今天是:2025年03月30日(星期日)
2020年03月30日 | 把ATmega128开发板转为Arduino
2020-03-30 来源:eefocus
AVR环境:
编译环境: ubuntu + avr-gcc
烧写工具: avrdude+usbasp
具体构建步骤查看上一篇博客。
avr环境多种多样,在linux下还可以用eclipse集成环境。在window下推荐用WINAVR,其实本质上和linux下一样是用avr-gcc,烧写工具用prgisp.当然有了avr jtag仿真器就更好了,不用usbasp.
下载arduino工具:
arduino.cc/en/Main/Software
我下载的linux 64位版本,下载后解压到主目录下。
开发板:
BK-AVR128开发板
一、制作属于atmega128的bootloader
代码主要是arduino工具自带的,编译时有点问题,我改了几处。
可以直接到我的资源里面下载编译好的hex文件直接烧写到单片机就可以了:
download.csdn.net/detail/canyue102/5809329
源代码boot _mega128.c:
/* Serial Bootloader for Atmel megaAVR Controllers */
/* tested with ATmega8, ATmega128 and ATmega168 */
/* should work with other mega's, see code for details */
/* 20090308: integrated Mega changes into main bootloader */
/* source by D. Mellis */
/* 20080930: hacked for Arduino Mega (with the 1280 */
/* processor, backwards compatible) */
/* by D. Cuartielles */
/* 20070626: hacked for Arduino Diecimila (which auto- */
/* resets when a USB connection is made to it) */
/* by D. Mellis */
/* 20060802: hacked for Arduino by D. Cuartielles */
/* based on a previous hack by D. Mellis */
/* and D. Cuartielles */
/* Monitor and debug functions were added to the original */
/* code by Dr. Erik Lins, chip45.com. (See below) */
/* Thanks to Karl Pitrich for fixing a bootloader pin */
/* problem and more informative LED blinking! */
/* For the latest version see: */
/* http://www.chip45.com/ */
/* based on stk500boot.c */
/* Copyright (c) 2003, Jason P. Kyle */
/* All rights reserved. */
/* see avr1.org for original file and information */
/* This program is free software; you can redistribute it */
/* and/or modify it under the terms of the GNU General */
/* Public License as published by the Free Software */
/* Foundation; either version 2 of the License, or */
/* (at your option) any later version. */
/* This program is distributed in the hope that it will */
/* be useful, but WITHOUT ANY WARRANTY; without even the */
/* implied warranty of MERCHANTABILITY or FITNESS FOR A */
/* PARTICULAR PURPOSE. See the GNU General Public */
/* License for more details. */
/* You should have received a copy of the GNU General */
/* Public License along with this program; if not, write */
/* to the Free Software Foundation, Inc., */
/* 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA */
/* Licence can be viewed at */
/* http://www.fsf.org/licenses/gpl.txt */
/* Target = Atmel AVR m128,m64,m32,m16,m8,m162,m163,m169, */
/* m8515,m8535. ATmega161 has a very small boot block so */
/* isn't supported. */
/* Tested with m168 */
/* $Id$ */
/* some includes */
#include #include #include #include #include #include /* the current avr-libc eeprom functions do not support the ATmega168 */ /* own eeprom write/read functions are used instead */ #if !defined(__AVR_ATmega168__) || !defined(__AVR_ATmega328P__) #include #endif /* Use the F_CPU defined in Makefile */ /* 20060803: hacked by DojoCorp */ /* 20070626: hacked by David A. Mellis to decrease waiting time for auto-reset */ /* set the waiting time for the bootloader */ /* get this from the Makefile instead */ #define MAX_TIME_COUNT (F_CPU>>1) /* 20070707: hacked by David A. Mellis - after this many errors give up and launch application */ #define MAX_ERROR_COUNT 5 /* set the UART baud rate */ /* 20060803: hacked by DojoCorp */ //#define BAUD_RATE 115200 #ifndef BAUD_RATE #define BAUD_RATE 19200 #endif /* SW_MAJOR and MINOR needs to be updated from time to time to avoid warning message from AVR Studio */ /* never allow AVR Studio to do an update !!!! */ #define HW_VER 0x02 #define SW_MAJOR 0x01 #define SW_MINOR 0x10 /* Adjust to suit whatever pin your hardware uses to enter the bootloader */ /* ATmega128 has two UARTS so two pins are used to enter bootloader and select UART */ /* ATmega1280 has four UARTS, but for Arduino Mega, we will only use RXD0 to get code */ /* BL0... means UART0, BL1... means UART1 */ #ifdef __AVR_ATmega128__ #define BL_DDR DDRF #define BL_PORT PORTF #define BL_PIN PINF #define BL0 PINF7 #define BL1 PINF6 #elif defined __AVR_ATmega1280__ /* we just don't do anything for the MEGA and enter bootloader on reset anyway*/
有位研究生网友提出,就是没觉得手机天线行业有什么技术含量,理由是这个行业用不到公式。 在此,我想有必要就此进行一些陈述,这也是长久以来自己的一些想法。 百闻不如一见,在学校里做东西,和在公司里做东西,是有差异的,这个差异有的时候还 ...… 查看全部问答> |
有时因为没有电路图,但是自己所从事的行业好歹与电子沾边,于是总喜欢拆开来看看或者动手调调。 有的时候,不小心就被某个地方电一下。 哎,现在有点怕了。 请大家说说你们是否被电过?如何预防?… 查看全部问答> |
娱乐界的颁奖晚会、红地毯炒的沸沸扬扬,吸引N多媒体的目光,而为什么没有专门为科学家和工程师举办多一些这种活动? 美国《纽约时报》专栏作家Thomas L. Friedman提出建议,认为应该大力宣传像是“英特尔科学奖”颁奖晚会这样的活动,让其现场实 ...… 查看全部问答> |
function gps; sDataPath = \'D:\\s\\\'; sDataFile = dir(sDataPath); %sDataPath这是你存放dat数据文件的路径 m = length(sDataFile); k = 0; for i = 1:m if sDataFile(i).isdir co ...… 查看全部问答> |
我要找硬件开发兼职人员(在杭州)急 联系qq 33938019 msn:zhubin@zhubin.net 邮箱:zhubin@zhubin.net … 查看全部问答> |
看看这个帖子,什么都明白了 https://bbs.eeworld.com.cn/thread-290320-1-1.html ydw621会员放错误文档,完全是骗论坛币… 查看全部问答> |
