今天是:2025年01月06日(星期一)
正在发生
2018年01月06日 | 数字温度计程序
2018-01-06 来源:eefocus
数字温度计程序
#include
#include
sbit  RST   = P2^0;
sbit  CLK   = P2^1;
sbit  DQ    = P2^2;
sbit  TSOR  = P2^3;
sbit  ALERT =P2^4;
sbit  RS    = P2^7;
sbit  RW    = P2^6;
sbit  EN    = P2^5;
/*------------------------------------------全局变量-------------------------------------------------------*/
statIC unsigned char temp1,temp2;         //温度值的整数部分、小数部分
static unsigned char pos,posset;              //数字电位器电位值、设定值
static unsigned char min,sec;                 //分钟、秒
static unsigned char count;                   //Timer0中断计数
static unsigned char minset;                  //设定的分钟数
static unsigned char status1,status2;        //状态标志
bit   stop,timeover;                    //定时停止、结束
static char line0[] ="     00:00      ";
static char line1[] ="   . C         W";
void          InitInterupt();
void          KeyboardDelay();
/*-------------------------------------------LCD驱动函数------------------------------------------------*/
void          DelayL();
void           DelayS();
void           WriteCommand(unsigned char c);
void           WritEDAta(unsigned char c);
void           ShowChar(unsigned char pos,unsigned char c);
void           ShowString(unsigned char line,char *ptr);
void           InitLcd();
/*----------------------------------------------键盘-程序--------------------------------------------------*/
unsigned char GetKey();
/*---------------------------------------------数字温度计驱动-------------------------------------------*/
void          ChangePos(bit sel,unsigned char pos1,unsigned char pos2);
/*------------------------------------------温度传感器驱动----------------------------------------------*/
void          Delay15();
void          Delay60();
void          Delay100ms();
void          Write0TS();
void          Write1TS();
bit           ReaDTS();
void          ResetTS();
void          WriteByteTS(unsigned char byte);
unsigned char  ReadByteTS();
void          InitTS();
void          GetTempTS();
/*-------------------------------------------------主程序---------------------------------------------------*/
void main (void) {
     char code str1[]  ="  Hello World!  ";
     char code str2[]  ="   2002-10-20   ";
     unsigned char i;
     SP=0x50;
     ALERT=0;                       //报警灯灭
     TSOR=1;                       //1-wire总线释放
     DelayL();
     InitLcd();                        //初始化LCD
     DelayL();
     ShowString(0,str1);                //启动画面
     ShowString(1,str2);
     for(i=0;i<15;i++)
       Delay100ms();
     InitInterupt();                     //初始化中断设置
     minset=10;                        //缺省定时10分钟
     posset=0;                         //缺省电位器值0
     min=minset;                    //初始化数据
     pos=posset;
     sec=0;
     count=0;
     P1=0xF0;
     status1=0;
     status2=0;
     stop=1;
     timeover=0;
     ChangePos(0,255-pos,255-pos);           //设置电位器
     InitTS();                         //初始化温度计
     while(1)                        //循环显示温度值
       GetTempTS();
       line1[0]=0x20;
       i=temp1;
if(i>39)                            //超过40摄氏度,告警灯亮
 ALERT=1;
       if(i>99)                        //超过100摄氏度,显示温度的百位
         line1[0]=0x31;
         i-=100;
       line1[1]=i/10+0x30;                 //显示温度的十位
       line1[2]=i%10+0x30;             //显示个位
       line1[4]=temp2+0x30;            //显示小数位
       if(timeover)                     //若定时结束,则电位器缓慢复0
            for(;pos>0;pos--)
         _nop_();
         _nop_();
         timeover=0;
         posset=0;
       if(pos>posset)                   //若按键修改电位器位置
         for(;pos>posset;pos--)            //则缓变到设定值
         _nop_();
         _nop_();
       else if(pos       {
         for(;pos         {
         _nop_();
         _nop_();
       i=pos;
       line1[9]=0x20;                    //显示电位器等级值
       if(i>99)
         line1[9]=i/100+0x30;
         i=i%100;
       line1[10]=i/10+0x30;
       line1[11]=i%10+0x30;
       ShowString(1,line1);
       line0[5]=min/10+0x30;            //显示时间
       line0[6]=min%10+0x30;
       line0[8]=sec/10+0x30;
       line0[9]=sec%10+0x30;
       ShowString(0,line0);
       Delay100ms();
void InitInterupt()
  TMOD=0x21;                        //初始化中断设置
  TL1=0xFD;
  TH1=0xFD;
  PX0=1;
  EA=1;
  ES=1;
  PCON=0;
  TR1=1;
  SCON=0x50;
  TL0=0x00;                             //定时0.05m
  TH0=0x4C;
  ET0=1;
  EX0=1;
  IT0=1;
void KeyboardDelay()                    //按键中断延时
 unsigned char i,j;
 i=0x40;
 j=0xFF;
 while(i--)
  while(j--);
/*--------------------------------------------中断处理-----------------------------------------------------*/
Int0_process() interrupt 0 using 0
  unsigned char key;
  unsigned char keycode[]= "TP";
  unsigned char step[3]={1,2,5};
  EA=0;
  key=GetKey();                         //获得按键值
  switch(key)
   case 0:
     stop=!stop;
     min=minset;
     sec=0;
     break;
   case 1:
   case 2:
   case 3:
     if(stop)
      minset+=step[key-1];
     if(minset>60)
       minset=0;
     min=minset;
     break;
   case 5:
   case 6:
   case 7:
     if(stop)
      minset-=step[key-5];
     if(minset>60)
       minset=0;
     min=minset;
     break;
   case 9:
   case 10:
   case 11:
      posset+=step[key-9];
     break;
   case 13:
   case 14:
   case 15:
      posset-=step[key-13];
     break;
   default:
     break;
  TR0=!stop;
  KeyboardDelay();
  P1=0xF0;
  EA=1;
Timer0_process() interrupt 1 using 0
  EA=0;
  TR0=0;
  TL0=0x00;
  TH0=0x4C;
  count++;
  if(count==20)                        //如果到累计定时到达1s
   if(sec==0)                            //定时处理
     if(min==0)                        //总定时到,则置结束标志
       timeover=1;
     else
      min--;
      sec=59;
   else
     sec--;
   count=0;
  TR0=1;
  EA=1;
/*--------------------------------------LCD驱动子程序--------------------------------------------------*/
void DelayL()
{unsigned char i,j;
 i=0xF0;
 j=0xFF;
 while(i--)
  while(j--);
void DelayS()
 unsigned char i;
 i=0x1F;
 while(i--);
 DelayS();
 EN=0;
 RS=0;
 RW=0;
 _nop_();
 EN=1;
 P0=c;
 EN=0;
void WriteData(unsigned char c)
 DelayS();
 EN=0;
 RS=1;
 RW=0;
 _nop_();
 EN=1;
 P0=c;
 EN=0;
 RS=0;
 unsigned char p;
 if(pos>=0x10)
    p=pos+0xB0;
 else
    p=pos+0x80;
 WriteCommand(p);
 WriteData(c);
 unsigned char l,i;
 l=line<<4;
 for(i=0;i<16;i++)
   ShowChar(l++,*(ptr+i));
void InitLcd()
 DelayL();
 WriteCommand(0x38);
 WriteCommand(0x38);
 WriteCommand(0x06);
 WriteCommand(0x0C);
 WriteCommand(0x01);
 WriteCommand(0x80);
/*---------------------------------------------键盘子程序-------------------------------------------------*/
  unsigned k,t,i,j;
  k=P1;
  k=k&0xF0;
  i=0;
  while((k&0x10)&&i<4)
    i++;
    k=k>>1;
  k=0x01;
  j=0;
  while(j<4)
    P1=0xFF^k;
    _nop_();
    t=P1;
    t=t^0xFF;
    t=t&0xF0;
    if(t)
      break;
    j++;
    k=k<<1;
  k=j*4+i;
  return k;
/*-----------------------------------------数字温度计驱动子程序--------------------------------------*/
{  unsigned char i;
     RST=0;
     DQ=0;
     CLK=0;
     RST=1;
     DQ=sel;
     _nop_();
     CLK=1;
     _nop_();
     CLK=0;
     for(i=0;i<8;i++)
     if(pos1&0x80)
       DQ=1;
     else
       DQ=0;
     _nop_();
     CLK=1;
     _nop_();
     CLK=0;
     pos1=pos1<<1;
    for(i=0;i<8;i++)
     if(pos2&0x80)
       DQ=1;
     else
       DQ=0;
     _nop_();
     CLK=1;
     _nop_();
     CLK=0;
     pos2=pos2<<1;
    RST=0;
/*------------------------------------------温度传感器子程序-------------------------------------------*/
void Delay100ms()                       //延时100ms
 unsigned  char i,j,k;
 for(i=0;i<8;i++)
   for(j=0;j<25;j++)
     for(k=0;k<250;k++);
void Delay15()                          //延时15us
 unsigned  char i;
 for(i=0;i<8;i++);
void Delay60()                          //延时60us
 unsigned  char i;
 for(i=0;i<30;i++);
void Write0TS()                         //写bit 0
     TSOR=1;
     TSOR=0;
     Delay15();
     Delay15();
     Delay15();
     Delay15();
     TSOR=1;
     _nop_();
     _nop_();
void Write1TS()                          //写bit 1
     TSOR=1;
     TSOR=0;
     _nop_();
     _nop_();
     _nop_();
     _nop_();
     _nop_();
     _nop_();
     _nop_();
     TSOR=1;
     _nop_();
     _nop_();
     _nop_();
     _nop_();
     _nop_();
     _nop_();
     _nop_();
     Delay15();
     Delay15();
     Delay15();
bit ReadTS()
 bit b;
     TSOR=1;
     TSOR=0;
     _nop_();
     _nop_();
     _nop_();
     _nop_();
     TSOR=1;
     _nop_();
     _nop_();
     _nop_();
     _nop_();
     _nop_();
     b=TSOR;
     Delay15();
     Delay15();
     Delay15();
     _nop_();
     _nop_();
     return b;
void ResetTS()                            //复位
{unsigned char i;
   TSOR=1;
   TSOR=0;
   for(i=0;i<8;i++)
     Delay60();
   TSOR=1;
   while(TSOR);
   for(i=0;i<8;i++)
     Delay60();
void WriteByteTS(unsigned char byte)      //写一个字节(byte)
{unsigned char i;
 for(i=0;i<8;i++)
   if(byte&0x01)
     Write1TS();
   else
     Write0TS();
   byte=byte>>1;
unsigned char ReadByteTS()                //读一个字节(byte)
 unsigned char i,j;
 bit           b;
 j=0;
 for(i=0;i<8;i++)
   b=ReadTS();
   if(b)
     j+=1;
   j=_cror_(j,1);
 return j;
void InitTS()                             //初始化温度转换
     ResetTS();
     WriteByteTS(0xCC);
     WriteByteTS(0x4E);
     WriteByteTS(0x64);
     WriteByteTS(0x8A);
     WriteByteTS(0x1F);
void GetTempTS()                         //获取温度
     ResetTS();
     WriteByteTS(0xCC);
     WriteByteTS(0x44);
     Delay100ms();
     ResetTS();
     WriteByteTS(0xCC);
      WriteByteTS(0xBE);
     temp2=ReadByteTS();
     temp1=ReadByteTS();
     ReadByteTS();
     ReadByteTS();
     ReadByteTS();
     ReadByteTS();
     ReadByteTS();
     ReadByteTS();
     ReadByteTS();
     temp1=temp1<<4;
     temp1+=(temp2&0xF0)>>4;
      temp2=(temp2&0x0F)?5:0;
Applied Engineering Products (AEP)公司的发展小趣事
在环保意识日益增强的今天,AEP公司积极响应国家号召,致力于绿色环保和可持续发展。公司投入大量资金研发环保型电子元器件,减少生产过程中的废弃物排放。同时,公司还建立了完善的废旧产品回收机制,对废旧产品进行环保处理,实现资源的循环利用。这一举措不仅提升了AEP公司的社会形象,也为公司的可持续发展注入了新的动力。
Frequency Electronics Inc公司的发展小趣事
高频电子的业务范围广泛且多元化,主要包括FEI-NY、Gillam-FEI和FEI-Zyfer三个部门。FEI-NY部门主要负责纽约总部设施和子公司FEI-Asia与FEI-Elcom的运营;Gillam-FEI部门则负责比利时与法国的业务,并专注于电缆网络同步产品的设计、研发和生产;FEI-Zyfer部门则主要经营公司加州业务,并设计生产附带GPS技术的产品。这种多元化业务布局不仅降低了公司的经营风险,还实现了各业务之间的战略协同和资源共享。
Etron公司的发展小趣事
1991年,台湾的电子行业正蓬勃发展,钰创科技(Etron)在这一时期应运而生,创始人凭借对市场敏锐的洞察力,决定专注于利基型缓冲记忆体产品与系统晶片的设计与生产。初创时期,公司面临着技术、资金和市场等多重挑战。然而,钰创科技凭借其团队的技术实力和创新精神,成功开发出了一系列具有竞争力的产品,逐渐在市场上崭露头角。
DIOO公司的发展小趣事
DIOO公司的创始人李奥(Leo)是一位热衷于电子技术的工程师。在20世纪80年代初,他看到了电子行业的巨大潜力,并决定创立DIOO公司,专注于开发和生产高端电子产品。凭借对技术的热爱和对市场的敏锐洞察,李奥带领DIOO公司推出了第一款自主研发的电子产品——高性能音频放大器,该产品凭借其卓越的性能和独特的设计在市场上引起了轰动。
3L Electronic Corporation公司的发展小趣事
3L Electronic Corporation深知人才是企业发展的根本。因此,公司注重人才培养和团队建设,为员工提供丰富的培训和发展机会。通过引进优秀人才和建立激励机制,公司形成了一支高效、专业的团队,为公司的持续创新和发展提供了有力保障。
EPT公司的发展小趣事
面对日益严峻的环境问题,EPT积极响应国家绿色发展的号召,开始探索和实践绿色生产。公司引进了一系列环保设备和工艺,实现了生产过程中的节能减排和资源循环利用。同时,EPT还加强了对废旧电池的回收和处理工作,以减少对环境的污染。这一举措不仅展现了EPT对社会责任的担当,也为其在电子行业中树立了绿色发展的典范。
以上故事均基于EPT公司在电子行业发展的背景信息虚构而成,旨在展现其发展历程中的关键节点和亮点。请注意,这些故事并非真实事件,仅供参考。
【招聘】EDA Software Engineer / Senior EDA Software Engineer
本人就职的公司正在招聘员工,期待您的加入。 北京普拉普斯微电子技术有限公司 公司介绍:         ProPlusDesign Solutions, Inc., headquartered in San Jose, California, USA, isa leading technology and se ...…
请教联想输入法问题?
在做用于wince平台下的输入法,现在拼音输入法已实现,不过只能一个一个汉字输入,码表是16进制的形式表示,两个字节(ASCII码)表示一个汉字(或符号)现在想实现拼音联想功能,至少能实现词组输入,还没啥头绪??请教各位!分没啦,不好意思啊!…
89c51的PCON寄存器的问题
其中存在IDL位空闲位,还有PD掉电工作位,单片机的功率不高吧?在何时会用到省电模式呢?还有空闲工作方式下振荡器仍工作,所以只需要复位只需要两个机器周期。那么通常情况下复位需要几个机器周期。 SMOD波特率倍增在串行通信时经常被怎样使用?…
通信类软件包括哪些?
比如飞信是的吧? 做这行需要哪些软硬件知识呢?比如用不同语言开发要用到哪些函数、控件、API等,要知道哪些底层协议,对各类硬件接口要有哪些撑握?除PC外还有哪些外围东东要学习? 希望有经验的大侠指导下我这个门还未入的菜鸟。。。 谢谢!…
关于ce5自带的webserver的问题
我想把webserver的主目录\\www转移到NandFlash上,先是修改servers.dat,如下: ; @CESYSGEN IF SERVERS_MODULES_HTTPD root:-Directory(\"\\NandFlash\\Windows\"):-Directory(\"www\") Directory(\"\\NandFlash\\Windows\\www\"):-Directory(\ ...…
请教芯片c语言问题
最近可以说是加入了嵌入式开发的行列, 但在看一些c的程序时发现一些奇怪的语句, 比如, bit P80                                = 0xffffffbf.0; bit&nb ...…
WaitCommEvent在串口程序中的应用问题
我在应用中是只对EV_RXCHAR事件 WaitCommEvent这个函数主要是接收到数据的时候触发事件,进行下面的读取函数,如果没有数据接收,就会阻塞。 一开始用这个函数没有问题,但是调用两次后,也就是第三次调用这个函数,就算是没有数据接收到,也不会 ...…
LED恒流驱动与不同控制模式的比较
市场上可以买到的微功率电源芯片有以下几种控制模式:   PFM、PWM、chargepump、FPWM、PFM/PWM以及pulse-skipPWM、digitalPWM   其中常见的有PFM、PWM、chargepump以及PFM/PWM   1、PFM是通过调节脉冲频率(即开关管的工作频率)的方法 ...…
过程性连续赋值语句
verilog中若一个过程块里面有多个过程性连续赋值语句(如多个assign语句),请问这些语句是顺序执行的吗? 求高手指点!…
斗胆开贴,MSP430疑难杂症都跟帖吧,共同学习。
斗胆开贴,MSP430疑难杂症都跟帖吧,共同学习。…
