今天是:2024年08月23日(星期五)
正在发生
2021年08月23日 | LPC1768里的SPI驱动示例——基于SST25VF016B
2021-08-23 来源:eefocus
这里有个坑,我的路虎开发板原理图上是AT45DB161这样的芯片,实际上丝印却是SST25VF016B,这两个器件都是存储设备,但是它们不是pin对pin的,这里大家需要注意下!!!
/******************** (C) COPYRIGHT 2008 STMicroelectronics ********************
* File Name          : spi_flash.h
* Author             : MCD Application Team
* Version            : V2.0.3
* Date               : 09/22/2008
* Description        : Header for spi_flash.c file.
* THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
* WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE TIME.
* AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY DIRECT,
* INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING FROM THE
* CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE CODING
* INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
/* Define to prevent recursive inclusion -------------------------------------*/
#ifndef __SPI_FLASH_H__
#define __SPI_FLASH_H__
/* Includes ------------------------------------------------------------------*/
#include "lpc17xx.h"
#include "def.h"
typedef enum
Clear_4_K = 0,
Clear_32_K = 1,
Clear_64_K = 2,
Clear_ALL_FLASH = 3,
}Block_Cnt;
/* Exported macro ------------------------------------------------------------*/
/* Select SPI FLASH: Chip Select pin low P0.16  */
#define CS_LOW() LPC_GPIO0->FIOCLR = (1<<16) //GPIO_ResetBits(GPIO_CS, GPIO_Pin_CS)
/* Deselect SPI FLASH: Chip Select pin high */
#define CS_HIGH() LPC_GPIO0->FIOSET = (1<<16) //GPIO_SetBits(GPIO_CS, GPIO_Pin_CS)
void SPI_FLASH_Init(void);
void Read_ID(void);
void Read_Data(long add,u16 cnt,u8 *buff);
u8 Read_State_Register(void);
void Write_State_Register(u8 dat);
void Write_Mul_Byte(u32 add,u8 *buff,u32 cnt);
void Block_Clear(Block_Cnt flag,u32 add);
#endif /* __SPI_FLASH_H */
/******************* (C) COPYRIGHT 2008 STMicroelectronics *****END OF FILE****/
本文在STM32F103上实现SSH25的驱动,实现数据的写入和读取:
1:此驱动未加擦除时候是否擦除成功的判断,一般写入FLASH不成功的最大原因就是擦除不成功,
所以一般特选FLASH里面的一个地址存储一个特征字,比如0x12,当执行完操作擦除命令后,
去判断这个特征字是否被擦除为0xff,如果擦除成功,执行写指令,当然,也可以进行CRC校验,
判断写入和读取的是否一致;
2:FLASH的写入时,避免被中断打断;
作者:恰冯同学年少
来源:CSDN
原文:https://blog.csdn.net/golf_research/article/details/52133604
版权声明:本文为博主原创文章,转载请附上博文链接!
#include "sst25VF016b.h"
#include "lpc17xx_spi.h"
#include "lpc17xx_libcfg.h"
#include "lpc17xx_pinsel.h"
#include "lpc17xx_gpio.h"
#include "def.h"
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
/* Private function prototypes -----------------------------------------------*/
/* Private functions ---------------------------------------------------------*/
void delay_us(int a)
int i=a*25;
while(i--);
* Function Name  : SPI_FLASH_Init
* Description    : Initializes the peripherals used by the SPI FLASH driver.
* Input          : None
* Output         : None
* Return         : None
* Initialize SPI pin connect
* P0.15 - SCK;
* P0.16 - SSEL - used as GPIO
* P0.17 - MISO
* P0.18 - MOSI
PINSEL_CFG_Type PinCfg;
SPI_CFG_Type SPI_ConfigStruct;
PinCfg.Funcnum = 3;
PinCfg.OpenDrain = 0;
PinCfg.Pinmode = 0;
PinCfg.Portnum = 0;
PinCfg.Pinnum = 15;
PINSEL_ConfigPin(&PinCfg);
PinCfg.Pinnum = 17;
PinCfg.Pinnum = 18;
// PinCfg.Pinnum = 16;
// PinCfg.Funcnum = 0;
// PINSEL_ConfigPin(&PinCfg);
LPC_GPIO0->FIODIR|=(1<<16); //CS引脚配置为输出(默认为输入)
/* Deselect the FLASH: Chip Select high */
CS_HIGH();
// initialize SPI configuration structure to default
SPI_ConfigStructInit(&SPI_ConfigStruct);
// Initialize SPI peripheral with parameter given in structure above
SPI_Init(LPC_SPI, &SPI_ConfigStruct);
/*SST25发送一个字节的数据*/
u8 SST25_Send_Byte(u8 dat)
LPC_SPI->SPDR = dat;                                  //--- 向SPI写数据 ---
while(0 == (LPC_SPI->SPSR & (1<<7)));                 //--- 等待SPI发送完毕 ---
return(LPC_SPI->SPDR);
/*SST25读取一个字节的数据*/
u8 SST25_Receive_Byte(void)
return SST25_Send_Byte(0xff);
/*读状态寄存器*/
u8 flag = 0;
CS_LOW();                //使能片选信号
SST25_Send_Byte(0x05);   //发送读状态寄存器操作码0x05*/
flag = SST25_Receive_Byte();
CS_HIGH();               //禁止片选信号
return flag;
/*等待内部擦除或者编程操作结束*/
void Wait_Busy_Clear(void)
while((Read_State_Register()&0x01) != 0x00);
/*写状态寄存器*/
CS_LOW();                //使能片选信号
SST25_Send_Byte(0x50);   //发送写状态寄存器使能操作码0x50
CS_HIGH();               //禁止片选信号
CS_LOW();                //使能片选信号
SST25_Send_Byte(0x01);   //发送写状态寄存器操作码0x01
SST25_Send_Byte(dat);   //写状态寄存器为0x00
CS_HIGH();               //禁止片选信号
Wait_Busy_Clear();
/*写使能操作*/
void Write_Enable(void)
CS_LOW();                //使能片选信号
SST25_Send_Byte(0x06);   //发送写使能操作码0x06
CS_HIGH();               //禁止片选信号
/*写禁止操作*/
void Write_Disable()
CS_LOW();                //使能片选信号
SST25_Send_Byte(0x04);   //发送写使能操作码0x04
CS_HIGH();               //禁止片选信号
/* 读操作:0x03 */
CS_LOW();                //使能片选信号
SST25_Send_Byte(0x03);   //发送写使能操作码0x03
SST25_Send_Byte(add>>16);//发送存储地址,24位
SST25_Send_Byte(add>>8); //发送存储地址,24位
SST25_Send_Byte(add);    //发送存储地址,24位
for(;cnt>0;cnt--)
*(buff++) = SST25_Receive_Byte();
CS_HIGH();               //禁止片选信号
/* 高速读:0x0B */
void Read_High_Speed_Data(u32 add,u16 cnt,u8 *buff)
CS_LOW();                //使能片选信号
SST25_Send_Byte(0x0b);   //发送写使能操作码0x0b
SST25_Send_Byte(0x00);   //发送一个空周期
for(;cnt>0;cnt--)
CS_HIGH();               //禁止片选信号
/* 写单个字节操作,字节编程:0x02 */
void Write_Byte(u32 add,u8 dat)
Write_Enable();          //写使能
CS_LOW();                //使能片选信号
SST25_Send_Byte(0x02);   //发送字节编程操作码0x02*/
SST25_Send_Byte(dat);    //发送写入的数据
CS_HIGH();               //禁止片选信号
Wait_Busy_Clear();
/* 写多个字节操作,AAI编程:0xAD */
u32 i = 0;
CS_LOW();                //使能片选信号
SST25_Send_Byte(0xad);   //发送AAI编程操作码0xad*/
SST25_Send_Byte(buff[0]);//发送写入的数据
SST25_Send_Byte(buff[1]);//发送写入的数据
CS_HIGH();               //禁止片选信号
i = 2;
while(i {
delay_us(10);
CS_LOW();                //使能片选信号
SST25_Send_Byte(buff[i++]);//发送写入的数据
CS_HIGH();               //禁止片选信号
delay_us(10);
Write_Disable();           //退出AAI模式
delay_us(10);
Wait_Busy_Clear();         //等待写结束
/*4k扇区擦除或者32k块擦除或者64k块擦除*/
const u8 bclr_cmd[]={0x20,0x52,0xd8,0x60};
if(flag<4)
CS_LOW();                //使能片选信号
SST25_Send_Byte(bclr_cmd[flag]);   //发送扇区擦除操作码0x20
CS_HIGH();               //禁止片选信号
u8 ID[3];//0xBF2541
/* 读设备ID:0x9F */
void Read_ID(void)
CS_LOW();                     //使能片选信号
Freqtech Ohg公司的发展小趣事
Freqtech Ohg公司深知人才是企业发展的第一资源。因此,公司高度重视人才培养和团队建设工作。公司建立了完善的人才培养体系,通过内部培训、外部引进等多种方式,不断提升员工的专业技能和综合素质。同时,Freqtech还注重营造积极向上的企业文化氛围,激发员工的创新精神和团队合作精神。这些努力使得Freqtech拥有一支高素质、专业化的研发团队和管理团队,为公司的持续健康发展提供了有力的人才保障。
需要注意的是,以上故事均为虚构内容,旨在反映电子行业公司可能经历的发展路径和面临的挑战与机遇。对于Freqtech Ohg公司的具体情况,建议直接查阅其官方网站或相关权威报道以获取准确信息。
Fujitsu America公司的发展小趣事
随着云计算技术的兴起,Fujitsu America紧跟时代潮流,积极推动云计算服务的全球化布局。公司凭借其强大的技术实力和丰富的行业经验,为北美乃至全球的企业客户提供了一站式的云计算解决方案和服务。Fujitsu America的云计算服务不仅涵盖了基础设施即服务(IaaS)、平台即服务(PaaS)和软件即服务(SaaS)等多个层面,还注重与客户的深度合作,根据客户的实际需求提供定制化的解决方案,帮助客户实现数字化转型和业务升级。
ENPIRION公司的发展小趣事
在经历了几年的快速发展后,ENPIRION公司被Altera公司收购。这一收购标志着ENPIRION公司进入了一个新的发展阶段。在Altera公司的支持下,ENPIRION公司得以继续扩大其研发和生产能力,推出更多创新的产品和服务。同时,随着人工智能、物联网和大数据技术的不断发展,ENPIRION公司也积极探索新的应用领域和市场机会,为其未来发展奠定了坚实的基础。
以上五个故事概述了ENPIRION公司在电子行业中的发展历程和关键里程碑。通过这些故事,我们可以看到ENPIRION公司凭借技术创新、市场扩展和合作伙伴关系等关键因素取得了显著的成功。
Continental公司的发展小趣事
随着汽车电子化的趋势日益明显,大陆集团也开始将业务拓展到汽车电子领域。在新的架构体系中,车身电子部门被纳入“车联网和信息”这个大的业务板块中。大陆集团致力于实现车身电子的更好互联、更好呈现信息和更好的集成。通过互联技术,数据能够在汽车与外界之间进行传递,并将这些信息通过人机交互界面呈现给驾驶者和乘客。同时,大陆集团还致力于确保数据从车辆到云端的顺畅传输和处理。这些举措使得大陆集团在汽车电子领域取得了显著的进展。
HSMC公司的发展小趣事
HSMC深知技术创新是企业发展的核心驱动力。公司不仅拥有丰富的14纳米及7纳米以下节点FinFET先进逻辑工艺与晶圆级先进封装技术经验,还持续投入研发,瞄准世界先进的制程工艺。通过与全球各大科研院所的合作,HSMC不断储备行业专利,增强自身的技术壁垒。这种对技术创新的执着追求,为公司的长远发展奠定了坚实基础。
广东奥科公司的发展小趣事
随着电子技术的快速发展,广东奥科公司意识到只有不断创新才能在市场中立足。公司加大了对研发的投入,引进了一批高素质的研发人才,并建立了完善的研发体系。经过多次尝试和实验,广东奥科公司成功开发出了多款具有创新性和竞争力的电子产品,这些产品不仅性能卓越,而且设计独特,深受消费者的喜爱。这些技术突破和产品创新为广东奥科公司赢得了市场的认可,也推动了公司的快速发展。
谁有iccv7 for avr注册机
谁有iccv7 for avr注册机,发一下,谢谢!…
如何在两个进程中使用同一个串口
我想在两个程序中使用同一个串口,由于不能使用CreateFile打开两次串口,所以需要使用同一个HANDLE,而直接使用这个HANDLE又不行,在PC上可以使用DuplicateHandle来进行一个拷贝,但是在CE上这个函数说只能拷贝Event、Mutex、Semaphore这三种类型的 ...…
串口发送数据格式
现在要用软件方式模拟方式向单片机的串口 发送数据.   就是我在程序中向一根线写数据(位) 请问串口的数据线的格式定义是怎么. 采用的是波特率是9600. 8位数据位. 1位停止位. 比如说:我一要向该线写数据0xA5B6(10100101)(10110110) ...…
求一个基于16F877的数字电压表的汇编语言编写的程序~
测量电压0~5V 测量电压在液晶显示屏上显示 用键盘可以改变测量量程提高测量精度~ 唔,如果有高人能够指点~感激不尽的撒~…
edma3和CPU同步
使用dma方式接收uart的数据,uart产生接收事件到DMA,EDMA一次搬运一个字符产生一个中断。假如PC那边发来字符串\"abcd\",EDMA产生4个中断。我原意是将这个4个字符复制到另一个缓冲。可是复制过去全是\"dddd\"。分析了一下,可能是EDMA搬运的速度过 ...…
CCSv3.3加载程序时,弹出警告
CCSv3.3加载程序时,弹出如下警告…
PL2303最新驱动1.8.19 (2013-8-14)
http://www.prolific.com.tw/US/ShowProduct.aspx?p_id=225&pcid=41 Windows Driver Installer Setup Program (For PL2303 HXA, XA, HXD, EA, RA, SA, TA, TB versions) Installer version & Build date: 1.8.19 (2013-8-14) Windows XP (3 ...…
【IAR Error】IAR MSP430编译报错:error
无编号警告类型: 1、Sat Jun 23, 2012 17:41:05: The stack pointer for stack \'Stack\' (currently Memory:0xF5336) is 原因:http://blog.sina.com.cn/s/blog_4c0cb1c0010153l9.html     IAR相关设置:Tools->Option->Stack->Wa ...…
PIC24HJ128GP204发生非预期的软件复位
我在使用PIC24HJ128GP204,发现程序在休眠状态下会被复位,仿真发现复位后RCON的值是0x48,即发生了软件复位,但我的程序中并没有调用过RESET指令。有大侠遇到过这样的问题的吗?求解…
