单片机
51单片机读写RC522卡参考例程及上位机调试软件源码
2020-08-27 来源:51hei
原理图:
单片机源程序如下:
#include 'reg52.h'
#include 'main.h'
#include 'mfrc522.h'
#include
//M1卡的某一块写为如下格式,则该块为钱包,可接收扣款和充值命令
//4字节金额(低字节在前)+4字节金额取反+4字节金额+1字节块地址+1字节块地址取反+1字节块地址+1字节块地址取反
unsigned char code data2[4]  = {0x12,0,0,0};
unsigned char code DefaultKey[6] = {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF};
unsigned char g_ucTempbuf[20];
unsigned char idata MLastSelectedSnr[4];
unsigned char idata RevBuffer[30];
unsigned char data SerBuffer[20];
bit CmdValid;
void iccardcode()
          unsigned char cmd;
        unsigned char status;
        cmd = RevBuffer[0];
        switch(cmd)
                case 1:     // Halt the card     //终止卡的操作
                        status= PcdHalt();;
                        RevBuffer[0]=1;
                        RevBuffer[1]=status;
                        break;
                case 2:     // Request,Anticoll,Select,return CardType(2 bytes)+CardSerialNo(4 bytes)
                                // 寻卡,防冲突,选择卡    返回卡类型(2 bytes)+ 卡系列号(4 bytes)
                        status= PcdRequest(RevBuffer[1],&RevBuffer[2]);
                        if(status!=0)
                                if(status!=0)
                                        RevBuffer[0]=1;
                                        break;
                        RevBuffer[0]=3;
                        break;
                case 3:                         // 防冲突 读卡的系列号 MLastSelectedSnr
                        status = PcdAnticoll(&RevBuffer[2]);
                        if(status!=0)
                                RevBuffer[0]=1;
                                break;
                        memcpy(MLastSelectedSnr,&RevBuffer[2],4);
                        RevBuffer[0]=5;
                        break;
                case 4:                                    // 选择卡 Select Card
                        status=PcdSelect(MLastSelectedSnr);
                        if(status!=MI_OK)
                                RevBuffer[0]=1;
                                break;
                        RevBuffer[0]=3;
                        break;
                case 5:            // Key loading into the MF RC500's EEPROM
            status = PcdAuthState(RevBuffer[1], RevBuffer[3], DefaultKey, MLastSelectedSnr);// 校验卡密码
                        RevBuffer[0]=1;
                        break;
                case 6:
                        RevBuffer[0]=1;
                        break;
                case 7:
                    RevBuffer[0]=1;
                        break;
                case 8:     // Read the mifare card
                            // 读卡
                        status=PcdRead(RevBuffer[1],&RevBuffer[2]);
                        if(status==0)
                        {RevBuffer[0]=17;}
                        else
                        {RevBuffer[0]=1;}
                        break;
                case 9:     // Write the mifare card
                            // 写卡  下载密码
                        status=PcdWrite(RevBuffer[1],&RevBuffer[2]);
                        RevBuffer[0]=1;
                        break;
                case 10:
            PcdValue(RevBuffer[1],RevBuffer[2],&RevBuffer[3]);
                        RevBuffer[0]=1;
                        break;
                case 12:    // 参数设置
                    PcdBakValue(RevBuffer[1], RevBuffer[2]);
                        RevBuffer[0]=1;        //contact
                        RevBuffer[1]=0;
                        break;
//系统初始化
void InitializeSystem()
    P0 = 0xFF; P1 = 0xFF; P3 = 0xFF;
        ET2 = 0;
        T2CON = 0x04;
    PCON = 0x80;
    SCON = 0x70;
    TMOD = 0x21;        //TMOD = 0x22;
        TH1   = BAUD_9600;
        TL1   = TH1;
        TR1   = 1;             // 波特率发生器
        TH0 = 0x60;
    TL0 = 0x60;
    TR0 = 0;
    ET0=0;
        ET1=0;
        EA=1;
        EX0=1;
        IT0 = 1;
        TR2=0;
        ES = 1;
        CmdValid=0;
     LED_GREEN = 1;
     PcdReset();
     PcdAntennaOff();
     PcdAntennaOn();
         M500PcdConfigISOType( 'A' );
     LED_GREEN = 0;
         delay_10ms(10);
     LED_GREEN = 1;
         delay_10ms(10);
     LED_GREEN = 0;
//用T2做延时子程序
// 接收和发送中断
void isr_UART(void) interrupt 4 using 1
    unsigned char len, i;
          unsigned int j=0;
          if(RI)
                len=SBUF;
                RI=0;
                for(i=0;i                {
                        while(!RI)
                                j++;
                                if(j>1000)
                                    break;
                        if(j<1000)
                                RevBuffer[i]=SBUF;
                                RI=0;
                                j=0;
                        else
                            break;
                if(i==len)
                        REN=0;
                        CmdValid=1;
        else if(!RI && TI)
                TI=0;
                len=RevBuffer[0];
                for(i=0;i                {
                        SBUF=RevBuffer[i];
                        while(!TI);
                        TI=0;
                REN=1;
  void main( )
    unsigned char baud;
     InitializeSystem( );
    while (1)
            if (CmdValid)
                    CmdValid = FALSE;
                    if(RevBuffer[0]==11)            //为了加快相应速度 测试风鸣器
                            RevBuffer[2]=RevBuffer[1];
                            RevBuffer[1]=0;
                            CALL_isr_UART();
                LED_GREEN = 1;
                            delay_10ms(RevBuffer[2]);
                LED_GREEN = 0;
                    else if(RevBuffer[0]==13)   //设置通讯波特率
                            switch(RevBuffer[1])
                                    case 0:
                                            baud=BAUD_9600;
                                            break;
                                    case 1:
                                            baud=BAUD_14400;
                                            break;
                                    case 2:
                                            baud=BAUD_19200;
                                            break;
                                    case 3:
                                            baud=BAUD_28800;
                                            break;
                                    case 4:
                                            baud=BAUD_38400;
                                            break;
                                    case 5:
                                            baud=BAUD_57600;
                                            break;
进入单片机查看更多内容>>
相关视频
  • RISC-V嵌入式系统开发
  • SOC系统级芯片设计实验
  • 云龙51单片机实训视频教程(王云,字幕版)
  • 2022 Digi-Key KOL 系列: 你见过1GHz主频的单片机吗?Teensy 4.1开发板介绍
  • TI 新一代 C2000™ 微控制器:全方位助力伺服及马达驱动应用
  • MSP430电容触摸技术 - 防水Demo演示
精选电路图
  • PIC单片机控制的遥控防盗报警器电路
  • RS-485基础知识:处理空闲总线条件的两种常见方法
  • 带有短路保护系统的5V直流稳压电源电路图
  • 如何构建一个触摸传感器电路
  • 如何调制IC555振荡器
  • 基于ICL296的大电流开关稳压器电源电路
    相关电子头条文章
