【接上一章节明远智睿MY-IMX6 Linux-4.1.15 编译参考手册(2)】
4.3 编译设备树目标文件执行编译命令
=====> Input:
make myimx6ek140p-6y-256m-emmc.dtb
=====> Output:
DTC arch/arm/boot/dts/myimx6ek140p-6y-256m-emmc.dtb
【注意】:上面 make 后面的 myimx6ek140p-6y-256m-emmc.dtb 改为与开发板型号对应的配置文件。
********** MY-IMX6-EK140 **********
myimx6ek140-6g-128m-emmc.dtb myimx6ek140-6y-128m-emmc.dtb
myimx6ek140-6g-128m-nand.dtb myimx6ek140-6y-128m-nand.dtb
myimx6ek140-6g-256m-emmc.dtb myimx6ek140-6y-256m-emmc.dtb
myimx6ek140-6g-256m-nand.dtb myimx6ek140-6y-256m-nand.dtb
myimx6ek140-6g-512m-emmc.dtb myimx6ek140-6y-512m-emmc.dtb
myimx6ek140-6g-512m-nand.dtb myimx6ek140-6y-512m-nand.dtb
********** MY-IMX6-EK140P **********
myimx6ek140p-6g-128m-emmc.dtb myimx6ek140p-6y-128m-emmc.dtb
myimx6ek140p-6g-128m-nand.dtb myimx6ek140p-6y-128m-nand.dtb
myimx6ek140p-6g-256m-emmc.dtb myimx6ek140p-6y-256m-emmc.dtb
myimx6ek140p-6g-256m-nand.dtb myimx6ek140p-6y-256m-nand.dtb
myimx6ek140p-6g-512m-emmc.dtb myimx6ek140p-6y-512m-emmc.dtb
myimx6ek140p-6g-512m-nand.dtb myimx6ek140p-6y-512m-nand.dtb
********** MY-IMX6-EK200 **********
myimx6ek200-6q-1g.dtb myimx6ek200-6q-2g.dtb myimx6ek200-6q-512m.dtb
myimx6ek200-6u-1g.dtb myimx6ek200-6u-2g.dtb myimx6ek200-6u-512m.dtb
myimx6ek200-6s-512m.dtb myimx6ek200-6s-1g.dtb myimx6ek200-6s-128m.dtb
myimx6ek200-6qp-1g.dtb myimx6ek200-6qp-2g.dtb myimx6ek200-6qp-512m.dtb
********** MY-IMX6-EK314 **********
myimx6ek314-6q-1g.dtb myimx6ek314-6q-2g.dtb myimx6ek314-6q-512m.dtb
myimx6ek314-6u-1g.dtb myimx6ek314-6u-2g.dtb myimx6ek314-6u-512m.dtb
myimx6ek314-6s-512m.dtb myimx6ek314-6s-1g.dtb myimx6ek314-6s-128m.dtb
myimx6ek314-6qp-1g.dtb myimx6ek314-6qp-2g.dtb myimx6ek314-6qp-512m.dtb
********** MY-IMX6-EK336 **********
myimx6ek336-6q-1g.dtb myimx6ek336-6q-2g.dtb myimx6ek336-6q-512m.dtb
复制设备树目标文件
=====> Input:
cp arch/arm/boot/dts/myimx6ek140p-6y-256m-emmc.dtb ./
4.4 编译内核模块包执行编译
=====> Input:
make modules
=====> Output:
scripts/kconfig/conf --silentoldconfig Kconfig
CHK include/config/kernel.release
WRAP arch/arm/include/generated/asm/bitsperlong.h
WRAP arch/arm/include/generated/asm/current.h
LD [M] sound/usb/snd-usb-audio.ko
LD [M] sound/usb/snd-usbmidi-lib.ko
LD [M] sound/core/snd-rawmidi.ko
创建内核模块的保存目录
=====> Input:
mkdir modules
安装内核模块到指定目录
=====> Input:
make modules_install INSTALL_MOD_PATH=./modules
=====> Output:
INSTALL crypto/tcrypt.ko
INSTALL drivers/dma/dmatest.ko
INSTALL drivers/i2c/algos/i2c-algo-pca.ko
INSTALL sound/usb/snd-usb-audio.ko
INSTALL sound/usb/snd-usbmidi-lib.ko
DEPMOD 4.1.15-myimx6-svn368
打包内核模块文件
=====> Input:
tar cjf kernel-modules.tar.bz2 -C modules lib
4.5 目标文件zImage、myimx6ek*.dtb 和 kernel-modules.tar.bz2 即编译得到的目标文件,保存这三个文件
5 Linux C程序编译5.1 准备源码打开网盘到 5_MY-Demo -> MY-Linux-C-Demo,下载 hello.c 文件,并复制到虚拟机。
5.2 编译目标文件=====> Input:
$CC hello.c -o hello.out
Note: 如果有“未找到命令”的信息,是因为交叉编译工具链的配置没有生效,可以按前面 “交叉编译工具链安装” 中的 “source 工具链配置文件” 操作一次后再执行此步骤
5.3 运行Linux C目标程序把编译得到的 hello.out 复制到开发板上
在开发板上运行Linux C目标程序
=====> Input:
chmod +x ./hello.out
./hello.out
=====> Output:
MYZR Technology Co.,Ltd.
Tel: 0756-3628023/3628021
6 Linux QT5程序编译6.1 准备源码打开网盘到 5_MY-Demo,下载 MY-Linux-QT5-Demo-AboutUs-svn*.tar.bz2 文件,并复制到虚拟机。
解压源码包到工作目录
=====> Input:
tar xf MY-Linux-QT5-Demo-AboutUs-svn*.tar.bz2-C ~/my-work/02_source/
6.2 QT程序编译进入源码目录
=====> Input:
cd ~/my-work/02_source/AboutUs/
生成Makefile文件
=====> Input:
qmake
Note: 如果有“未找到 'qamke' 命令”的信息,是因为交叉编译工具链的配置没有生效,可以按前面 “交叉编译工具链安装” 中的 “source 工具链配置文件” 操作一次后再执行此步骤
编译目标文件
=====> Input:
make
=====> Output:
/home/myzr/my-work/03_toolchain/fsl-imx-x11-glibc-x86_64-meta-toolchain-qt5-cortexa7hf-neon-toolchain-4.1.15-2.1.0/sysroots/x86_64-pokysdk-linux/usr/bin/qt5/uic widget.ui -o ui_widget.h
arm-poky-linux-gnueabi-g++ -march=armv7ve -mfpu=neon -mfloat-abi=hard -mcpu=cortex-a7 --sysroot=/home/myzr/my-work/03_toolchain/fsl-imx-x11-glibc-x86_64-meta-toolchain-qt5-cortexa7hf-neon-toolchain-4.1.15-2.1.0/sysroots/cortexa7hf-neon-poky-linux-gnueabi -Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed -Wl,-O1 -o AboutUs main.o widget.o qrc_source.o moc_widget.o -lQt5Widgets -lQt5Gui -lQt5Core -lGLESv2 -lEGL -lpthread
6.3 在 MY-IMX6-A9 设备上运行把编译得到的 AboutUs 复制到开发板上
在开发板上运行QT5目标程序
=====> Input:
chmod +x ./AboutUs
./AboutUs -platform eglfs
6.4 在 MY-IMX6-A7 设备上运行把编译得到的 AboutUs 复制到开发板上
在开发板上运行QT5目标程序
=====> Input:
export DISPLAY=:0.0
chmod +x AboutUs
./AboutUs
6.5 运行结果可以看到开发板显示屏上输出了 MYZR 的 Logo 和一些信息。
