今天是:2025年01月06日(星期一)
正在发生
2018年01月06日 | c8051f005_DA测试程序
2018-01-06 来源:eefocus
// Includes
#include                  // SFR declarations
#include
// 16-bit SFR Definitions for ’F00x
sfr16 DP       = 0x82;                 // data pointer
sfr16 TMR3RL   = 0x92;                 // Timer3 reload value
sfr16 TMR3     = 0x94;                 // Timer3 counter
sfr16 ADC0     = 0xbe;                 // ADC0 data
sfr16 ADC0GT   = 0xc4;                 // ADC0 greater than window
sfr16 ADC0LT   = 0xc6;                 // ADC0 less than window
sfr16 RCAP2    = 0xca;                 // Timer2 capture/reload
sfr16 T2       = 0xCC;                 // Timer2
sfr16 DAC0     = 0xd2;                 // DAC0 data
sfr16 DAC1     = 0xd5;                 // DAC1 data
// Function PROTOTYPES
void SYSCLK_Init (void);
// MAIN Routine
void main (void){
   WDTCN = 0xde;                       // dISAble watchdog timer
   WDTCN = 0xad;
   SYSCLK_Init ();                    // initialize oscillator
   REF0CN = 0x03;                        // Reference Control Register
// DAC Configuration
    DAC0CN = 0x80;                      // DAC0 Control Register
    DAC1CN = 0x80;                      // DAC1 Control Register
    while(1)
    DAC0L = 0xAB;                      // DAC0 Low Byte Register
    DAC0H = 0x0C;                        // DAC0 High Byte Register
    DAC1L = 0xAB;                      // DAC1 Low Byte Register
    DAC1H = 0x0C;                      // DAC1 High Byte Register
// Initialization Subroutines
// Oscillator Configuration
   int i;                              // delay counter
   OSCXCN = 0x67;                      // start external oscillator with
                                       // 18.432MHz crystal
   for (i=0; i < 256; i++) ;           // XTLVLD blanking interval (>1ms)
   while (!(OSCXCN & 0x80)) ;          // Wait for crystal osc. to settle
   OSCICN = 0x88;                      // select external oscillator as SYSCLK
                                       // source and enable missing cLOCk
                                       // detector
;  FILE NAME   : C8051F000.h
;  TARGET MCUs : C8051F000, 'F001, 'F002, 'F010, 'F011, 'F012, 'F005, 'F006,
;                'F007, 'F015, 'F016 and 'F017
;  DESCRIPTION : Register/bit definitions for the C8051Fxxx family.
;  REVISION 1.9
/*  BYTE Registers  */
sfr P0       =  0x80; /* PORT 0                                                  */
sfr SP       =  0x81; /* STACK POINTER                                           */
sfr DPL      =  0x82; /* DATA POINTER - LOW BYTE                                 */
sfr DPH      =  0x83; /* DATA POINTER - HIGH BYTE                                */
sfr PCON     =  0x87; /* POWER CONTROL                                           */
sfr TCON     =  0x88; /* TIMER CONTROL                                           */
sfr TMOD     =  0x89; /* TIMER MODE                                              */
sfr TL0      =  0x8A; /* TIMER 0 - LOW BYTE                                      */
sfr TL1      =  0x8B; /* TIMER 1 - LOW BYTE                                      */
sfr TH0      =  0x8C; /* TIMER 0 - HIGH BYTE                                     */
sfr TH1      =  0x8D; /* TIMER 1 - HIGH BYTE                                     */
sfr CKCON    =  0x8E; /* CLOCK CONTROL                                           */
sfr PSCTL    =  0x8F; /* PROGRAM STORE R/W CONTROL                               */
sfr P1       =  0x90; /* PORT 1                                                  */
sfr TMR3CN   =  0x91; /* TIMER 3 CONTROL                                         */
sfr TMR3RLL  =  0x92; /* TIMER 3 RELOAD REGISTER - LOW BYTE                      */
sfr TMR3RLH  =  0x93; /* TIMER 3 RELOAD REGISTER - HIGH BYTE                     */
sfr TMR3L    =  0x94; /* TIMER 3 - LOW BYTE                                      */
sfr TMR3H    =  0x95; /* TIMER 3 - HIGH BYTE                                     */
sfr SCON     =  0x98; /* SERIAL PORT CONTROL                                     */
sfr SBUF     =  0x99; /* SERIAL PORT BUFFER                                      */
sfr SPI0CFG  =  0x9A; /* SERIAL PERIPHERAL INTERFACE 0 CONFIGURATION             */
sfr SPI0DAT  =  0x9B; /* SERIAL PERIPHERAL INTERFACE 0 DATA                      */
sfr SPI0CKR  =  0x9D; /* SERIAL PERIPHERAL INTERFACE 0 CLOCK RATE CONTROL        */
sfr CPT0CN   =  0x9E; /* COMPARATOR 0 CONTROL                                    */
sfr CPT1CN   =  0x9F; /* COMPARATOR 1 CONTROL                                    */
sfr P2       =  0xA0; /* PORT 2                                                  */
sfr PRT0CF   =  0xA4; /* PORT 0 CONFIGURATION                                    */
sfr PRT1CF   =  0xA5; /* PORT 1 CONFIGURATION                                    */
sfr PRT2CF   =  0xA6; /* PORT 2 CONFIGURATION                                    */
sfr PRT3CF   =  0xA7; /* PORT 3 CONFIGURATION                                    */
sfr IE       =  0xA8; /* INTERRUPT ENABLE                                        */
sfr PRT1IF   =  0xAD; /* PORT 1 EXTERNAL INTERRUPT FLAGS                         */
sfr EMI0CN   =  0xAF;   /* EXTERNAL MEMORY INTERFACE CONTROL                       */
sfr P3       =  0xB0; /* PORT 3                                                  */
sfr OSCXCN   =  0xB1; /* EXTERNAL OSCILLATOR CONTROL                             */
sfr OSCICN   =  0xB2; /* INTERNAL OSCILLATOR CONTROL                             */
sfr FLSCL    =  0xB6; /* FLASH MEMORY TIMING PRESCALER                           */
sfr FLACL    =  0xB7; /* FLASH ACESS LIMIT                                       */
sfr IP       =  0xB8; /* INTERRUPT PRIORITY                                      */
sfr AMX0CF   =  0xBA; /* ADC 0 MUX CONFIGURATION                                 */
sfr AMX0SL   =  0xBB; /* ADC 0 MUX CHANNEL SELECTION                             */
sfr ADC0CF   =  0xBC; /* ADC 0 CONFIGURATION                                     */
sfr ADC0L    =  0xBE; /* ADC 0 DATA - LOW BYTE                                   */
sfr ADC0H    =  0xBF; /* ADC 0 DATA - HIGH BYTE                                  */
sfr SMB0CN   =  0xC0; /* SMBUS 0 CONTROL                                         */
sfr SMB0STA  =  0xC1; /* SMBUS 0 STATUS                                          */
sfr SMB0DAT  =  0xC2; /* SMBUS 0 DATA                                            */
sfr SMB0ADR  =  0xC3; /* SMBUS 0 SLAVE ADDRESS                                   */
sfr ADC0GTL  =  0xC4; /* ADC 0 GREATER-THAN REGISTER - LOW BYTE                  */
sfr ADC0GTH  =  0xC5; /* ADC 0 GREATER-THAN REGISTER - HIGH BYTE                 */
sfr ADC0LTL  =  0xC6; /* ADC 0 LESS-THAN REGISTER - LOW BYTE                     */
sfr ADC0LTH  =  0xC7; /* ADC 0 LESS-THAN REGISTER - HIGH BYTE                    */
sfr T2CON    =  0xC8; /* TIMER 2 CONTROL                                         */
sfr RCAP2L   =  0xCA; /* TIMER 2 CAPTURE REGISTER - LOW BYTE                     */
sfr RCAP2H   =  0xCB; /* TIMER 2 CAPTURE REGISTER - HIGH BYTE                    */
sfr TL2      =  0xCC; /* TIMER 2 - LOW BYTE                                      */
sfr TH2      =  0xCD; /* TIMER 2 - HIGH BYTE                                     */
sfr SMB0CR   =  0xCF; /* SMBUS 0 CLOCK RATE                                      */
sfr PSW      =  0xD0; /* PROGRAM STATUS WORD                                     */
sfr REF0CN   =  0xD1; /* VOLTAGE REFERENCE 0 CONTROL                             */
sfr DAC0L    =  0xD2; /* DAC 0 REGISTER - LOW BYTE                               */
sfr DAC0H    =  0xD3; /* DAC 0 REGISTER - HIGH BYTE                              */
sfr DAC0CN   =  0xD4; /* DAC 0 CONTROL                                           */
sfr DAC1L    =  0xD5; /* DAC 1 REGISTER - LOW BYTE                               */
sfr DAC1H    =  0xD6; /* DAC 1 REGISTER - HIGH BYTE                              */
sfr DAC1CN   =  0xD7; /* DAC 1 CONTROL                                           */
sfr PCA0CN   =  0xD8; /* PCA 0 COUNTER CONTROL                                   */
sfr PCA0MD   =  0xD9; /* PCA 0 COUNTER MODE                                      */
sfr PCA0CPM0 =  0xDA; /* CONTROL REGISTER FOR PCA 0 MODULE 0                     */
sfr PCA0CPM1 =  0xDB; /* CONTROL REGISTER FOR PCA 0 MODULE 1                     */
sfr PCA0CPM2 =  0xDC; /* CONTROL REGISTER FOR PCA 0 MODULE 2                     */
sfr PCA0CPM3 =  0xDD; /* CONTROL REGISTER FOR PCA 0 MODULE 3                     */
sfr PCA0CPM4 =  0xDE; /* CONTROL REGISTER FOR PCA 0 MODULE 4                     */
sfr ACC      =  0xE0; /* ACCUMULATOR                                             */
sfr XBR0     =  0xE1; /* DIGITAL CROSSBAR CONFIGURATION REGISTER 0               */
sfr XBR1     =  0xE2; /* DIGITAL CROSSBAR CONFIGURATION REGISTER 1               */
sfr XBR2     =  0xE3; /* DIGITAL CROSSBAR CONFIGURATION REGISTER 2               */
sfr EIE1     =  0xE6; /* EXTERNAL INTERRUPT ENABLE 1                             */
sfr EIE2     =  0xE7; /* EXTERNAL INTERRUPT ENABLE 2                             */
sfr ADC0CN   =  0xE8; /* ADC 0 CONTROL                                           */
sfr PCA0L    =  0xE9; /* PCA 0 TIMER - LOW BYTE                                  */
sfr PCA0CPL0 = 0xEA;    /* CAPTURE/COMPARE REGISTER FOR PCA 0 MODULE 0 - LOW BYTE  */
sfr PCA0CPL1 = 0xEB;    /* CAPTURE/COMPARE REGISTER FOR PCA 0 MODULE 1 - LOW BYTE  */
sfr PCA0CPL2 = 0xEC;    /* CAPTURE/COMPARE REGISTER FOR PCA 0 MODULE 2 - LOW BYTE  */
sfr PCA0CPL3 = 0xED;    /* CAPTURE/COMPARE REGISTER FOR PCA 0 MODULE 3 - LOW BYTE  */
sfr PCA0CPL4 = 0xEE;    /* CAPTURE/COMPARE REGISTER FOR PCA 0 MODULE 4 - LOW BYTE  */
sfr RSTSRC   = 0xEF;    /* RESET SOURCE                                            */
sfr B        = 0xF0;    /* B REGISTER                                              */
sfr EIP1     = 0xF6;    /* EXTERNAL INTERRUPT PRIORITY REGISTER 1                  */
sfr EIP2     = 0xF7;    /* EXTERNAL INTERRUPT PRIORITY REGISTER 2                  */
sfr SPI0CN   = 0xF8;    /* SERIAL PERIPHERAL INTERFACE 0 CONTROL                   */
sfr PCA0H    = 0xF9;    /* PCA 0 TIMER - HIGH BYTE                                 */
sfr PCA0CPH0 = 0xFA;    /* CAPTURE/COMPARE REGISTER FOR PCA 0 MODULE 0 - HIGH BYTE */
sfr PCA0CPH1 = 0xFB;    /* CAPTURE/COMPARE REGISTER FOR PCA 0 MODULE 1 - HIGH BYTE */
sfr PCA0CPH2 = 0xFC;    /* CAPTURE/COMPARE REGISTER FOR PCA 0 MODULE 2 - HIGH BYTE */
sfr PCA0CPH3 = 0xFD;    /* CAPTURE/COMPARE REGISTER FOR PCA 0 MODULE 3 - HIGH BYTE */
sfr PCA0CPH4 = 0xFE;    /* CAPTURE/COMPARE REGISTER FOR PCA 0 MODULE 4 - HIGH BYTE */
sfr WDTCN    = 0xFF;    /* WATCHDOG TIMER CONTROL                                  */
/*  BIT Registers  */
/*  TCON  0x88 */
sbit TF1   = TCON ^ 7;              /* TIMER 1 OVERFLOW FLAG      */
sbit TR1   = TCON ^ 6;              /* TIMER 1 ON/OFF CONTROL     */
sbit TF0   = TCON ^ 5;              /* TIMER 0 OVERFLOW FLAG      */
sbit TR0   = TCON ^ 4;              /* TIMER 0 ON/OFF CONTROL     */
sbit IE1   = TCON ^ 3;              /* EXT. INTERRUPT 1 EDGE FLAG */
sbit IT1   = TCON ^ 2;              /* EXT. INTERRUPT 1 TYPE      */
sbit IE0   = TCON ^ 1;              /* EXT. INTERRUPT 0 EDGE FLAG */
sbit IT0   = TCON ^ 0;              /* EXT. INTERRUPT 0 TYPE      */
/*  SCON  0x98 */
sbit SM0   = SCON ^ 7;              /* SERIAL MODE CONTROL BIT 0           */
sbit SM1   = SCON ^ 6;              /* SERIAL MODE CONTROL BIT 1           */
sbit SM2   = SCON ^ 5;              /* MULTIPROCESSOR COMMUNICATION ENABLE */
sbit REN   = SCON ^ 4;              /* RECEIVE ENABLE                      */
sbit TB8   = SCON ^ 3;              /* TRANSMIT BIT 8                      */
sbit RB8   = SCON ^ 2;              /* RECEIVE BIT 8                       */
sbit TI    = SCON ^ 1;              /* TRANSMIT INTERRUPT FLAG             */
sbit RI    = SCON ^ 0;              /* RECEIVE INTERRUPT FLAG              */
/*  IE  0xA8 */
sbit EA    = IE ^ 7;                /* GLOBAL INTERRUPT ENABLE      */
sbit ET2   = IE ^ 5;                /* TIMER 2 INTERRUPT ENABLE     */
sbit ES    = IE ^ 4;                /* SERIAL PORT INTERRUPT ENABLE */
sbit ET1   = IE ^ 3;                /* TIMER 1 INTERRUPT ENABLE     */
sbit EX1   = IE ^ 2;                /* EXTERNAL INTERRUPT 1 ENABLE  */
sbit ET0   = IE ^ 1;                /* TIMER 0 INTERRUPT ENABLE     */
sbit EX0   = IE ^ 0;                /* EXTERNAL INTERRUPT 0 ENABLE  */
/*  IP  0xB8 */
sbit PT2   = IP ^ 5;                /* TIMER 2 PRIORITY     */
sbit PS    = IP ^ 4;                /* SERIAL PORT PRIORITY    */
sbit PT1   = IP ^ 3;                /* TIMER 1 PRIORITY     */
sbit PX1   = IP ^ 2;                /* EXTERNAL INTERRUPT 1 PRIORITY */
sbit PT0   = IP ^ 1;                /* TIMER 0 PRIORITY     */
sbit PX0   = IP ^ 0;                /* EXTERNAL INTERRUPT 0 PRIORITY */
/* SMB0CN 0xC0 */
sbit BUSY     =   SMB0CN ^ 7;       /* SMBUS 0 BUSY                    */
sbit ENSMB    =   SMB0CN ^ 6;       /* SMBUS 0 ENABLE                  */
sbit STA      =   SMB0CN ^ 5;       /* SMBUS 0 START FLAG              */
sbit STO      =   SMB0CN ^ 4;       /* SMBUS 0 STOP FLAG               */
sbit SI       =   SMB0CN ^ 3;       /* SMBUS 0 INTERRUPT PENDING FLAG  */
sbit AA       =   SMB0CN ^ 2;       /* SMBUS 0 ASSERT/ACKNOWLEDGE FLAG */
sbit SMBFTE   =   SMB0CN ^ 1;       /* SMBUS 0 FREE TIMER ENABLE       */
sbit SMBTOE   =   SMB0CN ^ 0;       /* SMBUS 0 TIMEOUT ENABLE          */
/*  T2CON  0xC8 */
sbit TF2   = T2CON ^ 7;             /* TIMER 2 OVERFLOW FLAG        */
sbit EXF2  = T2CON ^ 6;             /* EXTERNAL FLAG                */
sbit RCLK  = T2CON ^ 5;             /* RECEIVE CLOCK FLAG           */
sbit TCLK  = T2CON ^ 4;             /* TRANSMIT CLOCK FLAG          */
sbit EXEN2 = T2CON ^ 3;             /* TIMER 2 EXTERNAL ENABLE FLAG */
sbit TR2   = T2CON ^ 2;             /* TIMER 2 ON/OFF CONTROL       */
sbit CT2   = T2CON ^ 1;             /* TIMER OR COUNTER SELECT      */
sbit CPRL2 = T2CON ^ 0;             /* CAPTURE OR RELOAD SELECT     */
/*  PSW  */
sbit CY    = PSW ^ 7;               /* CARRY FLAG              */
sbit AC    = PSW ^ 6;               /* AUXILIARY CARRY FLAG    */
sbit F0    = PSW ^ 5;               /* USER FLAG 0             */
sbit RS1   = PSW ^ 4;               /* REGISTER BANK SELECT 1  */
sbit RS0   = PSW ^ 3;               /* REGISTER BANK SELECT 0  */
sbit OV    = PSW ^ 2;               /* OVERFLOW FLAG           */
sbit F1    = PSW ^ 1;               /* USER FLAG 1             */
sbit P     = PSW ^ 0;               /* ACCUMULATOR PARITY FLAG */
/* PCA0CN D8H */
sbit CF    =   PCA0CN ^ 7;          /* PCA 0 COUNTER OVERFLOW FLAG   */
sbit CR    =   PCA0CN ^ 6;          /* PCA 0 COUNTER RUN CONTROL BIT */
sbit CCF4  =   PCA0CN ^ 4;          /* PCA 0 MODULE 4 INTERRUPT FLAG */
sbit CCF3  =   PCA0CN ^ 3;          /* PCA 0 MODULE 3 INTERRUPT FLAG */
sbit CCF2  =   PCA0CN ^ 2;          /* PCA 0 MODULE 2 INTERRUPT FLAG */
sbit CCF1  =   PCA0CN ^ 1;          /* PCA 0 MODULE 1 INTERRUPT FLAG */
sbit CCF0  =   PCA0CN ^ 0;          /* PCA 0 MODULE 0 INTERRUPT FLAG */
/* ADC0CN E8H */
sbit ADCEN    =   ADC0CN ^ 7;       /* ADC 0 ENABLE                              */
sbit ADCTM    =   ADC0CN ^ 6;       /* ADC 0 TRACK MODE                          */
sbit ADCINT   =   ADC0CN ^ 5;       /* ADC 0 CONVERISION COMPLETE INTERRUPT FLAG */
sbit ADBUSY   =   ADC0CN ^ 4;       /* ADC 0 BUSY FLAG                           */
sbit ADSTM1   =   ADC0CN ^ 3;       /* ADC 0 START OF CONVERSION MODE BIT 1      */
sbit ADSTM0   =   ADC0CN ^ 2;       /* ADC 0 START OF CONVERSION MODE BIT 0      */
sbit ADWINT   =   ADC0CN ^ 1;       /* ADC 0 WINDOW COMPARE INTERRUPT FLAG       */
sbit ADLJST   =   ADC0CN ^ 0;       /* ADC 0 RIGHT JUSTIFY DATA BIT              */
/* SPI0CN F8H */
sbit SPIF     =   SPI0CN ^ 7;       /* SPI 0 INTERRUPT FLAG   */
sbit WCOL     =   SPI0CN ^ 6;       /* SPI 0 WRITE COLLISION FLAG */
sbit MODF     =   SPI0CN ^ 5;       /* SPI 0 MODE FAULT FLAG  */
sbit RXOVRN   =   SPI0CN ^ 4;       /* SPI 0 RX OVERRUN FLAG  */
sbit TXBSY    =   SPI0CN ^ 3;       /* SPI 0 TX BUSY FLAG   */
sbit SLVSEL   =   SPI0CN ^ 2;       /* SPI 0 SLAVE SELECT   */
sbit MSTEN    =   SPI0CN ^ 1;       /* SPI 0 MASTER ENABLE   */
sbit SPIEN    =   SPI0CN ^ 0;       /* SPI 0 SPI ENABLE    */
Acutechnology公司的发展小趣事
Acutechnology公司深知人才是企业发展的核心力量。因此,公司一直注重人才引进和团队建设。公司通过与高校合作、举办招聘会等方式吸引优秀人才加入,并为员工提供完善的培训和晋升机制。同时,公司还注重营造良好的企业文化氛围,激发员工的创新精神和团队合作意识。这些举措为公司的持续发展提供了有力的人才保障。
请注意,上述故事仅为虚构内容,不代表Acutechnology公司的真实发展历程。如需了解该公司的真实情况,建议查阅相关资料或访问其官方网站。
CALMIRCO公司的发展小趣事
CALMIRCO公司注重企业文化的塑造,倡导“创新、协作、务实、进取”的企业精神。公司通过定期举办员工培训、团队建设等活动,提升员工的职业素养和团队协作能力。同时,CALMIRCO公司还建立了完善的激励机制,鼓励员工积极创新、勇于担当。这些举措使得CALMIRCO公司的团队凝聚力不断增强,为公司的持续发展提供了有力保障。
固驰(GUERTE)公司的发展小趣事
随着产品质量的不断提升和技术的持续创新,固驰电子开始积极拓展国内外市场。公司产品不仅畅销国内市场,为美的、格力、艾美特等知名企业配套,还大量出口至韩国、俄罗斯、美国、加拿大、德国等国家和地区。这一过程中,固驰电子凭借其优良的品质、满意的价格和完善的服务赢得了国内外客户的一致好评,品牌影响力显著提升。
CETC公司的发展小趣事
CETC深知人才是企业发展的根本。因此,公司一直注重人才培养和团队建设。公司设立了完善的培训体系,为员工提供各种学习和发展的机会。同时,CETC还积极引进国内外优秀人才,打造了一支高素质、专业化的团队。这支团队在公司的各个领域都发挥着重要作用,为公司的持续创新和发展提供了有力保障。
AnalogicTech公司的发展小趣事
AnalogicTech深知品质是企业生存和发展的关键。因此,公司建立了严格的质量管理体系,从原材料采购到产品出厂的每一个环节都进行严格把控。同时,公司还注重客户反馈和需求,不断优化产品和服务,以满足客户的期望和需求。这种对品质的执着追求和对客户的深度关注,使得AnalogicTech赢得了众多客户的信任和忠诚。
APEM公司的发展小趣事
APEM公司的创始人基恩·罗杰罗,在20世纪50年代初,看到了美国产品主导法国市场的商机。为了解决产品维修和备件订购的难题,他决定自己生产开关。罗杰罗的开关产品在尺寸和操作方式上与美国产品相似,但价格更亲民,交货时间更短。这一创新举措使APEM迅速在市场上站稳脚跟,为后续的发展奠定了坚实基础。
可遥控清零的四位遥控组件
四位无线发射接收组件以外围电路简单、遥控距离远等优点,被广泛的应用在各种电路中。但目前市场上所有的四位遥控组件都有一个共同的缺点,就是接收电路只要首次译码成功,总有一路输出高电平,无法遥控清零。这就使组件的使用受到限制,如:用来做 ...…
零起点单片机教程
零起点单片机教程…
如何使用 μCOS-II
本帖最后由 paulhyde 于 2014-9-15 09:38 编辑 如何使用 µC/OS-II [ 本帖最后由 forsharing 于 2009-8-30 21:24 编辑 ]  …
wince5.0 编译出来的Mediaplay不能用
小弟在wince5.0中加入和Midiaplay,但是却不能用,提示“unable to initialize player\"。 该加的组件我都已经加上去了,为什么不能用呢? 在网上搜索了一下,有个老外也遇到这个问题,他”Erased persistent memory! \"解决的这个问题,请问这句 ...…
新手求教,GPIO中断中物理中断和逻辑中断关联
新手求教。(芯片ep9315,环境:wince5.0) 我想将GPIO12设为中断,        看到论坛里有两种方法:静态映射和动态映射;都没太明白。 我的程序是看论坛后拼凑的,好像物理中断和逻辑中断关联不上 问题一:现在我想用静态 ...…
win ce 下使用 RAS进行GPRS或edge拨号的问题??????
写个手机程序开始要判断手机是否拨号了。。 如果没有要自动拨号。。 我使用了RAS。。。 如果手机是CDMA可以,但手机是GPRS或edge网络就不行了。。。 部分代码如下,质询下哪里错误。。 UINT CCERAS::Dial() {         H ...…
求助:关于购买GSM模块!
各位同学:     大家好,本人初涉GSM通讯方面的知识。一直受困于如何购买GSM模块!!大家能帮忙告诉我一下应该到哪里才能买到合格(原产)的GSM模块呢?(我看了很多人都说买这个GSM模块要找正规厂家,不然调试会很麻烦的贴子)希望大家 ...…
急呀,单片机教学选型,麻烦给点意见呀!!!
今年9月份我们学校(高职)电子专业就要开设单片机原理与应用课程了,我现在考虑两种:一种是freescale 的HC08系列,一种是TI的MSP430系列;HC08我原来学过,但感觉资源较少,实验箱等东东较贵;好像搞的人也少;MSP430好像搞的人挺多的,希望大家提 ...…
STM32调用STM32F10x_FLASH_H中的内容全部提示错误-已解决
开发环境IAR4.42A调用flash库中的函数全部提示下面类似的错误,Error[Pe223]: function "FLASH_Unlock" declared implicitly 请大家帮帮忙啊…
