今天是:2024年09月24日(星期二)
正在发生
2021年09月24日 | s3c2440时钟+nandflash拷贝至SDRAM+开启mmu
2021-09-24 来源:eefocus
涉及6个文件
head.S,init.c,main.c,makefile,nand.c,out.lds
head.S
.text
.global _start
_start:
    b   Reset
HandleUndef:
    b   HandleUndef
HandleSWI:
    b   HandleSWI
HandlePrefetchAbort:
    b   HandlePrefetchAbort
HandleDataAbort:
    b   HandleDataAbort
HandleNotUsed:
    b   HandleNotUsed
    b   HandleIRQ
HandleFIQ:
    b   HandleFIQ
Reset:
ldr r0, =0x53000000
mov r1, #0x0
str r1, [r0] @disable watchdog
msr cpsr_c, #0xd2 @IRQ mode,ARM mode,IRQ disable
ldr sp, =3072
msr cpsr_c, #0xd3 @Supervisor mode,ARM mode,IRQ disable
ldr sp, =1024*4 @set up stack,4K
msr cpsr_c, #0x53 @Supervisor mode,ARM mode,IRQ enable
ldr sp, =4096
bl clock_init
bl memsetup
bl nand_init
       ldr r0, =0x30000000 @target address(sdram),nand_read 1parameter
       mov r1, #4096 @start address,nand_read 2parameter
       mov r2, #2048*2 @size copy to sdram,nand_read 3parameter
bl nand_read
bl  create_page_table
bl  mmu_init
ldr sp, =0xB4000000 @pstack go to sdram
ldr lr, =halt_loop
ldr pc, =main
halt_loop:
b halt_loop
HandleIRQ:
sub lr, lr, #4
stmdb sp!, {r0-r12,lr}
ldr lr, =int_return
ldr pc, =TIMER_Handle
int_return:
ldmia sp!, { r0-r12,pc }^
init.c
#define BWSCON (*(volatile unsigned long *)0x48000000)
#define BANKCON0 (*(volatile unsigned long *)0x48000004)
#define BANKCON1 (*(volatile unsigned long *)0x48000008)
#define BANKCON2 (*(volatile unsigned long *)0x4800000C)
#define BANKCON3 (*(volatile unsigned long *)0x48000010)
#define BANKCON4 (*(volatile unsigned long *)0x48000014)
#define BANKCON5    (*(volatile unsigned long *)0x48000018)
#define BANKCON6    (*(volatile unsigned long *)0x4800001C)
#define BANKCON7    (*(volatile unsigned long *)0x48000020)
#define REFRESH       (*(volatile unsigned long *)0x48000024)
#define BANKSIZE     (*(volatile unsigned long *)0x48000028)
#define MRSRB6 (*(volatile unsigned long *)0x4800002C)
#define MRSRB7 (*(volatile unsigned long *)0x48000030)
#define CLKDIVN (*(volatile unsigned long *)0x4C000014)
#define MPLLCON (*(volatile unsigned long *)0x4C000004)
#define S3C2440_MPLL_400MHZ 0x5C011
void memsetup()
BWSCON=0x22011110;
BANKCON0=0x00000700;//sram
BANKCON1=0x00000700;//rom
BANKCON2=0x00000700;
BANKCON3=0x00000700;
BANKCON4=0x00000700;
BANKCON5=0x00000700;
BANKCON6=0x00018005;//sdram
BANKCON7=0x00018005;
REFRESH=0x008C04F4;
BANKSIZE=0x000000B1;
MRSRB6=0x00000030;
MRSRB7=0x00000030;
void clock_init()
CLKDIVN=0x05;
__asm__(
    "mrc    p15, 0, r1, c1, c0, 0n"
    "orr    r1, r1, #0xc0000000n"
    "mcr    p15, 0, r1, c1, c0, 0n"
      MPLLCON=S3C2440_MPLL_400MHZ;
void create_page_table(void)
#define MMU_FULL_ACCESS     (3 << 10)
#define MMU_DOMAIN          (0 << 5)
#define MMU_SPECIAL         (1 << 4)
#define MMU_CACHEABLE       (1 << 3)
#define MMU_BUFFERABLE      (1 << 2)
#define MMU_SECTION         (2)
#define MMU_SECDESC         (MMU_FULL_ACCESS | MMU_DOMAIN | MMU_SPECIAL | MMU_SECTION)
#define MMU_SECDESC_WB      (MMU_FULL_ACCESS | MMU_DOMAIN | MMU_SPECIAL |
                             MMU_CACHEABLE | MMU_BUFFERABLE | MMU_SECTION)
#define MMU_SECTION_SIZE    0x00100000
    unsigned long virtuladdr, physicaladdr;
    unsigned long *mmu_tlb_base = (unsigned long *)0x30000000;
    virtuladdr = 0;
    physicaladdr = 0;
    *(mmu_tlb_base + (virtuladdr >> 20)) = (physicaladdr & 0xFFF00000) | MMU_SECDESC_WB;//0~4096 the same
    virtuladdr = 0x56000000;
    physicaladdr = 0x56000000;
    *(mmu_tlb_base + (virtuladdr >> 20)) = (physicaladdr & 0xFFF00000) | MMU_SECDESC;
    virtuladdr = 0x4A000000;
    physicaladdr = 0x4A000000;
    virtuladdr = 0x51000000;
    physicaladdr = 0x51000000;
    /*SDRAM to 0xB0000000~0xB4000000*/
    virtuladdr = 0xB0000000;
    physicaladdr = 0x30000000;
    while (virtuladdr < 0xB4000000)
        virtuladdr += 0x100000;
        physicaladdr += 0x100000;
 * 启动MMU
void mmu_init(void)
    unsigned long ttb = 0x30000000;
__asm__(
    "mov    r0, #0n"
    "mcr    p15, 0, r0, c7, c7, 0n"
    "mcr    p15, 0, r0, c7, c10, 4n"
    "mcr    p15, 0, r0, c8, c7, 0n"
    "mov    r4, %0n"
    "mcr    p15, 0, r4, c2, c0, 0n"
    "mvn    r0, #0n"
    "mcr    p15, 0, r0, c3, c0, 0n"
    "mrc    p15, 0, r0, c1, c0, 0n"
    "bic    r0, r0, #0x3000n"
    "bic    r0, r0, #0x0300n"
    "bic    r0, r0, #0x0087n"
    "orr    r0, r0, #0x0002n"
    "orr    r0, r0, #0x0004n"
    "orr    r0, r0, #0x1000n"
    "orr    r0, r0, #0x0001n"
    "mcr    p15, 0, r0, c1, c0, 0n"
    : "r" (ttb) );
main.c
led1 f4,led2 f5,led3 f6,int0 f0
#define GPFCON (*(volatile unsigned long *)0x56000050)
#define GPFDAT (*(volatile unsigned long *)0x56000054)
#define GPF4_OUT (1<<(4*2))
#define GPF5_OUT (1<<(5*2))
#define GPF6_OUT (1<<(6*2))
#define GPF4_CON_MSK (3<<(4*2))
#define GPF5_CON_MSK (3<<(5*2))
#define GPF6_CON_MSK (3<<(6*2))
#define GPF4_DAT_MSK (1<<(4))
#define GPF5_DAT_MSK (1<<(5))
#define GPF6_DAT_MSK (1<<(6))
#define TIMER0_MSK (1<<(10))
#define TCFG0 (*(volatile unsigned long *)0x51000000)
#define TCON (*(volatile unsigned long *)0x51000008)
#define TCNTB0 (*(volatile unsigned long *)0x5100000C)
#define INTOFFSET (*(volatile unsigned long *)0x4A000014)
#define SRCPND (*(volatile unsigned long *)0X4A000000)
#define INTMSK (*(volatile unsigned long *)0X4A000008)
#define PRIORITY (*(volatile unsigned long *)0x4A00000C)
#define INTPND (*(volatile unsigned long *)0X4A000010)
void init_timer0()
SRCPND=0x0;
INTMSK=~TIMER0_MSK;
TCFG0=0xff;
TCNTB0=0xffff;
TCON=0xa;
TCON=0x9;
void led_set_out()
GPFCON&=~(GPF4_CON_MSK|GPF5_CON_MSK|GPF6_CON_MSK);
    GPFCON|=GPF4_OUT|GPF5_OUT|GPF6_OUT;
GPFDAT&=~(GPF4_DAT_MSK);
GPFDAT&=~(GPF5_DAT_MSK);
GPFDAT&=~(GPF6_DAT_MSK);
GPFDAT|=(1<<4);
GPFDAT|=(1<<5);
GPFDAT|=(1<<6);
void led_reset(int ledn)
if(ledn==1)
GPFDAT|=(1<<4);
else if(ledn==2)
GPFDAT|=(1<<5);
else
GPFDAT|=(1<<6);
void led_set(int ledn)
if(ledn==1)
else if(ledn==2)
else
void TIMER_Handle()
int i;
led_set(1);
for(i=0;i<1000000;i++);
led_reset(1);
SRCPND=1< INTPND=1<}
int main()
int i;
led_set_out();
init_timer0();
while(1)
led_reset(2);
for(i=0;i<10000000;i++);
led_set(2);
return 0;
makefile
out.bin : head.S  main.c nand.c init.c
arm-linux-gcc -c -o head.o head.S
arm-linux-gcc -c -o main.o main.c
arm-linux-gcc -c -o nand.o nand.c
arm-linux-gcc -c -o init.o init.c
arm-linux-ld -Tout.lds head.o main.o nand.o init.o -o out_elf
arm-linux-objcopy -O binary -S out_elf out.bin
arm-linux-objdump -D -m arm  out_elf > out.dis
#rm -f out.dis out_elf *.o
clean:
rm -f out.dis out.bin out_elf *.o
nand.c
#define LARGER_NAND_PAGE
#define GSTATUS1        (*(volatile unsigned int *)0x560000B0)
#define BUSY            1
#define NAND_SECTOR_SIZE    512
#define NAND_BLOCK_MASK     (NAND_SECTOR_SIZE - 1)
#define NAND_SECTOR_SIZE_LP    2048
#define NAND_BLOCK_MASK_LP     (NAND_SECTOR_SIZE_LP - 1)
typedef unsigned int S3C24X0_REG32;
/* NAND FLASH (see S3C2410 manual chapter 6) */
typedef struct {
    S3C24X0_REG32   NFCONF;
    S3C24X0_REG32   NFCMD;
    S3C24X0_REG32   NFADDR;
    S3C24X0_REG32   NFDATA;
    S3C24X0_REG32   NFSTAT;
    S3C24X0_REG32   NFECC;
} S3C2410_NAND;
/* NAND FLASH (see S3C2440 manual chapter 6, www.100ask.net) */
typedef struct {
AMICC [AMIC TECHNOLOGY]公司的发展小趣事
在电子行业发展日新月异的背景下,AMICC始终坚持技术创新。公司投入大量研发资源,成功开发出一系列具有自主知识产权的新型半导体产品。这些产品不仅提高了性能,还降低了成本,为公司在市场竞争中赢得了优势。同时,AMICC还积极与国内外高校和研究机构合作,推动产学研深度融合,为公司的持续发展注入新的活力。
D1 International Inc公司的发展小趣事
D1 International Inc公司自创立之初,就专注于技术创新。公司的创始人们深知,在竞争激烈的电子行业中,只有拥有独特的技术优势才能立足。因此,他们投入大量资源研发新型电子元器件,其中一款高性能的芯片因其低功耗和高效能,迅速在市场上获得了认可。这一技术的成功研发,为D1 International Inc公司赢得了第一桶金,也为公司后续的发展奠定了坚实的基础。
ACCRETECH公司的发展小趣事
随着技术的不断成熟,D1 International Inc公司开始积极拓展市场。公司不仅在国内市场取得了显著的成果,还成功打入国际市场。与此同时,D1 International Inc公司也注重与其他企业的战略合作。通过与知名电子制造商的合作,D1 International Inc公司的产品线得到了极大的丰富,同时也提升了公司的品牌影响力。
HBControls公司的发展小趣事
如果确认是保险丝熔断,需要关闭电源后更换相同规格的保险丝。
Eureka Microelectronics Inc公司的发展小趣事
随着Eureka产品线的不断拓展,公司开始积极拓展海外市场。通过与国际知名电子制造商的合作,Eureka的产品逐渐打入国际市场。同时,公司也积极参与国际展会和技术交流活动,提升了品牌知名度和影响力。这些努力不仅帮助Eureka扩大了市场份额,也促进了公司与国际同行的交流与合作。
Ferroxcube公司的发展小趣事
在21世纪初,随着电子行业的飞速发展,对于高性能磁性元件的需求也日益增长。Ferroxcube公司,作为世界第二大磁性元件生产商,凭借其卓越的技术和产品质量,迅速在市场上占据了一席之地。公司不断投入研发,推出了一系列创新的磁芯和磁环产品,深受客户好评。
在一次重要的行业展会上,Ferroxcube展示了一款新型的高性能磁芯,其优越的性能和稳定性吸引了众多行业内人士的关注。一家知名的电源制造商对这款产品表现出了浓厚的兴趣,并表达了合作的意愿。经过几轮深入的洽谈,双方达成了战略合作协议,Ferroxcube的磁芯成为了这家电源制造商的首选元件。
这一合作不仅为Ferroxcube带来了大量的订单,还提升了公司在行业内的知名度和影响力。公司借此机会加大了研发投入,进一步巩固了其在磁性元件领域的领先地位。
有谁知道AMAT HDP PSG 在0.13LG ILD 的DEFECT怎么解决。
在0.13LG ILD PSG的PROCESS之后,总是会被YE检到外形平平的defect,作过SEM CUT check,证实DEFECT就在film里面,小弟我解了3年了还是没搞定,有没有大虾知道如何解决啊???…
CDMA1x移动车载视频监控管理系统
1  设计要求1.1  技术设计要求采用2卡或4卡CDMA1x无线网络进行实时视频传输, 前端采集、传输设备安装在车辆上在移动使用支持中心组网、分级管理支持电视墙观看视频支持无线观看视频(笔记本,PDA)视频信息可传送到各级管理机 ...…
高频的资料在那个部分
我个人觉得高频这方面得知识在电子信息工程世界中应该单独列一个版块出来,这方面不好做,但是我想可以有这一部分,有模电部分,就应该加高频的部分,希望版主可以采纳。…
论坛里是否有对24G平面微带技术雷达信号处理的高手啊?
我司有做24G平面微带技术雷达,但目前的难点集中在DSP信号处理上,不知道论坛中是否有这方面的高手一同探讨一下;如用在交通测速测距、安防监控、液位物位测量等方面的信号处理,用什么样的DSP处理比较能突显产品的特点呢? 欢迎大家来给我意见。…
EPM240装5个串口可装的下?
我知道发错了地方,但是很急,这人气旺,,谅解一下啦。。 DEV_OE、DEV_CLRn不接也可以的吧?…
用奶瓶制作有源音箱
从网上看到的用奶瓶DIY音箱,觉得好有趣,于是摘下来和大家分享。 接MP3 这是在网络上找到的图稍微做了一些修改 试听 先钻四个孔 四个孔都装上铜柱 调音板要裝机的孔 底部钻孔后所上螺絲 上一编文章: …
关于wince5.0英文版模拟器 中文的问题
首先,非常感谢大家的帮助 我的开发工具是vs2005 手持设备是casio dt-x7。他的操作系统是wince5.0英文版。 目前,我在使用模拟器进行测试,但是,中文不能显示,从数据库读出和写入的也都是乱码。 现在想请教,我现在想测试中文的东西。 怎样 ...…
关于Wince->WM的猜想
请教坛子里的高手,如果我想把WM的上层,比如注册表和应用程序直接copy到wince的工程里面,是否可以得到WM下面的所有应用和界面?理论上wm是基于ce5的,我们能提供一个平台,然后仅仅移植WM的AP和注册表。WM的AP和注册表可以从既有的WM的BSP编译后 ...…
界面问题
我在wince下用evc编程做了一个界面,发现上面的按钮太小了,想放大一些,可是组合框那个控件的宽度好象改不了,只能改长度,不知道有没有哪位大侠知道怎么做啊??…
