今天是:2024年12月16日(星期一)
正在发生
2020年12月16日 | TQ210 —— s5pv210 lowlevel_init.S分析(uboot第一阶段)
2020-12-16 来源:eefocus
 * Memory Setup stuff - taken from blob memsetup.S
 * Copyright (C) 1999 2000 2001 Erik Mouw (J.A.K.Mouw@its.tudelft.nl) and
 *                     Jan-Derk Bakker (J.D.Bakker@its.tudelft.nl)
 * Modified for the Samsung SMDK2410 by
 * (C) Copyright 2002
 * David Mueller, ELSOFT AG,
 * See file CREDITS for list of people who contributed to this
 * project.
 * This program is free software; you can redistribute it and/or
 * modify it under the terms of the GNU General Public License as
 * published by the Free Software Foundation; either version 2 of
 * the License, or (at your option) any later version.
 * This program is distributed in the hope that it will be useful,
 * but WITHOUT ANY WARRANTY; without even the implied warranty of
 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
 * GNU General Public License for more details.
 * You should have received a copy of the GNU General Public License
 * along with this program; if not, write to the Free Software
 * Foundation, Inc., 59 Temple Place, Suite 330, Boston,
 * MA 02111-1307 USA
#include
#include
#include
#include "tq210_val.h"
@ 讲start.S的时候已经说过这个TEXT_BASE了
_TEXT_BASE:
.word TEXT_BASE
.globl lowlevel_init
lowlevel_init:
push {lr}   @ 将上一个函数的返回地址压入栈中
/* check reset status  */
@ 检查复位标志,如果是睡眠唤醒,跳过接下来的初始化
ldr r0, =(ELFIN_CLOCK_POWER_BASE+RST_STAT_OFFSET) @ 跳转到目的地Reset Control Register的地址传送给r0 Address = 0xE010_A000 =0xE010_0000+0xA000
ldr r1, [r0]  @ 将存储器地址为 R0(内存储的值) 的字数据读入寄存器 R1
bic r1, r1, #0xfff6ffff   @将r1与0xfff6ffff的反码按位进行与运算(既和0xfff6ffff进行与非运算),并写入r1;结合上一步,可知,这一步的作用是16和19bit置一,其他位清零
cmp r1, #0x10000  @ 判断16bit是不是等于1
beq wakeup_reset_pre  @ 如果是从睡眠状态唤醒,就跳转到wakeup_reset_pre,既跳过接下来的初始化
    cmp r1, #0x80000    @ 判断是不是从深度空闲(Deep-IDLE)状态唤醒
beq wakeup_reset_from_didle   @ 如果是,就跳转到wakeup_reset_from_didle
/* IO Retention release */
ldr r0, =(ELFIN_CLOCK_POWER_BASE + OTHERS_OFFSET)  @ 将跳转目的地址MISC Register的地址传送给r0   Address = 0xE010_E000 =0xE010_0000+0xE000
ldr r2, =IO_RET_REL  @将IO_RET_REL( ((1 << 31) | (1 << 29) | (1 << 28)) )存入r2
    orr r1, r1, r2  @ 将r1和r2的值进行或运算,结果存入r1
str r1, [r0]  @ 将r1的值写入以r0内的值为地址的内存空间
/* Disable Watchdog */
@ 关闭看门狗
ldr r0, =ELFIN_WATCHDOG_BASE /* 0xE2700000 */
mov r1, #0
str r1, [r0]
/* SRAM(2MB) init for SMDKC110 */
/* GPJ1 SROM_ADDR_16to21 */
@ 配置sram引脚,16位数据宽度,22位地址宽度
ldr r0, =ELFIN_GPIO_BASE
ldr r1, [r0, #GPJ1CON_OFFSET]
bic r1, r1, #0xFFFFFF
ldr r2, =0x444444
orr r1, r1, r2
str r1, [r0, #GPJ1CON_OFFSET]
ldr r1, [r0, #GPJ1PUD_OFFSET]
ldr r2, =0x3ff
bic r1, r1, r2
str r1, [r0, #GPJ1PUD_OFFSET]
/* GPJ4 SROM_ADDR_16to21 */
ldr r1, [r0, #GPJ4CON_OFFSET]
bic r1, r1, #(0xf<<16)
ldr r2, =(0x4<<16)
orr r1, r1, r2
str r1, [r0, #GPJ4CON_OFFSET]
ldr r1, [r0, #GPJ4PUD_OFFSET]
ldr r2, =(0x3<<8)
bic r1, r1, r2
str r1, [r0, #GPJ4PUD_OFFSET]
/* CS0 - 16bit sram, enable nBE, Byte base address */
ldr r0, =ELFIN_SROM_BASE /* 0xE8000000 */
mov r1, #0x1
str r1, [r0]
/* PS_HOLD pin(GPH0_0) set to high */
@ 设置PMIC(Power Management IC)控制引脚,既电源管理ic引脚(基于I2C)
ldr r0, =(ELFIN_CLOCK_POWER_BASE + PS_HOLD_CONTROL_OFFSET)
ldr r1, [r0]
orr r1, r1, #0x300
orr r1, r1, #0x1
str r1, [r0]
/* when we already run in ram, we don't need to relocate U-Boot.
* and actually, memory controller must be configured before U-Boot
* is running in ram.
/*下面的代码事实上只是判断pc和_TEXT_BASE(0X23e00000)的最高两位是否相同*/
     /* 根据s5pv210的数据手册可知,首先,系统会运行固化在irom的BL0,紧接着会从外部nand
      * 或sdcard等设备读取前16K的BL1代码到IRAM中的0xD0020000处。然后从0xD0020010处运行(因为前16byte是校验和的值)
      * BL1的作用是初始化DRAM,拷贝BL2到DRAM中_TEXT_BASE(0X23e00000)处,然后跳到DRAM中运行
      * 因此可以通过最高两位来判断代码是在哪里运行
      * 同时可知,当代码已经就在DRAM中运行时,就必须跳过DRAM的初始化
ldr r0, =0xff000fff
bic r1, pc, r0 /* r0 <- current base addr of code */
ldr r2, _TEXT_BASE /* r1 <- original base addr in ram */
bic r2, r2, r0 /* r0 <- current base addr of code */
cmp     r1, r2                  /* compare r0, r1                  */
beq     1f /* r0 == r1 then skip sdram init   */
/* init PMIC chip */
#ifdef CONFIG_TQ210_IIC_PM_CHIP
bl PMIC_InitIp
#endif
/* init system clock */
@ 时钟初始化 PLL初始化,要想看懂此汇编,请查看datsheet中,clk control章节
bl system_clock_init
/* Memory initialize */
@ 内存初始化
bl mem_ctrl_asm_init
1:
/* for UART */
@ 串口初始化,要看懂此汇编, 请查看datsheet中, 请查看串口章节
bl uart_asm_init
bl tzpc_init
@ 这段不执行
#if defined(CONFIG_ONENAND)
bl onenandcon_init
#endif
    @ nand初始化
#if defined(CONFIG_NAND)
/* simple init for NAND */
bl nand_asm_init
#endif
ldr r1, [r0]
bic r1, r1, #0xfffeffff
cmp r1, #0x10000
/* ABB disable */
ldr r0, =0xE010C300
orr r1, r1, #(0x1<<23)
str r1, [r0]
/* Print 'K' */
ldr r0, =ELFIN_UART_CONSOLE_BASE
ldr r1, =0x4b4b4b4b
str r1, [r0, #UTXH_OFFSET]
pop {pc} @ 返回到start.S
wakeup_reset_from_didle: @ 从深度睡眠中唤醒
/* Wait when APLL is locked */
ldr r0, =ELFIN_CLOCK_POWER_BASE
lockloop:
ldr r1, [r0, #APLL_CON0_OFFSET]
and r1, r1, #(1<<29)
cmp r1, #(1<<29)
bne lockloop @ 这里使用循环
beq exit_wakeup
wakeup_reset_pre:
mrc p15, 0, r1, c1, c0, 1 @Read CP15 Auxiliary control register
and r1, r1, #0x80000000 @Check L2RD is disable or not
cmp r1, #0x80000000
bne wakeup_reset @if L2RD is not disable jump to wakeup_reset
bl disable_l2cache
bl v7_flush_dcache_all
/* L2 cache enable at sleep.S of kernel
* bl enable_l2cache
#ifdef CONFIG_TQ210
bl enable_l2cache
#endif
wakeup_reset:
bl tzpc_init
bl onenandcon_init
#endif
bl nand_asm_init
#endif
exit_wakeup:
/*Load return address and jump to kernel*/
ldr r0, =(INF_REG_BASE+INF_REG0_OFFSET)
ldr r1, [r0] /* r1 = physical address of s5pc110_cpu_resume function*/
mov pc, r1 /*Jump to kernel */
nop
nop
 * system_clock_init: Initialize core clock and bus clock.
 * void system_clock_init(void)
system_clock_init:
   /* 这一段的作用是将Clock Source Control Registers值清空
    * 具体的作用是将VPLL_SEL、EPLL_SEL、MPLL_SEL和APLL_SEL的时钟源设置为FINVPLL,将MUX_MSYS_SEL、MUX_DSYS_SEL和MUX_PSYS_SEL时钟源设置为SCLKMPLL
    * 将ONENAND_SEL时钟源设置为HCLK_PSYS
    * 为什么这样设置,因为未设置 PLL 和各种分频系数之前,我们不能使用 PLL,为了保险起见,暂时直接使用频率较低
    * 的外接的 24MHz 晶振,待设置好 PLL 和分频系数后再重新设置各种时钟开关
ldr r0, =ELFIN_CLOCK_POWER_BASE @0xe0100000
/* Set Mux to FIN */
ldr r1, =0x0
str r1, [r0, #CLK_SRC0_OFFSET]
ldr r1, =APLL_LOCKTIME_VAL   @将APLL_LOCKTIME_VAL(0x2cf)装入r1
str r1, [r0, #APLL_LOCK_OFFSET]  @将r1内的值装入地址为(r0内的值+CLK_SRC0_OFFSET = 0xe0100000)的内存,即设置APLL的锁定周期
* A PLL requires locking period when input frequency is changed or frequency division (multiplication) values are
     * changed.PLL_LOCK register specifies this locking period, which is based on PLL’s source clock. During this
     * period, output will be low state
/* Disable PLL */
#if defined(CONFIG_CHECK_MPLL_LOCK)
retryloop:
#endif
ldr r1, =0x0
str r1, [r0, #APLL_CON0_OFFSET]  @ 将APLL控制寄存器的值清空,这个寄存器的第31位置零关闭APLL 25-16bit配置MDIV的分频
@ 13-8bit配置PDIV的分频 2-0bit配置SDIV的分频
ldr r1, =0x0
str r1, [r0, #MPLL_CON_OFFSET]   @ 配置MPLL
ldr r1, =0x0
str r1, [r0, #MPLL_CON_OFFSET]   @ 重复配置MPLL,确保MPLL配置成功
ldr    r1, [r0, #CLK_DIV0_OFFSET] @ Clock Divider Control Register(0xe0100300)
ldr r2, =CLK_DIV0_MASK             @ CLK_DIV0_MASK(0x7fffffff)
bic r1, r1, r2                     @ 首先清零
ldr r2, =CLK_DIV0_VAL              @ CLK_DIV0_VAL
orr r1, r1, r2
str r1, [r0, #CLK_DIV0_OFFSET]
    *CLK_DIV0_VAL = ((0<    *   |(3<    *#define APLL_RATIO         0
    *#define A2M_RATIO          4
    *#define HCLK_MSYS_RATIO    8
    *#define PCLK_MSYS_RATIO    12
    *#define HCLK_DSYS_RATIO    16
    *#define PCLK_DSYS_RATIO    20
    *#define HCLK_PSYS_RATIO    24
    *#define PCLK_PSYS_RATIO    28
ldr r1, =APLL_VAL
ldr r1, =MPLL_VAL
ldr r1, =VPLL_VAL
str r1, [r0, #VPLL_CON_OFFSET]
#if defined(CONFIG_EVT1)
ldr r1, =AFC_ON
str r1, [r0, #APLL_CON1_OFFSET]
#endif
mov r1, #0x10000
1: subs r1, r1, #1    @ 延时 将r1-1的值存入r1
bne 1b                @ 如果运算结果不等零(即CPSR寄存器标志位Z不等于一),退回到前面标签“1”处执行  当 CPSR 寄存器中的 Z
                          @ 条件码置位时(即前面的计算结果为零),则顺序执行(即运行接下来的:ldr   r1, [r0, #CLK_SRC0_OFFSET])
DESIGNERSYSTEMS公司的发展小趣事
DESIGNERSYSTEMS公司意识到,要在电子行业持续发展,必须不断拓展市场。他们积极寻求跨界合作的机会,与汽车、医疗、航空航天等多个行业的领军企业建立了合作关系。通过跨界合作,DESIGNERSYSTEMS不仅将自身的技术优势应用于更广泛的领域,还从合作伙伴那里学到了更多行业知识和经验,进一步提升了自身的综合实力。
Carlo Gavazzi公司的发展小趣事
随着技术的不断进步和市场需求的不断变化,Carlo Gavazzi公司始终保持着创新的活力。公司不断推出新产品,从最初的电气元件到后来的控制和自动化解决方案,再到能源管理和节能方案,产品线日益丰富。这种多元化的产品策略不仅满足了客户的多样化需求,也为公司带来了更广阔的市场空间。
Cofan Usa Inc公司的发展小趣事
在追求经济效益的同时,Cofan Usa Inc公司也注重可持续发展和社会责任。公司积极推广环保理念,采用环保材料和节能技术,减少生产过程中的环境污染。同时,公司还积极参与社会公益事业,为社会发展和环境保护贡献自己的力量。
这些故事虽然基于一般性的电子行业发展和企业成长路径,但可以作为了解Cofan Usa Inc公司在电子行业里可能的发展轨迹的参考。如果需要更具体和详细的故事,建议查阅该公司的官方资料、行业报告或相关新闻报道。
Hi-Tron Semiconductor Corp公司的发展小趣事
随着全球市场的日益开放和竞争的加剧,Cofan Usa Inc公司开始实施国际化战略。公司在海外设立分支机构和研发中心,积极寻求与国际知名企业的合作机会。通过引进国际先进的技术和管理经验,公司不断提升自身的创新能力和国际化水平。
Elcoma公司的发展小趣事
随着公司业务的不断发展,Elcoma意识到要进一步拓展市场,必须与国际同行建立合作关系。他们积极寻求与全球知名电子企业的合作机会,通过技术交流和合作研发,不断提升自身的技术水平和市场竞争力。同时,Elcoma还积极参与国际电子展会和论坛,展示公司的最新技术和产品,吸引了众多国际客户的关注。这些国际合作不仅为Elcoma带来了更多的商业机会,也进一步提升了公司的国际影响力。
Engineered Components Co公司的发展小趣事
Engineered Components Co(ECC)公司成立于XXXX年,由几位在电子制造领域有丰富经验的工程师共同创立。他们看到了电子行业中对于高质量、高精度电子元件的迫切需求,因此决定专注于此领域。ECC在创立初期就确立了以客户需求为导向,以技术创新为驱动的发展战略。他们通过自主研发,生产出了第一批高精度电子连接器,并在市场上获得了良好的反响。
protel模拟电路仿真详解.
protel模拟电路仿真详解. 文件大小: 441 K 软件等级: ★★★ 软件类别: 国产软件…
DSP音频频率扫频仪
本帖最后由 paulhyde 于 2014-9-15 09:00 编辑 TI 的DSP设计大赛中,有个做音频频率数字扫频仪的,有哪位高手可以给我讲解下这个方案图么?  …
SPWM与SVPWM的比较
SPWM与SVPWM的比较作者:power   来源:网络   点击: 699    日期:2007-09-04    SPWM与SVPWM的比较                  SPWM原理  ...…
请教一下关于用PB定制wince的问题
我用PB定制了wince后,在最后编译的时候提示:first-chance exception  in gwes.exe (0xc0000005:access violation) 就是不能出来wince界面,只出来一个黑框,没有我的电脑,回收站等 请问这是什么原因呢?…
问个硬件方面问题!
请问大家一个问题,自认为在eeworld是高手如林的地方! 865GV双通道(注意是865GV双通道)主板能用一条好的DDR内存带一条坏的DDR内存点亮主板,其它大部分主板都不行!请大家解析一下这其中的原因! 现在想求一个有865GV同样功能的上DDR2内存的主 ...…
请教在V3.41中定义变量的问题
出问题的代码如下: #pragma memory = dataseg(DATA16_N) float fa; ... 我的本意是想把变量定义在非易失RAM中(0x200~5ff),在编译后,从第二句开始就提示如下警告信息: Warning[Be008]: a #pragma dataseg is active but is not applica××e to ...…
您还在为pdg文件打不开而发愁吗?pdg转pdf工具帮您解决
很多时候我们都要下载一些电子资料,有许多是pdg格式的资料,这种格式的资料不仅需要专门的软件进行查阅,而且看起来很不方便。我给大家推荐的这个工具就可以帮大家解决很多问题。它不仅能将pdg文件转换为图像文件,还能将图像文件转换为pdf格式的 ...…
FPGA与ARM速度比较?
都说FPGA速度比ARM快,具体指哪些方面呢?…
