51单片机洗衣机proteus仿真与源码设计
2019-12-31 来源:51hei
一个功能很全的模拟洗衣机仿真与源码,是51单片机控制的,有强洗按钮,弱洗按钮,标准洗按钮,甩干按钮.
液位传感器,排水阀按钮等功能一应俱全.
仿真原理图如下
还带各种指示灯:
单片机源程序如下:
#include #define uchar unsigned char #define uint unsigned int #define qiang_ledon qiang_led=1; #define qiang_ledoff qiang_led=0; #define biao_ledon biao_led=1; #define biao_ledoff biao_led=0; #define ruo_ledon ruo_led=1; #define ruo_ledoff ruo_led=0; #define piao_ledon piao_led=1; #define piao_ledoff piao_led=0; #define sgan_ledon sgan_led=1; #define sgan_ledoff sgan_led=0; #define jin_ledon jin_led=1; #define jin_ledoff jin_led=0; #define pai_ledon pai_led=1; #define pai_ledoff pai_led=0; unsigned char code Tab[11]={0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F}; //数码管显示0~9的段码表 unsigned char int_time; //记录中断次数 unsigned char second; //储存秒 uint t=0,tt=0; sbit k1=P0^0; sbit k2=P0^1; sbit k3=P0^2; sbit sg=P0^3; sbit hk1=P0^4; sbit hk2=P0^5; sbit ledon=P0^7; sbit qiang_led=P2^0; sbit biao_led=P2^1; sbit ruo_led=P2^2; sbit piao_led=P2^3; sbit sgan_led=P2^4; sbit jin_led=P2^5; sbit pai_led=P2^6; sbit p30=P3^0; sbit p31=P3^1; sbit beepon=P2^7; sbit sm1=P3^6; sbit sm2=P3^7; void delay2(void) { unsigned char m; for(m=0;m<200;m++) ; } void delay1(int s) { int i; for(;s>0;s--) for(i=0;i<65;i++); } void delay(uint i) { uchar j; for(i;i>0;i--) for(j=255;j>0;j--); } void DisplaySecond(unsigned char k) { sm1=0; //P2.6引脚输出低电平, DS6点亮 P1=Tab[k/10]; //显示十位 delay2(); delay2(); sm1=1; sm2=0; //P2.7引脚输出低电平, DS7点亮 P1=Tab[k%10]; //显示个位 delay2(); delay2(); P3=0xff; //关闭所有数码管 P1=1; //显示个位 delay2(); delay2(); } void beep() { p30=0; p31=0; t=0; while(1) { beepon^=1; delay(300); if(t>=80) break; } beepon=0; biao_led=0; } void f_qiang() { qiang_ledon; t=0; tt=0; int_time=0; second=00; while(1) { if(tt>=400) break; t=0; while(t<80&&tt<=400) { p31=0; p30=1; //正转 4s DisplaySecond(second); } t=0; //反转 4s while(t<80&&tt<=400) { p30=0; p31=1; DisplaySecond(second); } } p30=0; p31=0; } void f_biao() { qiang_led=0; biao_led=1; t=0; tt=0; int_time=0; second=00; while(1) { if(tt>=400) break; t=0; while(t<60&&tt<=400) { p31=0; p30=1; //正转3s DisplaySecond(second); } t=0; //反转3s while(t<60&&tt<=400) { p30=0; p31=1; DisplaySecond(second); } } p30=0; p31=0; } void f_ruo() { qiang_led=0; biao_led=0; ruo_led=1; t=0; tt=0; int_time=0; second=00; while(1) { if(tt>=400) break; t=0; while(t<40&&tt<=400) { p31=0; p30=1; //正转2s DisplaySecond(second); } t=0; //反转 2s while(t<40&&tt<=400) { p30=0; p31=1; DisplaySecond(second); } } p30=0; p31=0; } void f_piao() { qiang_ledoff; biao_ledoff; piao_ledon; t=0; tt=0; int_time=0; second=00; while(1) { if(tt>=400) break; t=0; while(t<40&&tt<=400) { p31=0; p30=1; //正转2s DisplaySecond(second); } t=0; //反转2s while(t<40&&tt<=400) { p30=0; p31=1; DisplaySecond(second); } } p30=0; p31=0; piao_ledoff; } void pai_leds() { p30=0; p31=0; pai_led=1; //排水阀灯亮 等待霍尔开关2 while(hk2); if(hk2==0) //如果闭合 pai_led=0; //排水灯灭 } void jin() { p30=0; p31=0; jin_ledon; while(hk1); if(hk1==0) jin_ledoff; } void sgan() { sgan_ledon; //甩干灯亮 t=0; int_time=0; second=00; while(t<=400) { p31=0; p30=1; DisplaySecond(second); } sgan_ledoff; } void sgan1() { sgan_ledon; t=0; int_time=0; second=00; while(t<=400) { p31=0; p30=1; DisplaySecond(second); } piao_ledoff; sgan_ledoff; beep(); t=401; } void f_an1() { qiang_ledon; //方案1灯亮 jin(); //进入强洗 f_qiang(); //循环20S delay1(4000);//延时4s f_biao(); //循环20S delay1(4000);//延时4s f_ruo(); //循环20S ruo_ledoff; pai_leds(); delay1(1000); //延时1S 进入甩干 sgan(); //甩干20s sgan_ledoff; ruo_ledoff; piao_ledoff; jin(); delay1(1000); //延时1S 进入漂洗 f_piao(); //循环20S sgan_ledoff; piao_ledoff; pai_leds(); delay1(1000); //延时1S 进入甩干 sgan1();//最终甩干20S delay(500);//延时 beep(); } void f_an2() { biao_ledon; //方案1灯亮 jin(); f_biao(); //循环20S delay1(4000); //延时4S f_ruo(); //循环20S ruo_ledoff; pai_leds(); delay1(1000); //延时1S 进入甩干 sgan(); //甩干20s ruo_ledoff; piao_ledoff; jin(); delay1(1000); //延时1S 进入漂洗 f_piao(); //循环20S sgan_led=0; pai_leds(); delay1(1000); //延时1S 进入甩干 sgan();//最终甩干20s delay(500);//延时5s piao_led=0; beep(); } void f_an3() { ruo_led=1; //方案1灯亮 jin(); f_ruo(); //循环20S ruo_ledoff; pai_leds(); delay1(1000); //延时1S 进入甩干 sgan(); //甩干20S ruo_ledoff; piao_ledoff; jin(); delay1(1000); //延时1S 进入漂洗 f_piao(); //循环20S sgan_led=0; pai_leds(); delay1(1000); //延时1S 进入甩干 sgan();//最终甩干20s delay(500);//延时5s piao_led=0; p30=0; beep(); } int main(void) { TMOD=0x01; //方式1 16位计数器 TH0=-50000/256; //设定初值 TL0=-50000%256; EA=1; //开总中断 ET0=1; //开定时器0中断 TR0=1; //启动定时器0 P2=0; int_time=0; //中断次数初始化 second=00; //秒初始化 while(1) { if(k1==0) { delay(10); if(k1==0) { f_an1(); } } if(k2==0) { delay(10); if(k2==0) { f_an2(); } } if(k3==0) { delay(10); if(k3==0) { f_an3(); } } if(sg==0) { delay(10); if(sg==0) { sgan1(); } } } return 0; } void time0() interrupt 1 using 1 { int_time ++; //每来一次中断,中断次数int_time自加1 if(int_time==20) //够20次中断,即1秒钟进行一次检测结果采样 ……………………
下一篇:单片机循迹小车制作程序
