今天是:2025年04月11日(星期五)
正在发生
2020年04月11日 | TM1637数码管显示STC51单片机驱动程序
2020-04-11 来源:eefocus
Coder : Farman
Date  : 2018-01-02
参考了厂家的TM1637数据手册,在此表示感谢。
#include   //包含52单片机头文件
#include "Delay.h"
sbit I2C_SCL = P2^1;   //定义模拟IIC总线的时钟线
sbit I2C_SDA = P2^0;   //定义模拟IIC总线的数据线
#define TM1637_BRIGHTNESS 7 // 0 - 7
void I2C_delay()
    nop_();
void I2C_start()
    I2C_SCL = 1;
    I2C_SDA = 1;
    I2C_delay();
    I2C_SDA = 0; // 时钟线设置为常态,低电平。
I2C 总线写1个字节
不包含应答位的检测
void I2C_write_byte(char byte_to_write)
    unsigned char i;
    for(i=0; i<8; i++)
        I2C_SCL = 0;
        I2C_SDA = byte_to_write & 0x01;
        I2C_delay();
        I2C_SCL = 1;
        I2C_delay();
        I2C_SCL = 0;
        I2C_delay();
        byte_to_write >>= 1;
    return;
void I2C_check_ack()
    // I2C 检查应答位,实际未检查,只发送了应答位时钟,认为TM1637工作正常
    I2C_SCL = 0;
    I2C_delay();//在第八个时钟下降沿之后延时5us,开始判断ACK 信号
    while(I2C_SDA)
    I2C_SCL = 1;
    I2C_delay();
    I2C_SCL=0;
void I2C_send_ack()
    I2C_SDA = 0;
    I2C_delay();
    I2C_SCL = 1;
    I2C_delay();
    I2C_SCL = 0;
    I2C_delay();
    I2C_SDA = 1;
    I2C_delay();
void I2C_stop()
    I2C_SCL = 0;
    I2C_delay();
    I2C_SDA = 0;
    I2C_delay();
    I2C_SCL = 1;
    I2C_delay();
    I2C_SDA = 1;
// TM1637模块操作函数
void TM1637_write_command_byte(unsigned char command)
    I2C_start();
    I2C_write_byte(command);
    I2C_check_ack();
    I2C_stop();
// bright : 0 - 7
void TM1637_display_switch_and_bright(bit enable_display, unsigned char bright)
    TM1637_write_command_byte(0x80 + (enable_display ? 0x08 : 0x00) + bright);
void TM1637_write_display_bytes(unsigned char first_addr,
                                unsigned char bytes_to_write[],
                                unsigned char num_of_bytes)
    unsigned char i;
    I2C_start();
    I2C_write_byte(0x40);
    I2C_check_ack();
    I2C_stop();
    I2C_start();
    I2C_write_byte(0xC0 + first_addr);
    I2C_check_ack();
    for(i=0; i    {
        I2C_write_byte(bytes_to_write[i]);
        I2C_check_ack();
    I2C_stop();
// addr: 0 - 5
void TM1637_write_display_byte(unsigned char addr, unsigned char segments)
    I2C_start();
    I2C_write_byte(0x40 + addr);
    I2C_check_ack();
    I2C_stop();
    I2C_start();
    I2C_write_byte(0xC0 + addr);
    I2C_check_ack();
    I2C_write_byte(segments);
    I2C_check_ack();
    I2C_stop();
code unsigned char TM1637_SEG_TAB[] =
     0x3F // 00111111 0
    ,0x06 // 00000110 1
    ,0x5B // 01011011 2
    ,0x4F // 01001111 3
    ,0x66 // 01100110 4
    ,0x6d // 01101101 5
    ,0x7d // 01111101 6
    ,0x07 // 00000111 7
    ,0x7F // 01111111 8
    ,0x6F // 01101111 9
    ,0x77 // 01110111 A
    ,0x7C // 01111100 b
    ,0x39 // 00111001 C
    ,0x5E // 01011110 d
    ,0x79 // 01111001 E
    ,0x71 // 01110001 F
void TM1637_show_digit(unsigned char pos, unsigned char digit, bit with_dot)
    TM1637_write_display_byte(pos, TM1637_SEG_TAB[digit] | (with_dot ? 0x20 : 0x00));
void TM1637_init()
    unsigned char i;
    TM1637_display_switch_and_bright(1, TM1637_BRIGHTNESS);
    for(i=0; i<6; i++)
        TM1637_write_display_byte(i, 0xFF);
    Delay200ms();
    for(i=0; i<6; i++)
        TM1637_write_display_byte(i, 0x00);
    Delay200ms();
    for(i=0; i<6; i++)
    Delay200ms();
    for(i=0; i<6; i++)
    Delay200ms();
void TM1637()
    unsigned char seg;
    unsigned char i, j;
    TM1637_init();
    while(1)
        for(i=0; i<16; i++)
            for(j=0; j<6; j++)
                TM1637_show_digit(j, i, 0);
            Delay1s();
HM International公司的发展小趣事
机顶盒,全称为数字视频变换盒,是现代家庭娱乐中不可或缺的重要设备。从广义上讲,任何与电视机连接的网络终端设备均可视为机顶盒,其发展历程涵盖了从模拟频道增补器到数字卫星、地面及有线电视机顶盒的广泛范畴。而从狭义角度看,机顶盒特指那些具备数字处理能力的设备,如IPTV机顶盒、DVB-S卫星机顶盒、DVB-T地面机顶盒及DVB-C有线电视机顶盒等。
机顶盒的核心功能在于接收并转换数字电视信号,使之能在传统或智能电视上播放。它不仅能接收来自有线电缆、卫星天线及宽带网络的信号,还能提供电子节目指南、网页浏览等增值服务。通过机顶盒,用户能够享受到高清乃至4K超高清的电视节目,体验更为细腻的画面和震撼的音效。此外,机顶盒还具备网络交互能力,支持在线购物、观看网络视频、玩游戏等多元化活动,使电视机从单向接收信息的设备转变为智能互动终端。
随着技术的不断进步,机顶盒正朝着高清化、智能化方向发展。未来,机顶盒将不仅限于基本的信号接收与解码功能,还将融入更多智能推荐、语音识别等先进技术,为用户提供更加个性化、便捷的娱乐体验。总之,机顶盒作为连接电视与互联网的桥梁,正以其丰富的功能和广泛的应用场景,不断满足用户日益增长的娱乐需求。
Elpida Memory公司的发展小趣事
尽管Elpida Memory已经不复存在,但其在DRAM领域的技术和经验仍然对全球半导体产业产生了深远的影响。Elpida Memory在技术研发、生产管理和市场营销等方面的经验,为后来的半导体企业提供了宝贵的借鉴和参考。同时,Elpida Memory的失败也提醒了半导体企业需要时刻保持警惕和创新精神,以应对日益激烈的市场竞争和技术变革。
Danaher Corporation公司的发展小趣事
丹纳赫集团一直重视科技创新和产品研发。在电子行业,丹纳赫集团不断推出具有创新性和竞争力的产品,如高精度测量仪器、自动化测试设备和电子制造解决方案等。这些产品不仅满足了客户对高质量、高效率生产的需求,还帮助丹纳赫集团在电子行业中树立了良好的品牌形象。
Grande Electronics Ltd公司的发展小趣事
确保遥控器中的电池电量充足,避免电池电量不足导致的发射问题。
Amkor公司的发展小趣事
如电池电量不足、电源线路断路或短路,导致发射电路无法正常工作。
Alliance Memory公司的发展小趣事
定期清洁遥控器表面的灰尘和污垢,避免按键接触不良等问题。
Spartan-6 and Virtex-6 FPGA Embedded Kit FAQ
1. Where can I purchase an Embedded kit?   2. How much do the Spartan-6 and Virtex-6 FPGA Embedded Kits cost? 3. When will I get my kit? 4. What are included in the Embedded Kits? 5. What expansion ports are avail ...…
ini多国语言unicode问题求助
我的多国语言用ini文件的方式来实现,在记事本中写好了多国语言后,保存为unicode编码。 在读取这个ini文件时查看内存中读出的S为 53 00 00 00,而在程序中自己定义的宽字节S在内存中则为53 00。 看起来读的unicode的ini文件中的字符好像多了2个 ...…
有关bufil的
求问bufif的功能是什么,比如说这段程序 bufif mybuf(out,in,enable)是什么意思? 刚学Verilog 数字系统设计 以后可能常来这边求教了!…
请问要从支持HL7协议的病人监护仪的网口读出数据和波形,谁会做?报酬详谈
请问要从支持HL7协议的病人监护仪的网口读出数据和波形,谁会做?报酬详谈 QQ:312969842…
usb驱动+钩子
谁有USB驱动+HOOK的例子和资料呀。 特别感谢!!!!…
求教C64x中EMIF中BE[7:0]的作用?
本帖最后由 dontium 于 2015-1-23 13:38 编辑 请大家帮忙,在C64x的EMIF在SDRAM接口中,如何通过BE[7:0]实现8bit、16bit、32bit、64bit的寻址方式? …
大哥大姐们求助!!!!
我用的NCP14025V的升压芯片但是纹拨太大,求教怎么解决啊,或者推荐别的芯片,实在不行我想把3.3V升压到7,8V再用别的芯片降到5V不知道可行否;…
利用6517A对惰性气体或高真空中的小型晶体高值电阻测量的典型误差来源
屏蔽与防护 为了降低静电干扰,利用具有地电位的导体包围样本和线缆(屏蔽)。 为了防止漏电流影响测量,利用具有同样电势的导体对至静电计[1]输入端的连接进行包围(防护)。测量电流时,需要将防护装置连接至电压源的LO端。 在高真空系统( ...…
用51单片机设计频率计并用lcd显示,我用加载了hex文件但是lcd没显示内容。解决者立...
用51单片机设计频率计并用lcd显示,我加载了hex文件但是lcd没显示内容。我用proteus仿真时用的是AT89c51,没有问题,结果也正确。实际硬件电路用的是STC89c52,结果不出来。该怎么解决啊/ 能完美解决者定当重谢,…
