JZ2440裸板之SDRAM启动分析
2018-10-14 来源:eefocus
启动文件head.S源码:
@ File:head.S
@ 功能:设置SDRAM,将程序复制到SDRAM,然后跳到SDRAM继续执行
.equ MEM_CTL_BASE, 0x48000000
.equ SDRAM_BASE, 0x30000000
.text
.global _start
_start:
bl disable_watch_dog @ 关闭WATCHDOG,否则CPU会不断重启
bl memsetup @ 设置存储控制器
bl copy_steppingstone_to_sdram @ 复制代码到SDRAM中
ldr pc, =on_sdram @ 跳到SDRAM中继续执行
on_sdram:
ldr sp, =0x34000000 @ 设置堆栈
bl main
halt_loop:
b halt_loop
disable_watch_dog:
@ 往WATCHDOG寄存器写0即可
mov r1, #0x53000000
mov r2, #0x0
str r2, [r1]
mov pc, lr @ 返回
copy_steppingstone_to_sdram:
@ 将Steppingstone的4K数据全部复制到SDRAM中去
@ Steppingstone起始地址为0x00000000,SDRAM中起始地址为0x30000000
mov r1, #0
ldr r2, =SDRAM_BASE
mov r3, #4*1024
1:
ldr r4, [r1],#4 @ 从Steppingstone读取4字节的数据,并让源地址加4
str r4, [r2],#4 @ 将此4字节的数据复制到SDRAM中,并让目地地址加4
cmp r1, r3 @ 判断是否完成:源地址等于Steppingstone的未地址?
bne 1b @ 若没有复制完,继续
mov pc, lr @ 返回
memsetup:
@ 设置存储控制器以便使用SDRAM等外设
mov r1, #MEM_CTL_BASE @ 存储控制器的13个寄存器的开始地址
adrl r2, mem_cfg_val @ 这13个值的起始存储地址
add r3, r1, #52 @ 13*4 = 54
1:
ldr r4, [r2], #4 @ 读取设置值,并让r2加4
str r4, [r1], #4 @ 将此值写入寄存器,并让r1加4
cmp r1, r3 @ 判断是否设置完所有13个寄存器
bne 1b @ 若没有写成,继续
mov pc, lr @ 返回
.align 4
mem_cfg_val:
@ 存储控制器13个寄存器的设置值
.long 0x22011110 @ BWSCON
.long 0x00000700 @ BANKCON0
.long 0x00000700 @ BANKCON1
.long 0x00000700 @ BANKCON2
.long 0x00000700 @ BANKCON3
.long 0x00000700 @ BANKCON4
.long 0x00000700 @ BANKCON5
.long 0x00018005 @ BANKCON6
.long 0x00018005 @ BANKCON7
.long 0x008C07A3 @ REFRESH
.long 0x000000B1 @ BANKSIZE
.long 0x00000030 @ MRSRB6
.long 0x00000030 @ MRSRB7
leds.c源码:
#define GPFCON (*(volatile unsigned long *)0x56000050)
#define GPFDAT (*(volatile unsigned long *)0x56000054)
#define GPF4_out (1<<(4*2))
#define GPF5_out (1<<(5*2))
#define GPF6_out (1<<(6*2))
void wait(volatile unsigned long dly)
for(; dly > 0; dly--);
int main(void)
unsigned long i = 0;
GPFCON = GPF4_out|GPF5_out|GPF6_out; // 将LED1,2,4对应的GPF4/5/6三个引脚设为输出
while(1){
wait(30000);
GPFDAT = (~(i<<4)); // 根据i的值,点亮LED1,2,4
if(++i == 8)
i = 0;
return 0;
Makefile文件:
sdram.bin : head.S leds.c
arm-linux-gcc -c -o head.o head.S
arm-linux-gcc -c -o leds.o leds.c
arm-linux-ld -Ttext 0x30000000 head.o leds.o -o sdram_elf
arm-linux-objcopy -O binary -S sdram_elf sdram.bin
arm-linux-objdump -D -m arm sdram_elf > sdram.dis
clean:
rm -f sdram.dis sdram.bin sdram_elf *.o
注意:
虽然nor flash、网卡和SDRAM的接口一样都是内存类接口,但是SDRAM属于内存类设备,nor flash、网卡不属于内存类设备,叫做RAM Like。
此实验在测试时不能直接下载到内存中直接运行,要先烧写到nand flash中再运行,否则从片内内存拷贝4k到SDRAM中运行系统会崩溃。
具体下载方法参见:“JZ2440开发板裸板烧写方法”
上一篇:JZ2440裸板之MMU操作
