今天是:2025年01月26日(星期日)
2018年01月26日 | I2C_示例程序
2018-01-26 来源:eefocus
I2C_示例程序
; File Name: I2C.ASM
; Author: Andy Yu
; Date: July 22, 1998
#define I2C_ASM
include i2c.inc
publIC InitI2CBusMaster
public _i2c_bLOCk_write
public _i2c_block_read
public SendData
public TxmtStartBit
public Txmt_Slave_Addr
public IsSlaveActive
public _Bus_Busy
public _Txmt_Progress
public _Rcv_Progress
public _Txmt_SuCCess
public _Rcv_Success
public _Ack_Error
public _10BitAddr
public _Slave_RW
public _SlaveActive
public DataByte
public SlaveAddr
public tempCount
public TempStore
; General Equate
TRUE EQU 1
FALSE EQU 0
LSB EQU 0
MSB EQU 7
Carry EQU [0ah].0
; Port Assignment
PortCTRlAddr EQU (PortAddr+1)
I2CPORT EQU [PortAddr]
SCL EQU [PortAddr+1].SCL_Bit ;PBC
SDA EQU [PortAddr+1].SDA_Bit ;PBC
PSCL EQU [PortAddr].SCL_Bit ;PB
PSDA EQU [PortAddr].SDA_Bit ;PB
; Data Section
I2CData .section 'data'
I2CStatus label byte
_Bus_Busy dbit
_Abort dbit
_Txmt_Progress dbit
_Rcv_Progress dbit
_Txmt_Success dbit
_Rcv_Success dbit
_Fatal_Error dbit
_Ack_Error dbit
I2CCtrl label byte
_10BitAddr dbit
_Slave_RW dbit
_Last_Byte_Rcv dbit
_reserve3 dbit
_reserve4 dbit
_reserve5 dbit
_SlaveActive dbit
_Time_Out dbit
DataByte db ?
DataByteCopy db ?
BitCount db ?
SlaveAddr db ? ; reserve 2 bytes to support 10 bit addr
tempCount db ?
TempStore db ?
DelayCount db ?
; Code Section
I2CCode .section 'code'
; IsSlaveAcitve
IsSlaveActive proc
clr _Slave_RW
call TxmtStartBit
call Txmt_Slave_Addr
clr _SlaveActive
snz _Ack_Error
set _SlaveActive
call TxmtStopBit
ret
IsSlaveActive endp
; _i2c_block_write
_i2c_block_write proc
call TxmtStartBit ; start
clr _Slave_RW ; slave address
snz _Txmt_Success
jmp ending
MOV A,TempStore ; subaddress
MOV DataByte,A
call SendData
_block_wr1_loop:
snz _Txmt_Success
jmp ending
MOV A,_IAR
MOV DataByte,A
inc _MP
call SendData
sdz tempCount
jmp _block_wr1_loop
ending:
call TxmtStopBit ; stop
ret
_i2c_block_write endp
; _i2c_block_read
_i2c_block_read proc
call TxmtStartBit
set _Slave_RW
clr _Last_Byte_Rcv
sz _Txmt_Success
jmp _block_rd1_loop
call TxmtStopBit
ret A,FALSE
_block_rd1_loop:
call GetData
MOV A,DataByte
MOV _IAR,A
inc _MP
sdz tempCount
jmp _block_rd1_loop
set _Last_Byte_Rcv
call GetData
MOV A,DataByte
MOV _IAR,A
call TxmtStopBit
ret A,TRUE
_i2c_block_read endp
; InitI2CBusMaster
InitI2CBusMaster proc
MOV A,I2CPORT ; clear latches
and A,NOT I2CPORTMASK
MOV I2CPORT,A
RELEASE_BUS
clr I2CStatus
clr I2CCtrl
ret
InitI2CBusMaster endp
; TxmtStartBit
TxmtStartBit proc
set SDA
set SCL
DELAY_tSETUP_START
clr SDA
DELAY_tHOLD_START
set _Bus_Busy
ret
TxmtStartBit endp
; TxmtStopBit
TxmtStopBit proc
clr SCL
clr SDA
set SCL
DELAY_tSETUP_STOP
set SDA
DELAY_tBUS_FREE
clr _Bus_Busy
ret
TxmtStopBit endp
; SendData
SendData proc
TxmtByte:
MOV A,DataByte
MOV DataByteCopy,A
set _Txmt_Progress
clr _Txmt_Success
MOV A,08h ; for BitCount=8 downto 1
MOV BitCount,A
TxmtNextBit:
clr SCL
rlc DataByteCopy
clr SDA
sz Carry
set SDA
DELAY_tLOW
set SCL
DELAY_tHIGH
sdz BitCount
jmp TxmtNextBit ; end for
;--- check ACK
clr SCL
set SDA
DELAY_tLOW
set SCL
DELAY_tHIGH
sz PSDA
jmp TxmtErrorAck
clr SCL
clr _Txmt_Progress
set _Txmt_Success
clr _Ack_Error
ret
TxmtErrorAck:
RELEASE_BUS
set SDA
set SCL
clr _Bus_Busy
clr _Txmt_Progress
clr _Txmt_Success
set _Ack_Error
ret
SendData endp
; GetData
GetData proc
RcvByte:
set _Rcv_Progress
clr _Rcv_Success
MOV A,08h
MOV BitCount,A
RcvNextBit:
clr SCL
set SDA
DELAY_tLOW
set SCL
DELAY_tHIGH
clr Carry
sz PSDA
set Carry
rlc DataByte
sdz BitCount
jmp RcvNextBit
; generate ACK
clr SCL
clr SDA
sz _Last_Byte_Rcv
set SDA
DELAY_tLOW
set SCL
DELAY_tHIGH
RcvEnd:
clr SCL
clr _Rcv_Progress
set _Rcv_Success
clr _Ack_Error
ret
GetData endp
; Txmt_Slave_Addr
Txmt_Slave_Addr proc
clr _Ack_Error
snz _10BitAddr
jmp SevenBitAddr
snz _Slave_RW
jmp TenBitAddrWR
TenBitAddrRd:
clr _Slave_RW
call TenBitAddrWR
snz _Txmt_Success
ret A,FALSE
call TxmtStartBit
set _Slave_RW
MOV A,SlaveAddr[1]
MOV DataByte,A
set DataByte.LSB
call SendData
jmp _AddrSendTest
snz _Txmt_Success
jmp _AddrSendFail
TenBitAddrWR:
MOV A,SlaveAddr[1]
MOV DataByte,A
clr DataByte.LSB
call SendData
snz _Txmt_Success
jmp _AddrSendFail
MOV A,SlaveAddr
MOV DataByte,A
jmp EndTxmtAddr
SevenBitAddr:
MOV A,SlaveAddr
MOV DataByte,A
clr DataByte.LSB
sz _Slave_RW
set DataByte.LSB
EndTxmtAddr:
call SendData
_AddrSendTest:
snz _Txmt_Success
jmp _AddrSendFail
ret A,TRUE
_AddrSendFail:
snz _Ack_Error
ret A,FALSE
call TxmtStopBit
ret A,FALSE
Txmt_Slave_Addr endp
; File Name: I2C.INC
; Author: Andy Yu
; modify these equates to suit your application
PortAddr EQU 14H ; SCL=PB0, SDA=PB1 14H is PB's port addr
SCL_Bit EQU 0
SDA_Bit EQU 1
I2CPORTMASK EQU 03h
_IAR EQU [00h]
_MP EQU [01h]
; fill delay codes to fit specific I2C slaves
DELAY_tSETUP_START macro ; START Condition Setup Time (600ns HT24C0x)
endm
DELAY_tHOLD_START macro ; START Condition Hold Time (600ns HT24C0x)
endm
DELAY_tSETUP_STOP macro ; STOP Condition Setup Time (600ns HT24C0x)
endm
DELAY_tBUS_FREE macro ; Bus Free Time (1300ns HT24C0x)
endm
DELAY_tLOW macro ; Clock Low Time (600ns HT24C0x)
endm
DELAY_tHIGH macro ; Clock High Time (1300ns HT24C0x)
endm
ifndef I2C_ASM
extern InitI2CBusMaster : near
extern _i2c_block_write : near
extern _i2c_block_read : near
extern SendData : near
extern TxmtStartBit : near
extern Txmt_Slave_Addr : near
extern IsSlaveActive : near
extern _Bus_Busy : bit
extern _Txmt_Progress : bit
extern _Rcv_Progress : bit
extern _Txmt_Success : bit
extern _Rcv_Success : bit
extern _Ack_Error : bit
extern _10BitAddr : bit
extern _Slave_RW : bit
extern _SlaveActive : bit
extern DataByte : byte
extern SlaveAddr : byte
extern tempCount : byte
extern TempStore : byte
endif
; LOAD_ADDR_8
LOAD_ADDR_8 macro SLAVE_ADDRESS
clr _10BitAddr
MOV A,(SLAVE_ADDRESS and 0ffh)
MOV SlaveAddr,A
endm
; I2C_TEST_DEVICE
I2C_TEST_DEVICE macro
call IsSlaveActive
endm
; RELEASE_BUS
RELEASE_BUS macro
set SDA ; set to hi-impedence
set SCL
endm
; I2C_WRITE_SUB
I2C_WRITE_SUB macro _BYTES_, _SourcePointer_, _SubAddress_
MOV A,_SubAddress_
MOV TempStore,A
MOV A,_BYTES_ ; loop data
MOV tempCount,A
MOV A,_SourcePointer_
MOV _MP,A
call _i2c_block_write
endm
; I2C_READ
I2C_READ macro _BYTES_, _DestPointer_
MOV A,_BYTES_-1
MOV tempCount,A
MOV A,_DestPointer_
MOV _MP,A
call _i2c_block_read
endm
; I2C_READ_SUB
I2C_READ_SUB macro _BYTES_, _DestPointer_, _SubAddress_
clr _Slave_RW
call TxmtStartBit
MOV A,_SubAddress_
MOV DataByte,A
call SendData
I2C_READ _BYTES_, _DestPointer_
endm
; File Name: TEST.ASM
; Author: Andy Yu
; Purpose: test i2c routines
include i2c.inc
include ht48c50.inc
MySlaveAddr EQU 0a2h
tdata .section 'data'
PagEDAta db 8 dup(?)
Addr db ?
Add1 db ?
PageCount db ?
Temp db ?
Count db ?
main .section at 0 'code'
jmp start
start:
call InitI2CBusMaster
LOAD_ADDR_8 MySlaveAddr
I2C_TEST_DEVICE
snz _SlaveActive
jmp Error
; write HT24c01 with their address
clr Addr
MOV A,16 ; for PageCount = 16 downto 1
MOV PageCount,A
PageWriteLp:
call FillPageData ; Fill PageData with address
I2C_WRITE_SUB 8, offset PageData, Addr
snz _Txmt_Success
jmp Error
AckPoll:
I2C_TEST_DEVICE
snz _SlaveActive
jmp AckPoll
MOV A,8
addm A,Addr ; Addr += 8
sdz PageCount
jmp PageWriteLp
; read back check
clr Addr
MOV A,16; for PageCount = 16 downto 1
MOV PageCount,A
PageReadLp:
I2C_READ_SUB 8, offset PageData, Addr
snz _Rcv_Success
jmp Error
MOV a,0a0h
MOV add1,a
call CheckPageData
snz ACC.0
jmp Error
MOV a,8
addm A,add1 ; Add1 += 8
sdz PageCount
jmp PageReadLp
jmp $; success
Error:
jmp $ ; fail
FillPageData proc
; PageData=Add,Add+1,...,Add+7
MOV A,offset PageData ; MP0 = offset PageData
MOV MP0,A
MOV A,0a0h ; Temp = Addr
MOV Temp,A
MOV A,8
MOV Count,A ; for Count = 8 downto 1
FillLp:
MOV A,Temp
MOV R0,A
MOV PAC,A
inc Temp
inc MP0
sdz Count
jmp FillLp ; end for
ret
FillPageData endp
CheckPageData proc
; PageData must be Addr,Addr+1,...,Addr+7
MOV MP0,A
MOV A,add1 ; Temp = Addr
MOV Temp,A
MOV A,8
MOV Count,A ; for Count = 16 downto 1
CheckLp:
MOV A,R0
XOR A,Temp
snz Z
ret A,0
inc Temp
inc mp0
sdz count
jmp checkLp
ret A,1
CheckPageData endp
上一篇:KEY_按键示例程序
下一篇:Ht47实时时钟(RCT)应用
第一次使用PIC16F73。很简单,就是在B口的第二位输出高电平就可以了。必须要调试通过的哟。 还问一个问题: 在单片机的输出管脚上如果没有接负载,使用程序输出1,就可以使用万用表量到高电平吗?… 查看全部问答> |
我用的是刷卡的方式加载NK.NB0. 为什么我编译生成的NK.NB0 BOOT引导无法识别和加载 串口打印信息如下。 System ready! Preparing for download... Boot Configure is found OEMPredownload... SD card is inserted, pi ...… 查看全部问答> |
在自己的shell程序下调用tcpmp浏览图片,在全屏模式下slide show,如果从大图片切换到小图片,上一张图片在边缘处上总是会残留,无法完全刷新。但在wince下直接调用tcpmp就是好的。不知道我的init还有哪些地方没有设置正确。请大家帮忙。 下面是我 ...… 查看全部问答> |
我用STM32的定时器2工作于编码器方式,可以正常得到编码器位置,但由于现在只有16位计数,位数不够,我想扩展到32位,经过试验未能解决,请帮忙提个思路。 一、先用定时器内部连接,将定时器2 的溢出送到定时器3 ...… 查看全部问答> |
本人是一名普通高校的学生,离毕业不到一个月了,电子信息类专业。在一个普通的城市度过了我四年的大学生活。此时,我正坐在一间即将不属于我的教室里。在此,我将写下这段时间关于专业知识学习的经历与体会,希望能给还有机会在大学继续学习的学生 ...… 查看全部问答> |
