今天是:2024年12月16日(星期一)
2020年12月16日 | TQ210——S5PV210 uboot顶层config.mk分析
2020-12-16 来源:eefocus
# (C) Copyright 2000-2006
# Wolfgang Denk, DENX Software Engineering, wd@denx.de.
# See file CREDITS for list of people who contributed to this
# project.
# This program is free software; you can redistribute it and/or
# modify it under the terms of the GNU General Public License as
# published by the Free Software Foundation; either version 2 of
# the License, or (at your option) any later version.
# This program is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
# GNU General Public License for more details.
# You should have received a copy of the GNU General Public License
# along with this program; if not, write to the Free Software
# Foundation, Inc., 59 Temple Place, Suite 330, Boston,
# MA 02111-1307 USA
# $@ 表示目标文件
# $^ 表示所有的依赖文件
# $< 表示第一个依赖文件
# $? 表示比目标还要新的依赖文件列表
# config.mk功能是配置单板信息和编译环境,被Makefile调用
# 此脚本在uboot顶层目录。如果目标存放目录不等于源码目录(这里不会执行)
ifneq ($(OBJTREE),$(SRCTREE))
ifeq ($(CURDIR),$(SRCTREE))
dir :=
else
dir := $(subst $(SRCTREE)/,,$(CURDIR))
endif
obj := $(if $(dir),$(OBJTREE)/$(dir)/,$(OBJTREE)/)
src := $(if $(dir),$(SRCTREE)/$(dir)/,$(SRCTREE)/)
$(shell mkdir -p $(obj))
# 所以上面的几行都不会执行,会执行下面这个,obj和src为空
else
obj :=
src :=
endif
# clean the slate ...
# 清楚标志
PLATFORM_RELFLAGS =
PLATFORM_CPPFLAGS =
PLATFORM_LDFLAGS =
# When cross-compiling on NetBSD, we have to define __PPC__ or else we
# will pick up a va_list declaration that is incompatible with the
# actual argument lists emitted by the compiler.
# [Tested on NetBSD/i386 1.5 + cross-powerpc-netbsd-1.3]
# ARCH=arm,这段不会执行
ifeq ($(ARCH),ppc)
ifeq ($(CROSS_COMPILE),powerpc-netbsd-)
PLATFORM_CPPFLAGS+= -D__PPC__
endif
ifeq ($(CROSS_COMPILE),powerpc-openbsd-)
endif
endif
ifeq ($(ARCH),arm)
PLATFORM_CPPFLAGS+= -D__ARM__
endif
endif
endif
CONFIG_SHELL := $(shell if [ -x "$$BASH" ]; then echo $$BASH;
else if [ -x /bin/bash ]; then echo /bin/bash;
else echo sh; fi ; fi)
# 除了darwin-pcc外其他都采用gcc编译器
ifeq ($(HOSTOS)-$(HOSTARCH),darwin-ppc)
HOSTCC = cc
else
HOSTCC = gcc
endif
# HOSTCPPFLAGS的值为空,HOSTCFLAGS = -Wall -Wstrict-prototypes -O2
# -fomit-frame-pointer
HOSTCFLAGS = -Wall -Wstrict-prototypes -O2 -fomit-frame-pointer
HOSTSTRIP = strip
# Option checker (courtesy linux kernel) to ensure
# only supported compiler options are used
# cc-option用于检查编译器CC是否支持某选项。将2个选项作为参数传递给cc-option函数,
# 该函数调用CC编译器检查参数1是否支持,若支持则函数返回参数1,
# 否则返回参数2 (因此CC编译器必须支# 持参数1或参数2,若两个都不支持则会编译出错)
# 可以像下面这样调用cc-option函数,并将支持的选项添加到FLAGS中:
# FLAGS +=$(call cc-option,option1,option2)
cc-option = $(shell if $(CC) $(CFLAGS) $(1) -S -o /dev/null -xc /dev/null
> /dev/null 2>&1; then echo "$(1)"; else echo "$(2)"; fi ;)
# Include the make variables (CC, etc...)
# 下面一些是定义交叉工具链的集合
AS = $(CROSS_COMPILE)as
LD = $(CROSS_COMPILE)ld
CC = $(CROSS_COMPILE)gcc
CPP = $(CC) -E
AR = $(CROSS_COMPILE)ar
NM = $(CROSS_COMPILE)nm
LDR = $(CROSS_COMPILE)ldr
STRIP = $(CROSS_COMPILE)strip
OBJCOPY = $(CROSS_COMPILE)objcopy
OBJDUMP = $(CROSS_COMPILE)objdump
RANLIB = $(CROSS_COMPILE)RANLIB
# 加载产生的单板配置文件autoconf.mk和config.mk,均在include目录下
# config.mk中内容是ARCH CPU BOARD VENDOR SOC5个变量信息
# autoconf.mk为单板配置宏的集合,打开/关闭 用 y/n表示
# Load generated board configuration
sinclude $(OBJTREE)/include/autoconf.mk
ifdef ARCH
sinclude $(TOPDIR)/$(ARCH)_config.mk # include architecture dependend rules
endif
ifdef CPU
sinclude $(TOPDIR)/cpu/$(CPU)/config.mk # include CPUspecific rules
endif
ifdef SOC
sinclude $(TOPDIR)/cpu/$(CPU)/$(SOC)/config.mk # include SoC specific rules
endif
ifdef VENDOR
BOARDDIR = $(VENDOR)/$(BOARD)
else
BOARDDIR = $(BOARD)
endif
ifdef BOARD
sinclude $(TOPDIR)/board/$(BOARDDIR)/config.mk # include board specific rules
endif
ifneq (,$(findstring s,$(MAKEFLAGS)))
ARFLAGS = cr
else
ARFLAGS = crv
endif
RELFLAGS= $(PLATFORM_RELFLAGS)
DBGFLAGS= -g # -DDEBUG
OPTFLAGS= -Os #-fomit-frame-pointer
ifndef LDSCRIPT
#LDSCRIPT := $(TOPDIR)/board/$(BOARDDIR)/u-boot.lds.debug
ifeq ($(CONFIG_NAND_U_BOOT),y)
LDSCRIPT := $(TOPDIR)/board/$(BOARDDIR)/u-boot-nand.lds
else
endif
endif
OBJCFLAGS += --gap-fill=0xff
gccincdir := $(shell $(CC) -print-file-name=include)
CPPFLAGS := $(DBGFLAGS) $(OPTFLAGS) $(RELFLAGS)
-D__KERNEL__
ifneq ($(TEXT_BASE),)
CPPFLAGS += -DTEXT_BASE=$(TEXT_BASE)
endif
CPPFLAGS += -I$(OBJTREE)/include2 -I$(OBJTREE)/include
endif
CPPFLAGS += -I$(TOPDIR)/include
CPPFLAGS += -fno-builtin -ffreestanding -nostdinc
-isystem $(gccincdir) -pipe $(PLATFORM_CPPFLAGS)
# 没有定义BUILD_TAG,执行else分支,赋值CFLAGS
ifdef BUILD_TAG
CFLAGS := $(CPPFLAGS) -Wall -Wstrict-prototypes
-DBUILD_TAG='"$(BUILD_TAG)"'
else
endif
CFLAGS += $(call cc-option,-fno-stack-protector)
# avoid trigraph warnings while parsing pci.h (produced by NIOS gcc-2.9)
# this option have to be placed behind -Wall -- that's why it is here
# 不执行
ifeq ($(ARCH),nios)
ifeq ($(findstring 2.9,$(shell $(CC) --version)),2.9)
CFLAGS := $(CPPFLAGS) -Wall -Wno-trigraphs
endif
endif
# $(CPPFLAGS) sets -g, which causes gcc to pass a suitable -g # option to the assembler. # CPPFLAGS设置了-g参数 AFLAGS_DEBUG := # turn jbsr into jsr for m68k ifeq ($(ARCH),m68k) ifeq ($(findstring 3.4,$(shell $(CC) --version)),3.4) AFLAGS_DEBUG := -Wa,-gstabs,-S endif endif AFLAGS := $(AFLAGS_DEBUG) -D__ASSEMBLY__ $(CPPFLAGS) # 设置uboot的链接选项 LDFLAGS += -Bstatic -T $(LDSCRIPT) $(PLATFORM_LDFLAGS) ifneq ($(TEXT_BASE),) LDFLAGS += -Ttext $(TEXT_BASE) endif # Location of a usable BFD library, where we define "usable" as # "built for ${HOST}, supports ${TARGET}". Sensible values are # - When cross-compiling: the root of the cross-environment # - Linux/ppc (native): /usr # - NetBSD/ppc (native): you lose ... (must extract these from the # binutils build directory, plus the native and U-Boot include # files don't like each other) # # So far, this is used only by tools/gdb/Makefile. # 不是arm架构,不执行 ifeq ($(HOSTOS)-$(HOSTARCH),darwin-ppc) BFD_ROOT_DIR = /usr/local/tools else ifeq ($(HOSTARCH),$(ARCH)) # native BFD_ROOT_DIR = /usr else #BFD_ROOT_DIR = /LinuxPPC/CDK# Linux/i386 #BFD_ROOT_DIR = /usr/pkg/cross# NetBSD/i386 BFD_ROOT_DIR = /opt/powerpc endif endif ifeq ($(PCI_CLOCK),PCI_66M) CFLAGS := $(CFLAGS) -DPCI_66M endif ######################################################################### # 输出这些信息为环境变量 export CONFIG_SHELL HPATH HOSTCC HOSTCFLAGS CROSS_COMPILE AS LD CC CPP AR NM STRIP OBJCOPY OBJDUMP MAKE export TEXT_BASE PLATFORM_CPPFLAGS PLATFORM_RELFLAGS CPPFLAGS CFLAGS AFLAGS ######################################################################### # 指定隐含的编译规则,例如:根据以上的定义,以“.s”结尾的目标文件将根据第一条规则由同名但后 # 缀为“.S”的源文件来生成,若不存在“.S”结尾的同名文件则根据最后一条规则由同名的“.c”文件生 # 成。 ifndef REMOTE_BUILD %.s: %.S $(CPP) $(AFLAGS) -o $@ $< %.o: %.S $(CC) $(AFLAGS) -c -o $@ $< %.o: %.c $(CC) $(CFLAGS) -c -o $@ $< else $(obj)%.s: %.S $(CPP) $(AFLAGS) -o $@ $< $(obj)%.o: %.S $(CC) $(AFLAGS) -c -o $@ $< $(obj)%.o: %.c $(CC) $(CFLAGS) -c -o $@ $< endif #########################################################################
6410 2d加速的BitBLt运行不正常。弄过的兄弟给点建议 在linux 2.6.33上弄的,只想实现最简单的从一块区域拷贝到另外一块区域显示的功能。 将(linux 2.6.28的)中g2d部分的代码移植到了video s3c-fb中,通过io_ctrl实现的。但移植的代码更本不能使用。 然后自己按照手册,配置的寄存器。 从FIFO sta ...… 查看全部问答> |
我试了下,不执行擦除操作,反复在一段空间里写入不同的数,后面的数能覆盖前面的数,这不就行了吗?为什么要先擦除再写,何况擦除的时间那么长,影响程序实时性。 有知道的大虾指教下。我写入的地址段是F400H。… 查看全部问答> |
本帖最后由 paulhyde 于 2014-9-15 03:57 编辑 大赛给你印象最深的事情是什么? 是老师的帮助?是同学之间的相互合作? 是自己的不懈努力,还是四天三夜就睡了十几个小时? ······ … 查看全部问答> |
终于用811读取出ADXL345的数据了,庆祝下,源码参考了网上的,呵呵 static unsigned char DataX1, DataX2, DataY1, DataY2, DataZ1, DataZ2; //xyz的高低字节 static unsi ...… 查看全部问答> |
