单片机
linux-2.6.38到tiny6410的移植手册(连载4)__USB设备(U盘,摄像头,wifi)
2024-10-15 来源:cnblogs
今天来讲讲一些USB设备(U盘,摄像头,wifi)的驱动吧,它的特点是内核已经带非常完善的驱动了,
我们需要的就是配置而已,和很少的修改而已。
一、首先是U盘得支持。
1、vi arch/arm/mach-s3c64xx/mach-mini6410.c
124行增加
/* Initializes OTG Phy. to output 48M clock */
void s3c_otg_phy_config(int enable) {
        u32 val;
        if (enable) {
                __raw_writel(0x0, S3C_PHYPWR);  /* Power up */
                val = __raw_readl(S3C_PHYCLK);
                val &= ~S3C_PHYCLK_CLKSEL_MASK;
                __raw_writel(val, S3C_PHYCLK);
                __raw_writel(0x1, S3C_RSTCON);
                udelay(5);
                __raw_writel(0x0, S3C_RSTCON);  /* Finish the reset */
                udelay(5);
        } else {
                __raw_writel(0x19, S3C_PHYPWR); /* Power down */
2、vi drivers/usb/host/ohci-s3c2410.c
修改方法
@@ -25,10 +25,14 @@
#define valid_port(idx) ((idx) == 1 || (idx) == 2)
+#ifdef CONFIG_MACH_MINI6410
+extern void s3c_otg_phy_config(int enable);
+#endif
/* clock device associated with the hcd */
static struct clk *clk;
-static struct clk *usb_clk;
+static struct clk *otg_clk, *usb_clk;
/* forward definitions */
@@ -47,6 +51,11 @@
     dev_dbg(&dev->dev, 's3c2410_start_hc:n');
+    clk_enable(otg_clk);
+    s3c_otg_phy_config(1);
+#endif
     clk_enable(usb_clk);
     mdelay(2);            /* let the bus clock stabilise */
@@ -79,6 +88,7 @@
     clk_disable(clk);
     clk_disable(usb_clk);
+    clk_disable(otg_clk);
/* ohci_s3c2410_hub_status_data
@@ -375,6 +385,13 @@
         goto err_clk;
+    otg_clk = clk_get(&dev->dev, 'otg');
+    if (IS_ERR(otg_clk)) {
+        dev_err(&dev->dev, 'cannot get otg clockn');
+        retval = -ENOENT;
+        goto err_otg;
     s3c2410_start_hc(dev, hcd);
     hcd->regs = ioremap(hcd->rsrc_start, hcd->rsrc_len);
@@ -395,6 +412,10 @@
  err_ioremap:
     s3c2410_stop_hc(dev);
     iounmap(hcd->regs);
+    clk_put(otg_clk);
+ err_otg:
     clk_put(usb_clk);
  err_clk:
3、make menuconfig
Device Drivers  --->
    SCSI device support  --->
         <*> SCSI device support
         <*> SCSI disk support
         <*> SCSI generic support
    USB support
         <*>   Support for Host-side USB
         [*]     USB device filesystem (DEPRECATED)
        <*>   USB Monitor
        <*>   OHCI HCD support
        <*>   USB Mass Storage support
File systems  --->
    DOS/FAT/NT Filesystems  --->
           <*> MSDOS fs support
            <*> VFAT (Windows-95) fs support
          (936) Default codepage for FAT
         (cp936) Default iocharset for FAT
启动之后插入u盘显示
[root@FriendlyARM /]# usb 1-1.2: new full speed USB device using s3c2410-ohci and address 3
usb 1-1.2: New USB device found, idVendor=1043, idProduct=8012
usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
usb 1-1.2: Product: USB Flash Drive
usb 1-1.2: Manufacturer: Generic
uba: uba4
挂载 mount /dev/uba4 /mnt后即能看到u盘里的数据了
二、说说usb摄像头的和usb-wifi的支持吧,这两个东西得看你的设备是什么芯片,
先说usb摄像头吧,关于摄像头的驱动驱动配置比较简单,只是关于驱动接口有两种版本,分别
是V4L和V4L2,从2.6以后以后有了V4L2,我的linux2.6.38已经看不到关于v4l支持了,
在linux2.6.30.4的版本中我们还能看到
中有Video For linux API 1的支持,但38的版本却看不到了,所以 像gspcav1-20071224.tar.gz这样的v4l接口的驱动就加不进去了,
而很多V4l接口的usb测试程序也就用不了了,网上很少有V4l2的测试程序,所以友善也就没有开源的他的USB摄像头程序了(个人理解,不知是否正确)
既然这样我们就学友善的,按V4l2的来配置吧
我的摄像头芯片是sunplus凌阳的SPCA2000C的,支持UVC,支持UVC的就可以不用管是什么芯片了,选上一个就行
Device Drivers  --->
           <*> Multimedia support  --->
                        <*>   Video For Linux
                        [*]   Video capture adapters  --->
                                   [*]   V4L USB devices  --->
                                                 <*>   USB Video Class (UVC)    选上这个就行了
make zImage后启动,插上usb摄像头,显示
[root@FriendlyARM /]# usb 1-1.1: new full speed USB device using s3c2410-ohci and address 4
usb 1-1.1: New USB device found, idVendor=04fc, idProduct=2003
usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
usb 1-1.1: Product: Sunplus Camera
usb 1-1.1: Manufacturer: Sunplus Camera
usb 1-1.1: SerialNumber: CN0316-MM00-OV03-VH-R61.01.00
uvcvideo: Found UVC 1.00 device Sunplus Camera (04fc:2003)
input: Sunplus Camera as /devices/platform/s3c2410-ohci/usb1/1-1/1-1.1/1-1.1:1.0/input/input1
在/dev/多了个video0,
测试的话用mjpg-streamer就能够测试了具体看友善光盘A中的   开发文档和教程  中的 专题04 通过Web远程浏览并控制Mini6410上的摄像头
此外,我还有个中星微的芯片是ZC0301的摄像头,它的配置是
Device Drivers  --->
                        <*>   Video For Linux
                                   <*>   GSPCA based webcams  --->
                                                     <*>   ZC3XX USB Camera Driver
make zImage插上后显示
[root@FriendlyARM /]# usb 1-1.1: USB disconnect, address 4
usb 1-1.1: new full speed USB device using s3c2410-ohci and address 5
usb 1-1.1: New USB device found, idVendor=0ac8, idProduct=301b
usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
usb 1-1.1: Product: PC Camera
usb 1-1.1: Manufacturer: Vimicro Corp.
gspca: probing 0ac8:301b
zc3xx: probe 2wr ov vga 0x0000
zc3xx: probe sensor -> 0011
zc3xx: Find Sensor HV7131R
input: zc3xx as /devices/platform/s3c2410-ohci/usb1/1-1/1-1.1/input/input2
gspca: video0 created
它采集到得数据直接是jpeg的,所以不能用mjpg-stream来测试,友善修改后mjpg-stream要求采集的数据是yuv货mjpg的,
我找了个基于v4l2的测试程序,看http://hi.baidu.com/aokikyon/blog/item/6e4e622c3e6f9be18b13993f.html,它将采集到数据直接存到了jpeg文件里面
见附件也行
三、说说usb-wifi的驱动
我的usb-wifi芯片是Ralink的RT2571WF,这个我是拆开看的,所以它的配置是
--- Wireless
      <*>   cfg80211 - wireless configuration API
     <*>   Generic IEEE 802.11 Networking Stack (mac80211)
[*]   Wireless LAN  --->
    <*>   Ralink driver support  --->
         <*>   Ralink rt2501/rt73 (USB) support
然后make zImage后显示
usb 1-1.2: New USB device found, idVendor=148f, idProduct=2573
usb 1-1.2: New USB device strings: Mfr=0, Product=0, SerialNumber=0
接着输入命令
0.ifconfig wlan0 up
1.列出区域内的无线网络
iwlist wlan0 scan
2.连接到网络
iwconfig wlan0 essid 'MyHome' key s:12345
这个密码是无线路由的密码,如果没有就不用输入了。由于无线路由的密码形式有很多种,有wep和wpa什么的。
我们用的事wep,所以在输入key后加个s。
3.设置ip
ifconfig wlan0 10.10.86.91
3.启动网卡
ifconfig wlan0 up
这样就能够ping通了
总之,USB设备内核已经做的很多驱动,我们要做的是根据芯片选上对应的配置。
友善里面为USB做的驱动有两个,一个是usb转串口,一个是3g上网卡,这两个驱动是要自己加的,源码在
drivers/usb/serial/3g_devices.c
drivers/usb/serial/pl2303.c
大家只要将这两文件拷贝过来,编译进内核就可以使用了
进入单片机查看更多内容>>
相关视频
  • RISC-V嵌入式系统开发
  • SOC系统级芯片设计实验
  • 云龙51单片机实训视频教程(王云,字幕版)
  • 2022 Digi-Key KOL 系列: 你见过1GHz主频的单片机吗?Teensy 4.1开发板介绍
  • TI 新一代 C2000™ 微控制器:全方位助力伺服及马达驱动应用
  • MSP430电容触摸技术 - 防水Demo演示
精选电路图
  • 家用电源无载自动断电装置的设计与制作
  • 短波AM发射器电路设计图
  • 使用ESP8266从NTP服务器获取时间并在OLED显示器上显示
  • RS-485基础知识:处理空闲总线条件的两种常见方法
  • 如何调制IC555振荡器
  • 基于TDA2003的简单低功耗汽车立体声放大器电路
    相关电子头条文章
