今天是:2025年03月30日(星期日)
2020年03月30日 | 基于ATMEGA8515的SPI驱动ST7565P液晶屏的程序
2020-03-30 来源:eefocus
这是用SPI方式来驱动12864液晶的源程序,液晶屏的控制芯片为ST7565P经测试SPI的时钟可达到振荡频率的二分频。比用普通IO口模拟串行的方式快多了。。。
下面贴出源代码,有详细注释。。。。
本程序简单实用,可拿去作简单参考。。。。
编译环境:GCC+AVR STUDIO
单片机:ATMEGA 8515
晶振: 3.6864M
#include #include #define COMMAND 1 #define DATA 0 ///////////////////////////////////////// //数据线定义: // SI==========PB5 // // A0==========PC0 // CS==========PC2 // RES=========PC1 // SCL=========PB7 // ///////////////////////////////////////// unsigned char gushi[8][112]PROGMEM= { {0x10,0x10,0x92,0x92,0x92,0xF2,0x9E,0x92,0x92,0x92,0x92,0x92,0xFE,0x10,0x10,0x00, //君问归期未有期 0x00,0x00,0xF8,0x01,0x06,0xE0,0x22,0x22,0x22,0x22,0xE2,0x02,0x02,0xFE,0x00,0x00, 0x00,0xF8,0x00,0x00,0xFF,0x00,0x04,0x84,0x84,0x84,0x84,0x84,0x84,0xFC,0x00,0x00, 0x00,0x04,0xFF,0x54,0x54,0x54,0xFF,0x04,0x00,0xFE,0x22,0x22,0x22,0xFE,0x00,0x00, 0x40,0x40,0x48,0x48,0x48,0x48,0xC8,0xFF,0x48,0x48,0x48,0x48,0x48,0x40,0x40,0x00, 0x00,0x04,0x84,0x44,0xE4,0x34,0x2C,0x27,0x24,0x24,0x24,0xE4,0x04,0x04,0x04,0x00, 0x00,0x04,0xFF,0x54,0x54,0x54,0xFF,0x04,0x00,0xFE,0x22,0x22,0x22,0xFE,0x00,0x00}, {0x40,0x20,0x10,0x0C,0xFE,0x45,0x44,0x44,0x44,0x44,0x44,0x44,0xFD,0x00,0x00,0x00, 0x00,0x00,0xFF,0x00,0x00,0x03,0x02,0x02,0x02,0x02,0x03,0x40,0x80,0x7F,0x00,0x00, 0x00,0x87,0x40,0x30,0x0F,0x00,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x3F,0x00,0x00, 0x42,0x22,0x1B,0x02,0x02,0x0A,0x33,0x62,0x18,0x07,0x02,0x22,0x42,0x3F,0x00,0x00, 0x20,0x20,0x10,0x10,0x08,0x06,0x01,0xFF,0x01,0x02,0x04,0x08,0x18,0x30,0x10,0x00, 0x02,0x01,0x00,0x00,0xFF,0x09,0x09,0x09,0x29,0x49,0xC9,0x7F,0x00,0x00,0x00,0x00, 0x42,0x22,0x1B,0x02,0x02,0x0A,0x33,0x62,0x18,0x07,0x02,0x22,0x42,0x3F,0x00,0x00}, {0x00,0x00,0xFE,0x42,0x42,0x42,0x42,0x7E,0x42,0x42,0x42,0x42,0xFE,0x00,0x00,0x00, //巴山夜雨涨池 0x00,0x00,0xE0,0x00,0x00,0x00,0x00,0xFF,0x00,0x00,0x00,0x00,0x00,0xE0,0x00,0x00, 0x04,0x04,0x84,0xC4,0x3C,0x14,0x85,0x66,0xBC,0x24,0x24,0x24,0xE4,0x24,0x04,0x00, 0x02,0x02,0xF2,0x32,0x52,0x92,0x12,0xFE,0x32,0x52,0x92,0x12,0xF2,0x02,0x02,0x00, 0x10,0x61,0x86,0x60,0xF2,0x12,0x12,0x1E,0x80,0xFF,0xA0,0x90,0x88,0x86,0x80,0x00, 0x24,0x24,0xE4,0xFC,0xA2,0x22,0x22,0x80,0x70,0x00,0xFF,0x40,0x20,0x18,0x00,0x00, 0x10,0x60,0x02,0x8C,0x60,0x80,0xF8,0x40,0x40,0xFE,0x20,0x20,0x10,0xF0,0x00,0x00}, {0x00,0x00,0x3F,0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x78,0x20,0x00, 0x00,0x20,0x7F,0x20,0x20,0x20,0x20,0x3F,0x20,0x20,0x20,0x20,0x20,0x7F,0x00,0x00, 0x02,0x01,0x00,0xFF,0x00,0x82,0x41,0x22,0x14,0x09,0x14,0x23,0x40,0xC0,0x40,0x00, 0x00,0x00,0xFF,0x01,0x02,0x04,0x00,0x7F,0x01,0x02,0x44,0x80,0x7F,0x00,0x00,0x00, 0x04,0xFC,0x03,0x00,0x01,0x41,0x81,0x7F,0x00,0xFF,0x42,0x0C,0x30,0x60,0x20,0x00, 0x02,0x01,0x00,0xFF,0x00,0x83,0x40,0x20,0x18,0x07,0x01,0x06,0x18,0xE0,0x40,0x00, 0x08,0x08,0x7C,0x03,0x00,0x00,0x3F,0x40,0x40,0x5F,0x40,0x42,0x44,0x43,0x70,0x00}, {0x80,0x40,0xF0,0x1C,0x07,0xE2,0x24,0x24,0x24,0xE4,0x04,0x04,0xFC,0x04,0x04,0x00, //何当共剪西窗烛 0x00,0x00,0x40,0x42,0x5C,0x48,0x40,0x40,0x7F,0x40,0x50,0x4E,0x44,0xC0,0x00,0x00, 0x00,0x10,0x10,0x10,0x10,0xFE,0x10,0x10,0x10,0x10,0xFE,0x10,0x10,0x10,0x00,0x00, 0x00,0x04,0xF4,0x54,0x55,0x56,0x54,0xF4,0x04,0x04,0xE6,0x05,0x04,0xF4,0x04,0x00, 0x02,0xF2,0x12,0x12,0x12,0xFE,0x12,0x12,0x12,0xFE,0x12,0x12,0x12,0xF2,0x02,0x00, 0x00,0x4C,0x44,0xE4,0x54,0x44,0x64,0xD5,0x46,0x44,0x4C,0x54,0xD4,0x24,0x2C,0x00, 0x80,0x60,0x00,0xFF,0x20,0x18,0xF0,0x10,0x10,0xFF,0x12,0x10,0xF0,0x10,0x00,0x00}, {0x00,0x00,0x7F,0x00,0x00,0x07,0x02,0x02,0x02,0x07,0x20,0x40,0x3F,0x00,0x00,0x00, 0x00,0x00,0x20,0x22,0x22,0x22,0x22,0x22,0x22,0x22,0x22,0x22,0x22,0x7F,0x00,0x00, 0x02,0x02,0x82,0x42,0x32,0x1F,0x0A,0x02,0x02,0x06,0x0B,0x32,0xE2,0x42,0x02,0x00, 0x00,0x08,0x8F,0x89,0x49,0x2B,0x1D,0x0B,0x08,0x08,0x08,0x4A,0x8C,0x7B,0x00,0x00, 0x00,0x7F,0x28,0x24,0x22,0x21,0x20,0x20,0x20,0x21,0x22,0x22,0x22,0x7F,0x00,0x00, 0x00,0x00,0x00,0xFF,0x44,0x62,0x55,0x49,0x55,0x43,0x41,0x40,0xFF,0x00,0x00,0x00, 0x40,0x20,0x18,0x07,0x04,0x28,0x63,0x21,0x21,0x3F,0x11,0x15,0x1B,0x30,0x00,0x00}, {0x80,0x88,0x88,0x88,0xFF,0x88,0x88,0x88,0x00,0xFE,0x02,0x02,0x02,0xFE,0x00,0x00, //却话巴山夜雨时 0x40,0x41,0x4E,0xC4,0x00,0x20,0x24,0x24,0x24,0x24,0xFC,0x22,0x22,0x22,0x20,0x00, 0x00,0x00,0xFE,0x42,0x42,0x42,0x42,0x7E,0x42,0x42,0x42,0x42,0xFE,0x00,0x00,0x00, 0x00,0x00,0xE0,0x00,0x00,0x00,0x00,0xFF,0x00,0x00,0x00,0x00,0x00,0xE0,0x00,0x00, 0x04,0x04,0x84,0xC4,0x3C,0x14,0x85,0x66,0xBC,0x24,0x24,0x24,0xE4,0x24,0x04,0x00, 0x02,0x02,0xF2,0x32,0x52,0x92,0x12,0xFE,0x32,0x52,0x92,0x12,0xF2,0x02,0x02,0x00, 0x00,0xFC,0x44,0x44,0x44,0xFC,0x10,0x90,0x10,0x10,0x10,0xFF,0x10,0x10,0x10,0x00}, {0x00,0x10,0x3C,0x13,0x10,0x08,0x0A,0x1C,0x08,0xFF,0x00,0x08,0x10,0x0F,0x00,0x00, 0x00,0x00,0x00,0x7F,0x20,0x10,0x00,0x7E,0x22,0x22,0x23,0x22,0x22,0x7E,0x00,0x00, 0x00,0x00,0x3F,0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x78,0x20,0x00, 0x00,0x20,0x7F,0x20,0x20,0x20,0x20,0x3F,0x20,0x20,0x20,0x20,0x20,0x7F,0x00,0x00, 0x02,0x01,0x00,0xFF,0x00,0x82,0x41,0x22,0x14,0x09,0x14,0x23,0x40,0xC0,0x40,0x00, 0x00,0x00,0xFF,0x01,0x02,0x04,0x00,0x7F,0x01,0x02,0x44,0x80,0x7F,0x00,0x00,0x00, 0x00,0x07,0x04,0x04,0x04,0x07,0x00,0x00,0x03,0x40,0x80,0x7F,0x00,0x00,0x00,0x00}, }; //////////////////////////////// //发送一个字节到ST7565P并等待发送完毕 //入口:要发送的字节 //返回值:无 //////////////////////////////// void SPIByte(unsigned char byte) { SPDR =byte; //写数据 while(!(SPSR &(1< //////////////////////////////////////////////// //将一个字节发送的ST7565P的函数 //入口参数: select ,data //select:根据此值确定发送给ST7565P的是数据还是命令 //data: 要发送给ST7565的一个字节 //返回值:无 //////////////////////////////////////////////// void LCD_SPISend(unsigned char select,unsigned chardata) { PORTC&= ~(1<<2); // CS=0芯片使能信号 if(select == COMMAND) //传输的是命令 { PORTC &=~(1<<0); //根据ST7565P的数据手册,传输命令时A0应该是为低电平 SPIByte(data); PORTC |=1<<0; // A0=1 } else { SPIByte(data); } PORTC|= 1<<2; //CS=恢复不使能 } //////////////////////////////////////////// //写坐标函数 //入口参数:x y //y: 页面地址,此液晶将显示区域分为9个页面,y的值域0~8 //x: 列地址,值域:0~127 //返回值:无 //////////////////////////////////////////// void LCD_XYSet(unsigned char x,unsigned chary) { LCD_SPISend(COMMAND,0xB0|y); //y的值为0~8 LCD_SPISend(COMMAND,0x10|(x>>4)); LCD_SPISend(COMMAND,0x00|(x&0x0F)); } ///////////////////////////////////// //延时函数 //入口: ms 当延时100毫秒时,ms的值为100即可 //返回值:无 ///////////////////////////////////// void DelayMs(volatile unsigned int ms) { volatile unsigned inti; volatile unsigned intj; for(i=0;i j=280; while(j--); } } ////////////////////////////////////////////////////// //初始化SPI及液晶屏的函数 //入口:无 //返回值:无 ///////////////////////////////////////////////////// void LCD_Init(void) { SPCR =0x5C; SPSR|= 1< DelayMs(100); SPIByte(0xFF); //可发可不发,无意义 PORTC&= ~(1<<1); //将复位脚拉低 DelayMs(5); //延时5ms,等待电源稳定 PORTC|= 1<<1; //将复位脚拉高 DelayMs(5); LCD_SPISend(COMMAND,0xAE); //将液晶屏的显示关掉 LCD_SPISend(COMMAND,0xA3); //设置偏压比 LCD_SPISend(COMMAND,0xA0); //设置SEG输出方向 LCD_SPISend(COMMAND,0xC8); //设置公共端输出扫描方向 LCD_SPISend(COMMAND,0x25); //调整 (1 +Rb/Ra) ratio 值,调整此值影响很大 LCD_SPISend(COMMAND,0x81); //开始设置α的命令 LCD_SPISend(COMMAND,0x28); //设置α的值,值越大对比度越强,调整此值影响不太,是微调的 DelayMs(5); LCD_SPISend(COMMAND,0x2F); //开启相关电压 DelayMs(50); LCD_SPISend(COMMAND,0xAF); //显示开 LCD_SPISend(COMMAND,0xF8); LCD_SPISend(COMMAND,0x01); //此两条命令是设置升压比的 DelayMs(500); //不知此延时可否省去,不过了安全起见,初次调试保留为好。。
我是菜鸟 看书遇到问题向大家请教 在看到运放初期的晶体管电流源时产生了疑问 基本BJT镜像电流源里 书上把2个BJT的BE结上的电压都认为是0.7 故把这2个PN结都看成是恒压源模型 但在后面的WILDLAR电流源里  ...… 查看全部问答> |
今年年初,国务院总理召开了国务院常务会议,决定加快推进电信网、广播电视网和互联网的三网融合,在具备条件的情况下,广电可以经营增值电信业务和部分基础电信业务、互联网业务,符合条件的电信企业可以从事部分广播电视生产和传输,这样的问题已 ...… 查看全部问答> |
在protel 99se 里面,自动布线和交互式布线有什么区别?交互式布线是什么意思? 我是刚学着画pcb,(以前是看懂别人画的即可),有很多不懂,要请教大家,谢谢!… 查看全部问答> |
include <msp430g2231.h>unsigned int flag = 0;void main(){ WDTCTL = WDTPW +WDTHOLD; //STOP WDT // FLL_CTL0 |= XCAP14PF; //匹配14PF的负载电容 P1SEL &= ~BIT5; &nb ...… 查看全部问答> |
