[求助] 按键加一问题
dinghao1   2018-4-24 17:50 楼主
while(1)
        if(key1==0)
                 delay_ms(1);
                        if(key1==0)
                                while(!key1);
                                k++;
                        if(key2==0)
                 delay_ms(1);
                        if(key2==0)
                                while(!key2);
                                k--;
                switch(k)
                case 1:display1();break;
                case 2:display2();break;
                case 3:display3();break;
回复评论 (10)
在做12864液晶屏翻页,想按一下k1翻到上一页,按k2翻到下一页,这样怎么实现不了
点赞  2018-4-24 17:54
按键k1k2控制k的大小,k等于几就翻到第几页
点赞  2018-4-24 18:00
不知道为什么不能实现
点赞  2018-4-24 18:00
#include
#include
#define uchar unsigned char
#define uint unsigned int
#include "4.h"
uchar  table []="       4.c      ";                //oo×ÖÕ¼óÃ2×Ö½ú
uchar  table1[]="    asdasdas    ";
uchar  table2[]="    SDASDSDD    ";
uchar  table3[]="    ò»¶tèyËÄ    ";
uchar k;
uchar key1num,key2num;
sbit LCD_SID=P0^6;
sbit LCD_SCLK=P0^5;
sbit key1=P1^1;
sbit key2=P1^3;
void delay_ms(uint z)
   uint x,y;
        for(x=z;x>0;x--)
                for(y=110;y>0;y--);
void sendbyte(unsigned char bbyte) //·¢Ëíò»¸ö×Ö½ú
unsigned char i;
for(i=0;i<8;i++)
   LCD_SID=bbyte&0x80; //è¡3ö×î¸ßλ
   LCD_SCLK=1;
   LCD_SCLK=0;
   bbyte<<=1; //×óòÆ
void write(bit start, unsigned char ddata) //D′Ö¸áî»òêy¾Y
  unsigned char start_data,Hdata,Ldata;
  if(start==0)
    start_data=0xf8;  //D′Ö¸áî
  else
        start_data=0xfa;  //D′êy¾Y
  Hdata=ddata&0xf0;    //衸ßËÄλ
  Ldata=(ddata<<4)&0xf0;  //è¡μíËÄλ
  sendbyte(start_data);   //·¢ËíÆeê¼DÅoÅ
  delay_ms(1); //Ñóê±
  sendbyte(Hdata);       //·¢Ëí¸ßËÄλ
  delay_ms(1);
  sendbyte(Ldata);    //·¢ËíμíËÄλ
  delay_ms(1);
/***********ò»DDÏÔê¾8¸öoo×Ö***********
***************oo×ÖÏÔê¾***************
***XÎaDDYÎaáD,KÎa×Öμĸöêy,*PÎaêy×é*
void chinese(uchar x,uchar y,uchar k,uchar *p)
        uchar hang,out,i;
        y=y-1;
        switch(x)
                case 1:hang=0x80;break;
                case 2:hang=0x90;break;
                case 3:hang=0x88;break;
                case 4:hang=0x98;break;
        out=hang+y;
        write(0,out);
        for(i=0;i              write(1,*p);
                  p++;
                                //write(1,p);
/**********ò»DDÏÔê¾16¸ö×Öĸ***********
***********ó¢ÎÄêy×ÖÏÔê¾***************
void english(uchar x,uchar y,uchar k,uchar *p)
        uchar hang,out,i;
        y=y-1;
        switch(x)
        out=hang+y;
        write(0,out);
                  p++;
       // write(1,p);
void lcd_init()
        write(0,0x30);  //8λ½éÃæ,»ù±¾Ö¸áî¼ˉ
        write(0,0x0F);  //ÏÔê¾′ò¿a,1a±ê¿a
        write(0,0x01);  //ÇåÆá,½«DDRAMμØÖ·¼ÆêyÆ÷1éáã
        delay_ms(10);
void display1()
                        write(0,0x01);
                        english(1,1,15,table);
        english(2,1,15,table);
        english(3,1,15,table);
        english(4,1,15,table);
                void display2()
                        write(0,0x01);
                        english(1,1,15,table2);
        english(2,1,15,table2);
        english(3,1,15,table2);
        english(4,1,15,table2);
                void display3()
                        write(0,0x01);
                        english(1,1,15,table3);
        english(2,1,15,table3);
        english(3,1,15,table3);
        english(4,1,15,table3);
void main()
    lcd_init();
   while(1)
        if(key1==0)
                 delay_ms(1);
                        if(key1==0)
                                while(!key1);
                                k++;
                        if(key2==0)
                 delay_ms(1);
                        if(key2==0)
                                while(!key2);
                                k--;
                switch(k)
    4.c (2018-4-24 18:01 上传)
    3.53 KB, 下载次数: 1
点赞  2018-4-24 18:02
大家看看这样可以么
点赞  2018-4-25 13:56
利用不同的key在中断里切换显示页面的内容就行。或者中断里做标志后处理。
点赞  2018-4-26 16:40
好的,谢谢
点赞  2018-4-27 08:03
代码写的 不规范。主函数里的while 都不加大括号。这样很容易出问题。多参考一下别人的代码。避免这类问题的出现。
点赞  2018-4-27 09:29
引用: ienglgge 发表于 2018-4-27 09:29
代码写的 不规范。主函数里的while 都不加大括号。这样很容易出问题。多参考一下别人的代码。避免这类问题 ...
好的,谢谢,加上可以了
点赞  2018-4-27 17:10
引用: lovelee 发表于 2018-4-26 16:40 利用不同的key在中断里切换显示页面的内容就行。或者中断里做标志后处理。
大神的意思是用状态机的思想
点赞  2020-3-25 12:41
    写回复
