今天是:2025年01月04日(星期六)
2021年01月04日 | 可复制任何人外观的机器人,你害怕吗
2021-01-04 来源:搜狐
There’s no doubt robots are cong online in a big way—just look at Boston Dynamics’Atlasanotfor proof of that statement. But while those robots actually look like robots, some manufacture are moving more in the direcon ofreplicants(replicant复制品), in that they’re ming to make their robots far morehumanlike(像人的).Take these new Robo-C s from Russian robot manufacturer, Promobot, for example, which aim toduplicate(复制)the earance of any human a buyer desires.
毫无疑问,机器人正在大规模上线——只要看看波士顿动力的Atlas 和Spot机器人,这些就是证据。但是,虽然这些机器人实际上看起来像机器人,但一些制造商正朝着复制者的方向改进,因为他们的目标是使他们的机器人更加人性化。以俄罗斯机器人制造商Promobot的这些新的Robo-C机器人为例,它的目的是复制任何买家想要的人的外观。
Although thecreepy(令人毛骨悚然的)factor may seem qui high on these androids, the company’s stated goals seem relativelybenign(温和的). According to Promobot’smission statement, the company bally wants to create robots that be deployed to help with customer service, sales,miscellaneous(各种各样的)client interactions, and personal in-home use. The robots are able to peorm “real employee functions” according to Promobot’s mission statement, and can answer questions about a company’s products, as well as perform “specific business tasks.”
尽管这些机器人上令人毛骨悚然的因素似乎相当高,但该宣称的目标似乎相对温和。根据Promobot 的使命声明,大致来说,公司希望创建可以在客户服务、销售、杂项客户交互和个人家庭方面有帮助的机器人。根据Promobot 的使命声明,机器人能够履行"真正的员工职能",并可以回答有关公司产品的问题,以及执行"特定业务任务"。
Ina statementannouncing the launch of the Robo-C androids, which comes The New York Post, Chairman of the Board of Directors of Promobot, Aleksei Iuzhakov, said that “Everyone will now be able to order a robot with any appearance—for professional or personal use.” Iuzhakov ded that these robots willtap into【(词组)开发,应用例:The company will try to tap into Japan's rice market.这家公司将努力开发日本的大米市场。】a huge market encompassing education, service, and entertainment, and gave use-case examples, including a robotic Michael Jordan selling basketball unorms or a robotic Shakespeare reng his own work in a museum.
Promobot机器人董事会主席阿列克谢·尤扎科夫在宣布Robo-C机器人的发布时说,"现在每个人都能订购任何外观的机器人,这些机器人可以供职业或私人使用。尤扎科夫还说,这些机器人将进入一个巨大的市场,包括教育、服务和娱乐,并给出了使用案例,包括一个卖篮球服的机器人迈克尔·乔丹,或者一个在博物馆里阅读自己作品的机器人莎士比亚。
The tech specs for the Robo-C droids aren’t especially impressive considering theother humanoid robotsthat have been coming online over the last couple of years, but there’s certainly an emphasis on getting facial expressions to be as on-point as possible. Any given Robo-C is capable of 600 facial expressions, is sheathed inlifelike(逼真的,惟妙惟肖的)artificial skin, and canemulate(模仿)emotions such as anger, wonder, and fear. Robo-C droids will also be able to speak 11 languages andutilize(使用)100,000 speech modules in order to answer questions andpartake(参与,参加)in conversation.
Robo-C机器人的技术规格并不是令人印象特别深刻,因为过去几年来已经上线了不少其他类人机器人,但让面部表情尽可能的像确实是一个很突出的点。任何给定的Robo-C都能有600种面部表情,在栩栩如生的人造皮肤中保护下,可以模仿愤怒、惊奇和恐惧等情绪。Robo-C机器人也将能够说11种语言,并使用10万个语音模块来回答问题和参与对话。
对此,不少网友表示想要克隆自己的爱豆,还有网友表达了对机器人代替真人做不法之事的担忧,你怎么看?
编辑:hfy
该开发实验板采用PCI-E x1接口,为方便用户进行自主开发,提供了80个可用的FPGA IO输入输出,用户可以自行设计应用接插板,如外部A/D数据采集,图象数据处理等系统应用,而不需要对PCI-E接口有过多的了解。 PCI-E接口芯 ...… 查看全部问答> |
大虾: 小弟一直想做FPGA。书是看了不少,可是还是很迷茫。因为大部分就是一些简单的实例,也有一些稍微复杂一点的。可是我总是感觉没有长进。 比如:我看到好多设计中都用到FIFO,可是异 ...… 查看全部问答> |
各位高人 本人被这两个指令搞得头昏脑胀了 请指教 这两个指令中的数据时怎样变换的 我的理解:BIN: 例如键盘输入528400 要把这个输入数计入到数据寄存器里 用BIN指令 过程是不是把这个BCD码当作 十进制然后才成相应的二进制 0000 0000 0000 1000 0 ...… 查看全部问答> |
求高人解惑!我用OP07设计的3倍输出电路运放,输出只能在1.69-4.33V之间,为什么? 第一次发图 不知道大家能看到不。 ------------------------------------ 我是用5V单电源供电,运放为OP07,便于实验,两个输入,U2接地,U1为0-4.5V的一个可调输入,参数设计为输出3倍的电压, 但是试验中,当我输入电压的3倍低于1 ...… 查看全部问答> |
我先有MULIICESERVER连的板子。BIOS已经烧到了板子的NORFLASH里面。 在用AXD调试。用LOAD把调试镜象.AXF文件下到板子里面.怎么只能在main函数设置断点.而且就能设置2次.设置2次以后清楚断点继续设置断点运行后.就不停止了. 这是为什么.… 查看全部问答> |
我目前使用的是freescale m31+ce5.0系统,通过修改hive注册表后,512m的nandflash现在已经有fat分区,并且在系统启动后能现在nand flash的磁盘。 我现在想改成两个fat的分区,一个用与存放system.hv等注册表和系统的一些应用程序,另一个提供用户 ...… 查看全部问答> |
w5100是自带网络协议的芯片,具体我不讲了,我就讲下中断方式应用,这个应用是采用TCP/IP网络协议,单片机是客户端跟服务器进行相连的。 这里先讲两种寄存器,W5100_IR和W5100_S0_IR,后面这个这个芯片总共 ...… 查看全部问答> |
