今天是:2025年01月06日(星期一)
正在发生
2018年01月06日 | c8051f005键盘测试程序
2018-01-06 来源:eefocus
c8051f005键盘测试程序
// Includes
#include
#include
#include
// Function PROTOTYPES
#define  uchar unsigned char
#define  uint  unsigned int
#define BAUDRATE             115200              // Baud rate of UART in bps
#define SYSCLK               11059200           // SYSCLK Frequency in Hz
void SYSCLK_Init (void);
void delaynus(unsigned int q) ;                 //N us延时函数
void PORT_Init (void);
void SPI0_Init (void);
void LCD_Init(void);
void SenDSPIByte(unsigned char ch);
void delaynms (unsigned int j);
void writecom(unsigned char com);
void writEDAta(unsigned char d);
void writechar(unsigned char ua);
void Write_COM(uchar ins);
void lcden(datad);
void LCD_set_xy( unsigned char x, unsigned char y );
void LCD_write_string(unsigned char n);
void lcd_key1(void);
void lcd_key2(void);
void lcd_key3(void);
void lcd_key4(void);
void UART0_Init (void);
void presskey(void);
// Global CONSTANTS
sbit S3=P1^0;
sbit S4=P1^1;
sbit S5=P1^2;
sbit S6=P1^3;
sbit lcdcs=P3^0;
unsigned char datad ,comd,kk,sdf,ppca;
unsigned char virt_port,v,b,m;
unsigned char lcd_data_count;
unsigned char *lcdpoint;
unsigned char   qqq;
unsigned char  data8;
unsigned int   i;
// MAIN Routine
void main(void){
        WDTCN = 0xde;                       // dISAble watchdog timer
        WDTCN = 0xad;
        SYSCLK_Init ();
        PORT_Init ();
        UART0_Init() ;                      // initialize crossbar and GPIO
        SPI0_Init ();
        LCD_Init() ;
        delaynms (20);
        delaynus (100);
        LCD_set_xy(0X00,0);
        delaynus (200);
        presskey();
        delaynus (200);
        LCD_write_string(16);
        delaynus (200);
        while(1)
        if(S3==0)
        Write_COM(0X01);
        delaynms (200);
        LCD_set_xy(0X00,0);
        delaynus (200);
        lcd_key1();
        delaynus (200);
        LCD_write_string(6);
        delaynus (200);
        else if(S4==0)
        Write_COM(0X01);
        delaynms (200);
        LCD_set_xy(0X00,0);
        delaynus (200);
        lcd_key2();
        delaynus (200);
        delaynus (200);
        else if(S5==0)
        Write_COM(0X01);
        delaynms (200);
        LCD_set_xy(0X00,0);
        delaynus (200);
        lcd_key3();
        delaynus (200);
        delaynus (200);
        else if(S6==0)
        Write_COM(0X01);
        delaynms (200);
        LCD_set_xy(0X00,0);
        delaynus (200);
        lcd_key4();
        delaynus (200);
        delaynus (200);
        else
// Initialization Subroutines
// PORT_Init
        XBR0 = 0x27;                        // XBAR0: Initial Reset Value
        XBR1 = 0x00;                        // XBAR1: Initial Reset Value
        XBR2 = 0x5c;                        // XBAR2: Initial Reset Value
        PRT0CF = 0x14;                      // Output configuration for P0
          PRT1CF = 0x10; // Output configuration for P3
           PRT3CF = 0x01; // Output configuration for P3
// SYSCLK_Init
      OSCXCN = 0x67;                      // start external oscillator with
      for (i=0; i < 256; i++) ;           // XTLVLD blanking interval (>1ms)
      while (!(OSCXCN & 0x80)) ;          // Wait for crystal osc. to settle
      OSCICN = 0x88;                      // select external oscillator as SYSCLK
// SPI0_Init
      SPI0CFG = 0x07;                        // data sampLED on 1st SCK rising edge
      SPI0CFG|=0xC0;                         //CKPOL =1;
      SPI0CN = 0x03;                         // Master mode; SPI enabled; flags
      SPI0CKR = SYSCLK/2/2000000-1;           // SPI cLOCk <= 8MHz (limited by
                                              // EEPROM spec.)
// UART0_Init
   SCON    = 0x50;                     // SCON: mode 1, 8-bit UART, enable RX
   TMOD    = 0x20;                     // TMOD: timer 1, mode 2, 8-bit reload
   TH1    = -(SYSCLK/BAUDRATE/16);     // set Timer1 reload value for baudrate
   TR1    = 1;                         // start Timer1
   CKCON |= 0x10;                      // Timer1 uses SYSCLK as time base
   PCON  |= 0x80;                      // SMOD = 1
   TI     = 1;                         // InDICate TX ready
// LCD_Init
void LCD_Init(void) //向LCD送命令
//      unsigned int xdata   x;
        delaynms(100);
        datad=0x00;
        SendSPIByte(datad);
        delaynms(10);
        Write_COM(0x30);
        delaynms(10);
        Write_COM(0x30);
        delaynms(10);
        Write_COM(0x30);
        delaynms(10) ;
        Write_COM(0x28);
        delaynms(100);
        virt_port=0;
        SendSPIByte(virt_port);
        lcden(virt_port);
        Write_COM(0x01);
        delaynms(100);
        Write_COM(0x06);
        delaynms(10) ;
        Write_COM(0x0C);
        delaynms(500) ;
// SendSPIByte
void SendSPIByte(unsigned char ch)
{       lcdcs=1;
        delaynus(100);
         SPIF = 0;
        SPI0DAT = ch;
        while (SPIF == 0);
        delaynus(100);
        lcdcs=0;
        delaynus(100);
        _nop_();                 // 等待写结束
// lcden
void lcden(datad)
          datad|=0x08;
          SendSPIByte(datad);
          datad&=0xf7;
          SendSPIByte(datad);
// delaynms
void delaynms (unsigned int uu)
   unsigned int oo,ll;
   for (oo=0;oo   {
    for(ll=0;ll<1140;ll++);
// writechar
        uint  j;
        uchar t,x;
        for(j=0;j<500;j++);
        datad|=0x02;
        SendSPIByte(datad);
        datad|=ua&0xf0;
        SendSPIByte(datad);
        datad|=0x08;
        SendSPIByte(datad);
        for(x=0;x<3;x++);
        datad&=0xf7;
        SendSPIByte(datad);
        for(x=0;x<3;x++);
        datad&=0x07;
        delaynus(100);
        t|=ua&0x0f;
        datad|=t<<4;
        SendSPIByte(datad);
        for(x=0;x<3;x++);
        datad|=0x08;
        SendSPIByte(datad);
        for(x=0;x<3;x++);
        datad&=0xf7;
        SendSPIByte(datad);
        for(x=0;x<3;x++);
       datad=0x00;
        t=0x00;
       SendSPIByte(datad);
// Write_COM
      uchar  t;
      uint j;
      for(j=0;j<5000;j++);                    //用延时代替查询
      virt_port|=ins&0xf0;
      //LCDE=1;
      virt_port|=0x08;
      for(i=3;i>0;i--);
      //LCDE=0;
      virt_port&=~0x08;
      virt_port&=0x07;
      t=ins<<4;
      virt_port|=t&0xf0;
      //LCDE=1;
      virt_port|=0x08;
      for(i=3;i>0;i--);
      //LCDE=0;
      virt_port&=~0x08;
      virt_port=0;
// LCD_set_xy
    unsigned char address;
    if (y == 0) address = 0x80 + x;
    else
    address = 0xc0 + x;
    Write_COM(address);
// LCD_write_string
    unsigned char data1;
    for(n;n>0;n--)
    data1=*lcdpoint;
    writechar(data1);
      delaynms(100);
    lcdpoint++;
    delaynus(10);
// presskey
void presskey(void)
     unsigned char xdata DDCdata[16]={0x50,0x4c,0x45,0x41,0x53,0x45,0x20,0x50,0x52,0x45,0x53,0x53,0x20,0x4b,0x45,0x59};
     lcdpoint=&DDCdata;
// lcd_key1
void lcd_key1(void)
    unsigned char xdata key1ok[6]={0x53,0x33,0x20,0x4f,0x4b,0x21};
    lcdpoint=&key1ok;
// lcd_key2
void lcd_key2(void)
    unsigned char xdata key2ok[6]={0x53,0x34,0x20,0x4f,0x4b,0x21};
    lcdpoint=&key2ok;
// lcd_key3
void lcd_key3(void)
    unsigned char xdata key3ok[6]={0x53,0x35,0x20,0x4f,0x4b,0x21};
    lcdpoint=&key3ok;
// lcd_key4
void lcd_key4(void)
    unsigned char xdata key4ok[6]={0x53,0x36,0x20,0x4f,0x4b,0x21};
    lcdpoint=&key4ok;
// delaynus
void delaynus(unsigned int q)       //N us延时函数
   for (i=0;i      {
      _nop_();
China Semiconductor Corp公司的发展小趣事
随着公司实力的不断增强,CSC开始将目光投向海外市场。公司积极实施国际化战略,在海外设立研发中心和生产基地,拓展国际市场。同时,CSC也加强了与国际同行的交流与合作,吸收借鉴国际先进经验和技术,不断提升自身的国际竞争力。通过国际化布局和全球视野的拓展,CSC逐渐成为了国际半导体产业的重要一员。
这五个故事只是CSC公司发展历程中的一部分缩影,但它们却充分展示了CSC在电子行业中的崛起之路。从初创时期的艰辛与突破,到技术创新的不断突破,再到市场拓展与品牌建设、产业链整合与协同发展以及国际化布局与全球视野的拓展,每一个阶段都凝聚了CSC人的智慧和汗水。正是这些努力和付出,使得CSC在激烈的国际竞争中脱颖而出,成为了中国半导体产业的佼佼者。
Chesivale Electronics公司的发展小趣事
Chesivale Electronics公司深知人才是企业发展的核心动力。因此,公司一直注重人才队伍建设。公司通过校园招聘、社会招聘等多种渠道吸引优秀人才加入,同时建立完善的培训机制和晋升机制,激发员工的积极性和创造力。这些措施使得公司的人才队伍不断壮大,为公司的发展提供了有力的人才保障。
Digitron公司的发展小趣事
Digitron公司成立于XXXX年,由一群热衷于电子技术的工程师和科学家创立。在成立初期,公司专注于开发高精度、高可靠性的温度数据记录器。这些设备在医药、冷链物流等领域得到了广泛应用,为Digitron公司赢得了良好的声誉。随着技术的不断进步,Digitron公司逐渐扩大了产品线,推出了更多适用于不同行业的数据记录器和传感器。
Defense Logistics Agency公司的发展小趣事
Defense Logistics Agency(DLA)于1961年成立,是美国国防部(DOD)的一个独立作战支援机构。在成立初期,DLA就明确了其战略定位:为全球范围内的美军及国防部其他部门提供统一、高效的后勤保障服务。这一战略定位的确立,为DLA的后续发展指明了方向。
Fair Rite公司的发展小趣事
1952年,理查德·帕克与合作伙伴埃德蒙·斯坦威克和杰克·韦伯在纽约的Wallkill共同创立了Fair Rite产品公司。当时,电子行业正处于起步阶段,对新型电子元器件的需求日益增长。Fair Rite凭借对市场敏锐的洞察力,开始专注于铁氧体元件的研发和生产。公司初期面临资金短缺和技术挑战,但通过不断努力和创新,逐渐在市场中树立了良好的口碑。
Federal Custom Cable公司的发展小趣事
Federal Custom Cable非常重视客户服务工作。他们建立了完善的客户服务体系,为客户提供从产品咨询、选型、定制到售后服务的全方位支持。同时,Federal Custom Cable还积极与合作伙伴建立长期稳定的合作关系,共同推动电缆行业的发展。这种以客户需求为导向、以合作伙伴关系为基础的经营模式,为Federal Custom Cable的持续发展提供了有力保障。
STM32学习笔记之ADC
STM32学习笔记之ADC…
各种常用的芯片型号一览!全面实用!
里面有很多芯片型号,寻找方便!…
开关电源变压器铁芯磁滞回线测量-part1开关电源原理与设计(连载59)
2-1-1-9.开关电源变压器铁芯磁滞回线测量 现代电子设备对电源的工作效率和体积以及安全要求越来越高,在开关电源中决定工作效率和体积以及安全要求的诸多因素,基本上都与开关变压器有关,而与开关变压器技术性能相关最大的要算是变压器的铁芯材 ...…
stc单片机测频率问题
我用STC单片机测量频率(0-26HZ).频率信号由外部中断1—INT1引进,采用下降沿触发方式,由TIMER1测量两个下降沿之间的时间。我写的程序只能测量1—3HZ的,频率再高一点就乱跳 下面是我的代码。主程序应该没什么问题,已经调好久了,就是找不出原因 ...…
IIC驱动
请问一下,IIC的流驱动程序的流程是怎样的?最好能够给出代码并且讲解,谢谢??…
请问哪里有DHCP CLIENT方面的资料啊
小弟想在VxWorks上开发DHCP客户端 请问哪里有这方面的资料啊 谢谢各位了…
网上找到的一个 拆解应急灯
这几天为咱活动 找一些相关的资料参考 准备好好参与下   找到了哥们暴力拆解应急灯的图 呵呵 转载一下     转自数码之家 …
ST原装的FlashLoaderv1.2怎么只提供了COM1和COM2选择?
                                 这是很不方便的,有很多用笔记本电脑的没有COM1和COM2,都用USB转出来的串口,一般都在串口4以上,建议ST把可用的 ...…
①F2812 XINT1中断后,程序总是跑飞??
问题有两个: 1。 为什么xint1的中断函数中要再次使能group1中断(下面代码中①)和总中断使能(下面代码中②)即使没有关闭中断(DINT)?其它的比如TIMER1,PWM,CAPTURE等中断则不需要在服务程序中再次使能 2。进入XINT1中断后,程序总是跑飞?? ...…
