATUS,RP0
BTFSCSTATUS,C
BSFTRISC,SDA
NOP
BSFTRISC,SCL
NOP
NOP
BCFSTATUS,RP0
DECFSZBCOUNT,F
GOTOTXLOOP
;检测是EEPROM否有ACK信号产生,产生为正常
;检测方法:
;1.将RC口的SCL.SDA分别设置为输出和输入状态
;2.延时2个指令周期,将SCL设置为高电平
;3.延时2个指令周期,检测RC口SDA的状态
;4.如果为高电平,设置错误状态,返回
;5.如果为低电平,延时2个指令周期后,将RC口SCL设置为低电平,继续执行
BSFSTATUS,RP0
BCFTRISC,SCL
BSFTRISC,SDA
NOP
NOP
BSFTRISC,SCL
NOP
BCFSTATUS,RP0
BTFSCRC,SDA
GOTOTX_ERR
BSFSTATUS,RP0
BCFTRISC,SCL
BCFSTATUS,RP0
BSFBUSSTA,TX_SUCCESS
BCFBUSSTA,ACK_ERROR
GOTOTX_END
TX_ERRBCFBUSSTA,TX_PROGRESS
BSFBUSSTA,ACK_ERROR
TX_ENDRETURN
;从EEPROM中读出8位的数据,并发送发送ACK信号
;入口:EEPROM存储器
;BUSCON寄存器
;出口:RXBUF寄存器
;BUSSTA寄存器
I2CRXBBCFSTATUS,RP0
BSFBUSSTA,RX_PROGRESS
MOVLW0X08
MOVWFBCOUNT
RXLOOPCLRWDT
BSFSTATUS,RP0
BCFTRISC,SCL;定义TRISC为输出
BSFTRISC,SDA;定义TRISC为输入
NOP
NOP
BSFTRISC,SCL;TRISC输出高电平
NOP
BCFSTATUS,RP0
BCFSTATUS,C
BTFSCRC,SDA;原指令为BTFSCTRISC,SDA
BSFSTATUS,C
RLFRXBUF,F
DECFSZBCOUNT,F
GOTORXLOOP
;发送ACK信号到EEPROM
;判断接收的是否为最后一个字节
;LAST_BYTE_RX为1,是SDA发送一个高电平,结束
;LAST_BYTE_RX为0,不是SDA发送一个低电平ACK,继续接收
BSFSTATUS,RP0
BCFTRISC,SCL
BCFTRISC,SDA
BTFSCBUSCON,LAST_BYTE_RX;检测是否是最后一个字节
BSFTRISC,SDA;是最后一个字节
NOP;发送ACK信号
BSFTRISC,SCL
NOP
NOP
NOP
NOP
BCFTRISC,SCL
BCFSTATUS,RP0
RETURN
;I2C开始信号
;输入:无
;输出:BUFSSTA
I2CSTART
BSFSTATUS,RP0
BSFTRISC,SDA;1US
NOP;1US
BSFTRISC,SCL;1US
NOP
NOP
BCFTRISC,SDA
NOP
NOP
BCFSTATUS,RP0
BSFBUSSTA,BUS_BUSY
RETURN
;I2C结束信号
;输入:无
;输出:BUSSTA
I2CSTOP
BSFSTATUS,RP0
BCFTRISC,SCL
BCFTRISC,SDA
BSFTRISC,SCL
NOP
NOP
BSFTRISC,SDA
NOP
BCFSTATUS,RP0
BCFBUSSTA,BUS_BUSY
RETURN
;D10@
;cLOCkin4MHz
;delay10ms
D10MOVLW0X0D
MOVWFREG1
LOOP2MOVLW0XFF
MOVWFREG2
LOOP1DECFSZREG2,f
GOTOLOOP1
DECFSZREG1,f
GOTOLOOP2
RETURN
I2CERRCLRWDT
NOP
NOP
NOP
RETURN
END
AIRPAX公司的发展小趣事
进入21世纪,AIRPAX开始积极拓展全球市场。通过与各国企业的合作与交流,AIRPAX的产品逐渐进入欧洲、亚洲等地区,服务于更多国家的客户。同时,AIRPAX还积极寻求与其他行业领先企业的战略合作,共同推动电气保护技术的发展。这些合作不仅提升了AIRPAX的品牌影响力,也为其带来了更多的商业机会。
AEM [ American Electronic Materials]公司的发展小趣事
AEM公司起源于美国,其创立之初便致力于电子元器件的研发与生产。在早期,AEM便以其独特的创新理念和先进的技术水平,迅速在电子元器件市场中崭露头角。公司通过不断的技术研发,成功开发出了一系列具有竞争力的电子元器件产品,如高性能的电阻器、电容器等,这些产品广泛应用于通信设备、计算机、消费电子等多个领域。
随着技术的不断进步,AEM逐渐积累了丰富的经验和专业知识,其产品在市场上得到了广泛的认可。同时,AEM还积极拓展海外市场,将产品出口到全球多个国家和地区,进一步提升了公司的国际影响力。
芯源半导体(CW)公司的发展小趣事
为了进一步提升公司的竞争力,芯源半导体(CW)公司开始实施国际化战略。公司积极拓展海外市场,参加国际展会和论坛,与国际同行进行交流与合作。同时,公司还设立了海外研发中心,引进国际优秀人才和技术资源,以加强公司的研发实力和市场竞争力。这些举措使芯源半导体(CW)公司在国际市场上逐渐崭露头角。
峰岹(Fortior Tech )公司的发展小趣事
GainSpan ( Telit)公司的发展小趣事
风华的故事始于1984年,当时广东肇庆风华电子厂成立,最初业务聚焦于收录机装配。一年后,即1985年,国内首条从美国引进的年产1亿只片式多层陶瓷电容器生产线落户风华,标志着公司正式踏入高新技术产业领域。这一举措不仅提升了公司的技术实力,也为后续的发展奠定了坚实基础。
DATATRONICS公司的发展小趣事
DATATRONICS公司自成立以来,一直致力于电子技术的研发与创新。某年,公司研发团队成功突破了一项关键技术瓶颈,开发出了一款高效能的数据处理芯片。这款芯片以其卓越的性能和稳定性,迅速获得了市场的认可。DATATRONICS借此机会,进一步扩大了产品线,提高了市场竞争力。
DS18B20 测温程序完全解读
硬件: 51板     (1)单线ds18b20接 P2.2     (2)使用外部电源给ds18b20供电,没有使用寄生电源奥 软件:      Kei uVision 2     刚开始对时序把握不好,可是在论坛里没找到比较详细的解释 ...…
几个关于嵌入式存储器的资料分享,涉及FLASH,ROM,RAM,NOR,NAND等概念
几个关于嵌入式存储器的资料分享,涉及FLASH,ROM,RAM,NOR,NAND等概念!…
arm300综合实验运行不了
不知道为什么,下载的电子菜单程序能编译,却没有运行,出现12x12 font file is not found!16x16 font file is not found! config.sys no found ,不知道怎么解决此问题…
modelsim中,添加库时遇到的问题“Could not find synplify.attributes.”
我在modelsim中添加altera_mf 库,可提示需要Synplify库,于是我到Synplify中找到synplify.vhd文件编译,最后再次编译Altera_mf库提示:Could not find synplify.attributes. 那位高手遇到过这个问题啊??…
100求助各位高手:关于串口收发程序!
EVC下串口通信原程序如下: /********************************** 函数名称: OpenPort 描    述: 打开串口 输入参数: LPCTSTR Port: 串口名,如\"COM0:\",\"COM1:\"                  ...…
WINCE下怎么把控制面板程序调出来
  WINCE下怎么把控制面板程序调出来   如在windows可以用如下的API调用控制面板中的\"日期/时间\"设置程序:      winexe(\"rundll32.exe   shell32.dll,Control_RunDLL   timeda ...…
怎么让Acticesync支持UDP?
本人做GPS车载终端,有了Acticesync就可以单步调试,可惜只能调试TCP的协议,对于UDP的没有办法调试,因为听说Acticesync不支持啊? 想问问个位高手: 1. 强悍的微软做出来的Acticesync难道真的就不支持UDP吗?????? 2. 如果不支持,怎么才能让它支持…
stm32学习(1)--SysTick
1. systick介绍 Systick 就是一个定时器而已,只是它放在了NVIC 中,主要的目的是为了 给操作系统提供一个硬件上的中断(号称滴答中断)。没有学过操作系统的同学, 可能会很郁闷,啥叫滴答中断?这里来简单地解释一下。操作系统进 ...…
想买个LM3S9B96板子,大约多少钱啊?
想买个LM3S9B96板子,大约多少钱啊?…
怎么用D触发器实现延时???
一个D触发器延时一个CLK周期,如果延时10个CLK周期 就是多打几拍,程序该怎么写? 一个D触发器的程序 reg  A_ZRE0_CROSS_MOVE;always @(posedge CLK_1K or negedge Rst)//延迟1个时钟的D触发器 &nb ...…
