[原创] ST MEMS状态机和机器学习.ucf文件转c代码工具。
littleshrimp   2022-4-21 13:00 楼主
请问LSM6DSOX 的FSM 和MLC功能 配置好的ucf文件后续如何转换成C代码嵌入到MCU
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.IO;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using System.Windows.Forms;
namespace UcfFile2CCode
    public partial class MainWindow : Form
        public MainWindow()
            InitializeComponent();
        private void button1_Click(object sender, EventArgs e)
            OpenFileDialog dialog = new OpenFileDialog();
            dialog.Filter = "ucf files (*.ucf)|*.ucf|All files (*.*)|*.*";
            dialog.Title = "请选择要转换的.ucf文件";
            if (dialog.ShowDialog() == DialogResult.OK)
                string ccode = "typedef struct {\r\n" +
                                "\tuint8_t address;\r\n" +
                                "\tuint8_t data;\r\n" +
                                "}ucf_line_t;\r\n\r\n" +
                                "const ucf_line_t ucf_lines[] = {\r\n";
                string[] ucfTextLines = File.ReadAllLines(dialog.FileName);
                foreach (string ucfTextLine in ucfTextLines)
                    if (ucfTextLine.IndexOf("Ac") == 0)
                        string[] sp = ucfTextLine.Split(' ');
                        ccode += string.Format("\t{{.address = {0}, .data = {1},}},\r\n", sp[1], sp[2]);
                ccode = ccode.Substring(0, ccode.Length - 3) + "\r\n};";
                File.WriteAllText(dialog.FileName + ".h", ccode);
UcfFile2CCode bin.zip (4.13 KB)
(下载次数: 2, 2022-4-21 12:57 上传)
UcfFile2CCode source.zip (14.87 KB)
虾扯蛋,蛋扯虾,虾扯蛋扯虾
回复评论
暂无评论,赶紧抢沙发吧
    写回复
