今天是:2025年03月12日(星期三)
正在发生
2018年03月12日 | 用HI-TECH C写的使用PIC12C508读写93LC46范例程式
2018-03-12 来源:eefocus
 * Processer : MicroChip PIC12C508        *
 * Compiler : Hi-TECH PICC 8.00 PL2      *
 * Writer : Jason Kuo          *
 * Description : It CAN read/write 93LC46 (64 x 16-bit organization) *
static volatile unsigned char RTCC @ 0x01;
static volatile unsigned char TMR0 @ 0x01;
static volatile unsigned char PCL @ 0x02;
static volatile unsigned char STATUS @ 0x03;
static          unsigned char FSR @ 0x04;
static volatile unsigned char OSCCAL @ 0x05;
static volatile unsigned char GPIO @ 0x06;
static          unsigned char control OPTION @ 0x00;
static volatile unsigned char control TRIS @ 0x06;
/* STATUS bits */
static bit  GPWUF @ (unsigned)&STATUS*8+7;
static bit PA0 @ (unsigned)&STATUS*8+5;
static bit  TO @ (unsigned)&STATUS*8+4;
static bit  PD @ (unsigned)&STATUS*8+3;
static bit  ZERO @ (unsigned)&STATUS*8+2;
static bit DC @ (unsigned)&STATUS*8+1;
static bit CARRY @ (unsigned)&STATUS*8+0;
/* OPTION bits */
#define  GPWU (1<<7)
#define  GPPU (1<<6)
#define  T0CS (1<<5)
#define  T0SE (1<<4)
#define  PSA (1<<3)
#define  PS2 (1<<2)
#define  PS1 (1<<1)
#define  PS0 (1<<0)
/*      OSCCAL bits    */
static volatile bit    CAL3    @ (unsigned)&OSCCAL*8+7;
static volatile bit    CAL2    @ (unsigned)&OSCCAL*8+6;
static volatile bit    CAL1    @ (unsigned)&OSCCAL*8+5;
static volatile bit    CAL0    @ (unsigned)&OSCCAL*8+4;
static volatile bit GP5 @ (unsigned)&GPIO*8+5;
static volatile bit GP4 @ (unsigned)&GPIO*8+4;
static volatile bit GP3 @ (unsigned)&GPIO*8+3;
static volatile bit GP2 @ (unsigned)&GPIO*8+2;
static volatile bit GP1 @ (unsigned)&GPIO*8+1;
static volatile bit GP0 @ (unsigned)&GPIO*8+0;
#define CONFIG_ADDR 0xFFF
/* code protection */
#define MCLREN  0xFFFF // memory clear enable
#define MCLRDIS  0xFFEF // memory clear dISAble
/*watchdog*/
#define WDTEN  0xFFFF // watchdog timer enable
#define WDTDIS  0xFFFB // watchdog timer disable
#define PROTECT  0xFFF7 // protect the program code
#define UNPROTECT 0xFFFF // do not protect the program code
/*osc configurations*/
#define EXTRC    0xFFFF // external resistor/caPACitor
#define INTRC  0xFFFE // internal
#define XT  0xFFFD // crystal/resonator
#define LP  0xFFFC // low power crystal/resonator
/* 93LC46 I/O PIN define */
#define CS  GP0  //Chip Select
#define CLK GP1  //Serial Data CLOCk
#define DI GP2  //Serial Data Input
#define DO GP4  //Serial Data Output
void Delay(unsigned int counter);
void Pulse(void);
void StartBit(void);
void EWEN(void);
void EWDS(void);
extern void Write93LC46(unsigned char Offset_Addr, unsigned int tx_data);
extern unsigned int Read93LC46(unsigned char Offset_Addr);
void InitPIC(void);
#define CLRWDT() asm(" clrwdt")
#define SLEEP()  asm(" sleep")
#define ___mkstr1(x) #x
#define ___mkstr(x) ___mkstr1(x)
#define __CONFIG(x) asm("tpsect config,class=CONFIG,delta=2");
  asm("tglobaltconfig_word");
  asm("config_word");
  asm("tdw "___mkstr(x))
#define __IDLOC(w)      asm("tpsect idloc,class=IDLOC,delta=2");
    asm("tglobaltidloc_word");
    asm("idloc_word");
    asm("tirpct__arg," ___mkstr(w));
    asm("tdw 0&__arg&h");
    asm("tendm")
__CONFIG(MCLRDIS & WDTDIS & EXTRC & PROTECT);
 Function : Delay
 Input : unsigned int (counter)
 Output : None
 Description : Delay routine
 if counter=1  delay 35us , if counter=10 delay 134us,
 if counter=100 delay 1.12ms,
 These delay is base on internal 4MHz
  while(counter>0) counter--;
 Function : Pulse
 Input : None
 Output : None
 Description : Send a pulse (10) to Serial Data Clock(CLK)
void Pulse(void)
    CLK = 1;
    Delay(25);
    CLK = 0;
 Function : StartBit
 Input : None
 Output : None
 Description :
 1. Set Chip Select(CS) = 1 (high)
 2. Set a Start Bit(1) to Serial Data Input(DI)
void StartBit(void)
    CS = 1;
    DI = 1;
    Pulse();
 Function : EWEN
 Input : None
 Output : None
 Description :  ERASE/WRITE Enable
void EWEN(void)
    unsigned char i,temp;
    StartBit();                  /* 1 */
    temp = 0x80;                        /* 0011xxxx ,(opcode:00, Address:11xxxx) */
    for(i=0; i<8; i++) {
        if(0x30 & temp)
            DI = 1;
        else
            DI = 0;
        Pulse();
        temp >>= 1;
    CS = 0;
 Function : EWDS
 Input : None
 Output : None
 Description :  ERASE/WRITE DISAble
void EWDS(void)
    unsigned char i;
    StartBit();                  /* 1 */
    DI = 0;                       /* 0000xxxx, (opcode:00, Address:00xxxx) */
    for(i=0; i<8; i++)
        Pulse();
    CS = 0;
 Function : Write93LC46
 Input : unsigned char Offset Address, unsigned int tx_data
 Output : None
 Description :  Write 16bits data in to 93LC46 Offset Address
    unsigned char Addr, i;
    unsigned int temp;
    EWEN();
    StartBit();                  /* 1 */
    Offset_Addr=Offset_Addr&0x3F; /* 6bits address */
    Addr = Offset_Addr + 0x40;          /* 01AAAAAA ,(opcode:01, address:AAAAAA) */
    temp = 0x0080;
        if(Addr & temp)
            DI = 1;
        else
            DI = 0;
        Pulse();
        temp >>= 1;
    temp = 0x8000;                      /* DDDDDDDDDDDDDDDD(16bits data)*/
    for(i=0; i<16; i++) {
        if(tx_data & temp)
            DI = 1;
        else
            DI = 0;
        Pulse();
        temp >>= 1;
    CS = 0;
    EWDS();
 Function : Read93LC46
 Output : unsigned int
 Description :  Read 16bits data from 93LC46 offset address
    unsigned char Addr, i, temp;
    unsigned int  rx_data;
    StartBit();                   /* 1 */
    Offset_Addr = Offset_Addr&0x3F; /* 6bits address */
    Addr = Offset_Addr + 0x80;           /* 10AAAAAA ,(opcode:10, address:AAAAAA) */
    temp = 0x80;
        if(Addr & temp)
            DI = 1;
        else
            DI = 0;
        Pulse();
        temp >>= 1;
    rx_data = 0x0000;                    /* DDDDDDDDDDDDDDDD(16bits data)*/
        Pulse();
        if(DO)
            rx_data |= 0x0001;
        if(i < 15)
            rx_data <<= 1;
    CS = 0;
    return(rx_data);
void InitPIC(void)
    OPTION = (GPWU | GPPU | PS2 | PS1 | PS0);
    TRIS = 0x10;
    CS = 0;
    CLK = 0;
    DI = 0;
/* Main routine */
void main(void)
 unsigned char addr;
 unsigned int rx_buf;
 InitPIC();
 /* Read a word then +1 and write back to 93LC46 */
 for (addr = 0; addr < 10; addr++)
  rx_buf = Read93LC46(addr);
  rx_buf = rx_buf+1;
  Write93LC46(addr, rx_buf);
CTS公司的发展小趣事
随着全球化趋势的加强,CTS公司开始积极拓展国际市场。公司在全球范围内设立了多个生产基地和销售网络,以便更好地服务全球客户。同时,CTS还加强了与国际知名企业的合作,共同推动电子行业的发展。
Cypress Industries公司的发展小趣事
2020年,Cypress迎来了其发展历程中的一个重要时刻——与德国半导体巨头英飞凌(Infineon)的合并。这次合并使Cypress成为英飞凌的一部分,双方在技术、市场和资源等方面实现了互补和整合。这次合并不仅增强了Cypress在全球半导体市场的竞争力,也为其未来的发展提供了更广阔的空间。
以上故事均基于Cypress Semiconductor(赛普拉斯半导体)的发展历史而创作,旨在客观描述公司在电子行业中的发展历程和成就。
Deutron Electronics Corp公司的发展小趣事
Deutron Electronics Corp深知研发和创新对于公司发展的重要性。因此,公司始终保持着对研发的高投入,不断引进和培养人才。公司建立了完善的研发体系,鼓励员工参与创新活动,并为他们提供了充足的资源和支持。这些措施使得Deutron Electronics Corp在研发方面取得了显著成果,为公司的发展提供了源源不断的动力。
EMS GmbH公司的发展小趣事
随着公司技术的不断成熟和产品的不断优化,EMS GmbH公司开始积极拓展市场。公司不仅在欧洲市场取得了显著的成绩,还逐渐将业务拓展至全球范围。通过参加国际展会、与合作伙伴建立战略合作关系等方式,EMS GmbH公司不断提升品牌知名度和影响力。同时,公司还注重产品质量和服务质量的提升,以确保在激烈的市场竞争中保持竞争优势。
CW Industries公司的发展小趣事
随着全球电子市场的不断扩大,CW Industries也积极拓展其国际业务。公司通过参加各种国际电子展会和交流活动,与全球各地的客户和合作伙伴建立了广泛的联系。这不仅为公司带来了更多的商机,还使得CW Industries能够及时了解国际市场的最新动态和技术趋势。通过这些国际交流活动,CW Industries不断提升其品牌影响力和市场竞争力。
Good-Ark公司的发展小趣事
为整个电路提供所需的电能。
[急]Arm9板子和非接触式IC卡读卡器能连接不?
想做一个小的开门系统,刷卡开门,请问高手们, 这个难度大不? Arm9板子和非接触式IC卡读卡器能连接不? 好不好连接,要写什么驱动不?…
(转贴)用电安全常识
这是在别的网站转过来的用电常识问答,请大家对比一下看看我们清楚的有多少。 家庭安全用电常识 (一)字节                              & ...…
抗电强度试验浅析
抗电强度试验浅析很多感性和容性器件在磁场和电路中都会具有贮存能量的性质。通常,磁场中的能量会转换成其他能量形式,有时,磁能被释放为高压脉冲进入配电系统,而且这样的释放是经常的(如在电动机启动过程中)。因为高压脉冲会通过配电系统进入 ...…
LED应用基础知识
replyreload += \',\' + 368856;LED 是取自 Light Emitting Diode 三个字的缩写,中文译为“发光二极管”,顾名思义发光二极管是一种可以将电能转化为光能具有二极管的特性的电子器件。一、LED的种类依据产品的用途可以分为:LAMP LED、SMD LED 、D ...…
AVR如何实现第二端口功能?
现在又要用mega64了 但是,看到PortA口的第二功能是地址线的低8位 那么是否有控制寄存器来控制A口到底是工作在IO口方式下,还是总线方式下呢? 记得以前datasheet里面写的有,现在找不到了。 只找到方向寄存器DDRA、数据PORTA和输入引脚寄存器P ...…
寻找wince学习、合作伙伴
大家好。我刚上wince,好多不懂,较紧,希望可以找到一些朋友一起学习,合作。有兴趣的可以q 2 8 0 4 0 3 3 3 8,或邮lssnh@126.com…
中断向量地址
中断向量的地址是 A;中断服务程序入口地址的地址 B:中断服务程序入口的地址 谢谢大家,帮忙选下,并写出理由。…
SD16_A怪现象
我用的是MSP430F4250,用AD读一个固定的电压,每隔一秒读一次,读出的值跳动很厉害,而且有缓慢增加的趋势,这是怎么回事呢?请教大家,望不吝赐教…
【求助】C语言的延时子程序
如何能写出一个高效的C语言延时程序,延时时间较准确的,请高手们给个程序!…
