今天是:2025年04月10日(星期四)
2018年04月10日 | 环保型排水管道检测机器人
2018-04-10 来源:网络整理
When it comes to robots that peorm internal inspecons of water pes, virtually all of them move along on rubber TIres or tres. As that rubber grips agnst the inside of the pipe, however, it dislodges rust parTIcles that ulTImately end up cong out of peoples' taps. In an effort to address that problem, the European Union TRACT project is developing a propeller-driven inspection robot that keeps the pipe-touching to a minimum.
The current 3D-printed prototype was created by Norway's SINF research group (which has previously developed a whee pipe-inspection robot), along with Breivoll Inspection Technologies and industrial design firm Inventas.
It has an articulated segmented body, with propelle located at either end. While those props provide the power to move it, spring-loaded fins on its body do lightly brush against the inside of the pipe, just to keep the bulk of the robot from contacting it.
Depending on which prop is activated, the robot move forward or backward through pipes as small as 10 cm (3.9 in) in diameter. It can travel up to 150 meters (492 ft) – making turns as sharp as 90 degrees as it goes – and then simply reverse back through the pipes to get to its starting point for retrieval.
The robot performs its inspections using 64 onboard ultrasound transducers. By emitting ultrasound signals into the pipe walls and then analyzing the reflected signals, it's able to determine the thickness of the metal. a significant amount of that thickness has been lost to corrosion at any given location, the transducers will pick up on it.
The TRACT project started last December, and is due to wrap up next year. You can see the robot in action, in the video below.
上一篇:俄罗斯推出人工智能面试机器人 节约时间和成本三分之一
下一篇:拥有学习能力的机器人
首先公司里是生产仪器的,仪器里信号处理部分是单片机控制的,再通过MAX232,给电脑送数据。电脑上的软件是用VB编的,没有对数据处理,只是把数据显示出来。我想问一下,为什么有时候仪器和电脑连接时电脑会死机呢?甚至连接时会把电脑的COM口给烧 ...… 查看全部问答> |
中国指纹锁品牌陷入的误区并不神秘,往往司空见惯,可是当局者迷一般的指纹锁品牌像“水煮青蛙”一样麻木不仁,不仅错失了打造品牌的良机,而且毁灭了企业基业常青的梦想。 健康长寿的品牌是企业的一个长期资产。如果一个品牌打造与 ...… 查看全部问答> |
usrTffsConfig()为什么不能建立一个始终存在的文件系统? 各位高手,我每次调用usrTffsConfig()后都能用devs查看到/tffs0存在,但一重启目标以后再用devs查看就没有/tffs0了。请问这是怎么回事啊?怎样才能让它建立以后就一直存在阿?另外,我在devs下曾建过的文件在重新使用usrTffsConfig后竟然还存在,这 ...… 查看全部问答> |
我是一般的本科生(电子信息专业),刚学完C语言、51单片机、MSP430,但单片机学得差不多,我现在要自学DSP或ARM,这两个哪个难一点?或者哪个将来更能派上用场(之前听过DSP到研究生才可以深入,这说法对不?),如果学DSP又有什么好的学习板介绍 ...… 查看全部问答> |
对于初学者的我,对430的3个时钟开始真的是乱死了,但是经过查阅手册和高手的教诲,终于懂了,特此来说一下,这只是简单的说一下,还有什么分频什么的我还没弄,等弄懂了我在写···一共3个时钟分别是 ACLK,MCLK,SMCLK.430的时钟分成3层 第 ...… 查看全部问答> |
https://www.eeworld.com.cn/training/ 早上看了看这个链接。 在 最热课程 里,看到一个430的进阶教程。 点开一看,没想到下载到的资料居然就成了什么 Hecular 的东西,而且资料很少。才那么三四页。 是不是放错了呢?管理员看看呗… 查看全部问答> |
问题描述: 在网上下载了一个红帽子6的iso镜像。安装在vmware9.0里面。 我手动在vim /etc/sysconfig/network-scripts/ifcfg-eth0 里面添加相应的信息。 DEVICE=eth0 BOOTPROTO=none ...… 查看全部问答> |
