今天是:2025年04月30日(星期三)
正在发生
2018年04月30日 | bot护理机器人
2018-04-30 来源:网络整理
Care-O-bot gets an upgrade, now er and avlable with opTIonal second
The Care-O-bot 4 is designed to be an affable service robot on a budget
Image Gallery (8 images)
Six and a half yea afr the previous iteraTIon, the Fraunhofer InsTItute has released an update to Care-o-bot. The affordable service robot for personal and professional use has been made it more agile, more modular and much more personable?, ?bringing science fiction fantasy a little closer to reality.
The third-generation Care-O-bot announced back in 2008 was an vanced ece of hardware for its time that could fetch you drinks, place emergency calls and host videoconferences, but which had the rather uninteresting earance and demeanor of a tid, somber-looking butler.
Compared to its predecessor, Care-O-bot 4 is a signit step forward. This latest iteration is much more agile, having gone from 20 degrees of freedom to 31 (including spherical joints at the torso and neck to let it bend and twist with grace). Its communication skills have also been revamped, and it can now convey information through a touchscreen, body gestures, sounds, text-to-speech, and even a laser pointer embedded in its arm.
When pitted against the ten-fingered, backwards-running, one-leg hopping Asimo the Care-O-bot doesn’t look all that impressive, but nor was it ever meant to compete with Honda’s flagship robot. Unlike its pricey Japanese cousin, Care-O-bot was designed from the start to be as economical as possible, with large portions of its internals made out of folding sheet metal and one of its standard sensors being a stock Microsoft Xbox Kinect.
The robot consists of six independent and configurable modules, from the rolling base, which can work by itself as an autonomous transportation unit, to either one or two robotic arms with seven degrees of freedom each and that, besides the laser pointer mentioned above, also include time-of-flight (TOF) cameras to measure real-time distance from its surroundings.
"Customers can choose between a wide range of sensors," Fraunhofer Institute’s Dr. Ulrich Reiser tells us. "You might choose to have color cameras in the front and a 3D TOF camera in the back, or several 3D-TOF cameras. The sensor ring is equipped with its own computation unit and receives power supply and standard connector, so you might have several sensor rings and exchange them for different applications."
The Care-O-bot could find use as a high-tech waiter, a mobile information center in museums, stores and airports, to collect and deliver objects or, like its predecessor, as a mobile personal and medical assistant.
Based on their experience from previous iterations, Reiser and team found that social interaction was crucial to making their robot more compelling, engaging, and acceptable to humans. That is why this time around Care-O-bot 4 tries to detect the current mood in its surroundings and react accordingly, communicating emotions (as facial expressions) through a touchscreen. In other words, if you believe its creators, Care-O-bot won’t just care for you as a patient?, ?it’ll care about you too.
Dr. Reiser tells us that battery capacity is 30 Ah (at around 48 V) and will typically last between three and five hours, depending on factors like the specific application and the number of degree of movements used.
Defender Security公司的发展小趣事
随着网络安全问题的全球化趋势日益明显,Defender Security公司开始积极拓展国际市场。他们与多家国际知名的网络安全企业建立了合作关系,共同应对全球网络安全挑战。通过技术交流和合作研发,Defender Security不断提升自己的国际竞争力,逐渐成为了全球网络安全领域的重要力量。
Emerson公司的发展小趣事
1954年至1973年,Emerson在总裁帕森斯的领导下,开始实施多元化战略。公司通过一系列并购活动,成功收购了包括威诺、美国电气电机、里奇工具等在内的36家公司,进一步拓宽了业务范围。同时,Emerson还注重研发和创新,通过不断推出新产品和技术,巩固了其在电气行业的领先地位。在此期间,公司的规模迅速扩大,从最初的2家工厂、4000名员工和5600万美元产值发展到82家工厂、31000名员工和8亿美元产值。
CINCH公司的发展小趣事
在快速发展的同时,CINCH公司也注重质量管理体系的建设。公司引进了国际先进的质量管理理念和方法,建立了完善的质量管理体系,并通过了ISO9001等质量管理体系认证。这一举措不仅提升了公司的产品质量和服务水平,还增强了客户对公司的信任度和满意度。
CAMBION公司的发展小趣事
在追求经济效益的同时,CAMBION公司也注重可持续发展和社会责任。公司积极推广环保理念,采用环保材料和节能技术生产电子产品。此外,CAMBION还关注社会公益事业,通过捐款、设立奖学金等方式支持教育事业和弱势群体。这些举措不仅提升了公司的社会形象,也为公司的长期发展奠定了坚实基础。
以上五个故事是基于电子行业的一般发展趋势和可能面临的挑战而构想的,它们并不特指CAMBION公司的实际发展经历。如需了解CAMBION公司的真实故事,建议查阅相关新闻报道、行业报告或公司官方资料。
Belden Wire and Cable公司的发展小趣事
1902年,Joseph C. Belden在美国伊利诺伊州芝加哥创立了Belden公司。在创立初期,公司主要生产电线和电缆产品,并逐渐在行业内崭露头角。1905年,经过大量的实验和研究,Belden公司成功研发出“Beldenamel”绝缘材料,这种灵活的搪瓷绝缘材料极大地提升了线缆的性能和可靠性,为公司的早期发展奠定了坚实的基础。
Beta Dyne Inc公司的发展小趣事
Beta Dyne Inc最初是一家专注于研发新型半导体材料的小型创业公司。在创始人的带领下,公司成功研发出一种具有高效能、低功耗特性的新材料,这一技术突破迅速引起了业界的关注。随后,Beta Dyne积极与各大电子设备制造商合作,将其新材料应用于智能手机、平板电脑等消费电子产品中,成功开拓了新的市场。
单片机汉字显示器件12232F
概述 12232F是一种内置8192个16*16点汉字库和128个16*8点ASCII字符集图形点阵液晶显示器,它主要由行驱动器/ 列驱动器及128×32全点阵液晶显示器组成。可完成图形显示,也可以显示7.5×2个(16×16点阵)汉字.与外部CPU接口采用并行或串行方式控制。 ...…
基于EM-LPC1700开发板CAN测试通过了,请高手指点
前段时间使用英蓓特公司开发的EM-LPC1700开发板http://arm.embedinfo.com/list.asp?id=317(采用NXP公司的最新的Cortex-M3内核,主频有100M)做CAN的测试,没通过,最近采用他们提供的新的测试例程终于通过了。在这里跟大家分享一下 首先,将他们 ...…
XILINX,ALTERA开发套件及资料
XILINX,ALTERA开发套件,下载线,并长期备有SPARTAN,VIRTEX系列常用芯片,并可免费提供ISE11.1,QUARTUS9.0软件及相关资料! QQ:379073540 MB:13910408597…
混合信号FPGA促进临床医疗应用发展
  由于医疗服务成本的不断攀升、慢性病的流行、人口的老龄化,以及中国、印度和巴西等大规模新兴市场的崛起,对价格低廉又稳健可靠的医疗设备的需求非常庞大,以期改善全球数百万病患的治疗和护理条件,并扩大疾病治疗范围。另一方面,医疗设备设 ...…
wince 5.0 + 2440 ,无法同时支持三种USB 设备同时工作??
有没有人测试过,2440+wince5.0 的usb host 同时只能接两种设备,当第三种设备插上的时候,就会提示需要安装驱动。 例如:我现在设备上插上 usb 鼠标 + csr 的蓝牙适配器,都工作正常,但是,这个时候,我再把U 盘插上,就会跳出一个要我指定驱动 ...…
哪儿有STM32F107关于以太网和USB部分的连接原理图?
                                 网上没找到,不知怎么连线,如果再有些设计参考就更好了。…
【 信号处理】级联信号处理器的FPGA实现
级联信号处理器的FPGA实现 需要的下过去看看 摘要:现代通信系统中,数字化已成为发展的必然趋势,数字信号处理则是数字系统中的重要环节。在数字信号处理方面提出一种级联信号处理器的FPGA实现方案,用以取代昂贵的专用数字处理芯片。首先对级联 ...…
【QT基础】windows下图标制作
  QT是跨平台的程序设计库,在windows下的程序往往想要有一个好看的图标,方法如下:     1、有无图标的区别:     2、首先要准备好.ico图标 下面这个是可以转换的网站:http://www.ico.la/old.html 可以格式 ...…
IQmath 反正切问题
      当我运行完左图那位置   我在下一语句设断点... 程序跑不下去...可以说跑飞了吧...    怎么办呢?   是不是IQ 的那函数用错了.... 为什么那数值那么大...应该是溢出了 所以才跑飞的…
