单片机
【51单片机快速入门指南】4.4.3:Madgwick AHRS 九轴姿态融合获取四元数、欧拉角
2022-07-15 来源:csdn
STC15F2K60S2 22.1184MHz
Keil uVision V5.29.0.0
PK51 Prof.Developers Kit Version:9.60.0.0
上位机:Vofa+ 1.3.10
移植自AHRS —— LOXO,算法作者:SOH Madgwick
传感器的方向
在这里插入图片描述
源码
       所用MCU为STC15F2K60S2 使用内部RC时钟,22.1184MHz
       stdint.h见【51单片机快速入门指南】1:基础知识和工程创建
       软件I2C程序见【51单片机快速入门指南】4: 软件 I2C
       串口部分见【51单片机快速入门指南】3.3:USART 串口通信
       MPU6050驱动程序见【51单片机快速入门指南】4.3: I2C读取MPU6050陀螺仪的原始数据
       HMC5883L/QMC5883L驱动程序见【51单片机快速入门指南】4.4:I2C 读取HMC5883L / QMC5883L 磁力计
       磁力计的椭球拟合校准见【51单片机快速入门指南】4.4.1:python串口接收磁力计数据并进行最小二乘法椭球拟合
       beta要按需调整,我这里取1.0
Madgwick_9.c
// Implementation of Madgwick's IMU and AHRS algorithms.
// See: http://www.x-io.co.uk/node/8#open_source_ahrs_and_imu_algorithms
// Date Author          Notes
// 29/09/2011 SOH Madgwick    Initial release
// 02/10/2011 SOH Madgwick Optimised for reduced CPU load
// 19/02/2012 SOH Madgwick Magnetometer measurement is normalised
// Header files
#include
#include 'MPU6050.h'
// Definitions
#define beta 1.0f // 2 * proportional gain (Kp)
// Variable definitions
float q0 = 1.0f, q1 = 0.0f, q2 = 0.0f, q3 = 0.0f; // quaternion of sensor frame relative to auxiliary frame
float Pitch = 0.0f, Roll = 0.0f, Yaw = 0.0f;
// Functions
float sampleFreq = 1;
float GYRO_K = 1;
void MPU6050_Madgwick_Init(float loop_ms)
sampleFreq = 1000. / loop_ms; //sample frequency in Hz
switch((MPU_Read_Byte(MPU_GYRO_CFG_REG) >> 3) & 3)
case 0:
GYRO_K = 1./131/57.3;
break;
case 1:
GYRO_K = 1./65.5/57.3;
break;
case 2:
GYRO_K = 1./32.8/57.3;
break;
case 3:
GYRO_K = 1./16.4/57.3;
break;
// Fast inverse square-root
// See: http://en.wikipedia.org/wiki/Fast_inverse_square_root
float invSqrt(float x)
float halfx = 0.5f * x;
float y = x;
long i = *(long*)&y;
i = 0x5f3759df - (i>>1);
y = *(float*)&i;
y = y * (1.5f - (halfx * y * y));
return y;
// AHRS algorithm update
// IMU algorithm update
void MadgwickAHRSupdate_6(float gx, float gy, float gz, float ax, float ay, float az)
float recipNorm;
float s0, s1, s2, s3;
float qDot1, qDot2, qDot3, qDot4;
float _2q0, _2q1, _2q2, _2q3, _4q0, _4q1, _4q2 ,_8q1, _8q2, q0q0, q1q1, q2q2, q3q3;
//将陀螺仪AD值转换为 弧度/s
gx = gx * GYRO_K;
gy = gy * GYRO_K;
gz = gz * GYRO_K;
// Rate of change of quaternion from gyroscope
qDot1 = 0.5f * (-q1 * gx - q2 * gy - q3 * gz);
qDot2 = 0.5f * (q0 * gx + q2 * gz - q3 * gy);
qDot3 = 0.5f * (q0 * gy - q1 * gz + q3 * gx);
qDot4 = 0.5f * (q0 * gz + q1 * gy - q2 * gx);
// Compute feedback only if accelerometer measurement valid (avoids NaN in accelerometer normalisation)
if(!((ax == 0.0f) && (ay == 0.0f) && (az == 0.0f))) {
// Normalise accelerometer measurement
recipNorm = invSqrt(ax * ax + ay * ay + az * az);
ax *= recipNorm;
ay *= recipNorm;
az *= recipNorm;
// Auxiliary variables to avoid repeated arithmetic
_2q0 = 2.0f * q0;
_2q1 = 2.0f * q1;
_2q2 = 2.0f * q2;
_2q3 = 2.0f * q3;
_4q0 = 4.0f * q0;
_4q1 = 4.0f * q1;
_4q2 = 4.0f * q2;
_8q1 = 8.0f * q1;
_8q2 = 8.0f * q2;
q0q0 = q0 * q0;
q1q1 = q1 * q1;
q2q2 = q2 * q2;
q3q3 = q3 * q3;
// Gradient decent algorithm corrective step
s0 = _4q0 * q2q2 + _2q2 * ax + _4q0 * q1q1 - _2q1 * ay;
s1 = _4q1 * q3q3 - _2q3 * ax + 4.0f * q0q0 * q1 - _2q0 * ay - _4q1 + _8q1 * q1q1 + _8q1 * q2q2 + _4q1 * az;
s2 = 4.0f * q0q0 * q2 + _2q0 * ax + _4q2 * q3q3 - _2q3 * ay - _4q2 + _8q2 * q1q1 + _8q2 * q2q2 + _4q2 * az;
s3 = 4.0f * q1q1 * q3 - _2q1 * ax + 4.0f * q2q2 * q3 - _2q2 * ay;
recipNorm = invSqrt(s0 * s0 + s1 * s1 + s2 * s2 + s3 * s3); // normalise step magnitude
s0 *= recipNorm;
s1 *= recipNorm;
s2 *= recipNorm;
s3 *= recipNorm;
// Apply feedback step
qDot1 -= beta * s0;
qDot2 -= beta * s1;
qDot3 -= beta * s2;
qDot4 -= beta * s3;
// Integrate rate of change of quaternion to yield quaternion
q0 += qDot1 * (1.0f / sampleFreq);
q1 += qDot2 * (1.0f / sampleFreq);
q2 += qDot3 * (1.0f / sampleFreq);
q3 += qDot4 * (1.0f / sampleFreq);
// Normalise quaternion
recipNorm = invSqrt(q0 * q0 + q1 * q1 + q2 * q2 + q3 * q3);
q0 *= recipNorm;
q1 *= recipNorm;
q2 *= recipNorm;
q3 *= recipNorm;
Pitch = asin(-2.0f * (q1*q3 - q0*q2))* 57.3f;
Roll = atan2(q0*q1 + q2*q3, 0.5f - q1*q1 - q2*q2) * 57.3f;
Yaw = atan2(q1*q2 + q0*q3, 0.5f - q2*q2 - q3*q3)* 57.3f;
void MadgwickAHRSupdate_9(float gx, float gy, float gz, float ax, float ay, float az, float mx, float my, float mz)
float recipNorm;
float hx, hy;
float _2q0mx, _2q0my, _2q0mz, _2q1mx, _2bx, _2bz, _4bx, _4bz, _2q0, _2q1, _2q2, _2q3, _2q0q2, _2q2q3, q0q0, q0q1, q0q2, q0q3, q1q1, q1q2, q1q3, q2q2, q2q3, q3q3;
// Use IMU algorithm if magnetometer measurement invalid (avoids NaN in magnetometer normalisation)
if((mx == 0.0f) && (my == 0.0f) && (mz == 0.0f))
MadgwickAHRSupdate_6(gx, gy, gz, ax, ay, az);
return;
//将陀螺仪AD值转换为 弧度/s
gx = gx * GYRO_K;
gy = gy * GYRO_K;
gz = gz * GYRO_K;
ax *= recipNorm;
ay *= recipNorm;
az *= recipNorm;
// Normalise magnetometer measurement
recipNorm = invSqrt(mx * mx + my * my + mz * mz);
mx *= recipNorm;
my *= recipNorm;
mz *= recipNorm;
_2q0mx = 2.0f * q0 * mx;
_2q0my = 2.0f * q0 * my;
_2q0mz = 2.0f * q0 * mz;
_2q1mx = 2.0f * q1 * mx;
_2q0 = 2.0f * q0;
_2q1 = 2.0f * q1;
_2q2 = 2.0f * q2;
_2q3 = 2.0f * q3;
_2q0q2 = 2.0f * q0 * q2;
_2q2q3 = 2.0f * q2 * q3;
q0q0 = q0 * q0;
q0q1 = q0 * q1;
q0q2 = q0 * q2;
q0q3 = q0 * q3;
q1q1 = q1 * q1;
q1q2 = q1 * q2;
q1q3 = q1 * q3;
q2q2 = q2 * q2;
q2q3 = q2 * q3;
q3q3 = q3 * q3;
// Reference direction of Earth's magnetic field
hx = mx * q0q0 - _2q0my * q3 + _2q0mz * q2 + mx * q1q1 + _2q1 * my * q2 + _2q1 * mz * q3 - mx * q2q2 - mx * q3q3;
hy = _2q0mx * q3 + my * q0q0 - _2q0mz * q1 + _2q1mx * q2 - my * q1q1 + my * q2q2 + _2q2 * mz * q3 - my * q3q3;
_2bx = sqrt(hx * hx + hy * hy);
_2bz = -_2q0mx * q2 + _2q0my * q1 + mz * q0q0 + _2q1mx * q3 - mz * q1q1 + _2q2 * my * q3 - mz * q2q2 + mz * q3q3;
_4bx = 2.0f * _2bx;
_4bz = 2.0f * _2bz;
s0 = -_2q2 * (2.0f * q1q3 - _2q0q2 - ax) + _2q1 * (2.0f * q0q1 + _2q2q3 - ay) - _2bz * q2 * (_2bx * (0.5f - q2q2 - q3q3) + _2bz * (q1q3 - q0q2) - mx) + (-_2bx * q3 + _2bz * q1) * (_2bx * (q1q2 - q0q3) + _2bz * (q0q1 + q2q3) - my) + _2bx * q2 * (_2bx * (q0q2 + q1q3) + _2bz * (0.5f - q1q1 - q2q2) - mz);
s1 = _2q3 * (2.0f * q1q3 - _2q0q2 - ax) + _2q0 * (2.0f * q0q1 + _2q2q3 - ay) - 4.0f * q1 * (1 - 2.0f * q1q1 - 2.0f * q2q2 - az) + _2bz * q3 * (_2bx * (0.5f - q2q2 - q3q3) + _2bz * (q1q3 - q0q2) - mx) + (_2bx * q2 + _2bz * q0) * (_2bx * (q1q2 - q0q3) + _2bz * (q0q1 + q2q3) - my) + (_2bx * q3 - _4bz * q1) * (_2bx * (q0q2 + q1q3) + _2bz * (0.5f - q1q1 - q2q2) - mz);
s2 = -_2q0 * (2.0f * q1q3 - _2q0q2 - ax) + _2q3 * (2.0f * q0q1 + _2q2q3 - ay) - 4.0f * q2 * (1 - 2.0f * q1q1 - 2.0f * q2q2 - az) + (-_4bx * q2 - _2bz * q0) * (_2bx * (0.5f - q2q2 - q3q3) + _2bz * (q1q3 - q0q2) - mx) + (_2bx * q1 + _2bz * q3) * (_2bx * (q1q2 - q0q3) + _2bz * (q0q1 + q2q3) - my) + (_2bx * q0 - _4bz * q2) * (_2bx * (q0q2 + q1q3) + _2bz * (0.5f - q1q1 - q2q2) - mz);
s3 = _2q1 * (2.0f * q1q3 - _2q0q2 - ax) + _2q2 * (2.0f * q0q1 + _2q2q3 - ay) + (-_4bx * q3 + _2bz * q1) * (_2bx * (0.5f - q2q2 - q3q3) + _2bz * (q1q3 - q0q2) - mx) + (-_2bx * q0 + _2bz * q2) * (_2bx * (q1q2 - q0q3) + _2bz * (q0q1 + q2q3) - my) + _2bx * q1 * (_2bx * (q0q2 + q1q3) + _2bz * (0.5f - q1q1 - q2q2) - mz);
s0 *= recipNorm;
s1 *= recipNorm;
s2 *= recipNorm;
s3 *= recipNorm;
qDot1 -= beta * s0;
qDot2 -= beta * s1;
qDot3 -= beta * s2;
qDot4 -= beta * s3;
q0 *= recipNorm;
q1 *= recipNorm;
q2 *= recipNorm;
q3 *= recipNorm;
// END OF CODE
Madgwick_9.h
#ifndef Madgwick_9_H_
#define Madgwick_9_H_
extern float Pitch, Roll, Yaw;
extern float q0, q1, q2, q3;
void MPU6050_Madgwick_Init(float loop_ms);
void MadgwickAHRSupdate_6(float gx, float gy, float gz, float ax, float ay, float az);
void MadgwickAHRSupdate_9(float gx, float gy, float gz, float ax, float ay, float az, float mx, float my, float mz);
#endif
使用方法
先调用MPU6050_Madgwick_Init(dt),参数为一次循环的时间,单位为ms
再使用MadgwickAHRSupdate_9姿态融合函数。
测试
陀螺仪、磁力计的原始数据经校准后输入MadgwickAHRSupdate_9函数
main.c
#include
#include 'intrins.h'
#include 'stdint.h'
#include 'USART.h'
#include './Software_I2C/Software_I2C.h'
#include 'XMC5883L.h'
#include './MPU6050/MPU6050.h'
#include './MPU6050/Madgwick_9.h'
void Delay1ms() //@22.1184MHz
unsigned char i, j;
_nop_();
_nop_();
i = 22;
j = 128;
do
while (--j);
} while (--i);
void delay_ms(uint32_t ms)
while(ms --)
Delay1ms();
#define LED_PORT P0
void main(void)
int16_t mag_x, mag_y, mag_z;
int16_t aacx,aacy,aacz; //加速度传感器原始数据
int16_t gyrox,gyroy,gyroz; //陀螺仪原始数据
MPU_Init();
xmc5883lInit();
AUXR &= 0xBF; //定时器时钟12T模式 1T的51使用12T的定时器程序时需要加入这两句
AUXR &= 0xFE; //串口1选择定时器1为波特率发生器
USART_Init(USART_MODE_1, Rx_ENABLE, STC_USART_Priority_Lowest, 22118400, 115200, DOUBLE_BAUD_ENABLE, USART_TIMER_1);
MPU6050_Madgwick_Init(10.48);
while(1)
MPU_Get_Accelerometer(&aacx, &aacy, &aacz); //得到加速度传感器数据
MPU_Get_Gyroscope(&gyrox, &gyroy, &gyroz); //得到陀螺仪数据
xmc5883lRead(&mag_x, &mag_y, &mag_z);
MadgwickAHRSupdate_9(gyrox+7, gyroy+23, gyroz-1, aacx, aacy, aacz, 1.108270606866881 * (mag_x + 297.2882033958856), 0.9218994400020794 * (mag_y + 3088.0092054124193), 0.9871899380641738 * (mag_z + 782.925290575134));
printf('%f, ', Pitch);
printf('%f, ', Roll);
printf('%frn', Yaw);
效果
在这里插入图片描述
进入单片机查看更多内容>>
相关视频
  • RISC-V嵌入式系统开发
  • SOC系统级芯片设计实验
  • 云龙51单片机实训视频教程(王云,字幕版)
  • 2022 Digi-Key KOL 系列: 你见过1GHz主频的单片机吗?Teensy 4.1开发板介绍
  • TI 新一代 C2000™ 微控制器:全方位助力伺服及马达驱动应用
  • MSP430电容触摸技术 - 防水Demo演示
精选电路图
  • 家用电源无载自动断电装置的设计与制作
  • 短波AM发射器电路设计图
  • 带有短路保护系统的5V直流稳压电源电路图
  • 如何调制IC555振荡器
  • 基于ICL296的大电流开关稳压器电源电路
  • 基于TDA2003的简单低功耗汽车立体声放大器电路
    相关电子头条文章
