今天是:2025年01月16日(星期四)
2018年01月16日 | “祝你平安”源程序
2018-01-16 来源:eefocus
ORG 0000H
LJMP START
ORG 000BH
INC 20H ;中断服务,中断计数器加1
MOV TH0,#0D8H
MOV TL0,#0EFH ;12M晶振,形成10毫秒中断
RETI
START:
MOV SP,#50H
MOV TH0,#0D8H
MOV TL0,#0EFH
MOV TMOD,#01H
MOV IE,#82H
MUSIC0:
NOP
MOV DPTR,#DAT ;表头地址送DPTR
MOV 20H,#00H ;中断计数器清0
MOV B,#00H ;表序号清0
MUSIC1:
NOP
CLR A
MOVC A,@A+DPTR ;查表取代码
JZ END0 ;是00H,则结束
CJNE A,#0FFH,MUSIC5
LJMP MUSIC3
MUSIC5:
NOP
MOV R6,A
INC DPTR
MOV A,B
MOVC A,@A+DPTR ;取节拍代码送R7
MOV R7,A
SETB TR0 ;启动计数
MUSIC2:
NOP
CPL P3.2
MOV A,R6
MOV R3,A
LCALL DEL
MOV A,R7
CJNE A,20H,MUSIC2 ;中断计数器(20H)=R7否?
;不等,则继续循环
MOV 20H,#00H ;等于,则取下一代码
INC DPTR
; INC B
LJMP MUSIC1
MUSIC3:
NOP
CLR TR0 ;休止100毫秒
MOV R2,#0DH
MUSIC4:
NOP
MOV R3,#0FFH
LCALL DEL
DJNZ R2,MUSIC4
INC DPTR
LJMP MUSIC1
END0:
NOP
MOV R2,#64H ;歌曲结束,延时1秒后继续
MUSIC6:
MOV R3,#00H
LCALL DEL
DJNZ R2,MUSIC6
LJMP MUSIC0
DEL:
NOP
DEL3:
MOV R4,#02H
DEL4:
NOP
DJNZ R4,DEL4
NOP
DJNZ R3,DEL3
RET
NOP
DAT:
db 26h,20h,20h,20h,20h,20h,26h,10h,20h,10h,20h,80h,26h,20h,30h,20h
db 30h,20h,39h,10h,30h,10h,30h,80h,26h,20h,20h,20h,20h,20h,1ch,20h
db 20h,80h,2bh,20h,26h,20h,20h,20h,2bh,10h,26h,10h,2bh,80h,26h,20h
db 30h,20h,30h,20h,39h,10h,26h,10h,26h,60h,40h,10h,39h,10h,26h,20h
db 30h,20h,30h,20h,39h,10h,26h,10h,26h,80h,26h,20h,2bh,10h,2bh,10h
db 2bh,20h,30h,10h,39h,10h,26h,10h,2bh,10h,2bh,20h,2bh,40h,40h,20h
db 20h,10h,20h,10h,2bh,10h,26h,30h,30h,80h,18h,20h,18h,20h,26h,20h
db 20h,20h,20h,40h,26h,20h,2bh,20h,30h,20h,30h,20h,1ch,20h,20h,20h
db 20h,80h,1ch,20h,1ch,20h,1ch,20h,30h,20h,30h,60h,39h,10h,30h,10h
db 20h,20h,2bh,10h,26h,10h,2bh,10h,26h,10h,26h,10h,2bh,10h,2bh,80h
db 18h,20h,18h,20h,26h,20h,20h,20h,20h,60h,26h,10h,2bh,20h,30h,20h
db 30h,20h,1ch,20h,20h,20h,20h,80h,26h,20h,30h,10h,30h,10h,30h,20h
db 39h,20h,26h,10h,2bh,10h,2bh,20h,2bh,40h,40h,10h,40h,10h,20h,10h
db 20h,10h,2bh,10h,26h,30h,30h,80h,00H
END
以下是hex文件:
:03000000020014E7
:10000B000520758CD8758AEF32758150758CD87533
:10001B008AEF75890175A8820090007D75200075A7
:10002B00F00000E4936033B4FF0302005400FEA31E
:10003B00E5F093FFD28C00B2B3EEFB120072EFB57A
:10004B0020F4752000A302002D00C28C7A0D007BDA
:10005B00FF120072DAF8A302002D007A647B001203
:10006B000072DAF9020023007C0200DCFD00DBF8F1
:10007B002200262020202020261020102080262041
:10008B0030203020391030103080262020202020C6
:10009B001C2020802B20262020202B1026102B808C
:1000AB0026203020302039102610266040103910C1
:1000BB0026203020302039102610268026202B10A9
:1000CB002B102B203010391026102B102B202B40EF
:1000DB004020201020102B102630308018201820A4
:1000EB0026202020204026202B20302030201C20B2
:1000FB00202020801C201C201C2030203060391038
:10010B00301020202B1026102B10261026102B1011
:10011B002B801820182026202020206026102B2032
:10012B00302030201C202020208026203010301042
:10013B003020392026102B102B202B404010401044
:0B014B00201020102B10263030800008
:00000001FF
下一篇:PC机与单片机的通讯程序
按照一本书上说所的和网上一些帖子所说的,应该是不可以的 但是我用evc3.0的开发的软件在华硕的A636N(用wm5.0)可以运行, 不知道到底是怎么回事… 查看全部问答> |
DSP2812 DevEmuRegs 设置问题 // On TMX samples, to get the best performance of on chip RAM blocks M0/M1/L0/L1/H0 internal // control registers bit have to be enabled. The bits are in Device emulation registers. DevE ...… 查看全部问答> |
bq24090[1]具有 10kΩ NTC 的 1A 单输入单节锂离子电池充电器 bq24040[1]自动启动功能的 800mA 单输入单节锂离子电池充电器 bq24200[1]具有温度传感器采用 MSOP-8 封装用于限流应用的 500mA 4.2V 单片锂离子充电器 bq24003[1]具有集成 FET 和 1 ...… 查看全部问答> |
招聘职位:嵌入式开发工程师招聘地点:成都招聘条件:• Bachelor degree (or above) of computer science, electronics or other related majors. • Minimum of 3 years of embedded systems programming. • S ...… 查看全部问答> |
中等电阻的测量——低功率纳米技术及其它敏感器件的交流与直流测量方法的比较 传统上,锁定放大器用来测量100mΩ至1MΩ的电阻,超出这个范围的话限制就会比较明显。即使测试电阻在这个范围内,使用直流反转法[1]的新仪器也能提供优势。举例来说,锁定放大器比直流反转系统具有两倍(或更高)的白噪声,1/f电压噪声[2]更是后 ...… 查看全部问答> |
CC1200 具有业界领先的覆盖范围与共存性,以及高达 1Mbps 的数据速率,专门针对高级电表基础设施 (AMI) 及家域网 (HAN) 的 1 GHz 以下无线连接而开发,可充分满足智能电网、家庭楼宇自动化以及告警与安全系统应用需求。CC1200 支持嗅 ...… 查看全部问答> |
