PIC16F877A单片机 (中断与定时器Timer1)
2022-01-12 来源:eefocus
1 基本原理
上图中,如果RC0左边外接了外部的晶振,那么T1OSCEN必须置一。这个外部的晶振频率一般都比较低。因为晶振频率越低,一般功耗越低。
为什么这里需要外接晶振呢?保证单片机在休眠模式下还可以计数,这一点是51单片机所不具备的。
2 实现代码
主要根据FIGURE6-2和中断的逻辑框图来编写代码,这样代码的可读性强,也便于理解。但有些寄存器在框图中没有说明,所以也需要仔细阅读定时器0的官方文档,即基本原理部分。
/*----------------函数功能:
中断 定时器1
#include //#include'delay.h'//调用延时子函数 __CONFIG(0xFF32);//芯片配置字,看门狗关,上电延时开,掉电检测关,低压编程关 //__CONFIG(HS&WDTDIS&LVPDIS); /*-----------宏定义--------------*/ #define uint unsigned int #define uchar unsigned char #define V0 RD0 uint i; /*-----------子函数声明--------------*/ /*-----------主函数--------------*/ void main() { // The corresponding data direction register is TRISA. // Setting a TRISA bit (= 1) will make the corresponding PORTA pi an input. // Clearing a TRISA bit (= 0) will make the corresponding PORTA pin an output. TRISD=0xfe; //设置数据方向 RD7-RD1为输入,RD0为输出 // 1 = Port pin is > VIH,即高电平 ; 0 = Port pin is < VIL,即低电平 PORTD=0X00; //端口赋初值 /********定时器TMR1初始化**********/ // Timer1 can operate in one of two modes: (1)As a Timer ;(2)As a Counter // The operating mode is determined by the clock select bit, TMR1CS // In Timer mode, Timer1 increments every instruction cycle. // In Counter mode, it increments on every rising edge of the external clock input // Counter mode is selected by setting bit TMR1CS. 1 = External clock from pin RC0/T1OSO/T1CKI (on the rising edge) // Timer mode is selected by clearing the TMR1CS. 0 = Internal clock (FOSC/4) TMR1CS=0; // TMR1时钟源选择内部指令周期(fosc/4) // T1CKPS1:T1CKPS0: Timer1 Input Clock Prescale Select bits 预分频器 //预分频 1:1,对应的编码为00 //T1CKPS0=0; // 00 = 1:1 prescale value //T1CKPS1=0; //预分频 1:8,对应的编码为11 T1CKPS0=1; // 11 = 1:8 prescale value T1CKPS1=1; // Timer1 External Clock Input Synchronization Control bit // When TMR1CS = 1. 1 = Do not synchronize external clock input. 0 = Synchronize external clock input // When TMR1CS = 0. This bit is ignored. Timer1 uses the internal clock when TMR1CS = 0. // The synchronize control bit, T1SYNC. has no effect since the internal clock is always in sync // T1SYNC=0; // 由于TMR1CS = 0,所以这一位被忽略了 // Timer1 can be enabled/disabled by setting/clearing control bit, TMR1ON // TMR1ON: Timer1 On bit. 1 = Enables Timer1; 0 = Stops Timer1 TMR1ON=1; //打开计数定时器TMR1,状态为ON // The Timer1 module is a 16-bit timer/counter consisting of two 8-bit registers (TMR1H and TMR1L) // which are readable and writable. //16位计数寄存器给初值,在这里没有考虑中断所造成的时钟延迟13个指令周期 TMR1H=(65536-100)/256; //定时100us*8(八分频),计数寄存器就会溢出 TMR1L=(65536-100)%256; // The TMR1 interrupt, if enabled,is generated on overflow // which is latched in interrupt flag bit, TMR1IF TMR1IF=0; //溢出中断标志位清零 // This interrupt can be enabled/disabled by setting/clearing TMR1 interrupt enable bit, TMR1IE TMR1IE=1; //溢出中断标志允许位 置一 PEIE=1; //外设中断允许位 置一 //*********开全局中断设置 //定时器T0设置了中断允许,此处要开全局中断 GIE=1; //总中断允许 while(1) // 死循环,单片机初始化后,就一直运行这个死循环 { } } /*************中断服务程序***************/ void interrupt ISR(void)//PIC单片机的所有中断都是这样一个入口 { // TMR1IF标志位为在计数寄存器由全1变为全0的时候,自动得到置一,即TMR1IF=1. if(TMR1IF==1) // 需要进一步判断是否为定时器1的溢出中断标志位 { //定时器中断后,要重置初值,以备下次中断 TMR1H=(65536-100)/256; TMR1L=(65536-100)%256; //溢出中断标志位清零 如果TMR1IF出现上升沿,则产生中断,所以中断发生之后要清零。 TMR1IF=0; // 执行中断处理程序,执行中断产生时想要执行的功能 if(++i>1250) //800us中断一次,再计次1250次后就是1s { i=0; V0=!V0; // 取反 实现一秒的闪烁 } } } 为什么有下面两行语句,这是由中断决定的,如下图所示。 PEIE=1; //外设中断允许位置一 GIE=1; //总中断允许
- 将DHT11与PIC16F877A连接进行温度和湿度的测量
- 基于PIC16F877A的呼吸灯的实现+Proteus的仿真
- PIC16F877A单片机 (中断与定时器Timer0)
- PIC16F877A单片机 (中断与定时器Timer2)
- PIC16F877A单片机 (外部中断)
- PIC16F877A单片机 (外部中断与定时器Timer0的综合使用)
- PIC16F877A单片机 (ADC)
- PIC16F877A单片机 (IIC总线+AT24C02芯片)
- PIC16F877A单片机 (IIC总线+PCF8563芯片)
- 英飞凌与西门子将嵌入式汽车软件平台与微控制器结合 为下一代SDV提供所需功能
