[求助] modelsim-altera 6.6d 破解后不能使用(急急急!)
gddxz   2011-6-23 09:55 楼主
操作系统是xp,破解时关掉了杀软、360。
modelsim-altera 6.6d的破解顺序是:
1、运行make.bat,生成了一个license.dat文件;(直接运行MentorKG.exe总是生成不了license。)
2、添加了系统环境变量MGLS_LICENSE_FILE;(生成LM_LICENSE_FILE也试过)
3、把MGLS.DLL和mgc.pkginfo文件拷贝到了win32aloem目录下,选择了覆盖。
到这里,破解完,运行程序没有报错。
在transcript中指定工程目录时报错,错误如下:
# can't read "map(桌)": no such element in array
并且一旦关闭程序就报错,且只能用任务管理器来强关。错误如下:
Error:can't read "map(桌)": no such element in array
save messages后得到的两个文件中内容为:
文件tcl_stacktrace.txt中的内容 Wed Jun 22 20:48:13 ?????? 2011
Trace back: can't read "map(?)": no such element in array
    while executing
"quit"
    (command for "WM_DELETE_WINDOW" window manager protocol)
  <2: ::tkerror {can't read "map(?)": no such element in array}
  <1: ::bgerror {can't read "map(?)": no such element in array}
Wed Jun 22 20:59:58 ?????? 2011
    while executing
"quit"
Wed Jun 22 21:36:43 ?????? 2011
    while executing
"quit"
文件transcript中的内容是:
# Reading C:/altera/11.0/modelsim_ae/tcl/vsim/pref.tcl
# error: Load_NoDesignLayout can't read "map(L)": no such element in array
# can't read "map(L)": no such element in array
#     while executing
# "subst -nocommands $string"
#     (procedure "encode" line 11)
#     invoked from within
# "encode $ukey"
#     (procedure "getMTIProperty" line 11)
# "getMTIProperty $geomKey main_size "" "
#     (procedure "LoadLayout" line 35)
# "LoadLayout NoDesign quitsim"
#     ("eval" body line 1)
# "eval "LoadLayout $new_layout_name quitsim""
#     (procedure "Layout:oad_NoDesignLayout" line 3)
# "Layout:oad_NoDesignLayout"
cd d:/Workspace/Matlab/s2_hdlcoder_work
#  Trace back: can't read "map(L)": no such element in array
#     while executing
# "quit"
#     (command for "WM_DELETE_WINDOW" window manager protocol)
#    <2: ::tkerror {can't read "map(L)": no such element in array}
#    <1: ::bgerror {can't read "map(L)": no such element in array}
路径中确定没有空格和中文字符。
这是怎么回事?该怎么解决?请各位大大帮忙啊!
回复评论 (5)
肯定没破解好!
一个为理想不懈前进的人,一个永不言败人! http://shop57496282.taobao.com/ 欢迎光临网上店铺!
点赞  2011-6-23 14:22
修改快捷键属性
点赞  2011-7-26 23:42
把桌面上的图标删除,直接从文件夹中的图标启动,就可以了!
点赞  2011-11-1 08:53
一次安装成功的我  不行的话 卸载重新安装
点赞  2011-11-1 08:59
这个问题是因为你的MODELSIM启动快捷文件的路径上 有中文 把路径上的中文改为英文就行了!!!
点赞  2014-4-17 14:16
    写回复
