今天是:2025年03月10日(星期一)
2020年03月10日 | STM32开发笔记76: 初始化RTC后死机的原因
2020-03-10 来源:eefocus
单片机型号:STM32L053R8T6
项目开发中只要初始化RTC,则系统死机。其初始化步骤可参考日志:STM32开发笔记44:RTC驱动程序的移植。按照日志STM32开发笔记75: 使用STM32CubeMX点亮一个LED使用STM32CubeMX直接生成程序则运行正常。
分析原因在于,少移植了2个函数:HAL_RTC_MspInit和HAL_RTC_MspDeInit。这两个函数的实现非常简单,可以靠STM32CubeMX直接生成。
void HAL_RTC_MspInit(RTC_HandleTypeDef *hrtc)
__HAL_RCC_RTC_ENABLE();
HAL_NVIC_SetPriority(RTC_IRQn, 0x0, 0);
HAL_NVIC_EnableIRQ(RTC_IRQn);
void HAL_RTC_MspDeInit(RTC_HandleTypeDef *hrtc)
__HAL_RCC_RTC_DISABLE();
将这2个函数直接植入rtc.cpp即可,这样就得到了完善的rtc.h和rtc.cpp。
#ifndef RTC_H_
#define RTC_H_
#include "stdint.h"
#if (defined STM32F091xC) || (defined STM32F070x6)
#include "stm32f0xx_hal.h"
#elif (defined STM32L053xx)
#include "stm32l0xx_hal.h"
#endif
#ifdef __cplusplus
extern "C"{
class CRtc
public:
RTC_HandleTypeDef hRTC;
public:
CRtc(void);
void EnterStopRtcMode(uint8_t u8_Second);
#endif
#endif
#include "include.h"
RTC_HandleTypeDef* pRTC = NULL;
CRtc::CRtc(void)
this->hRTC.Instance = RTC;
pRTC = &this->hRTC;
this->hRTC.Init.HourFormat = RTC_HOURFORMAT_24;
this->hRTC.Init.AsynchPrediv = 124;
this->hRTC.Init.SynchPrediv = 295;
this->hRTC.Init.OutPut = RTC_OUTPUT_DISABLE;
this->hRTC.Init.OutPutRemap = RTC_OUTPUT_REMAP_NONE; //不进行输出引脚重映射
this->hRTC.Init.OutPutPolarity = RTC_OUTPUT_POLARITY_HIGH;
this->hRTC.Init.OutPutType = RTC_OUTPUT_TYPE_OPENDRAIN;
if (HAL_RTC_Init(&this->hRTC) != HAL_OK)
Target.ErrorHandler(__FILE__, __LINE__);
void CRtc::EnterStopRtcMode(uint8_t u8_Second)
HAL_RTCEx_DeactivateWakeUpTimer(&hRTC);
HAL_RTCEx_SetWakeUpTimer_IT(&hRTC, (uint32_t)u8_Second * 2312, RTC_WAKEUPCLOCK_RTCCLK_DIV16);
HAL_PWR_EnterSTOPMode(PWR_LOWPOWERREGULATOR_ON, PWR_STOPENTRY_WFI);
void RTC_IRQHandler(void)
HAL_RTCEx_WakeUpTimerIRQHandler(pRTC);
除此之外,我们还需对RTC进行配置,和设置中断服务处理函数。
* @file stm32l0xx_hal_conf.h
* @author MCD Application Team
* @brief HAL configuration template file.
* This file should be copied to the application folder and renamed
* to stm32l0xx_hal_conf.h.
* @attention
© Copyright (c) 2016 STMicroelectronics. * All rights reserved.
* This software component is licensed by ST under BSD 3-Clause license,
* the "License"; You may not use this file except in compliance with the
* License. You may obtain a copy of the License at:
* opensource.org/licenses/BSD-3-Clause
/* Define to prevent recursive inclusion -------------------------------------*/
#ifndef __STM32L0xx_HAL_CONF_H
#define __STM32L0xx_HAL_CONF_H
#ifdef __cplusplus
extern "C" {
#endif
/* Exported types ------------------------------------------------------------*/
/* Exported constants --------------------------------------------------------*/
/* ########################## Module Selection ############################## */
* @brief This is the list of modules to be used in the HAL driver
#define HAL_MODULE_ENABLED
/*#define HAL_ADC_MODULE_ENABLED */
/*#define HAL_CRYP_MODULE_ENABLED */
/*#define HAL_COMP_MODULE_ENABLED */
/*#define HAL_CRC_MODULE_ENABLED */
/*#define HAL_DAC_MODULE_ENABLED */
/*#define HAL_FIREWALL_MODULE_ENABLED */
/*#define HAL_I2S_MODULE_ENABLED */
#define HAL_IWDG_MODULE_ENABLED
/*#define HAL_LCD_MODULE_ENABLED */
/*#define HAL_LPTIM_MODULE_ENABLED */
/*#define HAL_RNG_MODULE_ENABLED */
#define HAL_RTC_MODULE_ENABLED
/*#define HAL_SPI_MODULE_ENABLED */
#define HAL_TIM_MODULE_ENABLED
/*#define HAL_TSC_MODULE_ENABLED */
#define HAL_UART_MODULE_ENABLED
/*#define HAL_USART_MODULE_ENABLED */
/*#define HAL_IRDA_MODULE_ENABLED */
/*#define HAL_SMARTCARD_MODULE_ENABLED */
/*#define HAL_SMBUS_MODULE_ENABLED */
/*#define HAL_WWDG_MODULE_ENABLED */
/*#define HAL_PCD_MODULE_ENABLED */
/*#define HAL_EXTI_MODULE_ENABLED */
#define HAL_GPIO_MODULE_ENABLED
#define HAL_DMA_MODULE_ENABLED
#define HAL_I2C_MODULE_ENABLED
#define HAL_RCC_MODULE_ENABLED
#define HAL_FLASH_MODULE_ENABLED
#define HAL_PWR_MODULE_ENABLED
#define HAL_CORTEX_MODULE_ENABLED
/* ########################## Oscillator Values adaptation ####################*/
* @brief Adjust the value of External High Speed oscillator (HSE) used in your application.
* This value is used by the RCC HAL module to compute the system frequency
* (when HSE is used as system clock source, directly or through the PLL).
#if !defined (HSE_VALUE)
#define HSE_VALUE ((uint32_t)12000000U) /*!< Value of the External oscillator in Hz */
#endif /* HSE_VALUE */
#if !defined (HSE_STARTUP_TIMEOUT)
#define HSE_STARTUP_TIMEOUT ((uint32_t)100U) /*!< Time out for HSE start up, in ms */
#endif /* HSE_STARTUP_TIMEOUT */
* @brief Internal Multiple Speed oscillator (MSI) default value.
* This value is the default MSI range value after Reset.
#if !defined (MSI_VALUE)
#define MSI_VALUE ((uint32_t)2097000U) /*!< Value of the Internal oscillator in Hz*/
#endif /* MSI_VALUE */
* @brief Internal High Speed oscillator (HSI) value.
* (when HSI is used as system clock source, directly or through the PLL).
#if !defined (HSI_VALUE)
#define HSI_VALUE ((uint32_t)16000000U) /*!< Value of the Internal oscillator in Hz*/
#endif /* HSI_VALUE */
* @brief Internal High Speed oscillator for USB (HSI48) value.
#if !defined (HSI48_VALUE)
#define HSI48_VALUE ((uint32_t)48000000U) /*!< Value of the Internal High Speed oscillator for USB in Hz.
The real value may vary depending on the variations
in voltage and temperature. */
#endif /* HSI48_VALUE */
* @brief Internal Low Speed oscillator (LSI) value.
#if !defined (LSI_VALUE)
#define LSI_VALUE ((uint32_t)37000U) /*!< LSI Typical Value in Hz*/
#endif /* LSI_VALUE */ /*!< Value of the Internal Low Speed oscillator in Hz
in voltage and temperature.*/
* @brief External Low Speed oscillator (LSE) value.
* This value is used by the UART, RTC HAL module to compute the system frequency
#if !defined (LSE_VALUE)
#define LSE_VALUE ((uint32_t)32768U) /*!< Value of the External oscillator in Hz*/
#endif /* LSE_VALUE */
#if !defined (LSE_STARTUP_TIMEOUT)
#define LSE_STARTUP_TIMEOUT ((uint32_t)5000U) /*!< Time out for LSE start up, in ms */
#endif /* LSE_STARTUP_TIMEOUT */
/* Tip: To avoid modifying this file each time you need to use different HSE,
=== you can define the HSE value in your toolchain compiler preprocessor. */
/* ########################### System Configuration ######################### */
* @brief This is the HAL system configuration section
#define VDD_VALUE ((uint32_t)3300U) /*!< Value of VDD in mv */
#define TICK_INT_PRIORITY ((uint32_t)0U) /*!< tick interrupt priority */
#define USE_RTOS 0U
#define PREFETCH_ENABLE 0U
#define PREREAD_ENABLE 1U
#define BUFFER_CACHE_DISABLE 0U
/* ########################## Assert Selection ############################## */
2009年TPCA先进技术研讨会暨标竿论坛6日正式登场,第一场演讲由Prismark姜旭高博士揭开序幕,主题为PCB技术发展趋势与市场商机分析。姜旭高说,比起半导体产业来说,PCB技术发展速度相当缓慢,2000年以来,全球PCB产值几乎没有什么变化,但是台湾PC ...… 查看全部问答> |
目前设计小组凸显了两个设计方案,主要区别是处理器不同,大家赶快投票参与吧!第一组设计简单,使用了大家熟悉的51单片机第二组主要目标就是在利用SHT21的同时,将东西做得小巧,初定为纽扣电池可用USB充电目前在方案选定阶段,我们随后会公布最小 ...… 查看全部问答> |
请教下,怎样在PPC或Smartphone上调用TAPI或其他函数来设置回铃音静音或让打电话的人听不到呢呢,有知道的请不吝赐教,小弟先行谢过了.... 我想静音,但是调用waveoutsetvolume(0,0),还是没什么变化,请问如何解决,才能即使有回铃音,让他静音,让主叫方听不到就行.… 查看全部问答> |
#include <msp430x14x.h> void main(void) { WDTCTL = WDTPW + WDTHOLD; TACTL = TASSEL0 + TACLR; CCTL0 = CCIE; CCR0 = 16384; ...… 查看全部问答> |
最近在玩C8051单片机,AD转换的涉及到一个精度的问题,基准电压是3.3V,现在要采样的电压范围是0~48V,计算可得精度大概是188mv=48/3.3 * 3300/255 左右,那么现在要求的精度在100mv以内,怎么操作呢?是不是跟里面的放大增益有关呢?… 查看全部问答> |
已经安装arm-linux-gcc-4.1.2。在对linux-2.6.31进行内核编译时,使用到“make manuconfig”命令,但是出错了!出错提示信息如下: HOSTCC scripts/basic/fixdep/usr/local/libexec/gcc/i686-pc-linux-gnu/4.6.1/cc1:error while loading shared li ...… 查看全部问答> |
