今天是:2025年07月19日(星期六)
2020年07月19日 | S3C2440电阻触摸屏驱动设计
2020-07-19 来源:eefocus
实验:当触笔点击在触摸屏上时,SecureCRT上显示触点的X,Y坐标;
目的:测试电阻触摸屏驱动程序;
开发板:S3C2440
*版权所有(C)2015,ZJU
*文件名称:ts.c
*内容摘要:关于触摸屏的配置
*其它说明:开发板型号: TX2440
*    电阻屏
*当前版本:V1.0
*作    者:Frank
*完成日期:2015.12.22
#define  ADCCON (*(volatile unsigned int *)0x58000000) //ADC control register
#define  ADCTSC (*(volatile unsigned int *)0x58000004) //ADC Touch Screen Control Register
#define  ADCDLY (*(volatile unsigned int *)0x58000008) //ADC Start or interval delay register
#define  ADCDATA0 (*(volatile unsigned int *)0x5800000C) //ADC conversion data register
#define  ADCDATA1 (*(volatile unsigned int *)0x58000010) //ADC conversion data register
/*interrupt register*/
#define  SRCPND (*(volatile unsigned long *)0x4A000000)
#define  INTMSK (*(volatile unsigned long *)0x4A000008)
#define  INTPND (*(volatile unsigned long *)0x4A000010)
#define  INTOFFSET (*(volatile unsigned long *)0x4A000014)
#define  SUBSRCPND (*(volatile unsigned long *)0x4A000018)
#define  INTSUBMSK (*(volatile unsigned long *)0x4A00001C)
int xdata=0;
int ydata=0;
*函数名称:Ts_Init()
*功能描述:触摸屏工作初始化
*其他说明:配置ADC为触摸屏工作模式
*创建日期:2015.12.22
void Ts_Init(void)
/*1、设置AD转换时钟*/
ADCCON = (1 << 14) | (49 << 6); //AD转换频率=PCLK/(Val + 1),此处设为 1MHz
/*2、设置中断屏蔽位*/
INTMSK = ~(1 << 31);
INTSUBMSK = ~(1 << 9);
/*3、进入等待中断的模式*/
ADCTSC = 0xd3;
/***清除CPSR寄存器中的第7位I(IRQ disable),因为在start.S中关闭了中断****/
//这一步的目的是开启总中断
__asm__(
"mrs r0, cpsrn"
"bic r0, r0, #0x80n"
"msr cpsr_c, r0n"
*函数名称:Ts_Handler()
*功能描述:触摸屏中断处理
*其他说明:按下触摸屏后的中断处理
*创建日期:2015.12.22
void Ts_Handler(void)
/*1、启动XY坐标自动转换*/
ADCTSC = (1 << 2);
ADCCON |= (1 << 0);
/*2、等待转换完成*/
while(!(ADCCON & (1 << 15)));
/*3、获取坐标*/
xdata = ADCDATA0 & 0x3ff;
ydata = ADCDATA1 & 0x3ff;
/*4、清除按下中断*/
SUBSRCPND |= (1 << 9);
SRCPND = (1 << 31);
INTPND = (1 << 31);
/*5、进入等待弹起中断*/
ADCTSC = 0xd3;
ADCTSC |= (1 << 8);
while(1)
if (SUBSRCPND & (1 << 9))
break;
/*6、清除弹起中断*/
SRCPND = (1 << 31);
INTPND = (1 << 31);
//对读取到的X,Y坐标进行处理
printf("X is %d, Y is %dn", xdata, ydata);
printf("nr");
/*7、再次进入等待按下中断的状态*/
ADCTSC = 0xd3;
中断处理文件interrupt.c中触摸屏中断函数的调用程序:
*函数名称:handle_int()
*功能描述:中断处理函数
*其他说明:
void handle_int()
/*判断产生中断的中断源*/
unsigned long value = *(INTOFFSET);
switch (value)
case 31 :
Ts_Handler(); //触摸屏中断
break;
default :
break;
Defense Supply Center Columbus公司的发展小趣事
在电子行业,产品质量是企业生存和发展的关键。Defense Supply Center Columbus公司始终将质量管理放在首位,建立起一套完善的质量管理体系。公司严格按照国际标准进行生产和检测,确保每一件产品都符合质量要求。同时,公司还注重员工的培训和教育,提高员工的质量意识和操作技能。这些措施的实施,使得公司的产品质量得到了显著提升,赢得了客户的广泛赞誉。
东科半导体(DK)公司的发展小趣事
东科半导体(DK)公司一直将技术创新作为发展的核心驱动力。公司投入大量资金和资源用于研发,先后开发出AC/DC、同步整流、第三代半导体氮化镓芯片等先进技术。其中,东科半导体的同步整流芯片研发成功,其独特的两引脚封装技术为全球首创,为公司赢得了行业内的独家竞争优势。这一技术的成功应用,不仅提升了公司产品的性能,也进一步巩固了东科在电源管理芯片市场的领先地位。
ATO SOLUTION公司的发展小趣事
在电子行业的激烈竞争中,ATO SOLUTION公司通过一项创新性的技术突破,成功引领了市场的新潮流。该公司研发出了一款高效能的半导体芯片,极大地提升了电子设备的性能和能效比。这一技术的问世,迅速获得了行业内外的广泛关注和认可,为公司赢得了大量合作伙伴和客户,奠定了市场领先地位。
Corsair Memory Inc公司的发展小趣事
随着公司的发展,Corsair Memory Inc不仅局限于内存产品的生产,还积极扩大业务范围。其中,收购SCUF Gaming是Corsair在扩展业务版图上的重要一步。这一收购使Corsair得以进入游戏外设市场,进一步丰富了其产品线,也为其带来了更多的增长机会。
深圳杜因特(DOINGTER)公司的发展小趣事
经过数年的技术研发和产品迭代,杜因特成功开发出多款高性能的MOS场效应管产品,这些产品广泛应用于开关电源、液晶电视、充电器等多个领域。随着产品质量的不断提升和市场份额的逐步扩大,杜因特逐渐在电子行业树立了良好的品牌形象。
BOPLA公司的发展小趣事
在国内市场取得一定成绩后,BOPLA开始将目光投向海外市场。通过参加国际电子展会、与海外客户建立合作关系等方式,公司成功将产品打入国际市场。同时,BOPLA还积极调整产品策略,根据不同国家和地区的市场需求,推出定制化的电子元件产品,进一步扩大了市场份额。
有在吴江华冠通讯工作的朋友吗?
请问这里有在吴江华冠工作的朋友吗? 有问题想请教, 谢谢!…
S3c610 Codec移植的工作经验总结[bootloader级]
1. S3C6410与WM9713的I2S,AC97,PCM相比较: 1.I2S,AC97,PCM是不同的,各是各的,三者时序不同,要双方通信,必须要是 同一种时序,要么均是I2S,要么均是AC97,要么均是PCM 2.S3C6410的I2S,AC97,PCM复用同一组Pin脚,但同一时间只能用一种类型 ...…
不同时钟域的数据传输问题
单片机读写CPLD的时钟、SDRAM的时钟、还有像素时钟都是不同的 ,这个问题怎么处理?…
关于mini2440 mmu
前几天拿到一个mini2440,板子很精致。400M的主频,在跑uCos2的时候,发现速度很慢,可是却不知道为什么。怀疑是cache没有利用起来,可是我对于MMU也不是很明白,有没有点建议? void MMU_Init(void) {     int i,j;     / ...…
中九破解
1231111111111111111111111111111111…
C#在wince下的双缓冲如何实现?
用GDI绘图,非常闪砾,想用双缓冲实现,可发现网上搜到的双缓冲例子中用到的类,在wince下都没有,请问有人做过双缓冲绘图吗?如何实现,希望可以给出关键代码,谢谢…
Altera的EPCS是否存在校验码
对于FPGA芯片,在上电的时候从EPCS内加载配置文件的信息,我想知道数据从EPCS传输到FPGA的过程中,是否存在冗余校验,就像422,485等通信过程中存在的校验。或者,我想为FPGA的*.pof文件内是否存有数据的冗余校验信息。谢谢…
FirmwareLib的应用及C++工程建立过程杂谈
Firmware Lib的应用及C++工程建立过程杂谈Firmware Lib下在地址:http://www.st.com/stonline/products/support/micro/files/um0427.zipFirmware Lib用户手册下载地址:http://www.st.com/stonline/products/literature/um/134 ...…
【求助】timer_a如何设置进入定时器溢出中断
在增计数模式下设置了: CCR0 = 0x0fff; TACTL = TASSEL1 + MC1 + TAIE CCTL0 = CCIE; GIE 也置位了, 在TAR计数到0xffff时不能进中断!…
