今天是:2025年04月26日(星期六)
2018年04月26日 | 欧洲科学家开发仿生树木机器人
2018-04-26 来源:网络整理
European sciensts develong a roboTIc tree
The PLANTOID robot, with its "trunk" and sensor/leaf-bearing branches
Image Gallery (4 images)
The animal kingdom contains many examples of efficient forms of locomoTIon, so it's no wonder that we've been seeing a lot of animal-inspired robots – recent examples have included a roboTIc cheetah, fish and snake. Plants, however, just sit there ... don't they? Actually, they do move, just not necessarily in a Point A to Point B manner. With that in nd, Europe's PLANTOID project consortium is now in the process of developing a tree-like robot. Its descendants might ultimately find use in the exploration of other planets.
The base of the PLANTOID robot is a 3D-prind plastic "trunk," which houses a microprocessor. Extending out from the sides of that trunk are four plastic branches, the leaves of which are actually sensors capable of detecting and measuring factors such as temperature, humidity, gravity, touch, and chemical elements.
The robot's two roots, however, are where the real action is.
The robot on display, showing its tentacle-like and "growing" roots (bottom left and right, respectively)
One of those roots, which bends like a tentacle, has a tactile-sensor-equipped tip. Using that sensor, as it squirms its way through the dirt, the root change direction when it encounte solid obstacles ... much like a natural root does. It could also be equipped to sense and avoid toxic substances in the ground.
The other root (seen below) is actually able to grow down into the substrate. It has a rotating tip, which extrudes a coi cord behind it as it turns. The coils join together to form a tube-like root, which continues to grow as long as the tip keeps turning.
In its present form, the PLANTOID robot serves mainly as a proof-of-concept model. Down the ro, however, the technology developed for its roots could lead to better endoscopic surgical tools, or for tools used in locating victims buried in debris at disaster sites.
Complete PLANTOID-type robots could be also used to monitor things like soil conditions and pollutant levels here on Earth, or they could even find use gathering environmental data on other planets. Once deposited by an unmanned rover, a PLANTOID could secure itself in place its roots, then set about sensing the r and soil.
The project is being led by the Istituto Italia di Tecnologia, with the other members consisting of the Institute for Bioengineering of Catalonia (Spain), the Università degli Studi di Firenze (Italy) and EPFL (Switzerland). It began in 2012, and is due to wrap up next April. In the meantime, the researchers are looking into adding other functions to the roots, and devising ways in which the robots could draw power from their environment.
Sources: CORDIS, PLANTOID
自动翻译仅供参考
欧洲科学家开发仿生树木机器人
European科学家开发一种机器人tree
的PLANTOID机器人,它的“树干”和
叶轴承分公司
图片廊(4图像)
动物王国中含有的有效形式很多例子运动的,所以这也难怪,我们已经看到了大量的动物为灵感的机器人 - 最近的例子已经包括了机器人猎豹,鱼和蛇。植物,然而,只是坐在那里......不是吗?其实,他们根本动,只是不一定在A点到B点的方式。考虑到这一点,欧洲的PLANTOID项目财团正处于开发树状机器人的过程。它的后代最终可能会发现其他行星的探测使用。
平面机器人的基础是一个的塑料“躯干”,里面装有微处理器。从树干的侧面伸出的是四个塑料枝条,它们的叶子实际上是能够检测和诸如温度、湿度、重力、触觉和化学元素等因素的传感器。
机器人的两个根,但是,是其中实际行动。
上显示的机械手,显示出其触手状和“生长”根(底部左侧和右侧,分别)
其中的一个根,其中弯曲像触须,具有一个触摸-sensor配备尖端。使用该传感器,它通过扭动的方式,根可以改变方向,遇到坚实的障碍物时......就像一个天然的根一样。它也可以被配备成感测和避免在地有毒物质。
另一根(下面所示)实际上是能够成长向下到衬底。它有一个旋转的尖端,其挤压螺旋线背后的事实。线圈连接在一起,形成一个筒状根,继续只要成长为尖端不停转动。
在目前的形式下,PLANTOID机器人主要是作为概念验证的模型。下山的路,但是,对于其根源开发的技术能够带来更好的内窥镜手术,或用于定位受害者在灾难现场被埋在废墟中使用的工具。
完备PLANTOID型机器人也可以用于监视像土在地球上的条件和水平,或者他们甚至可以找到使用在其他行星上收集环境数据。一旦通过一个无人月球车存放,一个PLANTOID可以通过它的根保护自己的地方,再设置一下检测空气和土壤中。
该项目正率领因诺琴蒂基金会意大利迪TECNOLOGIA,与其他成员组成的研究所的加泰罗尼亚生物工程(西班牙)UNIVERSITA德利阿布鲁Studi住宅迪佛罗伦萨(意大利)和洛桑联邦理工学院(瑞士)。它始于2012年,并于明年四月收官。在此期间,研究人员正在研究加入其他功能的根源,并制定方法,使机器人能够从环境中吸取功率
下一篇:bot护理机器人
北京时间10月29日消息,据国外媒体报道,谷歌周三推出了一款免费手机导航应用,该款应用可向用户提供建议路线(turn-by-turn)。谷歌此举被认为可能会向GPS设备制造商发起攻击。 谷歌推出的新应用谷歌地图导航(Google Maps Navigation)是其手机版 ...… 查看全部问答> |
怎样知道已经编译好的windows ce核心是包含了.net框架的? 怎样知道已经编译好的windows ce核心是包含了.net框架的? 怎样知道.net框架的版本。 不看开发环境,只看板子上跑起来的windowsce… 查看全部问答> |
用USB连接的。 运行Windows CE Test Kit Server -〉connection ->start client...->connect 设备端,clientSide.exe 开始运行。(说明连接正常) 但是Quick Start 后,PC端跳出应用程序错误。 定制镜像时已经添加了cetk ,是不是SDK要重新制作的 ...… 查看全部问答> |
void Menu::OnStatic11() { // TODO: Add your control notification handler code here AfxMessageBox(_T(\"DAFAFA\")); } 在静态控件中点击时间不起作用是什么原因啊?… 查看全部问答> |
各位牛人,最近我在修改WINCE中开机弹出的WIFI对话框,有点小问题,就想请教一下,我的问题是:我用的中文系统,然后想在WIFI对应的中文对话框中加几个按钮,但是添加之后,全编译一次,开机启动WIFI对话框添加了按钮的那个页面什么都没有或者是显 ...… 查看全部问答> |
TI 模拟芯片超低价团购活动明天12点整截止! 还有需要团购的朋友,赶紧下手哟!~ 活动帖:https://bbs.eeworld.com.cn/thread-320222-1-1.html… 查看全部问答> |
