今天是:2025年02月03日(星期一)
2020年02月03日 | STM32单片机如何通过定时器的控制输出PWM
2020-02-03 来源:elecfans
STM32F103ZET6里共有8个定时器,其中高级定时器有TIM1-TIM5、TIM8,共6个。
我这里输出PWM的定时器是TIM2,空闲的定时器是TIM3。以TIM2为主定时器,TIM3为从定时器对TIM2的输出脉冲数进行计数。
查表可知,TIM3为从定时器选择TIM2为触发源,需要配置TS=001,即选择ITR1。
实现通过定时器控制输出PWM个数的功能,可以有如下一种配置方式:
void TIM2_Master__TIM3_Slave_Configuration(u32 PulseFrequency)
TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
TIM_OCInitTypeDef TIM_OCInitStructure;
u16 nPDTemp ;
TIMx Configuration: generate 4 PWM signals with 4 different duty cycles:
TIMxCLK = 72 MHz, Prescaler = 0x0, TIMx counter clock = 72 MHz
TIMx ARR Register = 0 =》 TIMx Frequency = TIMx counter clock/(ARR + 1)
TIMx Frequency = 72MHz.
TIM_Cmd(TIM2, DISABLE);
nPDTemp = 72000000UL/PulseFrequency;
// 时基配置:配置PWM输出定时器——TIM2
/* Time base configuration */
TIM_TimeBaseStructure.TIM_Period = nPDTemp-1;
TIM_TimeBaseStructure.TIM_Prescaler = 0;
TIM_TimeBaseStructure.TIM_ClockDivision = 0;
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
TIM_TimeBaseStructure.TIM_RepetitionCounter = 0;
TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
// 输出配置:配置PWM输出定时器——TIM2
/* PWM1 Mode configuration: Channel1 */
TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
TIM_OCInitStructure.TIM_Pulse = nPDTemp》》1;//50%
TIM_OC1Init(TIM2, &TIM_OCInitStructure);
TIM_OC1PreloadConfig(TIM2, TIM_OCPreload_Enable);
// 时基配置:配置脉冲计数寄存器——TIM3
TIM_TimeBaseStructure.TIM_Period = 0xFFFF;
TIM_TimeBaseStructure.TIM_Prescaler = 1;
TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);
/* Output Compare Active Mode configuration: Channel1 */
TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_Inactive;
TIM_OCInitStructure.TIM_Pulse = 0xFFFF; // 这里的配置值意义不大
TIM_OC1Init(TIM3, &TIM_OCInitStructure);
// 配置TIM2为主定时器
/* Select the Master Slave Mode */
TIM_SelectMasterSlaveMode(TIM2, TIM_MasterSlaveMode_Enable);
/* Master Mode selection */
TIM_SelectOutputTrigger(TIM2, TIM_TRGOSource_Update);
// 配置TIM3为从定时器
/* Slave Mode selection: TIM3 */
TIM_SelectSlaveMode(TIM3, TIM_SlaveMode_Gated);
TIM_SelectInputTrigger(TIM3, TIM_TS_ITR1);
TIM_ITConfig(TIM3, TIM_IT_CC1, ENABLE);
TIM_Cmd(TIM3, DISABLE);
中断服务程序如下:
u8 TIM2_Pulse_TIM3_Counter_OK = 0;
void TIM3_IRQHandler(void)
if (TIM_GetITStatus(TIM3, TIM_IT_CC1) != RESET)
TIM_ClearITPendingBit(TIM3, TIM_IT_CC1); // 清除中断标志位
TIM_Cmd(TIM2, DISABLE); // 关闭定时器
TIM_Cmd(TIM3, DISABLE); // 关闭定时器
TIM2_Pulse_TIM3_Counter_OK = 1;
应用程序为:
u16 pulsecnt = 10000;
void main(void)
SystemSetup(); // 初始化内核和外设
TIM2_Master__TIM3_Slave_Configuration(10000);//配置TIM2的脉冲输出为10k
while(1)
TIM_ITConfig(TIM3, TIM_IT_CC1, DISABLE); /* TIM enable counter */
TIM_Cmd(TIM3, ENABLE);
TIM3-》CCR1 = pulsecnt;
TIM3-》CNT = 0;
TIM_Cmd(TIM2, ENABLE); /* TIM enable counter */
while(TIM2_Pulse_TIM3_Counter_OK == 0);
这种配置方式下,使用的是TIM3的比较中断,我还没试验过其他的方式,想来应该也是可以的,比如用定时器更新中断
我在project.reg 里添加了如下内容 [HKEY_LOCAL_MACHINE\\SOFTWARE\\Microsoft\\FontPath] \"FontPath\"=\"\\\\Hard Disk\\\\Font\" ; 字库文件所在目录 [HKEY_LOCAL_MACHINE\\SOFTWARE\\Microsoft\\FontLink\\SystemL ...… 查看全部问答> |
本以为解决了,结果还不行! 目前的情况: 计算机发信号给LED显示屏,中间用433无线模块传输。发送端通过232转485接无线模块,接收端模块通过485接显示屏。正常。但因为433模块不好用,所以客户想用我们的超级无线传输模块。但是,他要求,用我们 ...… 查看全部问答> |
我在使用hive注册表保存方式的时候。。在系统进入到定位程序的时候就不动了。点屏幕定位针不动。。按esc也不行。。。但是点屏幕的时候在pb的debug中可以看到点的坐标。。。。按道理说系统应该是卡死了才对。。可是为什么那里还可以打印出来坐标了? ...… 查看全部问答> |
以全彩屏为例,通常红、绿、蓝白平衡配比为3:4:1 红色LED 灯亮度:亮度(CD)/M2÷点数/M2×0.3(白平衡配比占30%)÷2 绿色LED 灯亮度:亮度(CD)/M2÷点数/M2×0.6(白平衡配比占60%) 蓝色LED 灯亮度:亮度(CD)/M2÷点数/M2×0.1(白平衡 ...… 查看全部问答> |
【设计工具】利用 Xilinx FPGA 打造出高端比特精度和周期精度浮点 DSP 算法实现方案 系统要求和可用 FPGA 的当前趋势使浮点实现方法变得更加重用。本白皮书和视频说明了(与其它设计流程的不同之处)DSP 系统生成器 13.3 如何为用户提供针对比特精度、周期精度、单精度、双精度和定制精度浮点 ...… 查看全部问答> |
数字世界亚洲博览会展会场馆:北京国家会议中心举办时间:2012年8月02日~2012年8月05日 2012年北京国际应急救灾设备技术展览会展会日期:2012年8月29日~2012年8月31日展会场馆:全国农业展览馆 2012北京国际社会公共安全及司法监狱 ...… 查看全部问答> |
这件“神物”对我这个懒人来说肯定是特别的有用处!当然,如果你记性不好的话也是很有帮助的!它是一款锂电池的充电器!但它却拥有烤面包机一样的处理方式与漂亮的外观! 当你把要充的电板从上至下放入之 ...… 查看全部问答> |
摘要:为解决不同性能指标数据采集系统开发时间较长的问题,提出了一种将FPGA软核技术应用于高速数据采集系统设计的方法。系统以Xilinx公司的FPGA为例设计软核,使用VHDL语言对软核进行模块化设计。介绍了数据采集系统的硬件电路、USB固件程序、USB ...… 查看全部问答> |
