[作品提交] 【Follow me第二季第1期】02 控制板载炫彩LED,跑马灯点亮和颜色变换
聪聪哥哥   2024-9-8 23:16 楼主
基础任务1:控制板载炫彩LED,跑马灯点亮和颜色变换
该任务比较简单,使用这个用Adafruit_NeoPixel.h这个库就能实现,设置了七种不同的颜色进行循环切换,
程序流程图
代码如下:
#include <Arduino.h>
#include <Adafruit_NeoPixel.h>
#define PIN 8
#define NNUMPIN 10
Adafruit_NeoPixel pixels(NNUMPIN, PIN, NEO_GRB + NEO_KHZ800);
void setup() {
  // write your initialization code here
  pixels.begin();
void loop() {
  // write your code here
  static uint8_t led_num = 0;
  //static uint32_t colors[8] = {0x040304, 0x000505, 0x050005, 0x050500, 0x050005, 0x000A00, 0x0A0000,0x0A000A};
 static uint32_t colors[7] = {0x0A0000, 0x000A00, 0x00000A, 0x050500, 0x050005, 0x000505, 0x040304};
//static uint32_t colors[8] = {0x011011, 0x22022, 0x033033, 0x44044, 0x055055, 0x66066, 0x77777,0x088088};
  static uint8_t color_num = 0;
  static Adafruit_NeoPixel pixels(NNUMPIN, PIN, NEO_GRB + NEO_KHZ800);
  pixels.clear();
  pixels.setPixelColor(led_num, colors[color_num]);
  pixels.show();
  led_num++;
  if (led_num == NNUMPIN) {
  led_num = 0;
  color_num++;
  if (color_num == 8)
    color_num = 0;
  delay(200);
02-1
基础任务2:监测环境温度和光线,通过板载LED展示舒适程度
参考官方发布的原理图和CircuitPython库的代码可以得出引脚电压(A8)与温度、光照(A9)之间的关系。
#include "SensorAB.h"
#define PIN 8
#define NUMPIXELS 10
Adafruit_NeoPixel pixels(NUMPIXELS, PIN, NEO_GRB + NEO_KHZ800);
void setup() {
  Serial.begin(115200);
  pixels.begin();
void loop() {
  const double temperature = get_temperature(A9);
  const double photocell = get_photocell(A8);
  pixels.clear();
  if (temperature < 14) {
  pixels.setPixelColor(5, 0, 0, 10);
  } else if (temperature < 18 && temperature >= 14) {
  pixels.setPixelColor(6, 0, 5, 5);
  } else if (temperature >= 18 && temperature <= 20) {
  pixels.setPixelColor(7, 0, 10, 0);
  } else if (temperature > 20 && temperature <= 25) {
  pixels.setPixelColor(8, 5, 5, 0);
  } else if (temperature > 25) {
  pixels.setPixelColor(9, 10, 0, 0);
  if (photocell > 1000) {
  pixels.setPixelColor(0, 10, 0, 0);
  } else if (photocell > 500 && photocell <= 1000) {
  pixels.setPixelColor(1, 5, 5, 0);
  } else if (photocell >= 200 && photocell <= 500) {
  pixels.setPixelColor(2, 0, 10, 0);
  } else if (photocell >= 50 && photocell < 200) {
  pixels.setPixelColor(3, 0, 5, 5);
  } else if (photocell < 50) {
  pixels.setPixelColor(4, 0, 0, 10);
  pixels.show();
  Serial.print("temperature:" + String(temperature) + "  sheshidu  " + "photocell:" + String(photocell) + " lux\n");
  delay(1000);
double get_temperature(const uint32_t pin) {
  return 1.0/(log(1023.0/analogRead(pin)-1)/3950.0+1.0/(273.15+25))-273.15;
double get_photocell(const uint32_t pin) {
  return analogRead(pin)*3.3/1023.0/2.9*3446;
#ifndef SENSOR_H
#define SENSOR_H
#define R_T2 10000
#define B 3380000
#define T2 25
double get_temperature(uint32_t pin);
double get_photocell(uint32_t pin);
#endif //SENSOR_H
3-1
基础任务三(必做):接近检测——设定安全距离并通过板载LED展示,检测到入侵时,发起声音报警
使用红外传感器,,通过IR LED发射一定频率的脉冲,通过读取接收器测得的模拟值,当模拟值增大即有物体靠近。
试验现象:没有物体接近时灯珠全灭或显示一个,随着物体接近灯珠会亮的越来越多。
#include <Adafruit_CircuitPlayground.h>
#define SAFE_DISTANCE 500 // 定义安全距离
const int alertTone = 500; // 警报音调
const int irTransmitterPin = 25; //引脚定义
const int irReceiverPin = A10;
void setup()
  CircuitPlayground.begin();
  Serial.begin(9600); //
  pinMode(irReceiverPin, INPUT); // 红外传感器输入
   pinMode(irTransmitterPin, OUTPUT);// 红外led输出
  delay(100);
void loop() {
   sendIRPulse();
  int distance = analogRead(irReceiverPin); // 读取红外传感器的值
  displayDistance(distance);
  checkForIntrusion(distance);
  delay(300);
void displayDistance(int distance) {
  int ledCount = map(distance, 290, SAFE_DISTANCE, 1, 10); // 将距离值映射到0-10的LED数量
  Serial.print("Distance: ");
  Serial.print(distance);
  Serial.print(", LED Count: ");
  Serial.println(ledCount);
  for (int i = 0; i < 10; i++) {
    if (i < ledCount) {
      CircuitPlayground.setPixelColor(i, 0, 255, 0);
    } else {
      CircuitPlayground.setPixelColor(i, 0);
void checkForIntrusion(int distance) {
  if (distance > SAFE_DISTANCE) {
    Serial.println("Intrusion detected!");
    playAlertTone();
void sendIRPulse() {
  for (int i = 0; i < 32; i++) {
    digitalWrite(irTransmitterPin, HIGH);
    delayMicroseconds(13);
    digitalWrite(irTransmitterPin, LOW);
void playAlertTone() {
  CircuitPlayground.playTone(alertTone, 500); // 播放警报音500ms
回复评论
暂无评论,赶紧抢沙发吧
    写回复
