今天是:2025年03月09日(星期日)
正在发生
2020年03月09日 | c语言多文件 6410 led裸机程序
2020-03-09 来源:eefocus
// led4 gpk7
// led3 gpk6
// led2 gpk5
// led1 gpk4   0 ,light
//u32 rGPIOKCON0; //0x7f008800
// u32 rGPIOKCON1; //0x7f008804
// u32 rGPIOKDAT; //0x7f008808
//u32 rGPIOKPUD; //0x7f00880c
#include "def.h"
#include "gpio.h"
#define led1on  ~(1<<4)
#define led2on ~(1<<5)
#define led3on ~(1<<6)
#define led4on ~(1<<7)
void LedInit()
u32 TEMP;
GPIO->rGPIOKCON0 = 0X11112222;
TEMP = GPIO->rGPIOKPUD ;
TEMP &= (0XFF<<8);
TEMP = TEMP|(0XAA<<8);
GPIO->rGPIOKPUD = TEMP;
TEMP = GPIO->rGPIOKDAT ;
TEMP = TEMP&(0X0F);
GPIO->rGPIOKDAT = TEMP;
void delay(int times)
    int i;
    for(;times>0;times--)
      for(i=0;i<3000;i++);
void Led(char num,char flag)
u32 temp;
temp = GPIO->rGPIOKDAT;
switch(num){
case 1:  { if(flag) temp = temp&(led1on);
else  temp |=temp | (~led1on);
GPIO->rGPIOKDAT = temp;break;}
case 2:{ if(flag) temp = temp&(led2on);
else  temp |=temp | (~led2on);
case 3:{ if(flag) temp = temp&(led3on);
else  temp |=temp | (~led3on);
case 4:{ if(flag) temp = temp&(led4on);
else  temp |=temp | (~led4on);
default : break;
int main()
LedInit();
delay(1000);
while(1)
   Led(1,1);
   delay(1000);
   Led(1,0);
   delay(1000);
上面是c代码,main();
* Project Name : S3C6410 Validation
* Copyright 2006 by Samsung Electronics, Inc.
* All rights reserved.
* Project Description :
* This software is only for validating functions of the S3C6410.
* Anybody can use this software without our permission.
* File Name : gpio.h
* File Description : This file declares prototypes of GPIO API funcions.
* Author : Heemyung.Noh
* Dept. : AP Development Team
* Created Date : 2006/12/26
* Version : 0.1
* History
* - Created(Heemyung.Noh 2006/12/26)
*     - Added EINT (Wonjoon.jang 2007/01/03)
#ifndef __GPIO_H__
#define __GPIO_H__
#ifdef __cplusplus
extern "C" {
#endif
#include "def.h"
#include "sfr6410.h"
#define Low_Level 0x0
#define High_Level 0x1
#define Falling_Edge 0x2
#define Rising_Edge 0x4
#define Both_Edge 0x6
#define GPIO ( ( volatile oGPIO_REGS * ) (GPIO_BASE))
typedef struct tag_GPIO_REGS
u32 rGPIOACON; //0x7F008000
u32 rGPIOADAT;
u32 rGPIOAPUD;
u32 rGPIOACONSLP;
u32 rGPIOAPUDSLP;
u32 reserved1[3];
u32 rGPIOBCON; //0x7F008020
u32 rGPIOBDAT;
u32 rGPIOBPUD;
u32 rGPIOBCONSLP;
u32 rGPIOBPUDSLP;
u32 reserved2[3];
u32 rGPIOCCON; //0x7F008040
u32 rGPIOCDAT;
u32 rGPIOCPUD;
u32 rGPIOCCONSLP;
u32 rGPIOCPUDSLP;
u32 reserved3[3];
u32 rGPIODCON; //0x7F008060
u32 rGPIODDAT;
u32 rGPIODPUD;
u32 rGPIODCONSLP;
u32 rGPIODPUDSLP;
u32 reserved4[3];
u32 rGPIOECON; //0x7F008080
u32 rGPIOEDAT;
u32 rGPIOEPUD;
u32 rGPIOECONSLP;
u32 rGPIOEPUDSLP;
u32 reserved5[3];
u32 rGPIOFCON; //0x7F0080A0
u32 rGPIOFDAT;
u32 rGPIOFPUD;
u32 rGPIOFCONSLP;
u32 rGPIOFPUDSLP;
u32 reserved6[3];
u32 rGPIOGCON; //0x7F0080C0
u32 rGPIOGDAT;
u32 rGPIOGPUD;
u32 rGPIOGCONSLP;
u32 rGPIOGPUDSLP;
u32 reserved7[3];
u32 rGPIOHCON0; //0x7F0080E0
u32 rGPIOHCON1;
u32 rGPIOHDAT;
u32 rGPIOHPUD;
u32 rGPIOHCONSLP;
u32 rGPIOHPUDSLP;
u32 reserved8[2];
u32 rGPIOICON; //0x7F008100
u32 rGPIOIDAT;
u32 rGPIOIPUD;
u32 rGPIOICONSLP;
u32 rGPIOIPUDSLP;
u32 reserved9[3];
u32 rGPIOJCON; //0x7F008120
u32 rGPIOJDAT;
u32 rGPIOJPUD;
u32 rGPIOJCONSLP;
u32 rGPIOJPUDSLP;
u32 reserved10[3];
u32 rGPIOOCON; //0x7F008140
u32 rGPIOODAT;
u32 rGPIOOPUD;
u32 rGPIOOCONSLP;
u32 rGPIOOPUDSLP;
u32 reserved11[3];
u32 rGPIOPCON; //0x7F008160
u32 rGPIOPDAT;
u32 rGPIOPPUD;
u32 rGPIOPCONSLP;
u32 rGPIOPPUDSLP;
u32 reserved12[3];
u32 rGPIOQCON; //0x7F008180
u32 rGPIOQDAT;
u32 rGPIOQPUD;
u32 rGPIOQCONSLP;
u32 rGPIOQPUDSLP;
u32 reserved13[3];
u32 rSPCON; //0x7F0081A0
u32 reserved14[3];
u32 rMEM0CONSTOP; //0x7F0081B0
u32 rMEM1CONSTOP; //0x7F0081B4
u32 reserved15[2];
u32 rMEM0CONSLP0; //0x7F0081C0
u32 rMEM0CONSLP1; //0x7F0081C4
u32 rMEM1CONSLP; //0x7F0081C8
u32 reserved;
u32 rMEM0DRVCON; //0x7F0081D0
u32 rMEM1DRVCON; //0x7F0081D4
u32 reserved16[10];
u32 rEINT12CON; //0x7f008200
u32 rEINT34CON; //0x7f008204
u32 rEINT56CON; //0x7f008208
u32 rEINT78CON; //0x7f00820C
u32 rEINT9CON; //0x7f008210
u32 reserved17[3];
u32 rEINT12FLTCON; //0x7f008220
u32 rEINT34FLTCON; //0x7f008224
u32 rEINT56FLTCON; //0x7f008228
u32 rEINT78FLTCON; //0x7f00822C
u32 rEINT9FLTCON; //0x7f008230
u32 reserved18[3];
u32 rEINT12MASK; //0x7f008240
u32 rEINT34MASK; //0x7f008244
u32 rEINT56MASK; //0x7f008248
u32 rEINT78MASK; //0x7f00824C
u32 rEINT9MASK; //0x7f008250
u32 reserved19[3];
u32 rEINT12PEND; //0x7f008260
u32 rEINT34PEND; //0x7f008264
u32 rEINT56PEND; //0x7f008268
u32 rEINT78PEND; //0x7f00826C
u32 rEINT9PEND; //0x7f008270
u32 reserved20[3];
u32 rPRIORITY; //0x7f008280
u32 rSERVICE; //0x7f008284
u32 rSERVICEPEND; //0x7f008288
u32 reserved21;
u32 reserved22[348];
u32 rGPIOLCON0; //0x7f008810
u32 rGPIOLCON1; //0x7f008814
u32 rGPIOLDAT; //0x7f008818
u32 rGPIOLPUD; //0x7f00881c
u32 rGPIOMCON; //0x7f008820
u32 rGPIOMDAT; //0x7f008824
u32 rGPIOMPUD; //0x7f008828
u32 reserved23;
u32 rGPIONCON; //0x7f008830
u32 rGPIONDAT; //0x7f008834
u32 rGPIONPUD; //0x7f008838
u32 reserved24;
u32 reserved25[16];
u32 rSPCONSLP; //0x7f008880
u32 reserved26[31];
u32 rEINT0CON0; //0x7f008900
u32 rEINT0CON1; //0x7f008904
u32 reserved27[2];
u32 rEINT0FLTCON0; //0x7f008910
u32 rEINT0FLTCON1; //0x7f008914
u32 rEINT0FLTCON2; //0x7f008918
u32 rEINT0FLTCON3; //0x7f00891c
u32 rEINT0MASK; //0x7f008920
u32 rEINT0PEND; //0x7f008924
u32 reserved28[2];
u32 rSLPEN; //0x7f008930
oGPIO_REGS;
typedef enum GPIO_Id
// Value & 0xF000 : The muxing bit number of the configuration register
// Value & 0x0F00 : Control register number per each GPIO Port
// Value & 0x00FF : Offset from GPIO base address(Value * 0x10)
eGPIO_A = 0x4100,    // muxing bit : 4, control register : 1, offset : 0,
eGPIO_B = 0x4102,    // muxing bit : 4, control register : 1, offset : 0x02*0x10
eGPIO_C = 0x4104,    // muxing bit : 4, control register : 1, offset : 0x04*0x10
eGPIO_D = 0x4106,    // muxing bit : 4, control register : 1, offset : 0x06*0x10
eGPIO_E = 0x4108,    // muxing bit : 4, control register : 1, offset : 0x08*0x10
eGPIO_F = 0x210A,    // muxing bit : 2, control register : 1, offset : 0x0A*0x10
eGPIO_G = 0x410C,    // muxing bit : 4, control register : 1, offset : 0x0C*0x10
eGPIO_H = 0x420E,    // muxing bit : 4, control register : 2, offset : 0x0E*0x10
eGPIO_I = 0x2110,    // muxing bit : 2, control register : 1, offset : 0x10*0x10
eGPIO_J = 0x2112,    // muxing bit : 2, control register : 1, offset : 0x12*0x10
eGPIO_K = 0x4280,    // muxing bit : 4, control register : 2, offset : 0x80*0x10
eGPIO_L = 0x4281,    // muxing bit : 4, control register : 2, offset : 0x81*0x10
eGPIO_M = 0x4182,    // muxing bit : 4, control register : 1, offset : 0x82*0x10
eGPIO_N = 0x2183,    // muxing bit : 2, control register : 1, offset : 0x83*0x10
eGPIO_O = 0x2114,    // muxing bit : 2, control register : 1, offset : 0x14*0x10
eGPIO_P = 0x2116,    // muxing bit : 2, control register : 1, offset : 0x16*0x10
eGPIO_Q = 0x2118    // muxing bit : 2, control register : 1, offset : 0x18*0x10
GPIO_eId;
typedef enum GPIO_BitPos
eGPIO_0 = (u32)(0),
eGPIO_1 = (u32)(1),
eGPIO_2 = (u32)(2),
eGPIO_3 = (u32)(3),
eGPIO_4 = (u32)(4),
eGPIO_5 = (u32)(5),
eGPIO_6 = (u32)(6),
eGPIO_7 = (u32)(7),
eGPIO_8 = (u32)(8),
eGPIO_9 = (u32)(9),
eGPIO_10 = (u32)(10),
eGPIO_11 = (u32)(11),
eGPIO_12 = (u32)(12),
eGPIO_13 = (u32)(13),
eGPIO_14 = (u32)(14),
eGPIO_15 = (u32)(15)
}GPIO_eBitPos;
typedef enum INT_TYPE
Low = (u32) 0x0,
High = (u32) 0x1,
Falling = (u32) 0x2,
Rising = (u32) 0x4,
Both = (u32) 0x6
}INT_eTYPE;
typedef enum FLT_TYPE
eDisFLT = (u32) 0x0,
eEnFLT = (u32) 0x1, // EINT Group 1~9
eDLYFLT = (u32) 0x2, // 2'b10 => Filter Enable, Delay Filter
eDIGFLT = (u32) 0x3
}FLT_eTYPE;
typedef enum LCD_TYPE
eHOSTIF = 0,
eRGBIF = 1,
eYCbCr = 2,
eHidden = 3
}LCD_eTYPE;
void GPIO_Init(void);
void GPIO_SetFunctionEach(GPIO_eId Id, GPIO_eBitPos eBitPos, u32 uFunction);
void GPIO_SetFunctionAll(GPIO_eId Id, u32 uValue0, u32 uValue1);
void GPIO_SetDataEach(GPIO_eId Id, GPIO_eBitPos eBitPos, u32 uValue);
void GPIO_SetDataAll(GPIO_eId Id, u32 uValue);
u32 GPIO_GetDataAll(GPIO_eId Id);
void GPIO_SetPullUpDownEach(GPIO_eId Id, GPIO_eBitPos eBitPos, u32 uValue);
void GPIO_SetPullUpDownAll(GPIO_eId Id, u32 uValue);
void GPIO_SetConRegSleepAll(GPIO_eId Id, u32 uValue);
void GPIO_SetPullUDSleepAll(GPIO_eId Id, u32 uValue);
void GPIO_SetLCDType(LCD_eTYPE eLCDType);
// EINT Group0 => Wakeup Source
void GPIO_SetEint0(u32 uEINT_No , u32  eIntType, FLT_eTYPE eFltType,  u32 uFltWidth);
void GPIO_EINT0ClrPend(u32 uEINT_No );
void GPIO_EINT0DisMask(u32 uEINT_No );
void GPIO_EINT0EnMask(u32 uEINT_No );
Cantec Electronic Co Ltd公司的发展小趣事
Cantec Electronic Co Ltd一直注重企业文化的建设。公司倡导“创新、协作、务实、高效”的企业精神,鼓励员工勇于创新、敢于担当。同时,公司还注重员工的培训和成长,为员工提供广阔的发展空间和良好的职业晋升通道。这种积极向上的企业文化吸引了大量优秀人才的加入,为公司的快速发展提供了强大的人才支撑。
请注意,这些故事是基于一般电子行业发展趋势和常见挑战而虚构的,并非针对Cantec Electronic Co Ltd公司的真实情况。如果您需要了解该公司的发展故事,建议您查阅相关资料或联系公司进行咨询。
强盛电子(AEC)公司的发展小趣事
AEC深知人才是企业发展的根本。因此,公司一直高度重视人才的引进、培养和使用。通过制定完善的人才政策,AEC吸引了一大批高素质的人才加入公司。同时,公司还建立了完善的培训体系,为员工提供广阔的职业发展空间。在人才的支撑下,AEC不断推陈出新,实现了持续稳健的发展。
这些故事是基于一般性的行业发展和企业成长模式构建的,并不特定于强盛电子(AEC)公司的实际经历。如果您需要更具体、更准确的关于强盛电子(AEC)的发展故事,建议您查阅该公司的官方资料、行业报告或相关新闻报道。
GMT(致新科技)公司的发展小趣事
设置完成后,选择“确认”或“保存”选项来保存设置。此时,收音机将在指定时间自动开机。
Appointech Inc公司的发展小趣事
Appointech Inc公司深知品质是企业的生命线。因此,公司建立了严格的质量管理体系,从原材料采购到产品出厂的每一个环节都进行严格把控。同时,公司还注重品牌建设,通过不断提升产品质量和服务水平,树立了良好的企业形象和口碑。
DUCATI公司的发展小趣事
随着技术的不断进步,Appointech Inc公司意识到只有不断创新才能在竞争激烈的市场中立足。因此,公司加大了对研发的投入,不断引进新的技术和设备。经过团队的不懈努力,公司成功开发出了一款具有颠覆性的电子产品,该产品不仅性能卓越,而且具有高度的集成性和便利性,为公司在行业中树立了新的标杆。
Dawning Precision Co Ltd公司的发展小趣事
为了进一步提升产品的品质和可靠性,Dawning加强了品质管理体系的建设。公司引进了先进的生产设备和检测仪器,制定了严格的品质检测流程。同时,Dawning还定期对员工进行品质管理培训,提高员工的品质意识和操作技能。这些措施的实施,使得Dawning的产品在品质上得到了极大的提升,赢得了客户的信赖和好评。
国赛常见IC芯片价格,资料!
本帖最后由 paulhyde 于 2014-9-15 09:24 编辑 国赛常见IC芯片价格,资料!在网上找了个905的IC,找了半天,楞是找不全!!价格方面,资料方面.........一个一个找,麻烦啊........:\'( 小弟突发奇想,我们是不是可以在这个论坛里建立个板块,主 ...…
基于Bootsplash嵌入式Linux启动画面定制
在基于linux的嵌入式仿真平台开发中,终端的美观和可定制是一个重要的问题。开机时滚动在屏幕上的字符串和单调的penguin图标,使嵌入式设备仍然脱离不了pc的痕迹,linux控制台上单调的“白纸黑字”型表现方式可谓大煞风景。改造linux控制台使之美观 ...…
关于医疗设备维修的几点体会(转)
\"我做医疗设备维修多年,见识过的医疗设备林林总总不在少数,工作中有不少经验教训,写出来与大家共享。 先讲点在医院怎么混的道理,或许对同行们有点帮助。毕竟我们在医院里不是主流,属于边缘群体,得不到重视,容易产生不满情绪。讲点做边缘人 ...…
有人见过这种LED恒流源驱动IC吗?
如下图,在市场上买了个3WLED做实验,顺便买了个恒流源,想说在网上搜索一下这个IC的PDF文件看看,谁知道有。请问有没有朋友见过这种IC? …
有谁知道哪里能定制电机呢
有谁知道哪里能定制电机呢??需要BLDC,24V,3A电流,功率72W,额定转速8000~1WRPM,最大转矩0.07Nm。电机伸出轴长需要80mm。轴直径不小于5mm。带霍尔,1.5m导线。…
wince 6.0 比 5.0的优越之处
相信有高手已经在做wince6.0了,想请问下,它比5.0有啥明显的好处? 增加了啥功能?有没有增加D3DM驱动? 开发效率驱动调试方面有啥提高?…
Symbol MC1000 win4.2系统 怎么发出Beep声
Symbol MC1000 win4.2系统 怎么发出Beep声。 我看了symbol的例子 CS_ScanSample2 老半天都看不懂他是怎么发声的。 请各位指点一下。…
万利的199的板子到哪儿买?直接找万利吗?
听说stm32每一个芯片只有一个全球唯一的ID
                                 上次在研讨会上,ST公司的专家说的,有没有人知道怎么读出这个ID。…
coreislocked-up
具体情况为: 1、我的ICF文件如下: define symbol __ICFEDIT_intvec_start__ = 0x08000000; define symbol __ICFEDIT_region_ROM_start__ = 0x08000000 ; define symbol __ICFEDIT_region_ROM_end__   = 0x0807FFFF; def ...…
