[作品提交] 【得捷Follow me第4期】+FTP服务器(任务汇总帖)
jone5   2024-2-25 12:06 楼主
入门任务:开发环境搭建,BLINK,驱动液晶显示器进行显示(没有则串口HelloWorld)
搭配器件: W5500-EVB-Pico、 Adafruit Sharp Memory Display Breakout
 一.搭建开发环境
背景:
I/O
Pin Name
GPIO16
Connected to MISO on W5500
GPIO17
Connected to CSn on W5500
GPIO18
Connected to SCLK on W5500
GPIO19
Connected to MOSI on W5500
GPIO20
Connected to RSTn on W5500
GPIO21
Connected to INTn on W5500
GPIO24
VBUS sense - high if VBUS is present, else low
GPIO25
Connected to user LED
GPIO29
Used in ADC mode (ADC3) to measure VSYS/3
GP10
SPI0 SCK (LCD)
GP11
SPI0 TX(LCD)
GP12
SPI0 RX(LCD)
GP13
SPI0 Csn(LCD)
1.1 搭建CircuitoPython环境
      本次任务使用CircuitPython完成任务,首先下载CircuitPython最新固件,可通过以下链接获取:
https://learn.adafruit.com/getting-started-with-raspberry-pi-pico-circuitpython/circuitpython
下载完成后,通过Thony下载uf2固件,步骤如下图:
1.2 安装WIZnet 库
安装WIZnet Ethernet 库,通过以下路径下载https://learn.adafruit.com/ethernet-for-circuitpython/circuitpython-setup
下载完成后将以下三个文件夹拷贝至CircuitPython文件夹
1.3 安装显示屏库
打开以下路径:https://github.com/adafruit/Adafruit_CircuitPython_Bundle/releases   下载8.x版本bundle库
下载完成后可按下图将相关库文件放至lib文件夹
至此我们已经完成了开发环境搭建,接着开始最经典的点灯环节。
import random
import time
from adafruit_display_text.label import Label
from terminalio import FONT
from adafruit_bitmap_font import bitmap_font
import board
import displayio
import framebufferio
import sharpdisplay
import digitalio
import busio
def LCD_Init():
    #SPI1
    SPI1_SCK = board.GP10
    SPI1_TX = board.GP11
    SPI1_RX = board.GP12
    chip_select_pin = board.GP13
    # Release the existing display, if any
    displayio.release_displays()
    #display setting
    bus = busio.SPI(SPI1_SCK, MOSI=SPI1_TX, MISO=SPI1_RX)
    # Select JUST ONE of the following lines:
    # For the 400x240 display (can only be operated at 2MHz)  144*168
    framebuffer = sharpdisplay.SharpMemoryFramebuffer(bus, chip_select_pin, 144, 168)
    # For the 144x168 display (can be operated at up to 8MHz)
    #framebuffer = sharpdisplay.SharpMemoryFramebuffer(bus, chip_select_pin, width=144,height=168, baudrate=8000000)
    display = framebufferio.FramebufferDisplay(framebuffer)
    return display
def show(display):
    #creat the text label
    label = Label(font=FONT, text="BLACK\nLIVES\nMATTER", x=0, y=4, scale=1,line_spacing=1.2)
    #show it
    display.root_group = label
def LED_Init():
    led = digitalio.DigitalInOut(board.LED)
    led.direction = digitalio.Direction.OUTPUT
    return led
def led_flush(led):
    led.value = not led.value
    time.sleep(0.5)
def U_show():
    print("hello world")
if __name__ == '__main__':
    display = LCD_Init()
    led = LED_Init()
    show(display)
    while True:
        led_flush(led)
基础任务一:完成主控板W5500初始化(静态IP配置),并能使用局域网电脑ping通,同时W5500可以ping通互联网站点;通过抓包软件(Wireshark、Sniffer等)抓取本地PC的ping报文,展示并分析。
增加W5500 ping网功能
eth = WIZNET5K(spi_bus, cs, is_dhcp=False, mac=MY_MAC)
# Set network configuration
eth.ifconfig = (IP_ADDRESS, SUBNET_MASK, GATEWAY_ADDRESS, DNS_SERVER)
print("Chip Version:", eth.chip)
print("MAC Address:", [hex(i) for i in eth.mac_address])
print("My IP address is:", eth.pretty_ip(eth.ip_address))
基础任务二:主控板建立TCPIP或UDP服务器,局域网PC使用TCPIP或UDP客户端进行连接并发送数据,主控板接收到数据后,送液晶屏显示(没有则通过串口打印显示);通过抓包软件抓取交互报文,展示并分析。(TCP和UDP二选一,或者全都操作)
 通过任务一我们已经开启了W550的网络功能,接着我们开启Socket通信,
# Initialize a socket for our server
socket.set_interface(eth)
server = socket.socket()  # Allocate socket for the server
server_ip = None  # IP address of server
server_port = 50007  # Port to listen on
server.bind((server_ip, server_port))  # Bind to IP and Port
server.listen()  # Begin listening for incoming clients
conn, addr = server.accept()  # Wait for a connection from a client.
print("socket connected")
结果:
1.通过串口打印可以获取Pico的IP为192.168.124.13,接着我们通过TCP工具与Pico进行连接,并发送“123456789 ”数据。
2.通过wireshark捕获IP 17向IP 13发送的数据,可以知道通信协议为TCP协议,数据为”123456789“。
进阶任务:从NTP服务器(注意数据交互格式的解析)同步时间,获取时间送显示屏(串口)显示。
注意库Ntp库没有recv函数没有写入接收长度,因此需对以下函数进行修改
核心代码
#NTP
ntpserver_ip = eth.pretty_ip(eth.get_host_by_name("ntp.aliyun.com"))
print("NTP : %s" % ntpserver_ip)  #DNS Domain
ntp = NTP(iface = eth, ntp_address =ntpserver_ip ,utc=8)
cal = ntp.get_time()
print("The date is %s %d/%d/%d" %(days[cal.tm_wday], cal.tm_mday,cal.tm_mon,cal.tm_year))
print("The time is %d:%02d:%02d" %(cal.tm_hour,cal.tm_min,cal.tm_sec))
■  终极任务二:使用外部存储器,组建简易FTP文件服务器,并能正常上传下载文件。
【得捷Follow me第4期】FTP文件服务器
因本人没有SD模块,因此使用Pico内存模拟内存,使用MicroPython作为开发语言(从鲜de芒果 坛友了解到circuitpython对存储访问的管理较为严格,实现文件存储比较复杂,因此转为使用MicroPython进行开发。
总结
  我是第一次使用python对Pico进行开发,因此此次任务对我来说还是具有很强的学习意义的,非常感谢EEWORLD联合德捷的此次任务,给了我们很多学习的机会。因为第一次接触用python去开发Pico,由于工作繁忙,很多接口还不会使用,我会继续阅读学习使用c开发Pico,以熟悉此中开发方式原理并进行分享。
  最后再次感谢EEWorld提供此学习机会及分享的平台。非常感谢
附录:
1.源码路径
源码
2.视频说明
回复评论
暂无评论,赶紧抢沙发吧
    写回复
