[求助] 瑞萨78K0单片机在软件仿真时中断函数问题请教!!!
lqb7733   2016-8-17 09:52 楼主
瑞萨78K0单片机当在软件仿真时,点运行后,在中断函数中设断点,不会停,认为是没有进到中断中来,但需要开启的寄存器都已设好。
想问一下,在软件仿真时本来就是这样吗?还是 需要开启什么命令?现在手头没有仿真器,不能硬件仿真。测试程序如下:
#pragma sfr
#pragma ei
#pragma di
#pragma nop
#pragma interrupt INTTM000 INTM000
#pragma interrupt INTTM010 INTM010
#define uint unsigned int
#define uchar unsigned char
volatile uint gTm00PosWidth = 0;
volatile uint gTm00NegWidth = 0;
volatile uint gTm00PosWidth1 = 0;
volatile uint gTm00NegWidth1 = 0;
uint tm00_pul_cur_0 = 0;
uint tm00_pul_cur_1 = 0;
uint lowlength,i;
uchar highlength;
uchar highcount;
void time00_init(void)
        TMC00 = 0X00;
        TMMK000 = 1;/*disable INTTM000 interrupt*/
        TMIF000 = 0;/*clear INTTM000 interrupt flag*/
        TMMK010 = 1;/*disable INTTM010 interrupt*/
        TMIF010 = 0;/*clear INTTM010 interrupt flag*/
        TMPR010 = 1;
        PRM00 = 0X11;
        CRC00 = 0X07;
        P0.0 = 0;
        PM0.0 = 1;
        P3.2 = 1;
        PM3.2 = 0;
        PM6.1 = 1;
        P6.1 = 0;
void main(void)
        DI();
        WDTE = 0XAC;
        time00_init();
        TMIF010 = 0;
        TMMK010 = 0;
        TMC00 &= (uchar)~0x0c;
        TMC00 |= 0x08;
        EI();
        while(1)
                for(i = 0;i < lowlength;i ++)
                        NOP();
                        NOP();
                        WDTE = 0XAC;
__interrupt void INTM000()
__interrupt void INTM010()
        TMC00 &= (uchar)~0x01;        /* OVF00 clear */
        tm00_pul_cur_0 = CR010;
        tm00_pul_cur_1 = CR000;
        gTm00PosWidth = tm00_pul_cur_1;
        gTm00NegWidth = tm00_pul_cur_0 - tm00_pul_cur_1;
        lowlength = tm00_pul_cur_1;
        highcount++;
        if(highcount == 250)
                highcount = 0;
                P3.2 = ~P3.2;
回复评论
暂无评论,赶紧抢沙发吧
    写回复
