今天是:2024年09月22日(星期日)
2021年09月22日 | ARM协处理器指令
2021-09-22 来源:eefocus
ARM 微处理器可支持多达 16 个协处理器,用于各种协处理操作,在程序执行的过程中,每个协处理器只执行针对自身的协处理指令,忽略 ARM 处理器和其他协处理器的指令。ARM 的协处理器指令主要用于 ARM 处理器初始化 ARM 协处理器的数据处理操作,以及在ARM 处理器的寄存器和协处理器的寄存器之间传送数据,和在 ARM 协处理器的寄存器和存储器之间传送数据。 ARM 协处理器指令包括以下 5 条:
CDP 协处理器数操作指令
LDC 协处理器数据加载指令
STC 协处理器数据存储指令
MCR ARM 处理器寄存器到协处理器寄存器的数据传送指令
MRC 协处理器寄存器到ARM 处理器寄存器的数据传送指令
CP15系统控制协处理器
CP15 —系统控制协处理器 (the system control coprocessor)他通过协处理器指令MCR和MRC提供具体的寄存器来配置和控制caches、MMU、保护系统、配置时钟模式(在bootloader时钟初始化用到)
CP15的寄存器只能被MRC和MCR(Move to Coprocessor from ARM Register )指令访问
一些要说明的内容,摘录见下::
Co-processors
There are between zero and three possible co-processors. Most desktop ARM systems do not have logic for external co-processors, so we may either use that which is built into the ARM itself, or an emulated co-processor.
CP15 is reserved on the ARM 3 and later processors for internal configuration, as described in this document.
CP0 and CP1 is used by the floating point system. It may either be an external floating point chip (as used with the ARM 3), hardware built into the processor (as in the ARM 7500FE), or a totally software-based emulation (as with the FPEmulator that we all know).
Here is a short exercise for you:
10 DIM code% 16
20 P% = code%
30 [ OPT 3
40 CDP CP1, 0, C0, C1, C2, 0
50 ADFS F0, F1, F3
60 MOV PC, R14
70 ]
>RUN
00008F78 OPT 3
00008F78 EE010102 CDP CP1, 0, C0, C1, C2
00008F7C EE010102 ADFS F0, F1, F2
00008F80 E1A0F00E MOV PC, R14
What do you notice? :-)
When the ARM executes a co-processor instruction, or an undefined instruction, it will offer it to any co-processors which may be presently attached. If hardware is available to process the given instruction, then it is expected to do so. If it is busy at the time the instruction is offered, the ARM will wait for it.
If there is no co-processor capable of executing the instruction, the ARM will take its undefined instruction trap, in which case the following will happen:
The PSR and PC are both saved (the method differs for 26 bit and 32 bit ARMs)
SVC mode (26 bit) / UND mode (32 bit) is entered, and the I bit of the PSR is set
The instruction at address &00000004 is executed
This trap may be used to add instructions to the instruction set by emulation, or to implement a software emulation of hardware that isn't fitted. The Floating Point Emulator works by doing this.
To return, simply pull the saved PC and PSR (depends on 26/32 bit) and push them to the current PC and PSR, like MOVS PC, R14 in 26 bit systems. This will pick up with the instruction following the one which caused the trap.
All of the co-processor instructions can be executed conditionally. Please note that the conditionals relate to the status of the ARM processor, and not the status of any of the co-processors. This is because the ARM always tries the instruction first, and offers it around and maybe takes the undefined application trap, so the conditions are ARM related.
To make this clearer:
10 DIM code% 32
20 P% = code%
30 [ OPT 3
40 FLTS F0, R0
50 FLTS F1, R1
60 FMLS F2, F0, F1
70 FIX R0, F2
80 MOVS PC, R14
90 ]
100 INPUT "First number : "A%
110 INPUT "Second number: "B%
120 PRINT USR(code%)
This probably won't assemble without an enhanced BASIC assembler.
Anyway, you might think the ARM will hand over to the floating point co-processor to do the four FP instructions, then hand back afterwards.
If you did, you would be incorrect!
What actually is executed is:
MCR CP1, 0, R0, C0, C0
MCR CP1, 0, R1, C1, C0
CDP CP1, 9, C2, C0, C1
MRC CP1, 0, R0, C0, C2
It is worth pointing out that objasm specifies co-processor registers using the CR notation (ie, CR0 - CR15), which is first defined with the CN directive. It does not appear as if default co-processor instructions are defined in Nick Roberts' ASM, though I've only looked in the instructions at the "defined symbols" section...
Darren Salt's ExtBASICasm provides the register names C0 - C15 to refer to the co-processors. So if any of these examples fail when you try to assemble them, please check what format your assembler provides these instructions.
MRC
The instruction MRC transfers a co-processor register to an ARM register. It takes the form:
MRC The co-processor is denoted in most assemblers by CPx . The register The final MCR The instruction MCR transfers an ARM register to a co-processor register. It takes the form: MCR The co-processor is free to interpret the fields as it desires, but the standard interpretation is that the contents of the ARM register are written to the co-processor register using the operation code given, which may be further modified by the second co-processor register and/or the second operation code. 在U-Boot中我们用到了c7 和 c8这两个协处理器,再来看看MCR的详细用法: MCR指令: MCR指令将ARM处理器的寄存器中的数据传送到协处理器寄存器中。如果协处理器不能成功地执行该操作,将产生未定义的指令异常中断。 指令语法格式: MCR{ ,< opcode_1>, MCR{ 其中 指令执行的条件码.当 协处理器将执行的操作的操作码。对于CP15协处理器来说, 作为源寄存器的ARM寄存器,其值将被传送到协处理器寄存器中 作为目标寄存器的协处理器寄存器,其编号可能是C0,C1,…,C15。 mcr p15, 0, r0, c7, c7, 0 /* flush v3/v4 cache */ 可以看出,其中 rd为r0=0 CRn为C7 CRm为C7 对于这行代码的作用,以此按照语法,来一点点解释如下: 首先,mcr做的事情,其实很简单,就是“ARM处理器的寄存器中的数据传送到协处理器寄存器中”, 此处即是,将ARM的寄存器r0中的数据,此时r0=0,所以就是把0这个数据,传送到协处理器CP15中。 而对应就是写入到“ 而上面关于Register 7的含义中也说了,“Any data written to this location will cause the selected cache to be flushed”,即你往这个寄存器7中写入任何数据,都会导致对应的缓存被清空。而到底那个缓存被清空呢,即我们这行指令 mcr p15, 0, r0, c7, c7, 0 起了什么作用呢 那是由“ 而此处CRm为C7,opcode_2为0,而对于C7和0的组合的作用,参见上面的那个表中Register 7中的Flash I+D那一行, 当opcode_2为0,CRm为0111=7,就是我们要找的,其作用是“Flush I + D”,即清空指令缓存I Cache和数据缓存D Cache。 根据该表,同理,如果是opcode_2=0,而CRm=0101b=5,那么对应的就是去“Flush I”,即只清除指令缓存I Cache了。 而对应的指令也就是 mcr p15, 0, r0, c7, c5, 0 此注释说此行代码的作用是,清理v3或v4的缓存 其中v4,我们很好理解,因为我们此处的CPU是ARM920T的核心,是属于ARM V4的,而为何又说,也可以清除v3的cache呢? 那是因为,本身这些寄存器位域的定义,都是向下兼容的,参见上面引用的内容,也写到了: ARM 710 Register 7 - IDC flush (write only) Any data written to this location will cause the IDC (Instruction/Data cache) to be flushed. 即,对于ARM7的话,你写同样的这行代码 mcr p15, 0, r0, c7, c7, 0 也还是向register 7中写入了数据0,这也同样满足了其所说的“Any data written to this location”,也会产生同样的效果“cause the IDC (Instruction/Data cache) to be flushed”。 同理,可以看出此行是去操作寄存器8,而对应的各个参数为: rd为r0=0 CRn为C8 CRm为C7 opcode_2为0 对照寄存器8的表: Register 8 - TLB operations (write only) Any data written to this location will cause the selected TLB flush operation. The OPC_2 and CRm co-processor fields select which cache operation should occur: Function OPC_2 CRm Data Flush I + D %0000 %0111 - Flush I %0000 %0101 - Flush D %0000 %0110 - Flush D single %0001 %0110 Virtual address” 其含义为: 向寄存器8中写入数据,会导致对应的TLB被清空。具体是哪个TLB,由opcode_2和CRm组合决定, 此处opcode_2为0,CRm为7=0111b,所以对应的作用是“Flush I + D”,即清空指令和数据的TLB。
上一篇:s3c6410 时钟设置
当凯旋的时候 毕业了,嘲笑般的风声向我耳朵边刮来,顿时愣了,大学毕业了,多年经营不起的创业梦接近尾声,走向人生打工路开始了,毕业那晚,很多朋友都去聚会了,只有我和伙伴在商讨放弃多年心血,第二天早上,收拾了包袱,告别了朋友,各奔东西 ...… 查看全部问答> |
校验原理 在计算机得数值计算中,数值经常是以Bcd码表示的十进制进行运算的。即一位BCD码用4位二进制位表示。但是BCD的加法需要两个加法器来完成,如果分析一下BCD数的加法过程,原因就很清楚。请看下面: 令A=1000,B=0111,这两个数都是正 ...… 查看全部问答> |
现有一块12864液晶,显示基本上成功,可以显示预先设定的字符串,字符,但无法显示不确定的float类型值。 如a=12.5554或者其他什么值,求高手一段程序,或指点一二。… 查看全部问答> |
请问各位大虾,我想在我的驱动中加上处理内存的IRP,就是可以写内存,和读内存,要用什么DDK函数,我想给上层调用通过一个地址,就可以读出内存的值。AP通过一个地址和值,调用驱动就可以写内存。… 查看全部问答> |
我们公司有个USB接口的条形码扫描仪 领导想让加到现有的设备上,设备用的是Linux2.4的内核 请问,Linux支持这种USB接口的HID设备吗? 重编内核时,我需要加进哪些驱动选项? 请指教,多谢 或者我该哪些思路来驱动这个设备? … 查看全部问答> |
北京中电兴发科技有限公司诚聘C++ 、.NET、嵌入式工程师 C++软件工程师 岗位职责: 1、负责智能交通、平安城市、行业信息化高端应用全线产品配套软件平台的研发; 2、参与系统设计及功能架构; 3、编写代码及完成自测; 4、撰写技术文档。 任职资格: 1、计算机 ...… 查看全部问答> |
从电话到电视,从LAN到INTERNET,从微波到数字化通信,人们的生产生活时刻与影像和声音的传递息息相关,传统的信息交流 方式正在因科学技术的飞速发展而发生着巨大的变化。广播电视与通讯两大产业在这样的背景下延伸和发展,而它们之间却因大量的 ...… 查看全部问答> |
