出现这个错误是因为官方提供的交叉编译环境有点old了,解决办法是自己重新制作个交叉编译环境或更改/arch/arm/config.mk
具体更改内容如下
# Only test once
ifeq ($(CONFIG_$(SPL_)SYS_THUMB_BUILD),y)
#archprepare: checkthumb checkgcc6
checkthumb:
@if test "$(call cc-name)" = "gcc" -a \
"$(call cc-version)" -lt "0404"; then \
echo -n '*** Your GCC does not produce working '; \
echo 'binaries in THUMB mode.'; \
echo '*** Your board is configured for THUMB mode.'; \
false; \
fi
#else
#archprepare: checkgcc6
endif
#checkgcc6:
# @if test "$(call cc-name)" = "gcc" -a \
# "$(call cc-version)" -lt "0600"; then \
# echo '*** Your GCC is older than 6.0 and is not supported'; \
# false; \
# fi
然后编译即可通过
此内容由EEWORLD论坛网友star_66666原创,如需转载或用于商业用途需征得作者同意并注明出处
