[分享] 分享经验 [RK3399] Type-C改为普通USB
qq7643066   2021-2-17 10:58 楼主
CPURK3399
系统:Android 7.1.2
为了降低成本,主板将 Type-C 改为 MicroUSB 接口,节省了 fusb302芯片
参考 Rockchip 的官方文档第4部分:Micro USB2.0 OTG DTS配置
RKDocs/common/usb/Rockchip-Developer-Guide-Linux4.4-RK3399-USB-DTS-CN.pdf
&tcphy0 {
    status = "disabled";
&u2phy0 {
    status = "okay"; /* Micro USB2 PHY 删除了extcon属性 */
    otg-vbus-gpios = <&gpio3 RK_PC6 GPIO_ACTIVE_HIGH>; /* Vbus GPIO配置 */
    u2phy0_otg: otg-port { /* 文档中错误写成了u2phy1_otg */
        status = "okay";
&usbdrd3_0 {
    extcon = <&u2phy0>; /* Micro USB3控制器的extcon属性引用u2phy0 */
    status = "okay";
&usbdrd_dwc3_0 {
    dr_mode = "otg"; /* Micro USB3控制器的dr_mode配置为otg */
    maximum-speed = "high-speed"; /* maximum-speed 属性配置为high-speed */
    phys = <&u2phy0_otg>; /* phys 属性只引用USB2 PHY节点 */
    phy-names = "usb2-phy";
    status = "okay";
按照文档中说明,修改这部分就可以了,但是编译内核部分烧录后,不能进安卓系统,串口一直循环打印如下:
[    9.878630] init: Starting service 'surfaceflinger'...
[   10.294620] init: Service 'surfaceflinger' (pid 532) killed by signal 6
[   10.294664] init: Service 'surfaceflinger' (pid 532) killing any children in process group
[   10.294709] init: Service 'zygote' is being killed...
[   10.356365] init: Service 'zygote' (pid 254) killed by signal 9
[   10.356441] init: Service 'zygote' (pid 254) killing any children in process group
[   10.356634] init: write_file: Unable to open '/sys/android_power/request_state': No such file or directory
[   10.356778] init: write_file: Unable to write to '/sys/power/state': Invalid argument
[   10.356805] init: Service 'audioserver' is being killed...
[   10.357239] init: Service 'cameraserver' is being killed...
[   10.357327] init: Service 'media' is being killed...
[   10.357454] init: Service 'netd' is being killed...
[   10.358943] init: Starting service 'zygote'...
[   10.364342] init: Service 'audioserver' (pid 299) killed by signal 9
[   10.364427] init: Service 'audioserver' (pid 299) killing any children in process group
[   10.365879] init: Starting service 'audioserver'...
[   10.369573] init: Service 'netd' (pid 310) killed by signal 9
[   10.369677] init: Service 'netd' (pid 310) killing any children in process group
[   10.370582] init: Untracked pid 575 killed by signal 9
[   10.374127] init: Service 'media' (pid 297) killed by signal 9
[   10.374192] init: Service 'media' (pid 297) killing any children in process group
[   10.375119] init: Service 'cameraserver' (pid 300) killed by signal 9
[   10.375158] init: Service 'cameraserver' (pid 300) killing any children in process group
[   10.376450] init: Starting service 'media'...
[   10.378976] init: Starting service 'cameraserver'...
[   10.382610] init: couldn't write 580 to /dev/cpuset/camera-daemon/tasks: No such file or directory
[   12.079202] init: Starting service 'netd'...
开始怀疑是因为没有全部编译的问题,但是全部编译烧录后,还是不能开机,一直提示找不到 drm device,串口一直循环打印如下:
__bionic_open_tzdata: couldn't find any tzdata when looking for GMT!
Starting recovery (pid 185) on Fri Jan 18 08:52:30 2013
bootmode = emmc
recovery filesystem table
  0 /mnt/internal_sd vfat /dev/block/platform/fe330000.sdhci/by-name/user 0
  1 /mnt/external_sd vfat /dev/block/mmcblk0p1 0
  2 /system ext4 /dev/block/platform/fe330000.sdhci/by-name/system 0
  3 /cache ext4 /dev/block/platform/fe330000.sdhci/by-name/cache 0
  4 /metadata ext4 /dev/block/platform/fe330000.sdhci/by-name/metadata 0
  5 /data ext4 /dev/block/platform/fe330000.sdhci/by-name/userdata 0
  6 /cust ext4 /dev/block/platform/fe330000.sdhci/by-name/cust 0
  7 /custom ext4 /dev/block/platform/fe330000.sdhci/by-name/custom 0
  8 /misc emmc /dev/block/platform/fe330000.sdhci/by-name/misc 0
  9 /uboot emmc /dev/block/platform/fe330000.sdhci/by-name/uboot 0
  10 /charge emmc /dev/block/platform/fe330000.sdhci/by-name/charge 0
  11 /resource emmc /dev/block/platform/fe330000.sdhci/by-name/resource 0
  12 /parameter emmc /dev/block/platform/fe330000.sdhci/by-name/parameter 0
  13 /boot emmc /dev/block/platform/fe330000.sdhci/by-name/boot 0
  14 /recovery emmc /dev/block/platform/fe330000.sdhci/by-name/recovery 0
  15 /backup emmc /dev/block/platform/fe330000.sdhci/by-name/backup 0
  16 /trust emmc /dev/block/platform/fe330000.sdhci/by-name/trust 0
  17 /baseparameter emmc /dev/block/platform/fe330000.sdhci/by-name/baseparameter 0
  18 /frp emmc /dev/block/platform/fe330000.sdhci/by-name/frp 0
  19 /tmp ramdisk ramdisk 0
emmc_point is /dev/block/mmcblk1
sd_point is (null)
sd_point_2 is (null)
I:InternalSD_ROOT: /mnt/internal_sd
I:ExternalSD_ROOT: /mnt/external_sd
read cmdline
[    4.309235] fs_mgr: Warning: unknown flag resize
I:Boot command: boot-recovery
I:Got arguments from boot message
[    4.311229] fs_mgr: Warning: unknown flag resize
=== start void dumpCmdArgs(int, char **):296 ===
argv[0] =  recovery.
argv[1] =  --wipe_all.
locale is [en_US]
stage is []
reason is [(null)]
cannot find/open a drm device: No such file or directory
cannot open fb0: No such file or directory
[    4.352842] init: Service 'recovery' (pid 185) killed by signal 11
[    4.352952] init: Service 'recovery' (pid 185) killing any children in process group
[    9.358734] init: Starting service 'recovery'...
查看 dts 文件,里面还有一个地方 &cdn_dp 使用了 fusb0,屏蔽此处即可开机
&cdn_dp {
    extcon = <&fusb0>;
    phys = <&tcphy0_dp>;
最后建议把 i2c 中与 fusb302 通讯的部分也 disable 掉,此处不改也没有问题,只是 i2c 不通,但可以正常开机。
fusb0: fusb30x@22 {
    compatible = "fairchild,fusb302";
    reg = <0x22>;
    pinctrl-names = "default";
    pinctrl-0 = <&fusb0_int>;
    int-n-gpios = <&gpio1 2 GPIO_ACTIVE_HIGH>;
    vbus-5v-gpios = <&gpio4 26 GPIO_ACTIVE_HIGH>;
回复评论 (3)
感谢分享 学习了
点赞  2021-2-17 14:42
这样干之后要么只能host要么只能device
点赞  2021-2-17 15:22
感谢分享,楼主把代码整理一下(有编辑代码的控件),或者作为附件是最好的。
点赞  2021-2-17 21:10
    写回复
