今天是:2024年10月10日(星期四)
2020年10月10日 | 基于CC430设计的超低功耗MCU射频应用方案
2020-10-10 来源:elecfans
CC430系列是TI公司的集成了RF收发器的超低功耗MCU系统级芯片(SoC),器件具有功能强大的MSP430™ 16位RISC CPU,16位居寄存器,以及常数发生器,以得到最高的代码效率.工作电压1.8V-3.6V,CPU工作时的功耗160 µA/MHz,主要用在建筑物自动化,测试测量和财产跟踪.本文介绍CC430主要特性, CC430F613x和CC430F513x的功能方框图, 小于1GHz无线电方框图,以及CC430F61xx和CC430F51xx的典型应用电路图与材料清单.
The Texas Instruments CC430 family of ultralow-power microcontroller system-on-chip with integrated RF transceiver cores consists of several devices featuring different sets of peripherals targeted for a wide range of applicaTIons. The architecture, combined with five low-power modes is opTImized to achieve extended battery life in portable measurement applicaTIons. The device features the powerful MSP430™ 16-bit RISC CPU, 16-bit registers, and constant generators that contribute to maximum code efficiency.
The CC430 family provides a tight integration between the microcontroller core, its peripherals, software, and the RF transceiver, making these true system-on-chip solutions easy to use as well as improving performance.
CC430主要特性:
True System-on-Chip (SoC) for Low-Power Wireless Communication Applications
Wide Supply Voltage Range: 1.8 V to 3.6 V
Ultralow Power Consumption:
CPU Active Mode (AM): 160 µA/MHz
Standby Mode (LPM3 RTC Mode):2.0 µA
Off Mode (LPM4 RAM Retention): 1.0 µA
Radio in RX: 15 mA, 250 kbps, 915 MHz
MSP430 System and Peripherals
16-Bit RISC Architecture, Extended Memory, 50-ns Instruction Cycle Time
Wake-Up From Standby Mode in Less Than 6 µs
Flexible Power Management System with SVS and Brownout
Unified Clock System with FLL
16-Bit Timer TA0, Timer_A with Five Capture/Compare Registers
16-Bit Timer TA1, Timer_A with Three Capture/Compare Registers
Hardware Real-Time Clock
Two Universal Serial Communication Interfaces
USCI_A0 supporting UART, IrDA, SPI
USCI_B0 supporting I2C, SPI
12-Bit A/D Converter With Internal Reference, Sample-and-Hold, and Autoscan Features (Only CC430F613x and CC430F513x) Comparator
The CC430 has one active mode and five software selectable low-power modes of operation. An interrupt event can wake up the device from any of the low-power modes, service the request, and restore back to the low-power mode on return from the interrupt program.
The following six operating modes can be configured by software:
• Active mode (AM)
– All clocks are active
• Low-power mode 0 (LPM0)
– CPU is disabled
– ACLK and SMCLK remain active, MCLK is disabled
– FLL loop control remains active
• Low-power mode 1 (LPM1)
– CPU is disabled
– FLL loop control is disabled
• Low-power mode 2 (LPM2)
– CPU is disabled
– MCLK and FLL loop control and DCOCLK are disabled
– DCO’s dc-generator remains enabled
– ACLK remains active
• Low-power mode 3 (LPM3)
– CPU is disabled
– MCLK, FLL loop control, and DCOCLK are disabled
– DCO’s dc-generator is disabled
• Low-power mode 4 (LPM4)
– CPU is disabled
– ACLK is disabled
– Crystal oscillator is stopped
– Complete data retention
图1.CC430F613x功能方框图
图2. CC430F612x功能方框图
图3. CC430F513x功能方框图
图4. 小于1GHz无线电方框图
图5. CC430F61xx典型应用电路图
图6. CC430F51xx典型应用电路图
应用电路图材料清单:
请教一下,arm下linux正在运行,通过串口连接到电脑上,怎样把电脑上的文件传到arm里边的linux去?或者给个关键词我百度一下~… 查看全部问答> |
当初选择做技术,最主要的原因,是出于对科学技术的纯洁性的热爱,对人情世故的厌恶。但专于技术的工程师,要想有份有前途的工作,找到可以长久做下去的公司。“良禽择木而栖,贤臣择主而侍”,遇到下面五类性格的老板,能走多远就走多远。在此罗列 ...… 查看全部问答> |
想用TIM的外部时钟模式1的下做脉冲计数,可是仔细看了触发源很郁闷TS[2:0]:触发选择这3位选择用于同步计数器的触发输入。000:内部触发器0(ITR0),TIM1 001:内部触发器0(ITR1),TIM2 010:内部触发器0(ITR1),TIM3 011:内部 ...… 查看全部问答> |
430解码红外好久勒 怎么也进展 ,这个程序不知道错哪了 调了好久也没调出来 纠结呀! #include <msp430x14x.h>#include \"TFT_LCD24.h\"//#include \"char.h\"#include \"delay.h\" //数组a依次储存用户码、用户反码与键数 ...… 查看全部问答> |
