非常感谢王老五老兄的解答,其实这个问题在发帖当天就已经解决了,但是用了别的变通的方法,这个疑问还是成立的,所以一直没有结贴,我的最终解决方案依然是在PacketCompletion中释放了我为IRP分配的内存,并恢复了IRP原来的内容,因为都是非分页内存,所以在DISPATCH_LEVEL也不会有什么问题,让我纳闷的依然是,在DISPATCH线程中,IRQL的级别怎么会随便变换的,没有采取任何提升IRQL的动作,只是在一个事件上等待,我是最顶层的驱动,也不是DPC。如果IRQL随机变换的话,微软演示的例程也一样会死机蓝屏,难道大家都在以讹传讹?
下面是微软例程:
Scenario 2: Forward and wait
Use the following code if a driver wants to forward the IRP to a lower driver and wait for it to return so that it can process the IRP. This is frequently done when handling PNP IRPs. For example, when you receive a IRP_MN_START_DEVICE IRP, you must forward the IRP down to the bus driver and wait for it to complete before you can start your device. The Windows XP system has a new function named IoForwardIrpSynchronously that you can use to do this operation easily.
NTSTATUS
DispatchRoutine_2(
IN PDEVICE_OBJECT DeviceObject,
IN PIRP Irp
KEVENT event;
NTSTATUS status;
KeInitializeEvent(&event, NotificationEvent, FALSE);
// You are setting completion routine, so you must copy
// current stack location to the next. You cannot skip a location
// here.
IoCopyCurrentIrpStackLocationToNext(Irp);
IoSetCompletionRoutine(Irp,
CompletionRoutine_2,
&event,
TRUE,
TRUE,
TRUE
status = IoCallDriver(TopOfDeviceStack, Irp);
if (status == STATUS_PENDING) {
KeWaitForSingleObject(&event,
Executive, // WaitReason
KernelMode, // must be Kernelmode to prevent the stack getting paged out
FALSE,
NULL // indefinite wait
status = Irp->IoStatus.Status;
// <---- Do your own work here.
// Because you stopped the completion of the IRP in the CompletionRoutine
// by returning STATUS_MORE_PROCESSING_REQUIRED, you must call
// IoCompleteRequest here.
IoCompleteRequest (Irp, IO_NO_INCREMENT);
return status;
NTSTATUS
CompletionRoutine_2(
IN PIRP Irp,
IN PVOID Context
if (Irp->PendingReturned == TRUE) {
// You will set the event only if the lower driver has returned
// STATUS_PENDING earlier. This optimization removes the need to
// call KeSetEvent unnecessarily and improves performance because the
// system does not have to acquire an internal lock.
KeSetEvent ((PKEVENT) Context, IO_NO_INCREMENT, FALSE);
// This is the only status you can return.
return STATUS_MORE_PROCESSING_REQUIRED;
